CC-9P-NET
CC-9P-NET
    DIGIINTERNATIONAL
    JUMPSTART NS9360 EVAL BRD
CC-9P-NET 数据手册
ConnectCore™ 9P 9360 Compact High-Performance ARM9 Core Module 32-bit NET+ARM core module combines performance, peripheral options and design integration flexibility with complete embedded software platform support. Block Diagram 120-pin Connector USB Host USB Device Cost-effective and easy-to-use Digi JumpStart Kit® development solutions enable you to take advantage of the reliability and flexibility of the royalty-free ThreadX-based NET+OS® platform, the feature-complete high-level software components and applications of Microsoft® Windows® Embedded CE 6.0, or the readily available library of software and community support of the Linux® environment. 44.25, 38.75, or 27.75 MHz Peripherial Bus 32b-D, 32b-A Built on leading Digi 32-bit NET+ARM processor technology, the network-enabled ConnectCore 9P 9360 module provides a modular and scalable core processor solution. It significantly minimizes software and hardware design risk by simplifying the overall design process and improving time-to-market. ARM926DJ-S 177, 155, or 103 MHz 8KB I-CACHE 4kB D-CACHE Real Time Clock 10/100 Ethernet 10/100 Ethernet MII/RMII MAC Bus Arbiter 88.5, 77.5, or 51.5 MHz AHB Bus 32b-D, 32b-A CLK Generation IC 2 Memory Controller Ext. Peripheral Controller 16 GPIO The ConnectCore 9P 9360 module combines superior performance and a complete set of integrated peripherals and component connectivity options in a very compact and versatile form factor. It is the ideal solution for a wide variety of applications including medical, industrial/building automation and transportation. 7 GPIO Overview 32/64/128MB SDRAM Vectored Interrupt Control LCD Controller Power Manager 8 x Timers/Counters or 4 PWM AHB Arbiter 32/64/128MB NAND Flash Features/Benefits Platforms and Services • Powerful 32-bit Digi NS9360 processor (ARM9) • Integrated 10/100 Ethernet networking • On-chip LCD controller and USB host/device • Commerical and industrial operating temperature • FCC Class B low-emission module design Design Services Application Kits NET OS Supported Software Platforms Support • Digi processor technology for true long-term product availability • Complete NET+OS, Microsoft Windows Embedded CE 6.0 and Linux software platform support • Seamless migration path to fully integrated Digi NET+ARM system-on-chip solution www.digi.com Development Kits Digi JumpStart Kits® Overview Digi JumpStart Kit® for Microsoft Windows Embedded CE Digi JumpStart Kit® for NET+OS® TThis royalty-free turnkey solution for embedded software development is based on the ThreadX Real-Time Operating System (RTOS), one of the most reliable and field-proven RTOS solutions available. In addition to ThreadX, NET+OS provides the integrated building blocks needed to create product solutions with leading network security using Digi embedded modules and microprocessors. For professional NET+OS software development, the Eclipse based Digi ESP™ Integrated Development Environment (IDE) with graphical user interface and high-speed USB 2.0 hardware debugger is provided out-of-the-box. • • • • Royalty-free turnkey development solution Built on field-proven and compact ThreadX RTOS Fully integrated support for secure IPv4/IPv6 Professional Digi ESP IDE (Microsoft Windows) Microsoft Windows Embedded CE 6.0 is a highly componentized operating system, offering pre-tested technology components designed to create sophisticated embedded applications with minimized design effort and risk. It includes a wide range of ready-to-use components such as a graphical user interface, networking, web browser and multimedia. The professional Microsoft Visual Studio 2005 development tools also support native and managed code applications using various programming languages. The Digi JumpStart Kit for Microsoft Windows Embedded CE 6.0 provides a complete kit with all hardware and software components needed to start immediate software development on the ConnectCore 9P 9360 core module platforms. This includes support for key processor platform features such as power management modes. • • • • Complete kit for Windows Embedded CE 6.0 development Seamless integration into Microsoft Windows Embedded CE Full Digi Board Support Package (BSP) source code 180-day Visual Studio and Windows Embedded CE 6.0 trial Digi JumpStart Kit® for Embedded Linux Built around a standard Linux 2.6 kernel distribution, the Digi JumpStart Kit for Embedded Linux is tailored to the specific needs of embedded Linux development and provides an easy-to-use, complete off-the-shelf embedded development platform. It includes all components that are required to build secure network-enabled products based on the ConnectCore 9P 9360 family. The kit includes Digi ESP™ for Embedded Linux, a powerful and fully Linux-hosted Integrated Development Environment based on the open Eclipse™ framework. Ideal for new and experienced Linux developers, Digi ESP improves software design productivity by accelerating and greatly simplifying driver and application development through a user-friendly graphical interface. • • • • Complete embedded Linux development platform Royalty-free and with optimized 2.6 kernel and services Linux-based Digi ESP IDE for