CC-9C-V212-25
CC-9C-V212-25
    DIGIINTERNATIONAL
    IC MOD ARM926EJ-S 155MHZ 16MB
CC-9C-V212-25 数据手册
ConnectCore™ 9C Family Interchangeable Wired/Wireless Core Modules Highly integrated ARM9 core module family combines main processing functionality and integrated peripherals with on-board secure wireless/wired network connectivity. Block Diagram Related Products Design Services Accessory Kits Digi NET+OS Supported Software Platforms Support SPI 88.5, 77.5, or 51.5 MHz AHB Bus 32b-D, 32b-A LCD Controller 8 x Timers/Counters or 4 PWM JTAG PHY Real Time Clock RP-SMA U.FL 10/100 Ethernet MII/RMII MAC Bus Arbiter I2C RJ-45 Memory Controller E xt . Peripheral Controller 15 GPIO UART ARM ARM926EJ-S 177, 155, or 103 MHz 8kB I-Cache 44kK B D-Cache Header 802.11 a/b/g Radio 7 GPIO Serial Module x4 27-Channel DMA 1284 44.25, 38.75, or 25.75 MHz Peripheral Bus 32b-D, 32b-A USB Host USB Device Utilizing Digi’s own ARM processor and WLAN technology, the modules deliver a pre-certified, flexible and secure network-enabled solution for a wide variety of sophisticated applications. The cost-effective and easy-to-use Digi JumpStart Kit® development solutions allow software design using the royalty-free and complete ThreadX-based NET+OS® platform, the feature-complete selection of high-level software components in Windows® Embedded CE, or the open Linux® environment with its strong community and readily available library of software. Type A Connector USB Hub 144-pin SO-DIMM Edge Connector Built on leading Digi 32-bit NET+ARM technology, the ConnectCore 9C family provides a powerful network-enabled system-on-module solution. It combines main processor performance, secure wired/wireless LAN connectivity and embedded software/hardware design flexibility in a versatile and interchangeable SO-DIMM based form factor. GPIO (50 Pins) Overview Up to 256 MB SDRAM CLK Generation Vectored Interrupt Controller Power Manager AHB Arbiter 4/8 MB NOR Flash or Up to 256 MB NAND Flash Features/Benefits • Interchangeable 155 MHz ARM9 module in SO-DIMM form factor • Integrated 10/100 Mbit Ethernet interface • 802.11b/g wireless LAN with WPA2/802.11i security • Wide range of peripheral interfaces, including USB host/device and on-chip LCD controller • Extended operating temperature range • Pre-certified low-emission design • Digi processor and WLAN technology for true long-term availability • Seamless migration path to Digi NET+ARM system-on-chip solution www.digi.com Development Kits Digi JumpStart Kits Overview Digi JumpStart Kit for Microsoft Windows Embedded CE Digi JumpStart Kit for NET+OS This royalty-free turnkey solution for embedded software development is based on the ThreadX Real-Time Operating System (RTOS), one of the most reliable and field-proven RTOS solutions available. In addition to ThreadX, NET+OS provides the integrated building blocks needed to create product solutions with leading network security using Digi embedded modules and microprocessors. For professional NET+OS software development, the Eclipse based Digi ESP™ Integrated Development Environment (IDE) with graphical user interface and high-speed USB 2.0 hardware debugger is provided out-of-the-box. • • • • Royalty-free turn-key solution for embedded development Built on field-proven and compact ThreadX RTOS Fully integrated support for secure, IPv4/IPv6 networking applications Professional software development using Windowsbased Digi ESP IDE Microsoft Windows Embedded CE 6.0 is a highly componentized operating system, offering pre-tested technology components designed to create sophisticated embedded applications with minimized design effort and risk. It includes a wide range of ready-to-use components such as a graphical user