IX20-00G4
IX20-00G4
    DIGIINTERNATIONAL
    4G EDGE,GPRS,LTE 路由器 以太网,RS-232
IX20-00G4 数据手册
RUGGED, SECURE LTE ROUTER Manage this device with Digi Remote Manager DIGI IX20 Cloud managed networking for critical applications Digi IX20 is a full-featured cellular router that can scale from basic connectivity applications to industrial-class routing and security solutions. Its flexible power and connectivity options make it a versatile choice for use in industrial infrastructure, digital signage, retail kiosks, service terminals and other critical assets with a need for secure transactions. The high-performance architecture of the Digi IX20 router provides primary and backup WWAN connectivity over software selectable multi-carrier LTE. Digi IX20 supports software features for advanced security (stateful firewall, MAC filtering and VPN), redundancy (Digi SureLink®) and management (SNMP, event logging, analyzer trace and QOS), enabling it to be used in PCI or NERC-CIP compliant applications. FEATURES AND BENEFITS Gain critical insights into your deployed devices and manage your network with Digi Remote Manager® — the command center for your deployment. Digi Remote Manager (Digi RM) is a cloud-based solution that facilitates easy setup, mass configuration, maintenance and support for hundreds or even thousands of remote Digi devices. Digi RM lets you evaluate, update and configure your Digi enterprise products — and the health of your network — at scale after deployment. The Digi IX20 family of routers has a single part number, which simplifies inventory control for global distribution and deployment. In addition, Digi IX20 is designed for Digi CORE® plug-in LTE modems that can be changed out or upgraded without replacing the entire router. APPLICATION EXAMPLE – Compact and economical cellular routing platform with industrial feature set Secure Connection – Redundant connectivity with dual SIMs and Digi SureLink – Global bands and single part number to simplify global distribution, deployment and management – Built-in Digi TrustFence® for device security, secure encrypted connections, ongoing monitoring and support – Digi Remote Manager platform for easy setup, mass configuration and management HEADQUARTERS DIGI REMOTE MANAGER® VPN REMOTE SITE LTE / 3G DIGI IX20 – Dual Ethernet ports and single serial (RS-232) port Ethernet Digi WR21 Kiosk Digital Signage RELATED PRODUCTS Digi WR11 XT Wi-Fi Serial Digi WR31 Digi TX54 Digi Remote Manager Industrial Controller SPECIFICATIONS DIGI® IX20 CELLULAR CERTIFICATIONS Visit www.digi.com/resources/certifications for latest certifications LTE (G4) WITH DIGI CORE® PLUG-IN LTE MODEM 1002-CMG4 LTE Cat 4: B1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B28, B38, B39, B40, B41 3G: B1, B2, B4, B5, B6, B8, B19 2G EDGE / GPRS: 850 / 900 / 1800 / 1900 MHz CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Secured in cellular module WI-FI MODULE 1 x 1 SISO dual-band 802.11a/b/g/n/ac (2.4 GHz / 5 GHz) AUTHENTICATION TACACS+, Enterprise RADIUS MODES Client mode and access point mode simultaneously CLIENTS Maximum 10 clients (access point mode: regardless of combination of clients and access points) ACCESS POINTS Maximum 2 access points (access point mode: regardless of combination of clients and access points) SECURITY WPA/WPA-2 personal, WPA/WPA-2 enterprise CONNECTORS (1) 50 Ω SMA (center pin: male) SOFTWARE AND MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager®; SNMP v2/v3 (user installed/managed) LOCAL MANAGEMENT WebUI (HTTP/HTTPS); CLI (Telnet, SSH) MANAGEMENT/ TROUBLESHOOTING TOOLS FTP client, SCP; protocol analyzer with PCAP for Wireshark; event logging with syslog and SMTP client; NTP/SNTP; Nagios, Intelliflow, iPerf, Dynamic DNS, ping, traceroute MEMORY 256 MB RAM, 256 MB flash ETHERNET PORTS (2) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) DB9M; RS-232 DTE; signal support TXD, RXD, CTS, DTR, DCD, flow control software (XON/OFF), hardware supported (CTS/RTS) PHYSICAL DIMENSIONS (L x W x H) 107 mm x 162 mm x 35 mm (4.21 in x 6.38 in x 1.38 in) WEIGHT 0.65 kg (1.4 lb) STATUS LEDs Power, Internet, Wi-Fi, SIM 1, SIM 2, signal strength (5), LTE ENCLOSURE Glass-filled polyphenylene sulphide (PPS) / IP30 POWER REQUIREMENTS POWER INPUT 9 - 30 VDC, 1.0 A maximum POWER CONSUMPTION 2.5 W typical (idle); 6 W typical (peak Tx/Rx) ENVIRONMENTAL OPERATING TEMPERATURE RELATIVE HUMIDITY Models with Wi-Fi: -20° C to 70° C (-4° F to 158° F); device performance may be impacted above 50° C (122° F) Models without Wi-Fi: -40° C to 70° C (-40° F to 158° F); device performance may be impacted above 50° C (122° F) 5% to 95% (non-condensing) APPROVALS CELLULAR Visit www.digi.com/resources/certifications for latest cellular certifications SAFETY IEC62368-1, CB, EN62311 ENVIRONMENTAL ROHS3 EMISSIONS / IMMUNITY CE; RED; FCC Part 15, Subpart B; ICES-003; AU/NZS CISPR32 WARRANTY PRODUCT WARRANTY 3-year DIGI.COM ENTERPRISE SOFTWARE DESCRIPTION CELLULAR CONNECTIVITY PROTOCOL SUPPORT HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH; remote management via Digi Remote Manager®; Protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; Captive portal, Intelliflow; Nagios, DNS server, NTP server, Multicast, mDNS, IPerf SECURITY IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; TLS 1.2 and above, FIPS 197, open VPN client and server; VPN tunnels; Authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support VPN IPSec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; Cryptology: SHA-1/256/384/512, MD5, RSA; Encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) ROUTING / FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: RIP (v1, v2) OSPF, BGP; IP failover: VRRP; automatic failover, Digi SureLink® OTHER PROTOCOLS DHCP; dynamic DNS client compatible with No-IP/DynDNS DIGI REMOTE MANAGER® CAPABILITIES – Activate, monitor and diagnose your mission-critical devices from a single point of command and control — on your desktop or mobile app – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access – Keep tabs on device health and connectvity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready DIGI.COM PRODUCT IMAGES FRONT WITH ANTENNAS BACK PART NUMBERS DIGI® IX20 IX20-WAG4 Digi IX20 - LTE Cat 4 Global, Wi-Fi, (2) Ethernet, DB-9 RS-232; includes DIN rail clip, power supply, (2) cellular antenna, Wi-Fi antenna and Ethernet cable IX20-0AG4 Digi IX20 - LTE Cat 4 Global, (2) Ethernet, DB-9 RS-232, includes DIN rail clip, power supply, (2) cellular antenna and Ethernet cable IX20-W0G4 Digi IX20 - LTE Cat 4 Global, Wi-Fi, (2) Ethernet, DB-9 RS-232 IX20-00G4 Digi IX20 - LTE Cat 4 Global, (2) Ethernet, DB-9 RS-232 PART NUMBERS ACCESSORIES 76002104 Power supply with plug tips for US, UK, EU, AU 76002105 Wi-Fi antenna 76002106 Ethernet cable - 2 m (6 ft) 76000926 Cellular antenna 76002093 DIN rail mounting bracket kit 76002095 DIN rail clip kit DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004421 B6/920 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL GERMANY +49-89-540-428-0
IX20-00G4 价格&库存
很抱歉,暂时无法提供与“IX20-00G4”相匹配的价格&库存,您可以联系我们找货
