EX12-R004-OUS
EX12-R004-OUS
    DIGIINTERNATIONAL
    4G/3G LTE,HSPA+ 路由器 AT&T,Verizon RJ-45,RS-232
EX12-R004-OUS 数据手册
LTE CELLULAR EXTENDER FOR BUSINESS CONTINUITY Manage this device with Digi Remote Manager DIGI EX12 Avoid network outages with primary or backup LTE connectivity; integrate seamlessly with existing infrastructure Digi EX12 LTE cellular extender is an affordable, scalable failover solution that enables you to retrofit your infrastructure for cellular network access. With a carrier-certified, embedded LTE Cat 4 cellular modem, equipped with dual SIM slots, Digi EX12 provides uninterrupted primary or backup connectivity. It protects against downtime by automatically switching to a secondary cellular carrier should the primary SIM lose Internet access. This compact, high-performance device is also compatible with any dual-WAN networking appliance and helps you achieve reliable connectivity at any location using your existing equipment. for POS systems, ATMs, mobile kiosks, digital signage and more. Deployments are streamlined with installation accessories including mounting hardware, a disposable battery pack for site survey and a passive PoE injector for optimizing placement for the best cellular reception. Digi EX12 can be securely monitored and managed with Digi Remote Manager®, a cloud-based solution that facilitates setup, mass configuration and support for Digi and thirdparty devices. Digi Remote Manager lets you evaluate, update and configure your Digi enterprise routers and gateways — and the health of your network — at scale, after deployment. Couple the Digi EX12 with a dedicated wireline ISP connection to maximize uptime and ensure reliable network availability FEATURES AND BENEFITS APPLICATION EXAMPLE – Redundant connectivity with dual SIMs and Digi SureLink™ INTERNET – Optimized connectivity to any Ethernet device – Built-in Digi TrustFence® for device security, device identity and data privacy – Site survey battery pack to identify the best location for optimum cellular reception LTE BACK OFFICE OR IN STORE – Remote mounting kit for quick, easy installation – Automatic cellular carrier detection and switching with Carrier Smart Select™ BROADBAND MODEM (Cable/DSL ISP) POS TERMINAL – Digi Remote Manager software for easy setup, mass configuration and management DUAL-WAN CONNECTIVITY + POWER OVER ETHERNET RELATED PRODUCTS Digi EX15 Digi 6330-MX SERIAL OOB Digi 6310-DX Accessories Digi Remote Manager PRIVATE LAN POOR CELLULAR RECEPTION DIGI EX12 GUEST WI-FI GOOD CELLULAR RECEPTION SPECIFICATIONS DIGI® EX12 CELLULAR CONNECTIVITY EX12-R004-OUS LTE: B2, B4, B5, B12, B13, B14, B66, B71; 3G: B2, B4, B5; Transfer rate (max): 150 Mbps down, 50 Mbps up CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF); software selectable and hardware switchable SOFTWARE AND MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager; SNMP v1/v2c/v3 (user installed/managed) LOCAL MANAGEMENT RIP, RIPng, OSPFv2, OSPFv3, BGP, Babel, IS-IS MANAGEMENT/ TROUBLESHOOTING TOOLS FTP client, SCP; protocol analyzer with PCAP for Wireshark; event logging with Syslog and SMTP client; NTP/SNTP MEMORY 256 MB RAM, 512 MB flash ETHERNET PORTS (2) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) RS-232 (RJ-45) PHYSICAL DIMENSIONS (L x W x H) 127 mm x 127 mm x 25 mm (5.0 in x 5.0 in x 1.0 in) WEIGHT 0.24 kg (8.25 oz) STATUS LEDs LAN (link = solid, flashing = act), WAN (link = solid, flashing = act), LTE, 5 signal ENCLOSURE Plastic POWER REQUIREMENTS POWER INPUT 18 VDC 1 A OTHER Remote mounting kit: temporary battery, passive PoE injector, mounting bracket and accessories ENVIRONMENTAL OPERATING TEMPERATURE 0° C to 40° C (32° F to 104° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR PTCRB; US: AT&T, Verizon, Canada EMISSIONS / IMMUNITY FCC Part 15, Subpart B, Class A; CE, RCM; CAN ICES-3(B)/NMB-3(B) WARRANTY PRODUCT WARRANTY 3-year PRODUCT IMAGES DIGI EX12 TOP DIGI EX12 LEFT SIDE Main AUX/SMA DIGI EX12 RIGHT SIDE 25 mm 127 mm 127 mm SIM Erase LAN WAN Serial Power /PoE input 18 V DIGI.COM DIGI REMOTE MANAGER® CAPABILITIES – Centralized management of remote devices over 3G/4G/LTE – Define standard configurations and automatically monitor individual devices for PCI security compliance – Get alerts and create reports on performance statistics, including connection history, signal quality, latency, data usage and packet loss – No servers or applications to operate and maintain – Perform tasks across your entire device network in minutes – Edit configurations and update firmware for individual devices or groups – Monitor the status and location of remote devices via a web browser – Activate or deactivate cellular lines and monitor data to ensure you never incur overage charges INFRASTRUCTURE SECURITY – Hosted in a commercial-grade SAS 70-certified environment – Certified SSAE-16 facilities – Superior availability, operating to 99.9% or greater – Over 175 security controls in place to protect your data – Open APIs available to support application development – Enables compliance with security frameworks like PCI, HIPAA, NIST – Earned SkyHigh’s Cloud Trust Program highest rating of Enterprise-Ready PART NUMBERS EX12-R004-OUS PART NUMBERS DIGI EX12 Digi EX12: 2-port 10/100; RJ-45, RS-232; US and Canada, LTE / HSPA+ Cat 4; Cellular certifications: PTCRB, AT&T, Verizon, Canada ACCESSORIES 450069 18 V PSU power supply with barrel jack connector (replacement) 500170 10/100 base-T passive PoE adapter, green (replacement) 440084 4 meter flat Cat 6 Ethernet cable, white (replacement) 440091 0.5 meter flat Cat 6 Ethernet cable, white (replacement) 560083 Temporary site survey battery pack, 9 V with 152.4 mm power lead, 2.1 mm barrel connector (replacement) FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2019 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004393 A2/220 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
EX12-R004-OUS 价格&库存
很抱歉,暂时无法提供与“EX12-R004-OUS”相匹配的价格&库存,您可以联系我们找货
EX12-R004-OUS
  • 1+3949.772591+513.37412
EX12-R004-OUS
    库存:3
