WR21-M52B-DE1-SB
WR21-M52B-DE1-SB
    DIGIINTERNATIONAL
    CELLULAR ROUTER AT&T VERIZON
WR21-M52B-DE1-SB 数据手册
COMPACT ENTERPRISE CLASS 3G/4G/LTE ROUTER DIGI TRANSPORT® WR21 Compact, flexible, low-cost 3G/4G/LTE enterprise router for remote and mobile networking applications Digi TransPort WR21 is a full-featured cellular router offering the flexibility to scale from basic connectivity applications to enterprise class routing and security solutions. With its high-performance architecture, Digi TransPort WR21 provides primary and backup WWAN connectivity over 3G/4G/LTE. The platform includes software selectable multi-carrier and regional LTE variants. Flexible power and connectivity options, along with extended temperature ranges make Digi TransPort WR21 a versatile product for both commercial and industrial environments. BENEFITS The Digi TransPort WR21 supports enterprise software features for advanced security (stateful firewall, MAC filtering, VPN), redundancy (VRRP+, SureLink®), and management (SNMP, event logging, analyzer trace, and QOS), enabling the product to be used in PCI or NERC-CIP compliant applications. Digi management solutions provide easy setup, configuration and maintenance of large installations of remote Digi TransPort devices. Digi Remote Manager ® offers webbased device management for remote Digi cellular routers, gateways and third-party devices. APPLICATION EXAMPLE – Compact, low-cost, flexible cellular routing platform with enterprise feature set Encrypted WAN – Enterprise software with advanced routing protocols, VPN, and stateful firewall – High-performance architecture, flexible power and extended operating temperature – 3G/4G cellular interface supporting LTE and HSPA+ networks worldwide – Dual SIMs and Digi SureLink™ provide redundant connection DIGI REMOTE MANAGER® BANK HEADQUARTERS VPN 3G/4G/LTE REMOTE SITE DIGI TRANSPORT® WR21 – Digi Remote Manager software for easy setup, configuration, and maintenances RELATED PRODUCTS Digi TransPort® WR11 XT Digi TransPort® WR31 Ethernet or Serial Digi TransPort® WR44 R Accessories Digi Remote Manager ® ATM SPECIFICATIONS Digi TransPort® WR21 WIRELESS INTERFACES CELLULAR* LTE - NORTH AMERICA (M5) LTE CAT 4: 700(B12,13)/850(B5)/AWS(B4)/1900(B2) 3G HSPA+: 850/1900 MHz Transfer rate (max): 150 Mbps down, 50 Mbps up Approvals: PTCRB, AT&T, Telus (pending) LTE - EMEA/APAC (M7) LTE CAT 4: 800(B20)/900(B8)/1800(B3)/2100(B1)/2600(B7) HSPA: 900/2100 MHz EDGE: 900/1800 MHz Transfer rate (max): 150 Mbps down, 50 Mbps up Approvals: Vodafone (pending) LTE 450 - EMEA/APAC (M2) LTE CAT 3: 450(B31)/800(B20)/1800(B3)/2600 (B7) HSPA+: 900/2100 MHz EDGE: 900/1800 MHz Transfer rate (max): 100 Mbps down, 50 Mbps up GLOBAL HSPA+ (U9) 3G HSPA+: 850/900/1700AWS/1900/2100 MHz 2G EDGE/GPRS: 850/900/1800/1900 MHz Transfer rate (max): 21 Mbps down, 5.76 Mbps up Approvals: PTCRB, Vodafone EMEA CDMA EV-DO (D5) 3G EVDO Rev B: 450 MHz 2G 1XRTT: 450 MHz Transfer rate (max): 14.7Mbps down, 5.4Mbps up GSM-R (R5) 900/1800/1900 MHz (TRM-5); GPRS Class 10; Transfer rate (max): 42.8 Kbps up, 85.6 Kbps down CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Optional SIM slot cover plate GPS** CHANNELS 12 channel, continuous tracking SENSITIVITY Tracking1: -161 dBm; Acquisition2 (Assisted, non-LTE): -158 dBm; Acquisition (Assisted, LTE): -153 dBm; Acquisition (Standalone): -145 dBm PROTOCOL NMEA 0183 V3.0 COLD START < 0.2 m/s HORIZONTAL ACCURACY < 2 m (50%); < 5 m (90%) VELOCITY ACCURACY < 0.2 m/s OTHER ADDITIONAL FEATURES Send GPS via UDP/IP, TCP/IP (up to two destinations) or serial; Customize and/or send data using Python; GPS status query; Time source capable WIRED INTERFACES SERIAL PORTS (1) DB-9; DCE DTE/DCE DCE SIGNAL SUPPORT TXD, RXD, RTS, CTS, DTR, DCD, DSR, RI FLOW CONTROL Software (XON/XOFF), hardware supported ETHERNET PORTS (2) RJ-45; 10/100 Mbps (auto-sensing) USB PORTS (1) USB 2.0 Type A * Transfer rates are theoretical and network operator dependent. ** Optional hardware. WWW.DIGI.COM SPECIFICATIONS Digi TransPort® WR21 MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager (cloud based); SNMP v1/v2c/v3 (user installed/managed) LOCAL MANAGEMENT Web interface (HTTP/HTTPS); CLI (Telnet, SSH, SMS, Serial Port) MANAGEMENT/ TROUBLESHOOTING TOOLS FTP, SFTP, SCP; Protocol analyzer with PCAP for Wireshark; Event logging with Syslog and SMTP; NTP/SNTP MEMORY 128 MB NAND Flash/128 MB DDR2 SDRAM POWER INPUT 9 – 30 VDC, 18W min power source required CONSUMPTION 4W typical (Idle); 12W typical (Peak Tx/Rx) CONNECTOR Depending on model: Locking barrel or screw-down removeable terminal block PHYSICAL