XB3-C-V1-UT-001
XB3-C-V1-UT-001
    DIGIINTERNATIONAL
    DIP20模块
    手机 4G LTE CAT-1(Verizon) RF 收发器模块 集成式,芯片 + U.FL 通孔
XB3-C-V1-UT-001 数据手册
4G LTE CAT 1 CELLULAR SMART MODEM DIGI XBEE 3 CELLULAR LTE CAT 1 Digi XBee 3 smart modems offer the easiest way to integrate cellular connectivity into an OEM device or IoT gateway Digi XBee® 3 modules accelerate time to market for designers, OEMs and solution providers by quickly enabling wireless connectivity and easy-to-add functionality. Building on industry-leading technology, pre-certified Digi XBee 3 modules offer the flexibility to switch between multiple frequencies and wireless protocols as needed. Ideal for moderate bandwidth (typically < 25 MB per month) and low-cost IoT applications, Digi XBee 3 Cellular LTE Cat 1 modules are cost-competitive with modules based on older standards. BENEFITS – Integrated MicroPython programmability enables custom scripting directly on the modem – Transparent and API modes simplify software design – 90 days of free cellular service with development kits – FCC certified and carrier end-device certified for Verizon, AT&T, Telus and Bell – Smallest end-device certified cellular modem – Direct USB provides easy PPP integration option – OTA firmware updates – Enhanced with Digi TrustFence® security framework – Manage/configure with Digi XCTU and Digi Remote Manager® – Dual-mode radio for local configuration over Bluetooth® Low Energy using the Digi XBee Mobile app With Digi Remote Manager®, Digi XBee 3 modules can be easily configured and controlled from a central platform. Built-in Digi TrustFence® security, identity and data privacy features use multiple layers of control to protect against new and evolving cyber threats. Standard Digi XBee API frames and AT commands, MicroPython and Digi XCTU® simplify setup, configuration, testing and adding or changing functionality. Digi XBee 3 modules are the latest addition to the Digi XBee Ecosystem of wireless modules, adapters and software – all engineered to accelerate development and deployment. APPLICATION EXAMPLE END USER CLOUD-BASED APPLICATION CELL TOWER LTE Cat 1 DIGI XBEE 3 CELLULAR LTE CAT 1 Intelligent Lighting Systems Environmental Monitoring Sensors Precision Agriculture Oil/Gas Sensors RELATED PRODUCTS Digi XBee 3 Cellular LTE Cat 1 Development kit Digi ConnectCore 6UL SBC Pro XCTU Digi Remote Manager® Digi Wirless Design Services Digital Signage SPECIFICATIONS Digi XBee 3 Cellular LTE Cat 1 Smart Modem HARDWARE CELLULAR CHIPSET Telit LE866A1-NA (AT&T), LE866-SV1 (Verizon) FORM FACTOR Digi XBee 20-pin through-hole ANTENNA OPTIONS 1 U.FL: Cellular Primary, 1 U.FL: Cellular Diversity Embedded Bluetooth Antenna DIMENSIONS 24.38 mm x 32.94 mm (0.96 in x 1.3 in) OPERATING TEMPERATURE -40º C to 80º C (-40º F to 176º F) SIM SIZE 4FF Nano INTERFACE AND I/O DATA INTERFACE UART, SPI, USB OPERATING MODES Transparent and API over serial, PPP over USB