IX30-00A4
IX30-00A4
    DIGIINTERNATIONAL
    2G/3G BeiDou,FDD,Galileo,GLONASS,GNSS,GPS,QZSS,TDD 路由器 以太网,RS-232/422/485
IX30-00A4 数据手册
INDUSTRIAL FIRSTNET CAPABLE™ LTE ROUTER Manage this device with Digi Remote Manager DIGI IX30 Intelligent 4G LTE router designed for critical infrastructure and industrial applications Digi IX30 is an intelligent 4G LTE router designed for optimal performance and reliability across a wide range of critical infrastructure and industrial applications. This complete solution is fully integrated with software and security, providing a secure, reliable connection to industrial controllers, process automation equipment and smart grid assets on third party sites or remote locations. Software-defined, multi-carrier networking and global LTE and HSPA+ options make it easy to get connected. This drop-in connectivity gives operators a way to reduce downtime and service calls, and also increase revenue by bringing distributed sites online faster. The Digi IX30 router offers FirstNet Capable™ models designed to meet the demands of first responders for critical communications. Additional industrial use case applications for Digi IX30 include building and process automation controllers, IP cameras and access controllers, remote data loggers, flow meters, sensing equipment, telco infrastructure, and traffic and obstruction lighting. Gain critical insights into your deployed devices and manage your network with Digi Remote Manager® (Digi RM) — the command center for your deployment. Digi RM is a cloud-based solution that facilitates easy setup, as well as mass configuration, maintenance and visibility into the health of your network, whether you deploy dozens or thousands of devices. In the event of an interruption to your primary network connection, Digi RM also provides secure terminal access for out-of-band management of edge devices via serial port and command-line interface. APPLICATION EXAMPLE FEATURES AND BENEFITS – Global LTE and HSPA+ support and certification on major carrier networks around the world – Ethernet, serial I/O and Modbus bridging – Extremely resilient cellular connection through Digi’s patented SureLink®, VRRP+ protocol and dual SIM slots – GNSS receiver supporting GPS, GLONASS, BeiDou and Galileo MANAGED SERVICE PROVIDER CENTRAL APPLICATION 3G/4G/LTE – License-free enterprise software: VPN, firewall, logging and authentication DIGI IX30 – Digi Remote Manager platform for easy setup, mass DIGI REMOTE MANAGER® configuration and management – Rugged enclosure, optimized for DIN rail or shelf mounting – C1D2 and ATEX rated; NEMA TS2 temperature rated Traffic Controller Monitor Industrial Controller Meter Security Camera RELATED PRODUCTS PLC Digi IX10 Digi IX20 Digi IX15 Digi TX64 Digi Remote Manager® SPECIFICATIONS DIGI IX30 WIRELESS INTERFACES CELLULAR FIRSTNET CAPABLE™ LTE-ADVANCED CAT 7 LTE-Advanced Cat 7— FDD: B2, B4, B5, B7, B12, B13, B14 - FirstNet®, B25, B26, B66, B71; TDD: B41, B42, B43, B48; WCDMA: B2, B4, B5; GNSS: GPS, GLONASS, BeiDou, Galileo, QZSS LTE CAT 4 GLOBAL LTE Cat 4 — FDD: B1, B2, B3, B4, B5, B7, B12, B13, B18, B19, B20, B25, B26, B28; TDD: B38, B39, B40, B41; WCDMA: B1, B2, B4, B5, B6, B8, B19; GSM: B2, B3, B5, B8; GNSS: GPS, GLONASS, BeiDou, Galileo, QZSS LTE CAT 4 AU/NZ LTE Cat 4 — FDD: B1, B3, B5, B7, B8, B18, B19, B21, B28; TDD: B38, B39, B40, B41; 3G: B1, B5, B6, B8, B9, B19; GNSS: GPS, GLONASS, BeiDou, Galileo, QZSS CONNECTORS (3) 50 Ω SMA (2x cellular, 1x GNSS); center pin: female SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Screw-down SIM cover GNSS Protocol NMEA 0183 V3.0 Acquisition Time Hot Start 1 s; Warm Start 29 s; Cold Start 32 s Accuracy Horizontal: < 2 m (50%), < 5 m (90%); Altitude: < 4 m (50%), < 8 m (90%); Velocity: < 0.2 m/s SOFTWARE & MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager® (cloud based); SNMP v1/v2c/v3 (user installed/managed), SMS LOCAL MANAGEMENT Web