SER0032
SER0032
    DFROBOT
    SERVOMOTOR RC 7.4V HERKULEX
SER0032 数据手册
Herkulex DRS-0101 SKU:SER0032 Introduction Herkulex DRS-0101 is state of the art modular smart servos incorporating motor, gear reducer, control circutry and communications capability in one single package. Equipped with a lot of adapting pieces including Horn, Horn Bolt(BHT 2.6X8), Wheel Horn Bushing, Wheel Horn Washer, Wheel Horn Bolt(PHM 3X8), Cable Guard, I-type Joint, L-type Joint, L-type Joint(Single Nut), Bracket Bolt(PHT 2X5), Joint Bolt(PHM 2X5), Wire Harness(200mm) and with it's amazing structure, DRS-0101 is extremely easy to assemble. Two connectors attached to each servo allows serial connection as well as parallel connection if required. It carries different Control Algorithms like PID, Feedforward, Trapezoidal Velocity Profile so on and so forth, which makes the movement smoothly and precisely. By Using UART Serial communications ,we can lightly change the speed, position, LED, operational compliance, stop and operational status of up to 254 servos simultaneoulsy at once. Meanwhile we can get the feedback such as internal temperature, position, and overload sensors. Servos are capable of diagnosing seven different types of errors which are then indicated by the LED. And we can directly control the RGB of the LED for diagnostics and decorative purposes. It's especially suitable to mechanical arms, robots, joints and etc. Application      Education Robot Arm Humanoid Robot Hexapod Robot Any other servo driven application Mechanical specification          Carbon Brush Cored DC Motor A lot of adapting pieces Rotation angle range: 320° Continuous Rotation Resolution: 0.325° Stall torque: 12kg.cm (7.4v) Maximum Speed: 0.166s/60° (7.4v) Gear: 1:266, Super Engineering Plastic Size: 45mm(W) x 24.0mm(D) x 31mm(H) Weight: 45g Electrical specification  Working Voltage: 7~12VDC(Optimized 7.4V)  Rated Current: 450mA @ 7.4V : 1.7kgf.cm  Communication Link: Full Duplex Asynchronous Serial(TTL Level), Binary Packet, Multi Drop  Multi control through Servo ID: 0 ~ 253, 254(Broadcast only)  Maximum Baud Rate: 0.67Mbps  Feedback: Position, Speed, Temperature, Load, Voltage etc.  Various Control Algorithm: PID, Feedforward, Trapezoidal Velocity Profile, Velocity Override, Torque Saturator & Offset, Overload Protection, Neutral Calibration, Dead Zone Connection Diagram HerkuleX on UNO Tips: There is only one Hardware Serial port on UNO, so that Software Serial has to be used. However, the default baud rate of HerkuleX is up to 115200, which may be unstable when using the Software Serial. Thus it's recommended to change the baud rate of HerkuleX to 57600 first. Servo Motor Pinout Black :GND Red :VDD(7.4V) Blue :TXD Yellow :RXD HerkuleX on Mega Tips: There is no such problem as above with Mega as it has several Hardware Serial port. Servo Motor Pinout Black :GND Red :VDD(7.4V) Blue :TXD Yellow :RXD Sample Code for UNO #include int n=0xfe; //motor ID - verify your ID !!!! void setup() { delay(2000); //a delay to have time for serial monitor opening Serial.begin(115200); // Open serial communications Serial.println("Begin"); Herkulex.begin(115200,10,11); //open serial with rx=10 and tx=11 Herkulex.reboot(n); //reboot first motor delay(500); Herkulex.initialize(); //initialize motors delay(200); } void loop(){ Serial.println("Move Angle: -100 degrees"); Herkulex.moveOneAngle(n, -100, 1000, LED_BLUE); //move motor with 300 speed delay(1200); Serial.print("Get servo Angle:"); Serial.println(Herkulex.getAngle(n)); Serial.println("Move Angle: 100 degrees"); Herkulex.moveOneAngle(n, 100, 1000, LED_BLUE); //move motor with 300 speed delay(1200); Serial.print("Get servo Angle:"); Serial.println(Herkulex.getAngle(n)); } Sample Code for Mega #include int n=0xfe; //motor ID - verify your ID !!!! void setup() { delay(2000); //a delay to have time for serial monitor opening Serial.begin(115200); // Open serial communications Serial.println("Begin"); Herkulex.beginSerial1(115200); //open serial port 1 Herkulex.reboot(n); //reboot first motor delay(500); Herkulex.initialize(); //initialize motors delay(200); } void loop(){ Serial.println("Move Angle: -100 degrees"); Herkulex.moveOneAngle(n, -100, 1000, LED_BLUE); //move motor with 300 speed delay(1200); Serial.print("Get servo Angle:"); Serial.println(Herkulex.getAngle(n)); Serial.println("Move Angle: 100 degrees"); Herkulex.moveOneAngle(n, 100, 1000, LED_BLUE); //move motor with 300 speed delay(1200); Serial.print("Get servo Angle:"); Serial.println(Herkulex.getAngle(n)); }        https://www.dfrobot.com/wiki/index.php/Herkulex_DRS‐0101_SKU:SER0032 8‐23‐18
SER0032 价格&库存
很抱歉,暂时无法提供与“SER0032”相匹配的价格&库存,您可以联系我们找货
SER0032
  • 1+693.384751+89.67351
库存:2