SECURITY Digi Trustfence® security with Secure Boot and Protected JTAG CONFIGURATION TOOLS Digi XCTU® (Local), Digi Remote Manager (OTA) EMBEDDED PROGRAMMABILITY MicroPython with 512K flash / 64K RAM I/O 4 ADC lines (10-bit), 13 Digital I/O, I2C BLUETOOTH BLE CELLULAR CHARACTERISTICS TRANSMIT POWER Up to 23 dBm RECEIVE SENSITIVITY -102 dBm CARRIER APPROVALS AT&T End-Device Certified Bell End-Device Certified Telus End-Device Certified Verizon End-Device Certified Compatible with other LTE Cat 1 carriers; see Supported Bands SUPPORTED BANDS Bands 2, 4, 12 Bands 4, 13 (Verizon module) DOWNLINK/UPLINK SPEEDS 10 Mbit/s Downlink, 5 Mbit/s Uplink (USB) 921 Kbit/s Downlink and Uplink (UART) DUPLEX MODE Full-duplex POWER REQUIREMENTS (AT 3.3 VDC INPUT POWER) SUPPLY VOLTAGE 3.0 to 5.5 V PEAK TRANSMIT CURRENT 1000 mA Bluetooth disabled 1060 mA Bluetooth enabled AVG TRANSMIT CURRENT 850 mA AVG RECEIVE CURRENT 320 mA REGULATORY AND CARRIER APPROVALS FCC (USA) MCQ-XB3C1 and RI7XE866A1NA, MCQ-XB3C1 and RI7LE866SV1A (for Verizon module) IC (CANADA) 1846A-XB3C1 and 5131A-XE866A1-NA, 1846A-XB3C1 and 5131A-LE866-SV1A (for Verizon module) AT&T END-DEVICE CERTIFIED Complete (XB3-C-A1-UT-001 only) VERIZON END-DEVICE CERTIFIED Complete (XB3-C-V1-UT-001 only) TELUS END-DEVICE CERTIFIED Complete (XB3-C-A1-UT-001 only) BELL END-DEVICE CERTIFIED Complete (XB3-C-A1-UT-001 only) PTCRB Complete (XB3-C-A1-UT-001 only) WARRANTY PRODUCT WARRANTY 1-year DIGI.COM SPECIFICATIONS PART NUMBERS DESCRIPTION Digi XBee3 Cellular Smart Modem, LTE CAT 1 XB3-C-A1-UT-001 Digi XBee 3 Cellular Smart Modem, LTE Cat 1, North America XK3-C-A1-UT-U Digi XBee 3 Cellular Smart Modem, LTE Cat 1, Development Kit, AT&T XB3-C-V1-UT-001 Digi XBee 3 Cellular Smart Modem, LTE Cat 1, Verizon XK3-C-V1-T-UB Digi XBee 3 Cellular Smart Modem, LTE Cat 1, Development Kit, Verizon FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004232 A10/120 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
XB3-C-V1-UT-001
物料型号: - XB3-C-A1-UT-001:Digi XBee 3 Cellular智能调制解调器,LTE Cat 1,北美版。 - XK3-C-A1-UT-U:Digi XBee 3 Cellular智能调制解调器开发套件,LTE Cat 1,AT&T版。 - XB3-C-V1-UT-001:Digi XBee 3 Cellular智能调制解调器,LTE Cat 1,Verizon版。 - XK3-C-V1-T-UB:Digi XBee 3 Cellular智能调制解调器开发套件,LTE Cat 1,Verizon版。
器件简介: Digi XBee 3智能调制解调器提供了一种将蜂窝连接集成到OEM设备或物联网网关中的简便方式。这些模块基于行业领先的技术,提供预认证的灵活性,可以根据需要在多个频率和无线协议之间切换。
引脚分配: - Digi XBee 20-pin通孔。
参数特性: - 硬件:包括蜂窝芯片组(Telit LE866A1-NA适用于AT&T,LE866-SV1适用于Verizon)、天线选项、尺寸、工作温度、SIM卡尺寸。 - 接口和I/O:包括数据接口(UART、SPI、USB)、操作模式、安全性、配置工具、嵌入式编程能力、I/O、蓝牙。 - 蜂窝特性:包括发射功率、接收灵敏度、运营商认证、支持的频段、下行/上行速度、双工模式、电源要求。
功能详解: - 集成MicroPython可编程性,允许在调制解调器上直接进行自定义脚本编写。 - 透明和API模式简化了软件设计。 - 通过Digi XCTU和Digi Remote Manager进行管理和配置。 - 通过Digi XBee Mobile应用程序使用蓝牙低功耗进行本地配置。
应用信息: - 适用于中等带宽(通常<25 MB每月)和低成本物联网应用。 - 适用于照明系统、智能监控传感器、环境、精准农业、油气传感器、数字标牌等。
封装信息: - 尺寸:24.38mm x 32.94mm(0.96英寸x 1.3英寸)。 - SIM卡尺寸:4FF Nano。
XB3-C-V1-UT-001 价格&库存
很抱歉,暂时无法提供与“XB3-C-V1-UT-001”相匹配的价格&库存,您可以联系我们找货