interface, networking, web browser and multimedia. The professional Microsoft Visual Studio 2005 development tools also support native and managed code applications using various programming languages. The Digi JumpStart Kit for Microsoft Windows Embedded CE 6.0 provides a complete kit with all hardware and software components needed to start immediate software development on the ConnectCore 9C/Wi-9C core module platforms. This includes support for key processor platform features such as power management modes. • • • • Immediate Windows Embedded CE 6.0 development Seamless integration into Windows Embedded CE environment Full Digi Board Support Package (BSP) source code 180-day Visual Studio 2005 and Platform Builder trial Digi JumpStart Kit for Embedded Linux Built around a standard Linux 2.6 kernel distribution, the Digi JumpStart Kit for Embedded Linux is tailored to the specific needs of embedded Linux development and provides an easy-to-use, complete off-the-shelf embedded development platform. It includes all components that are required to build secure network-enabled products based on the ConnectCore 9C family. The kit includes Digi ESP™ for Embedded Linux, a powerful and fully Linux-hosted Integrated Development Environment based on the open Eclipse™ framework. Ideal for new and experienced Linux developers, Digi ESP improves software design productivity by accelerating and greatly simplifying driver and application development through a user-friendly graphical interface. • • • • Complete Linux embedded Linux development platform Royalty-free and with optimized 2.6 kernel and services Linux-based Digi ESP IDE for rapid product development Full Linux and Digi Board Support Package (BSP) source Digi JumpStart Kit Contents Software Platform Module Development Board CD/DVD Documentation Power Supplies and Accessories Other NET+OS Microsoft Windows Embedded CE ConnectCore 9C or ConnectCore Wi-9C module with 4 MB NOR Flash, 16 MB SDRAM, USB Host connector, Ethernet connector, 2 x antenna connectors, 2 dBi dipole antenna (ConnectCore Wi-9C) Embedded Linux ConnectCore 9C or ConnectCore Wi-9C module w/ 128 MB NAND Flash, 64 MB SDRAM, USB Host connector, Ethernet connector, 2 x antenna connectors, 2 dBi dipole antenna (ConnectCore Wi-9C) 4 serial ports (1 x RS-232/422/485, 1 x RS-232, 2 x TTL),VGA interface, LCD/Touchscreen connector, user/application connectors, I2C/SPI headers, screw terminal for access to 8 GPIO signals, 2 user push-buttons, 2 user LEDs, 9-30VDC power supply, power switch Digi NET+OS CD: NET+OS 7.x, Digi ESP IDE, BSP source code, sample code, support, documentation Digi Windows CE 6.0 CD: Microsoft Windows Embedded CE 6.0 BSP w/ source code, Universal Boot Loader (U-Boot) source code, sample code, documentation Microsoft Embedded Windows CE 6.0 evaluation DVD: 180-day trial of Microsoft Embedded Windows CE 6.0, Platform Builder, Visual Studio 2005 Quick start guide, Digi ESP tutorial, NET+OS porting guide, NET+OS API documentation, Advanced Web Server, hardware reference manual, development board schematics Quick start guide, Digi Windows CE 6.0 BSP user’s guide, hardware reference manual, development board schematics Digi Embedded Linux 4 DVD: Digi Embedded Linux, Digi ESP IDE, Linux and platform specific source code, Universal boot loader source code (U-Boot), sample code, documentation Quick start guide, Digi Embedded Linux user’s guide, hardware reference manual, development board schematics External wall power supply (110/240VAC to 12VDC @ 850 mA) with interchangeable outlet adapters (North America, EU, UK, and Australia), Ethernet cable, serial cable Digi JTAG Link USB 2.0 hardware debugger — — CC-9C-NET CC-9C-CE6 CC-9C-LX CC-W9C-CE6 CC-W9C-LX Kit Part Numbers