DIMENSIONS (L X W X H) 3.9 in x 5.2 in x 1.3 in (100 mm x 131 mm x 32 mm) WEIGHT 1.08 lb (0.49 kg) STATUS LEDS Power, Service, WWAN, 3x signal strength ENCLOSURE MATERIAL/RATING Industrial (Metal)/ IP30 MOUNTING Brackets for wall mount & DIN rail sold separately ENVIRONMENTAL OPERATING TEMPERATURE*** -35° C to +70° C (Reduced cellular performance may occur above +50° C) STORAGE TEMPERATURE -40° C to +85° C RELATIVE HUMIDITY 0% to 95% (non-condensing) @ 25° C ETHERNET ISOLATION 1.5 kV RMS SERIAL PORT PROTECTION (ESD) 15 kV HAZARDOUS (CLASS 1 DIV 2) Models with Serial (RS-232/422/485) compliant to ANSI/ISA-12.12.01-2015 APPROVALS CELLULAR PTCRB, NAPRD.03, GCF-CC, R&TTE, EN 301 511 SAFETY UL 60950, CSA 22.2 No. 60950, EN60950 EMISSIONS/IMMUNITY CE, FCC Part 15 Class B, AS/NZS CISPR 22, EN55024, EN55022 Class B WARRANTY PRODUCT WARRANTY ENTERPRISE SOFTWARE 5 years DESCRIPTION PROTOCOLS HTTP, HTTPS, FTP, SFTP, SSL, SMTP, SNMP (v1/v2c/v3), SSH, Telnet and CLI for web management; Remote management via Digi Remote Manager; SMS management, protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; Dynamic DNS client compatible with BIND9/No-IP/DynDNS SECURITY/VPN Stateful inspection firewall with scripting, address and port translation; VPN: IPSec with IKEv1, IKEv2, NAT Traversal; SSL, SSLv2, FIPS 197, open VPN client and server; PPTP, L2TP; (5) VPN tunnels (upgradable to a maximum of 50); Maximum VPN tunnels available: 5; Cryptology: SHA-1, MD5, RSA; Encryption: DES, 3DES and AES up to 256-bit (CBC mode for IPsec); Authentication: RADIUS, TACACS+, SCEP for X.509 certificates; Content filtering (via 3rd party); MAC address filtering; VLAN support; Ethernet port isolation ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: PPP, PPPoE, RIP (v1, v2) OSPF, SRI, BGP, iGMP routing (multicast); RSTP (Rapid Spanning Tree Protocol); IP failover: VRRP, VRRP+TM; Automatic failover/failback to second GSM network/standby APN; Verizon NEMO/DMNR for primary wireless access OTHER PROTOCOLS DHCP; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; QoS via TOS/DSCP/WRED; Modbus UDP/TCP to serial; X.25 including XOT, SNA/IP, TPAD and PAD; Protocol switch; Modbus bridging for connecting diverse field assets *** Standard temperature power supplies may reduce temperature range. WWW.DIGI.COM DIGI REMOTE MANAGER® CAPABILITIES – Centralized management of remote devices over 3G/4G/LTE – Define standard configurations and automatically monitor individual devices for PCI security compliance – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss – No servers or applications to operate and maintain – Complete tasks for your entire device network in minutes – Edit configurations and update firmware for your individual devices or groups – Monitor the status and location of your remote device via a web browser – Active or deactivate cellular lines and monitor data to ensure you never incur overage charges INFRASTRUCTURE SECURITY – Hosted in a commercial-grade SAS 70-certified environment – Certified SSAE-16 and ISO27001 facilities – Superior availability, operating to 99.9% or greater – Over 175 Security Controls in place to protect your data – Open APIs available to support application development – Enables compliance with security frameworks like PCI, HIPAA, NIST and more – Earned SkyHigh’s Cloud Trust Program highest ranking of Enterprise-Ready PRODUCT IMAGES PART NUMBERS DIGI TRANSPORT WR21 WR21-M52B-DE1-SB 4G LTE North America, RS-232, antennas and power supply not included WR21-M72B-DE1-SB 4G LTE EMEA/APAC, RS-232, antennas and power supply not included WR21-M22B-DE1-SB 4G LTE EMEA/APAC (450MHz), RS-232, antennas and power supply not included WR21-U92B-DE1-SB HSPA+ Global, RS-232, antennas and power supply not included WR21-D52A-DE1-TA CDMA 450MHz, RS-232/422/485, Class 1 Division 2 (C1D2), antennas included, power supply not included WR21-R32A-DE1-TB GSM-R, RS-232/422/485, Class 1 Division 2 (C1D2), antennas and power supply not included PART NUMBERS ACCESSORIES* 76002059 Accessory Kit DC - Includes DC power cable, ethernet cable and antennas (2) 76002060 Accessory Kit AC Std Temp - Includes AC/DC power supply (0° C to 40° C), ethernet cable and antennas (2) 76002061 Accessory Kit AC Extd Temp - Includes AC/DC power supply (-30° C to +70° C), ethernet cable and antennas (2) *Sold separately, unless otherwise noted. DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2018 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91001738 C11/1217 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
WR21-M52B-DE1-SB 价格&库存
很抱歉,暂时无法提供与“WR21-M52B-DE1-SB”相匹配的价格&库存,您可以联系我们找货
