TEL0092
TEL0092
    DFROBOT
    模块
    WiFi 802.11b/g/n RF 收发器模块 2.4GHz PCB 印制线 通孔
TEL0092 数据手册
Page 1 of 32 SKU:TEL0092 WiFi Bee-ESP8266 Wirelss module Contents 1 2 3 4 Introduction Specifications Pin out Tutorials 4.1 How to Use ? 4.1.1 1 Connect AP 4.1.2 2 (/wiki/index.php/File:TEL0092_frontpage.jpg) WiFi Bee-ESP8266 SKU:TEL0092 5 6 7 8 TCP_Client_Single 4.1.3 3 TCP_Client_multi 4.1.4 4 TCP_Pure_Data_Mode 4.1.5 5 Server mode 4.1.6 * Problem Shooting 4.2 Update Firmware Application AT command 6.1 How to enter AT mode Related link More Introduction Wifi Bee-ESP8266 is a Serial-to-WIFI module using XBEE design in a compact size, compatible with XBEE expansion base, applicable to a variety of 3.3V single-chip system. It can be used for Arduino, wireless data transfer, remote control. On-board switch can be used to easily select the Startup module or Upgrade firmware. Page 2 of 32 ESP8266 has a powerful on-chip processing and storage capacity, built-in 32-bit processor, built-in Lwip protocol stack. Support AP+STA mode co-exist. And you could configure various parameters via AT commands. Specifications 1. 2. 3. 4. 5. 6. 7. 8. 9. Wi-Fi Direct (P2P),soft-AP Built-in TCP/IP protocol stack Built-in low-power 32-bit CPU: can work as an application processor Support WPA WPA2/WPA2-PSK encryption Support UART interface Support for TTL serial port to wireless application Working voltage: 3.3V power
TEL0092 价格&库存
很抱歉,暂时无法提供与“TEL0092”相匹配的价格&库存,您可以联系我们找货
TEL0092
  • 1+52.074831+6.73727
