76002107
76002107
    DIGIINTERNATIONAL
    网络 配件套件 配用 Digi® IX15
76002107 数据手册
Manage this device with Digi Remote Manager DIGI IX15 Programmmable gateway connects Digi XBee-enabled devices to remote applications over cellular and Ethernet The versatile Digi IX15 functions as both gateway and router for customers seeking lower-cost, quicker-to-market alternatives to chip-down DIY designs for networking operations. The industrial-grade Digi IX15 connects Digi XBee® modules to cloud applications over cellular, providing the easiest path to Internet connectivity for the Digi XBee ecosystem of hardware, software, services and award-winning tools. With C1D2 certification and rugged enclosure, Digi IX15 is ideal for the harsh, corrosive environments found in oil and gas, water/wastewater, solar, agriculture and other industrial applications. For developers needing a highly secure, common platform to cut costs and time-to-market, Digi IX15 reduces risk and drives project efficiencies. The Digi IX15 gateway includes a simple, open source Python development environment that enables custom applications to perform edge computing locally while providing the most optimal, resilient connectivity between your XBee network and cloud-based applications. Gain critical insights into your deployed devices and manage your network with Digi Remote Manager® Manager (Digi RM) — the command center for your deployment. Digi RM is a cloudbased solution that facilitates easy setup, mass configuration, maintenance and visibility into the health of your network, whether you deploy dozens or thousands of devices. In the event of an interruption to your primary network connection, Digi RM also provides secure terminal access for out-of-band management of edge devices via serial port and command-line interface. APPLICATION EXAMPLE FEATURES AND BENEFITS – Open source Python environment for custom application development on the gateway – Zigbee®, DigiMesh®, 802.15.4, Bluetooth® 5.0 and RS-232/485 enabled for connection to local devices – LTE Cat 4 and 10/100 Ethernet WAN connectivity – Digi Remote Manager platform for easy setup, mass configuration/firmware updates, remote device management and out-of-band management Secure Connection HEADQUARTERS DIGI REMOTE MANAGER® VPN ZIGBEE® WIRELESS MESH NETWORK – Full-featured industrial cellular routing platform Cellular/Ethernet DIGI IX15 GATEWAY – Redundant connectivity with dual SIMs and Digi SureLink® – Built-in Digi TrustFence® for device security, device identity and data privacy RELATED PRODUCTS Bluetooth® Low Energy Street Lights Digi XBee® Modules Digi XBee® Tools Digi Remote Manager® Development Kits Digi IX10 DIGI XBEE® MODULES DIGI XBEE TOOLS SPECIFICATIONS DIGI IX15 DIGI XBEE® XBEE MODULE Standard: Digi XBee® 3 ZB 3.0 MMT; PRO: Digi XBee 3 PRO ZB 3.0 MMT ZIGBEE STACK Zigbee® Standard and Zigbee PRO versions available ZIGBEE TRANSMIT POWER Standard: 6.3 mW (8 dBm); PRO: 63 mW (18 dBm) ZIGBEE RECEIVER SENSITIVITY -102 dBm XBEE CONNECTOR (1) 50 Ω RP-SMA (center pin: male) CELLULAR CERTIFICATIONS Visit www.digi.com/resources/certifications for latest cellular certifications BANDS LTE Cat 4: B1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B28, B38, B39, B40, B41 3G: B1, B2, B4, B5, B6, B8, B19 2G EDGE / GPRS: 850 / 900 / 1800 / 1900 MHz CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Behind SiM cover, secured with screw (#1 Phillips) SOFTWARE AND MANAGEMENT PYTHON Python 3 REMOTE MANAGMENT Digi Remote Manager®; SNMP v2/v3 (user installed/managed) LOCAL MANAGMENT WebUI (HTTP/HTTPS); CLI (Telnet, SSH) MANAGEMENT / TROUBLESHOOTING TOOLS FTP client, SCP; protocol analyzer with PCAP for Wireshark; event logging with syslog and SMTP client; NTP/SNTP; Nagios, Intelliflow, iPerf, Dynamic DNS, ping, traceroute ETHERNET PORTS (1) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) RJ-45 10-pin (10P10C); RS-232/485; software selectable - RS-232 DTE (RXD, TXD, RTS, CTS, DTR, DCD, DSR, RI) - RS-485 (TX/RX+; RX/TX-); half-duplex PHYSICAL DIMENSIONS (L x W x H) 157 mm x 106 mm x 35 mm (6.18 in x 4.17 in x 1.38 in) WEIGHT 0.39 kg (0.86 lb) STATUS LEDs Power, SIM, LTE/Internet, XBee, signal strength (5) ENCLOSURE Glass-filled polyphenylene sulphide (PPS) / IP30 POWER REQUIREMENTS POWER INPUT 9 - 30 VDC, 1.0 A maximum POWER CONSUMPTION 2.5 W typical (idle); 6 W typical (peak Tx/Rx) ENVIRONMENTAL OPERATING TEMPERATURE -40° C to 74° C (-40° F to 165° F); device performance may be impacted above 60° C (140° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR AND REGULATORY Visit www.digi.com/resources/certifications for latest cellular and regulatory approvals SAFETY UL60950-1, IEC62368-1, CB, EN62311, UL 121201/CSA 213 (Class 1, Div 2) ENVIRONMENTAL ROHS3 EMISSIONS / IMMUNITY CE; RED; FCC Part 15, Subpart B**; ICES-003; AU/NZS CISPR32 WARRANTY PRODUCT WARRANTY 3-year* *Standard 3-year warranty upgradeable to 5 years with purchase of a Digi Remote Manager Premier 5-year subscription applicable to the product purchased only at the time of product purchase and with product registration at that time in Digi Remote Manager. **Compliant to limits for a Class A digital device when tested with power supply 76002104. DIGI.COM ENTERPRISE SOFTWARE DESCRIPTION CELLULAR CONNECTIVITY PROTOCOL SUPPORT HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH; remote management via Digi Remote Manager®; protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; dynamic DNS client compatible with BIND9/No-IP/DynDNS; captive portal, Intelliflow; Nagios, DNS server, NTP server, multicast, mDNS, IPerf SECURITY IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; TLS 1.2 and above, OpenVPN client and server; VPN tunnels; authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support VPN IPSec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; cryptology: SHA-1/256/384/512, MD5, RSA; encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) ROUTING / FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; GRE; multicast routing; routing protocols: RIP (v1, v2) OSPF, BGP; IP failover: VRRP; automatic failover, Digi SureLink® OTHER PROTOCOLS DHCP; dynamic DNS client compatible with No-IP/DynDNS DIGI REMOTE MANAGER® CAPABILITIES – Activate, monitor and diagnose your mission-critical devices from a single point of command and control — on your desktop or mobile app – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access – Keep tabs on device health and connectvity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready DIGI.COM PRODUCT IMAGES FRONT BACK PART NUMBERS DIGI IX15 IX15-00G4-XB2 Digi IX15 - XBee 3, LTE Cat 4, (1) Ethernet, RS-232/485 IX15-00G4-XBP2 Digi IX15 - XBee 3 PRO, LTE Cat 4, (1) Ethernet, RS-232/485 PART NUMBERS ACCESSORIES 76002107 Digi IX15 2.4 GHz Accessory Kit 76002104 Power supply with plug tips for US, UK, EU, AU DC-ANT-24DT (1) Magnetic table-top 2.4 GHz antenna 76002103 (1) Cellular antenna (order quantity 2) 76002095 DIN rail clip kit 76000645 Cable, RJ45M/DB09F, 48”, connects EIA 422/485 devices to Digi products that have 10-pin RJ-45 connectors* *For RS-232 cabling pinouts and recommended cables, please refer to the Digi products cabling guide at: www.digi.com/resources/documentation/Digidocs/PDFs/90000253.pdf PART NUMBERS DIGI REMOTE MANAGER® DIGI-RM-STD-1YR Digi Remote Manager Standard - 1-year subscription DIGI-RM-PRM-1YR Digi Remote Manager Premier - 1-year subscription DIGI-RM-PRM-3YR Digi Remote Manager Premier - 3-year subscription DIGI-RM-PRM-5YR Digi Remote Manager Premier - 5-year subscription FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2021 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004450 A10/321 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL GERMANY +49-89-540-428-0
76002107 价格&库存
很抱歉,暂时无法提供与“76002107”相匹配的价格&库存,您可以联系我们找货
    • 1+1494.289191+194.25276
    库存:31