Ethernet Only WLAN + Ethernet CC-W9C-NET Please refer to the feature specs on our website for detailed information about the specific software platform capabilities. Platform ConnectCore™ 9C ConnectCore™ Wi-9C Hardware Processor Type 32-bit NS9360 processor ARM Core ARM926EJ-S Cache 8k I-Cache/4k D-Cache Processor Speed 155 MHz Memory Base Population Up to 256 MB flash/SDRAM Flash: 4 MB / 8 MB NOR or 32-256 MB MB NAND RAM: 16-256 MB SDRAM RJ-45 Ethernet connector RP-SMA/U.FL antenna connectors 4-port USB hub component Additional Population Options Pins/Form Factor 144-pin SO-DIMM UART Up to 4 high-speed UARTs Maximum data rate 921 Kbps GPIO Up to 55 shared GPIOs Up to 7 high-current (8 mA) pins Up to 4 SPI Master data rate 11.25 Mbps Slave data rate 5.5 Mbps SPI I2C v1.0 bus interface; 7-bit and 10-bit address modes USB USB 2.0 Host/Device low/full speed interface with integrated PHY (Available through optional on-module connector or edge connector) External Memory Bus 8-bit address and data bus with external chip select LCD Controller On-chip for TFT / STN LCD panels (SVGA/18 bpp) PWM Up to 4 PWM functions External Interrupts 4 Timers/Counters Dimensions (L x W x H) Up to 8 16-/32-bit timers/counters 3.59 in (91.19 mm) x 2.055 in (52.2 mm) x 0.712 (18.08 mm) Height and width (overhang) varies depending on connector population. 3.59 in (91.19 mm) x 3.055 in (77.6 mm) x 0.712 (18.08 mm) Height and width (overhang) varies depending on connector population. Network Interface – Wired Standard IEEE 802.3 Physical Layer 10/100Base-T Data Rate 10/100 Mbps (auto-sensing) Mode Full or half duplex (auto-sensing) Connector On-module RJ-45 with magnetics (optional) Power-over-Ethernet 802.3af compliant power pass-through (Model with integrated RJ-45 only) Network Interface – Wireless LAN Standard — IEEE 802.11b/g Security — WEP/WPA/WPA2/802.11i Frequency — 2.4 GHz Data Rate — Up to 54 Mbps with fallback Modulation — DBPSK (1 Mbps), DQPSK (2 Mbps), CCK (11,5.5 Mbps), BPSK (6,9 Mbps), PSK (12,18 Mbps), 16-QAM (24,36 Mbps), 64-QAM (48, 54 Mbps) Transmit Power — 16 dBm typical Receive Sensitivity — -73 dBm at 54 Mbps Power Requirements Maximum USB Host 750 mA @ 3.3VDC 900 mA @ 3.3VDC 5VDC ± 10% @ 1A max. (optional) Platform ConnectCore™ 9C ConnectCore™ Wi-9C -40° C to +85°C (-40º F to 185º F) -30º C to 75º C (-22º F to 167º F) Environmental Operating Temperature Storage Temperature -50º C to 125º C (-58º F to 257º F) Relative Humidity 5% to 95% (non-condensing) Altitude 12,000 feet (3,658 meters) Regulatory Approvals FCC Part 15 Class B, EN 55022 Class B • EN 61000-3-2 and EN 61000-3-3 • ICES-003 Class B, VCCI Class II, AS 3548 • FCC Part 15 Sub C Section 15.247 • IC RSS-210 Issue 5 Section 6.2.2(o) • EN 300 328, EN 301 489-17 • UL 60950-1, EN 60950 (EU) • CSA C22.2, No. 60950 • EN 55024 • � Module Feature ConnectCore 9C/Wi-9C Top View ConnectCore 9C Side View ConnectCore Wi-9C Side View Visit www.digiembedded.com for part numbers. 91001407 D1/309 DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 877-912-3444 952-912-3444 info@digi.com Digi International France Digi International KK Digi International (HK) Limited +33-1-55-61-98-98 www.digi.fr +81-3-5428-0261 www.digi-intl.co.jp +852-2833-1008 www.digi.cn BUY ONLINE • www.digiembedded.com © 2005-2009 Digi International Inc. All rights reserved. Digi, Digi International, the Digi logo, the When Reliability Matters logo, ConnectCore, Digi ESP, Digi JumpStart Kit, NET+ and NET+OS are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. ARM and NET+ARM are trademarks or registered trademarks of ARM Limited. All other trademarks are the property of their respective owners.
CC-9C-V212-25 价格&库存
很抱歉,暂时无法提供与“CC-9C-V212-25”相匹配的价格&库存,您可以联系我们找货
