BLUETOOH BEE (SKU:TEL0023)
Contents
1 Introduction
2 Specifications
3 Pin out
4 Tutorial
4.1 Requirements
4.2 Connection
4.3 Enter AT mode
4.4 Typical AT command
4.5 Communicate with other devices
Introduction
DFRobot Bluetooth Bee Bluetooth wireless module adapts XBEE design. It has compact size, the
pinout is compatible with XBEE which is suitable for all kinds of microcontroller systems who have
3.3V power out, the module can use the AT commands to set baud rate. The Bluetooth Bee modules
somes with an on-board antenna, the antenna provides better signal quality. It acts like a transparent
serial port, which works with a variety of Bluetooth adapter and Bluetooth phone.
The module has been tested with all the Bluetooth adapter on the market matching to use (with the
Bluetooth, including laptops and mobile phones).
Specifications
Bluetooth chip: CSR BC417143
Bluetooth protocol: Bluetooth Specification v2.0 + EDR, not compatible with BLE.
USB Protocol: USB v1.1/2.0
Operating frequency: 2.4 ~ 2.48GHz unlicensed ISM band
Modulation: GFSK (Gaussian Frequency Shift Keying)
Transmit Power: ≤ 4dBm, Class 2
Transmission distance: 20 ~ 30m in free space
Sensitivity: ≤-84dBm at 0.1% BER
Transfer rate: Asynchronous: 2.1Mbps (Max) / 160 kbps; Synchronous: 1Mbps/1Mbps
Safety features: Authentication and encryption
Support profiles: Bluetooth serial port
Serial port settings: 1200 ~ 1382400 / N / 8 / 1
Baud rate default: 9600
Pair: 1234
Input Voltage: +3.3 DC/50mA
Operating temperature: -20 ~ +55
Module Size: 32 x 24 x 9mm
Pin out
Tutorial
You will learn how to check and set the BT module's settings by AT command, and it's easy to
connect this module with you phone and other BT2.0 devices.
Requirements
Hardware
Xbee USB adapter x1
Bluetooth Bee x1
Mini USB cable x1
Software
Arduino IDE V1.6.5 Click to Download Arduino IDE
Connection
1. Put the switch on BT to "AT", right side in the picture;
2. Stack BT module and Xbee adapter together;
3. Connect the Xbee adapter with PC by USB cable, the LED is ON.
1
2
3
Enter AT mode
1. Launch the Arduino > Choose the port(COM) > Open Serial Monitor; (If the COM port didn't show
up correctly, please install the driver for Xbee USB adapter.)
2. Choose "Both NL & CR ", "38400" > Send "at"/"AT" > Receive OK"";
3. Send "AT+UART?" > Receive serial settings.
4. Close Serial Monitor > Disconnect USB cable and the BT module with the adapter;
5. Remember to put the switch to left side: AT_off.
1
2
3
Typical AT command
AT+RESET > OK: It works as power cycle.
AT+ORGL > OK: Restore the default setting:
Device class: 0
Inquiry code: 0x009e8b33
Device mode: Slave mode
Binding mode: SPP
Serial port: 38400 bits/s; 1 stop bit, no parity
Pairing code: “1234”
Device name: “HHW-SPP-1800-2
Set/Poll device name
AT+NAME= > OK: Set device name
AT+NAME? > +NAME: ****/ FAIL: poll device name
Set/Poll device role
AT+ROLE= > OK : Param:0 – slave; 1 – Master; 2 – Slave-loop; Default: 0
AT+ROLE? > +ROLE: OK
AT+ADDR? > Return the address of the Bluetooth device
Some other similar Set&Poll commands:
AT+BIND=/ AT+BIND?
AT+PSWD=/ AT+PSWD?
AT+UART=,,/ AT+UART? > Default: 9600,0,0
Param1: baud rate (bits/s): 4800/ 9600/ 19200/ 38400/ 57600/ 115200/ 230400/ 460800/ 912600/
1382400
Param2: stop bit: 0- 1 bit/ 1- 2 bits/
Param3: parity bit: 0- None/ 1- Odd/ 2- Even
All AT Commands. http://image.dfrobot.com/image/data/TEL0026/TEL0026_Datasheet.pdf
Except the Apple devices and BLE module by DFRobot, the Bluetooth Bee are compatible with most
computers/ phones with built-in Bluetooth module and other bt modules.
For any questions/advice/cool ideas to share, please visit DFRobot Forum.
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“TEL0023”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+166.753611+21.56356