rapid product development Full Linux and Digi BSP source code included Digi JumpStart Kit® Contents Software Platform NET+OS® Module Development Board CD/DVD Documentation Power Supplies and Accessories Other Ethernet Only Microsoft Windows Embedded CE Embedded Linux ConnectCore 9P 9360 module w/ 128 MB NAND Flash, 64 MB SDRAM 4 serial ports (1 x RS-232/422/485, 1 x RS-232, 2 x TTL),VGA interface, LCD/Touchscreen connector, User/Application connectors, I2C/SPI headers, Screw terminal for access to 8 GPIO signals, 2 user push-buttons, 2 user LEDs, 9-30VDC power supply, Power switch Digi NET+OS CD: NET+OS 7, Digi ESP IDE, BSP source code, Sample code, Green Hills MULTI support option, User documentation Quick start guide, Digi ESP tutorial, NET+OS porting guide, NET+OS API documentation, Advanced Web Server, Hardware reference manual, Development board schematics Digi Windows CE 6.0 CD: Microsoft Windows Embedded CE 6.0 BSP w/source code, Universal Boot Loader (U-Boot) source code, Sample code, Documentation Microsoft Embedded Windows CE 6.0 evaluation DVD: 180-day trial of Microsoft Embedded Windows CE 6.0, Platform Builder, Visual Studio 2005 Quick start guide, Digi Windows CE 6.0 BSP user’s guide, Hardware reference manual, Development board schematics Digi Embedded Linux 4 DVD: Digi Embedded Linux, Digi ESP IDE, Linux and platform specific source code, Universal boot loader source code (U-Boot), Sample code, Documentation Quick start guide, Digi Embedded Linux user’s guide, Hardware reference manual, Development board schematics External wall power supply (110/240VAC to 12VDC @ 850 mA) with interchangeable outlet adapters (North America, EU, UK and Australia), Ethernet cable, Serial cable Digi JTAG Link USB 2.0 hardware debugger – – CC-9P-NET CC-9P-CE6 CC-9P-LX Please refer to the feature specs on our website for detailed information about the specific software platform capabilities. ConnectCore™ 9P 9360 Hardware Processor Type ARM Core Processor Speed Cache Memory Population Serial EEPROM 32-bit Digi NS9360 high-performance RISC processor ARM926EJ-S 177 MHz 4k D-Cache/8k I-Cache Up to 128 MB NAND flash Up to 128 MB SDRAM 8 KB UART 4 high-speed UARTs Maximum data rate 921.6 Kbps GPIO Up to 55 shared GPIO ports with 7 high-current (8 mA) pin options SPI Up to 4 SPI ports Master data rate up to 11.25 Mbps Slave data rate up to 5.5 Mbps I2C Fast mode (400 kHz) and normal mode (100 kHz) support 7-bit and 10-bit address modes USB External Memory Bus USB 2.0 Host/Device low/full speed interface with internal PHY (external PHY interface available) Parallel operation of host and device using combination of internal PHY and external PHY 28-bit address/32-bit data Up to SVGA (800x600) resolution LCD Controller Up to 18 bpp; 256K colors (TFT) 1, 2, 4 bpp palletized grayscale (STN) Up to 16 bpp 4:4:4 RGB, 3375 colors (Color Passive Matrix) Timers/PWM Up to 8 independent 16-/32-bit programmable timers/counters Up to 4 PWM functions External IRQs 4 Real-Time Clock JTAG Pins/Form Factor Dimensions (L x W x H) • (no battery-backup) • Small-footprint module with 2 x 120-pin board-to-board connectors 2.362 in (60 mm) x 1.732 in (44 mm) x 0.0395 in (10.0 mm) Network Interface - Wired Standard Physical Layer Data Rate Mode IEEE 802.3 10/100Base-T 10/100 Mbps (auto-sensing) Full or half duplex (auto-sensing) Environmental Operating Temperature Storage Temperature Relative Humidity Altitude 0° C to 70° C (32° F to 158° F) Industrial temperature version available. See website for information. -50° C to 125° C (-58° F to 257° F) 5% to 90% (non-condensing) 12,000 feet (3,658 meters) •● Module Feature Power Requirements (3.3V) Maximum 400 mA Regulatory Approvals FCC Part 15 Class B • EN55022:2006 Class B • ICES-003, Class B • VCCI, Class B • EN55024:1998 +A1:2001, A2:2003 • EN61000-3-2:2006 • EN61000-3-3:1995 +A1:2001, A2:2005 • UL 60950-1, EN 60950 (EU) • Bottom View Bottom View 44.00 10.00 10.00 24.00 44.00 •● Module Feature 24.00 2x Ø2.20 2x Ø2.20 2.40 2.40 Top View Top View Bottom View 44.00 10.00 24.00 X2 X2 max 3.0mm max 3.0mm 1.30 1.30 3.75 Side View Side View 3.75 X2 30.00 55.20 60.00 X1 30.00 X1 30.00 55.20 55.20 X1 60.00 60.00 2.40 2x Ø2.20 6.00 35.60 6.00 max 2.2mm max 2.2mm 35.60 max 3.0mm 1.30 3.75 ConnectCore™ 9P 9360 6.00 max 2.2mm 35.60 Visit www.digiembedded.com for part numbers. 91001351 C1/609 DIGI SERVICE AND SUPPORT - You can purchase with confidence knowing that Digi is here to support you with expert technical support and a strong five-year warranty. www.digi.com/support Digi International 877-912-3444 952-912-3444 info@digi.com Digi International France Digi International KK Digi International (HK) Limited +33-1-55-61-98-98 www.digi.fr +81-3-5428-0261 www.digi-intl.co.jp +852-2833-1008 www.digi.cn Buy online • www.digiembedded.com © 2005-2009 Digi International Inc. All rights reserved. Digi, Digi International, the Digi logo, ConnectCore, Digi JumpStart Kit and NET+ are trademarks or registered trademarks of Digi International Inc. in the United States and other countries worldwide. ARM and NET+ARM are trademarks or registered trademarks of ARM Limited. All other trademarks are the property of their respective owners.
CC-9P-NET 价格&库存
很抱歉,暂时无法提供与“CC-9P-NET”相匹配的价格&库存,您可以联系我们找货
