DF‐BluetoothV3 Bluetooth module (SKU:TEL0026)
From Robot Wiki
Contents
1 Introduction
2 Specification
3 PinOut
4 Set module in AT mode
o 4.1 How to enter into AT mode
o 4.2 Preparation
o 4.3 Steps
5 Tutorial
Introduction
This DF-Bluetooth module offers an affordable way to let your microcontroller talk to your
Bluetooth devices such as Bluetooth mobile phones, laptop, and Bluetooth adapter. The
Bluetooth module provides TTL level UART interface which is supported by almost every
microcontroller in the market.
It is also designed to be compatible with most popular Arduino controller. Simply plug into
Arduino IO Expansion Shield, a Bluetooth Arduino is ready to use.
Specification
Chips: CSR BC417143
Bluetooth Protocol: Bluetooth Specification v2.0 +EDR
Working Frequency: 2.4‐2.48GHz unlicensed ISM Band
Modulation Mode: GFSK (Gaussian Frequency Shift Keying)
Power: ≤4dBm, Class 2
Transmission Distance: 20‐30 in free space
Sensitivity: ≤‐84 dBm at 0.1% BER
Transmission rate: Asynchronous: 2.1 Mbps (Max)/160 kbps; Synchronous: 1Mbps/1Mbps
Security: Authentication and encryption
Support profiles: Bluetooth serial port
LED indicator: LINK
Power Supply: +3.5V‐+8V DC/50 mA
Working Temperature: ‐20°C‐+55°C
Dimension: 43x19.3x11mm
PinOut
Pin
Definition
GND
GND
VCC
3.5‐8V DC
RXD
RX (TTL Level)
TXD
TX (TTL Level)
The DF-Bluetooth V3 module has two switches on the module.
The NO.1 switch is used to set the LINK‐LED on/off for power saving.
The NO.2 switch(AT mode) is used to control the Bluetooth module
o In AT mode
o In Functional mode
So if you turn the NO.2 switch on, you can use the AT mode to set the Bluetooth module, e.g.
name, baud rate, master/slave mode etc.
Preparation
USB to TTL Converter x1
Bluetooth module x1
Software: CoolTerm, you can also use Arduino IDE serial monitor
http://freeware.the‐meiers.org/
Steps
Part 1: Ready to go
USB to TTL module
1.
2.
3.
4.
Plug the Bluetooth module into the USB to TTL module;
Turn on the AT mode switch of the Bluetooth module;
Connect the USB to TTL module to your computer;
Install the driver for the USB to Serial module if it can't be recognized.
Part 2: Setting
After connecting the module to computer, we can use CoolTerm software to talk with Bluetooth
module.
1. Click Connection ‐‐> Choose Options to set several parameters in CoolTerm.
2. Set Serial Port
1. Port: the port number can be got from the Device Manager of the computer
2. Baudrate: 38400
3. Data Bits: 8
4. Parity : none
5. Stop Bits: 1
3. Set Terminal
1. Terminal Mode: Line Mode
2. Key Emulation: CR+LF
Set Serial Port
Set Terminal
Part 3: Setting
Send AT command & return value
Now use the CoolTerm to send AT commands to the Bluetooth Module and see what
information the Bluetooth will answer to the computer.
For example:
Input: at
Return: OK
Input: at+name=DFRobot
Return: OK
Input: at+name?
Return:+name: DFRobot OK
Input: at+role=0
Return: OK
Input: at+role?
Return: +role:0 OK
AT+PSWD?
+PSWD:1234 OK
AT+ORGL (Restore the default setting:)
Return: OK
AT+UART=115200,0,0 Return: OK
o Param1: baud rate (bits/s) 4800/ 9600/ 19200/ 38400/ 57600/ 115200/ 230400/
460800/ 912600/ 1382400
o Param2: stop bit , 0‐ 1 bit/ 1‐ 2 bits
o Param3: parity bit, 0‐ None/ 1‐ Odd/ 2‐ Even
AT+RESET
Return: OK
Default setting
1. Device class: 0
2. Inquiry code: 0x009e8b33
3. Device mode: Slave mode
4. Binding mode: SPP
5. Serial port: 38400 bits/s; 1 stop bit, no parity (In datasheet, it said the default baud rate
is 9600 which is wrong.)
6. Pairing code: “1234”
7. Device name: “HHW‐SPP‐1800‐2
More AT command can be obtained from the TEL0026_Datasheet.
http://image.dfrobot.com/image/data/TEL0026/TEL0026_Datasheet.pdf
Part 4: Exit AT mode
Please turn the AT mode switch off and then repower the Bluetooth module.
Tutorial
The DF-Bluetooth module is based on the specification of Bluetooth V2.0, compatible with
V1.1. A Bluetooth adaptor is required to communicate with the DF-Bluetooth module. When it is
paired with other Bluetooth devices, the DF-Bluetooth is always set to slave mode.
The IVT BlueSoleil is recommended to manager all your Bluetooth devices.
STEPS
Step 1: Connect a Bluetooth adapter to the computer so that the computer can find the Bluetooth
module.
Step 2: Put the Bluetooth module on the Arduino board
Step 3: Open BlueSoleil software (Figure 1) and right click the yellow ball in the centre screen,
click “Search Devices” , an icon named EPBMX-COM will appear after few seconds. The
EPBMX-COM is the DF-Bluetooth module.
Figure 1
Step 4: Right click EPBMX-COM icon, click “Pair”. A window will popup ask for PassKey
which is “1234” by default (Figure 2).LINK-LED on the Bluetooth will blink if the Pair is
successful and the LED is on.
Figure 2
Step 5: Right click EPBMX-COM, click “Search Service”. Then a serial port will appear and
right click EPBMX-COM again and choose the choice “Connect Bluetooth Serial Port
(C0MXX)” and you can see the LINK-LED on the Bluetooth will be lit if the LED switch is on.
Figure 3
Step 6: Upload test code to Arduino. Please unplug the Bluetooth module from the Arduino
board while uploading test code.
void setup()
Serial.begin(9600);
//Set serial baud rate to 9600
void loop()
Serial.print("Hello!");
delay(1000);
//print out hello string
//1 second delay
Result
Plug the Bluetooth module on the Arduino board again after finishing uploading the codes. Then
open the serial monitor to see what Arduino is sending to Bluetooth module. You can also use
CoolTerm to check the communication.
Figure 4
NOTE:
1. Check the serial setting! Make sure the baud rate is set to 9600 on both master and slave.
2. When the DF‐Bluetooth is used on Arduino, please make sure you disconnect the DF‐
Bluetooth module before uploading any code to your Arduino. Or it will fail to upload any
sketch as the DF‐Bluetooth module occupying the TX/RX pins.
For any question/ advice/ cool idea to share with us, please visit DFRobot Forum
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“TEL0026”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+167.334491+21.64090
