CC-7U-NET
CC-7U-NET
    DIGIINTERNATIONAL
    JUMPSTART CONNECTCORE 7U MODULE
CC-7U-NET 数据手册
ConnectCore® 7U Universal ARM7 Core Module Embedded ARM core processor module offers a wide range of connectivity options and integrated networking support in a compact DIP form factor. Overview The ConnectCore 7U core processor module utilizes Digi’s high-performance NS7520 NET+ARM microprocessor, providing the ideal core processor platform for product designs demanding an additional level of performance, connectivity and flexibility. Combining core processing capabilities with long-term product availability, it is suited for applications including transportation, security/access control, building and industrial automation, retail, warehousing and others. Block Diagram 48pin Conn DATA[0-31] ADDR[0-9] ADDR[0-23] CS1 JTAG WE, OE, CS3, CS4 The module offers 16 MB of SDRAM and up to 8 MB of on-board Flash memory, an integrated 10/100 Mbit Ethernet MAC/PHY, up to two configurable UART/SPI ports, an I2C bus interface option, 16 shared GPIO ports for applicationspecific use, and an external 10-bit address/8-bit data bus interface for component integration flexibility. PORTA[0-7] PHY ® SDRAM 8/16MB NS7520 CS0 PORTC[0-7] The Digi JumpStart Kit for NET+OS delivers a ThreadXbased, IPv6-ready, royalty-free turnkey solution with all of the integrated building blocks needed for secure network-enabled embedded software development. ® DATA[0-7] MII FLASH 2/4/8MB EEPROM Features/Benefits Platforms and Services NET OS Supported Software Platform Support • Compact and versatile 48-pin DIP form factor • Powerful 32-bit Digi NS7520 (ARM7) processor • Integrated on-chip 10/100 Ethernet networking • Peripheral interface flexibility • Digi processor technology for true long-term product availability • Complete IPv6-ready NET+OS development platform • Seamless migration path to fully integrated Digi NET+ARM system-on-chip solution Design Services www.digi.com Digi JumpStart Kit® Overview Digi JumpStart Kit® for NET+OS® This royalty-free turnkey solution for embedded software development is based on the ThreadX Real-Time Operating System (RTOS), one of the most reliable and field-proven RTOS solutions available. In addition to ThreadX, NET+OS provides the integrated building blocks needed to create product solutions with leading network security using Digi embedded modules and microprocessors. For professional NET+OS software development, the Eclipse based Digi ESP™ Integrated Development Environment (IDE) with graphical user interface and high-speed USB 2.0 hardware debugger is provided out-of-the-box. • • • • Royalty-free turn-key solution for embedded development Built on field-proven and compact ThreadX RTOS Fully integrated support for secure, IPv4/IPv6 networking applications Professional software development using Windows-based Digi ESP IDE Please refer to the feature specs on our website for detailed information about the specific software platform capabilities. Digi JumpStart Kit® Contents Software Platform Module Development Board CD/DVD Documentation Power Supplies and Accessories Other Part Numbers (worldwide) NET+OS® ConnectCore 7U w/ 8 MB Flash, 16 MB SDRAM, Ethernet MAC/PHY 2 serial ports (RS-232, TTL), 2 user push-buttons, 2 user LEDs, Prototyping area, User/Application header, Status LEDs, Character display connector, Reset button, JTAG connector, 5VDC power supply Digi NET+OS CD: NET+OS 7.x, Digi ESP IDE, BSP Source code, Sample code, Support, Documentation Quick start guide, Digi ESP tutorial, NET+OS porting guide, NET+OS API documentation, Advanced Web Server, Hardware reference manual, Development board schematics External wall power supply (110/240VAC) with interchangeable outlet adapters (North America, EU, UK and Australia), JTAG adapter, Ethernet cable, Serial cable Digi JTAG Link USB 2.0 hardware debugger CC-7U-NET ConnectCore™ 7U Hardware Processor Type ARM Core Processor Speed Memory Base Population Serial EEPROM 32-bit NS7520 processor ARM7TDMI 55 MHz 2/8 MB NOR flash 16 MB SDRAM 8 KB UART Up to 230 Kbps GPIO Up to 16 shared GPIO ports SPI Master mode I2C Standard mode (100 kHz) External Memory Bus 10-bit address / 8-bit data; 2 external chip selects ConnectCore™ 7U Hardware (continued) Timers/PWM 2 independent 27-bit timers; IRQ/FIQ, 2 microseconds to 20 hours JTAG • Form Factor 48-Pin Dual In-Line Package (DIP) Dimensions (L x W x H) 2.475 in (62.87 mm) x 0.728 in (18.50 mm) Network Interface Standard IEEE 802.3 Physical Layer 10/100Base-T Data Rate 10/100 Mbps (auto-sensing) Mode Full or Half duplex (auto-sensing) Integrated MAC/PHY • Environmental Operating Temperature 0° C to +70° C (+32° F to +158° F) Storage Temperature -50° C to +125° C (-58° F to +257° F) Relative Humidity 5% to 90% (non-condensing) Altitude 12,000 feet (3,658 meters) Power Requirements (3.3V) Maximum 280 mA Regulatory Approvals EN55022:2005, Class B • IEC/CISPR 24:1997, modified + A1:2001+ A2:2002 • Bottom View Side View PCB Board 8.80 58.42 1.25 5.60 62.87 Socket 18.50 15.24 Components max 1.6mm Pin 1 Visit www.digiembedded.com for part numbers. 91001350 C1/509 DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 877-912-3444 952-912-3444 info@digi.com Digi International France Digi International KK Digi International (HK) Limited +33-1-55-61-98-98 www.digi.fr +81-3-5428-0261 www.digi-intl.co.jp +852-2833-1008 www.digi.cn BUY ONLINE • www.digiembedded.com © 2005-2009 Digi International Inc. All rights reserved. Digi, Digi International, the Digi logo, ConnectCore, Digi JumpStart Kit, NET+ and NET+OS are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. ARM and NET+ARM are trademarks or registered trademarks of ARM Limited. All other trademarks are the property of their respective owners.
CC-7U-NET 价格&库存
很抱歉,暂时无法提供与“CC-7U-NET”相匹配的价格&库存,您可以联系我们找货