UI (HTTP/HTTPS); CLI (Telnet, SSH, Serial) MANAGEMENT/ TROUBLESHOOTING TOOLS FTP, SFTP, SCP; protocol analyzer with PCAP for Wireshark; event logging with Syslog and SMTP; NTP/SNTP WIRED INTERFACES ETHERNET PORTS (2) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) DB-9 DTE STANDARD RS-232/422/485 SIGNAL SUPPORT TXD, RXD, RTS, CTS, DTR, DCD, DSR, RI FLOW CONTROL Software (XON/XOFF), hardware supported I/O CONNECTOR 12-pin screw down terminal block DIGITAL 0-30 VDC, 200 mA max.; (4) I/O, software-selectable; pulse counter input ANALOG (4) analog I/O; 4-20 mA or 0-10 V, software-selectable; 12-bit resolution USB PORTS (1) USB 2.0 Type A; 5 V 500 mA max PHYSICAL DIMENSIONS (L X W X H) 12.8 cm x 10 cm x 5.2 cm (5.04 in x 3.94 in x 2.05 in) WEIGHT 0.5 kg (1.1 lb) STATUS LEDS Signal Strength (5), LTE, Power ENCLOSURE/RATING Aluminum / IP30 MOUNTING DIN rail mount POWER REQUIREMENTS POWER INPUT 9 – 30 VDC, 18 W min power source required POWER CONNECTOR Screw down removable terminal block POWER CONSUMPTION 4 W typical (idle); 12 W typical (peak Tx/Rx) ENVIRONMENTAL HAZARDOUS (CLASS 1 DIV 2) Yes OPERATING TEMPERATURE -34° C to 74° C (-29° F to 165° F); reduced cellular performance may occur above 60° C (140° F) STORAGE TEMPERATURE -40° C to 85° C (-40° F to 185° F) ETHERNET ISOLATION 1.5 kV RMS SERIAL PORT PROTECTION (ESD) 15 kV RELATIVE HUMIDITY 5% to 95% (non-condensing) DIGI.COM SPECIFICATIONS DIGI IX30 APPROVALS CELLULAR IX30-00P7: PTCRB, Verizon, T-Mobile, AT&T, FirstNet Capable™; IX30-00G4: CE, RED, UKCA SAFETY Hazardous locations: ANSI/ISA-12.12.01-2015, CAN/CSA C22.2 NO.213-15 Ordinary locations: UL 62368-1, 2nd Edition, 2014-10-14; UL 62368:  2014, 2nd Edition ATEX standards: Protection method II 3 G Ex nA IIC T4 Gc EN 60079-0:2012+A11:2013, EN 60079-15:2010, DEMKO 15 ATEX 1574X Rev. 1 IECEX STANDARDS US/UL/ExTR17.0077/00 EMISSIONS/IMMUNITY CE, RED, FCC Part 15 Subpart B, ICES-003, AS/NZS CISPR 32 ENVIRONMENTAL ROHS3 WARRANTY PRODUCT WARRANTY 3-year* *Standard 3-year warranty upgradeable to 5 years with purchase of a Digi Remote Manager Premier 5-year subscription applicable to the product purchased only at the time of product purchase and with product registration at that time in Digi Remote Manager. ENTERPRISE SOFTWARE DESCRIPTION PROTOCOL SUPPORT HTTPS, TLS, SCP (client and server), SFTP, SNMP (v3), SSH, Telnet and CLI for web management; remote management via Digi Remote Manager®; protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS, Dynamic DNS client compatible with No-IP/DynDNS; Captive portal, Intelliflow; Nagios, DNS server, NTP server, Multicast, mDNS, IPerf SECURITY/VPN IP filtering, stateful inspection firewall with scripting, address and port translation; VPN: IPSec with IKEv1, IKEv2, NAT Traversal; SSLv3, FIPS 197, Open VPN client and server; L2TP; VPN tunnels; cryptology: SHA-1, MD5, RSA; encryption: DES, 3DES and AES up to 256bit (CBC mode for IPsec); authentication: RADIUS, TACACS+, SCEP for X.509; certificates; content filtering (via 3rd party); MAC address filtering; VLAN support ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; multicast routing; routing protocols: PPP, PPPoE, RIP (v1, v2) OSPF, BGP, iGMP routing (multicast); IP failover: VRRP, VRRP+TM; automatic failover/failback to second GSM network/standby APN; Digi SureLink® OTHER PROTOCOLS DHCP; Dynamic DNS client compatible with No-IP/DynDNS; QoS via TOS/DSCP; Modbus UDP/TCP to serial; Modbus bridging for connecting diverse field assets PRODUCT IMAGES 5.04 inches (12.8 cm) 3.94 inches (10 cm) 2.05 in (5.2 cm) DIGI.COM DIGI ACCELERATED LINUX (DAL OS) AND DIGI REMOTE MANAGER® CAPABILITIES – DAL OS with Digi Remote Manager: remote console access, Profile Configuration Manager, HTTP proxy, device event logs, configurable maintenance window – I/O ports: pulse counter, custom Digi device Python library – Serial: Digi RealPort®, Modbus, serial-over-TCP/UDP – Customization: Python 