TEL0086
TEL0086
    DFROBOT
    BLE MICRO EVB
TEL0086 数据手册
    DF‐Beacon EVB SKU: TEL0086 From Robot Wiki    DF‐Beacon EVB  Contents      1 Introduction  2 Specification  3 Pinout  4 Update BLE Firmware  5 Configure Bluetooth parameter  Introduction Bluno is great but I want small size for my product; Ble-link does well in its work but I don't want additional adapter to be inserted. Now, these problems are solved with BLE micro, a new kind of bluetooth 4.0 device. Comes in a small size, BLE Micro can be easily put on your PCB board, just ignore the problems like "how to design an antenna", "how to make a bluetooth chip work" and so on. BLE Micro is perfect for wearable projects. With it, you will be able to use Andriod or IOS devices to communicate with your clothes! And for developers, BLE Micro can be used for transparent transmission, or remote programmer uploading, and even building an HID connection with PC. It can be configurated by AT command and you can also update its firmware by USB. Of course, it supports iBeacon. With the latest firmware version 1.8, you can switch the mode between AT command and transparent transmission by serial port. STABLE POWER:   Please make sure to provide the BLE module with a reliable and stable 3.3V power supply whose noise should be less than 10mV, or its bootloader and the BT service will get lost. Specification           bluetooth chip:TI CC2540   Frequency: 2.4GHz  Transfer rate: ≤1Mbps  Modulation: GFSK, bluetooth low power, V4.0  Power consumption: working:10.6mA average ,ready mode:8.7mA   sensitivity: ‐93dB  Input Voltage: +3.3 DC  Operating temperature: ‐10   ~ +65     Transmission distance: 30m in free space  size:49mm * 35mmPinout    Pinout    DF‐Beacon EVB Pinout  Update BLE Firmware It is better to update the newest firmware for the better experience. As DF-Beacon EVB is using CC2540 chip, the method of the updating is very close to BLUNO The only difference is the firmware name. Please choose BLE LINK firmware. Or it won't work. How to update the BLE firmware. http://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267#Update_BLE_Firmware_on_Bl uno.EF.BC.88AT.2BVERSION_to_check_the_version.EF.BC.89 Configure Bluetooth parameter There are three revolutionary BLE firmware versions now, maybe it will be more. For the reason of unified management, we will put all BLE AT command on the BLUNO wiki page BLE AT Command Configuration http://www.dfrobot.com/wiki/index.php/Bluno_SKU:DFR0267#Configure_the_BLE_through_A T_command Powered By DFRobot © 2008-2017
TEL0086 价格&库存
很抱歉,暂时无法提供与“TEL0086”相匹配的价格&库存,您可以联系我们找货
