XK3-C-V1-T-UB
XK3-C-V1-T-UB
    DIGIINTERNATIONAL
    XBee® 3 XBee® 3 蜂窝式开发平台 评估板
XK3-C-V1-T-UB 数据手册
3 MONTHS OF FREE DATA DIGI XBEE 3 CELLULAR LTE CAT 1 DEVELOPMENT KIT The Digi XBee 3 Cellular LTE Cat 1 development kit provides OEMs with a simple, quick way to integrate cellular connectivity into their devices The Digi XBee® 3 Cellular embedded smart modem brings together the power and flexibility of the Digi XBee Ecosystem with the latest in LTE cellular technology. OEMs can quickly integrate cutting edge LTE cellular into their devices and applications, eliminating the painful, time-consuming and expensive FCC and carrier end-device certification process. Digi XBee 3 Cellular development kits help developers integrate cellular connectivity into applications using Digi XBee 3 embedded modems. Starting with simple examples, we provide step-by-step guidance as you assemble the kit components to create reliabile, low-power cellular communication connectivity for OEM devices like sensors and monitoring systems. Each kit includes three months of cellular data service, preactivated and ready to go, so your team can focus on your primary goal: prototyping and developing products. This kit is designed for anyone interested in getting started in the world of embedded cellular. Hardware and software engineers, corporate technologists, or educators and students can quickly learn more about cellular integration using the hands-on examples included in the kit. With the full suite of standard Digi XBee API frames and AT commands, Digi XBee customers can seamlessly transition to this new embedded modem with only minor software digi.com Your Kit Includes: 3 Digi XBee 3 Cellular LTE Cat 1 embedded modem 3 Digi XBee 3 development board 3 LTE Cat 1 SIM 3 3 months of free cellular service* 3 Antennas NUMBER DESCRIPTION XK3-C-A1-UT-U Digi XBee 3 Cellular LTE Cat 1 Development Kit, AT&T XK3-C-V1-T-UB Digi XBee 3 Cellular LTE Cat 1 Development Kit, Verizon *Service is limited to ~5MB/month and limited SMS. For testing purposes only; not for production. adjustments. OEMs can future proof their designs by adding Digi XBee 3 Cellular. Ideal for any OEM business following an agile roadmap, Digi XBee 3 Cellular provides the flexibility to switch between wireless protocols or upgrade to LTE Cat M1 or NB-IoT. SPECIFICATIONS Digi XBee XBee3® 3 Cellular CellularLTE Smart CatModem, 1 Smart LTE Modem CAT 1 HARDWARE CELLULAR CHIPSET Telit LE866A1-NA (AT&T), LE866-SV1 (Verizon) FORM FACTOR Digi XBee 20-pin through-hole ANTENNA OPTIONS 1 U.FL: Cellular Primary, 1 U.FL: Cellular Diversity Embedded Bluetooth Antenna DIMENSIONS 24.38 mm x 32.94 mm (0.96 in x 1.3 in) OPERATING TEMPERATURE -40º C to 80º C (-40º F to 176º F) SIM SIZE 4FF Nano INTERFACE AND I/O DATA INTERFACE UART, SPI, USB OPERATING MODES Transparent and API over serial, PPP over USB SECURITY Digi TrustFence® security with Secure Boot and Protected JTAG CONFIGURATION TOOLS Digi XCTU® (local), Digi Remote Manager (OTA) EMBEDDED PROGRAMMABILITY MicroPython with 512K flash / 64K RAM I/O 4 ADC lines (10-bit), 13 Digital I/O, I2C BLUETOOTH BLE CELLULAR CHARACTERISTICS TRANSMIT POWER Up to 23 dBm RECEIVE SENSITIVITY -102dBm SUPPORTED BANDS AT&T End-Device Certified Bell End-Device Certified Telus End-Device Certified Verizon End-Device Certified Compatible with other LTE Cat 1 carriers; see Supported Bands Bands 2,4,12 Bands 4, 13 (Verizon module) DOWNLINK/UPLINK SPEEDS 10 Mbit/s Downlink, 5 Mbit/s Uplink (USB) 921 Kbit/s Downlink and Uplink (UART) DUPLEX MODE Full-duplex CARRIER APPROVALS POWER REQUIREMENTS (AT 3.3 VDC INPUT POWER) SUPPLY VOLTAGE 3.0 to 5.5 V PEAK TRANSMIT CURRENT 1000 mA Bluetooth Disabled 1060 mA Bluetooth Enabled AVG TRANSMIT CURRENT 850 mA AVG RECEIVE CURRENT 320 mA REGULATORY AND CARRIER APPROVALS FCC (USA) MCQ-XB3C1 and RI7XE866A1NA, MCQ-XB3C1 and RI7LE866SV1A (for Verizon module) IC (CANADA) 1846A-XB3C1 and 5131A-XE866A1-NA, 1846A-XB3C1 and 5131A-LE866-SV1A (for Verizon module) AT&T END-DEVICE CERTIFIED Complete (XB3-C-A1-UT-001 only) VERIZON END-DEVICE CERTIFIED Complete (XB3-C-V1-UT-001 only) TELUS END-DEVICE CERTIFIED Complete (XB3-C-A1-UT-001 only) BELL END-DEVICE CERTIFIED Complete (XB3-C-A1-UT-001 only) PTCRB Complete (XB3-C-A1-UT-001 only) digi.com 877-912-3444 I 952-912-3444 PRODUCT IMAGES SPECIFICATIONS FOR MORE INFORMATION PLEASE VISIT DIGI.COM It’s the easy and fast way to build a wireless cellular device using Digi’s XBee modules. To learn more visit www.digi.com/xbeecellular. 877-912-3444 I 952-912-3444 © 1996-2020 Digi International Inc. All rights reserved. All other trademarks are the property of their respective owners. 91004236 A5/120
XK3-C-V1-T-UB 价格&库存
很抱歉,暂时无法提供与“XK3-C-V1-T-UB”相匹配的价格&库存,您可以联系我们找货