3, Python pip, PyCharm integration, shell scripting, containers, MQTT Client – Troubleshooting tools: iPerf and nuttcp bandwidth testing, Find Me tool – GNSS: NMEA/TAIP location forwarding to multiple servers, geo-fencing – Activate, monitor and diagnose your mission-critical devices from a single point of command and control – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access DAL OS DAL OS is Digi’s standard operating system integrated into Enterprise (EX), Industrial (IX) and Transportation (TX) routers, console servers and USB-connected devices. Developed for speed and simplicity, DAL OS enables advanced capabilities that support today’s demanding applications. Learn more at www.digi.com/DAL DIGI REMOTE MANAGER Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager – Keep tabs on device health and connectivity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready DIGI TRUSTFENCE® SECURE BOOT – Programs and code running on the device are validated to be from an approved source or manufacturer. PROTECTED HARDWARE PORTS TRUSTFENCE – Internal and external I/O ports are hardened and access-controlled to prevent unwanted local intrusion. AUTHENTICATION – Digi TrustFence provides data authentication and device identity management options. Furthermore, TrustFence ensures that products are not shipped with default user and password settings. Digi TrustFence is a device-security framework that simplifies the process of securing connected devices. BUILT-IN SECURITY. DELIVERED. Designed for mission-critical applications, Digi TrustFence® enables you to easily integrate device security, device identity, and data privacy capabilities into your product design. Digi TrustFence designs security into IoT devices that can grow and adapt with new and evolving threats. SECURE CONNECTIONS – Digi TrustFence utilizes the latest encryption protocols for data in motion and over-the-air (OTA) transmissions to ensure the integrity of data flowing across a network. ONGOING MONITORING AND SUPPORT – Digi provides ongoing threat measurement and monitoring services and performs external security audits and proactively communicates with customers regarding upcoming threats. Learn more at www.digi.com/trustfence DIGI.COM PART NUMBERS DIGI IX30 DIGI IX30 PRIMARY RESPONDER IX30-00P7 Digi IX30-PR — LTE-A Cat 7 North America, Primary Responder, FirstNet Capable, dual Ethernet, RS-232/422/485, GNSS DIGI IX30 IX30-00G4 Digi IX30 — LTE Cat 4 Global, 3G/2G fallback, dual Ethernet, RS-232/422/485, GNSS IX30-00A4 Digi IX30 — LTE Cat 4 AU, 3G/2G fallback, dual Ethernet, RS-232/422/485, GNSS FirstNet® and FirstNet Capable™ are registered trademarks and service marks of the First Responder Network Authority. PART NUMBERS AVAILABLE ACCESSORIES* 76002113 Digi IX30 Accessory Kit — PSU, antennas, Cat 6 Ethernet cable, GPS antenna 76002104 Power supply — 18 VDC, 1 A, wall mount level VI, industrial temperature, changeable plug tips, 2-pin combicon screw terminal plug 76002117 Power supply — 18 VDC, 1 A, wall mount level VI, commercial temperature, changeable plug tips, 2-pin combicon screw terminal plug 76002114 Antenna — 5G/LTE 600 MHz - 6 GHz, swivel, black 76000954 Antenna base — SMA, 1 m, RG174 76002106 Cable — UTP, Cat 6, 2 m (6 ft), black, flat patch cable *Sold separately, unless otherwise noted. PART NUMBERS DIGI REMOTE MANAGER® DIGI-RM-STD-1YR Digi Remote Manager Standard — 1-year subscription DIGI-RM-PRM-1YR Digi Remote Manager Premier — 1-year subscription DIGI-RM-PRM-3YR Digi Remote Manager Premier — 3-year subscription DIGI-RM-PRM-5YR Digi Remote Manager Premier — 5-year subscription FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2022 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004533 A9/522 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL GERMANY +49-89-540-428-0
IX30-00A4 价格&库存
很抱歉,暂时无法提供与“IX30-00A4”相匹配的价格&库存,您可以联系我们找货
IX30-00A4
  • 1+6303.275371+812.07770
