X2E-Z1R-W1-W
X2E-Z1R-W1-W
    DIGIINTERNATIONAL
    CONNECTPORT X2E ZB WI-FI ROUTER
X2E-Z1R-W1-W 数据手册
ZIGBEE SMART ENERGY CERTIFIED IP GATEWAY CONNECTPORT X2E® FOR SMART ENERGY Gateway with the ZigBee Smart Energy Public Application Profile 1.1 provides low-cost, interoperable IP-to-application connectivity for customer engagement ConnectPort X2e is an enhanced Smart Energy gateway optimized for large deployments of Smart Energy devices in a Home Area Network (HAN) including utility meters, thermostats and in-home displays. The wireless gateway provides a low-cost connection between Smart Energy devices and remote web applications or utilityhosted websites designed for consumer engagement and demand response. By sharing the homeowner’s broadband internet connection, the wireless gateway provides near realtime energy data access and control capabilities based on the Smart Energy devices enabled in the customer’s home. BENEFITS The ConnectPort X2e for Smart Energy is available in two configuration options. The Coordinator version is intended for stand-alone Smart Energy networks that do not have smart meters present. The Router version is configured to connect and read the smart metering system which has been installed at the site. APPLICATION EXAMPLE – Full certification to ZigBee Alliance Smart Energy Public Application Profile 1.1 and backwards compatible to 1.0 – Ethernet, Wi-Fi and cellular options for flexible broadband connectivity – Uses Digi Device CloudSM to manage connectivity, configuration and software upgrades as well as application integration via published APIs – Supports both stand-alone Smart Energy networks and Smart Energy metering systems – Enables the Home Area Network (HAN) and Smart Energy devices, such as Programmable Communicating Thermostat (PCT) and In-Home Display products from other manufacturers DEVICE CLOUD Ethernet or Wi-Fi UTILITY COMPANY SMART METER NETWORK ZIGBEE SMART ENERGY NETWORK IN RESIDENTIAL HOUSE CONNECTPORT X2E® FOR SMART ENERGY SE Certified Smart Meter RELATED PRODUCTS Modules SE Range Extenders Smart Plug Cellular Gateways Digi Device CloudSM SE Certified Thermostat XBEE-PRO® RANGE EXTENDER SE Certified In-Home Display SPECIFICATIONS ConnectPort X2e® for Smart Energy ConnectPort X2e® Cellular for Smart Energy GENERAL MANAGEMENT Secure enterprise management via Device Cloud PROTOCOLS UDP/TCP, DHCP LEDS Power, Network (LAN/WAN), ZigBee (HAN/PAN) Power, Network (LAN/WAN), ZigBee (HAN/PAN), Cellular signal strength SECURITY SSL tunnels SSL tunnels, Cellular network security ZIGBEE XBee® ZB SMT transmit power 6.3 mW (+8 dBm); Receiver sensitivity (1% PER) -102 dBm DIMENSIONS (L X W X H) 3 in x 3 in x 1 in (7.62 cm x 7.62 cm x 2.54 cm) 3 in x 4 in x 1 in (7.62 cm x 10.16 cm x 2.54 cm) WEIGHT 0.15 lb (0.07 kg) 0.37 lb (0.082 kg) DEVELOPMENT ZIGBEE PUBLIC APPLICATION PROFILE Smart Energy 1.1 (Backwards compatible to 1.0) PYTHON VERSION 2.7.1 PROCESSOR AND MEMORY (VARIES BY FIRMWARE AND OS VERSION) Freescale i.MX28, 20 MB RAM, 10 MB file space ETHERNET PORTS 1 RJ-45 port PHYSICAL LAYER 10/100Base-T DATA RATE 10/100 Mbps (auto-sensing) N/A MODE Full or half duplex (auto-sensing) N/A ROUTING Ethernet port designed for WAN backhaul only Ethernet port designed for configuration only 802.11 b/g/n N/A DATA RATE Up to 72.2 Mbps N/A TRANSMIT POWER 18 dBm typical (varies by mode and channel) N/A RECEIVER SENSITIVITY Up to -87 dBm @ 11 Mbps N/A MODES AP Client Modes only; Access Point Mode not supported N/A WI-FI POWER REQUIREMENTS POWER SUPPLY 5 VDC power supply with barrel connector included POWER CONSUMPTION Typical: 1.2 W, Max: 2.5 W Typical: 3.5 W, Max: 15 W ENVIRONMENTAL OPERATING TEMPERATURE 0° C to 40° C (32° F to 104° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) ETHERNET ISOLATION 500 VAC min per IEEE802.3/ANSI X3.263 REGULATORY APPROVALS MOBILE CERTIFICATIONS (GSM) N/A AT&T MOBILE CERTIFICATIONS (CDMA) N/A Verizon / Sprint SAFETY EN60950 EMISSIONS/IMMUNITY CE, FCC Part 15 (Class B), IC, ETSI WWW.DIGI.COM PART NUMBERS DESCRIPTION X2K-Z1C-W1-A Digi Smart Energy Developer Kit X2E-Z1C-E1-A ConnectPort X2e, ZigBee SE Coordinator, Ethernet X2E-Z1C-E1-W ConnectPort X2e, ZigBee SE Coordinator, Ethernet (International) X2E-Z1R-E1-A ConnectPort X2e, ZigBee SE Router, Ethernet X2E-Z1R-E1-W ConnectPort X2e, ZigBee SE Router, Ethernet (International) X2E-Z1C-W1-A ConnectPort X2e ZigBee SE Coordinator, Ethernet and Wi-Fi X2E-Z1C-W1-W ConnectPort X2e ZigBee SE Coordinator, Ethernet and Wi-Fi (International) X2E-Z1R-W1-A ConnectPort X2e ZigBee SE Router, Ethernet and Wi-Fi X2E-Z1R-W1-W ConnectPort X2e ZigBee SE Router, Ethernet and Wi-Fi (International) X2E-Z1C-H1-A ConnectPort X2e ZigBee SE Coordinator 3G GSM X2E-Z1R-H1-A ConnectPort X2e ZigBee SE Router 3G GSM X2E-Z1R-D2-A ConnectPort X2e ZigBee SE Router CDMA EVDO (Verizon) X2E-Z1C-D1-A ConnectPort X2e SE Coordinator EVDO (Sprint) X2E-Z1R-D1-A ConnectPort X2e SE Router EVDO (Sprint) X2E-Z1C-D2-A ConnectPort X2e ZigBee SE Coordinator CDMA EVDO (Verizon) FOR MORE INFORMATION PLEASE VISIT WWW.DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2016 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91001721 B2/616 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL FRANCE +33-1-55-61-98-98 / www.digi.fr DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
X2E-Z1R-W1-W 价格&库存
很抱歉,暂时无法提供与“X2E-Z1R-W1-W”相匹配的价格&库存,您可以联系我们找货
