SER0044
SER0044
    DFROBOT
    位置旋转 直流电机 伺服电机,RC(爱好) 4.8 ~ 7.2VDC
SER0044 数据手册
DSS-M15S 270° 15KG DF Metal Servo with Analog Feedback SKU: SER0044 DSS-M15S servos have been well received by customers in these years. It has extremely wide angle control range, huge load capacity and excellent quality. This DSSM15S with analog feedback has broken its internal potentiometer signal. This is an analog signal with 0~3.3V feedback. You can connect it to MCU to realize close-loop feedback control. DSS-M15S 270° Metal servo with feedback is compatible with Arduino Servo library. You can drive it with Arduino Board and read the angle value from analog side. Specification • • • • • • • • • • • • • • • • • • • • • • • • • • • • • Electronic specifications Operating voltage: 4.8-7.2V 6V test environment Operating speed (no load): 0.18 sec/60 degrees Resting current: 80mA Locking torque: 13.5KG*cm Stall current: 1.8A Standby current: 4mA 7V test environment Operating speed (no load): 0.16sec/60 degrees Resting current: 100mA Locking torque: 15KG*cm Stall current: 2A Standby current: 5mA Mechanical specifications Gear material: metal gear Operating angle: 270 degrees Wiring gauge: 28PVC Data line length: 320mm Gear bracket spline: 25T/5.80 Gear ratio: 310:1 Size: 54.5*20*47.5mm Control specifications Feedback signal: 0-3.3V Control signal: RC PWM Pulse range: 500-2500 us Median signal value: 1500us Clockwise rotation:
SER0044 价格&库存
很抱歉,暂时无法提供与“SER0044”相匹配的价格&库存,您可以联系我们找货
