TX54-A206
TX54-A206
    DIGIINTERNATIONAL
    4G/3G/2G LTE 路由器 AT&T,Sprint,Telstra,Verizon RS-232
TX54-A206 数据手册
DUAL CELLULAR / DUAL WI-FI MOBILE ACCESS ROUTER Manage this device with Digi Remote Manager DIGI TX54 Rugged and secure cellular router for mission critical industrial and transportation applications, including models for public safety networks The versatility and performance of Digi TX54 routers make them ideal for mission critical applications requiring continuous connectivity, field longevity and edge computing. Digi TX54 provides secure routing and gateway functionality across wired and wireless communication networks. Local private subnets are bridged across public networks to safeguard privacy and integrity. Digi TX54 is available with dual Wi-Fi radios to segment passenger Wi-Fi from fare collection, data, video and other applications, and offers models with both single and dual LTEAdvanced or LTE-Advanced Pro cellular modules. FEATURES AND BENEFITS Designed to meet the demands of first responders, Digi TX54 includes concurrent and independent dual cellular interfaces that prioritize critical communications. The industrial-grade design supports the most rugged conditions, including vibration and temperature changes. A Python development environment allows for edge computing and intelligence. Four Gigabit Ethernet ports connect other IP-capable systems, each configurable as an isolated secure LAN, or all four can function as a Layer 2 switch. Digi TrustFence®, a suite of hardware and firmware features, ensures the integrity of Digi TX54 security functions. Chip-level encryption protects the onboard file system. APPLICATION EXAMPLE – G  lobal models are available in both single and dual cellular options – Future-built with dual-core 880 MHz MIPS processor and PCIe 2.0 internal bus – Capable of segmenting private and public data communication across dual 600 Mbps LTE-Advanced Cat 11 or LTE-Advanced Pro Cat 12 cellular modules – High-speed 867 Mbps 802.11ac Wi-Fi for WAN or LAN service and optional dual Wi-Fi radios VPN Tunnel DIGI REMOTE MANAGER® CUSTOMER DATA CENTER Primary and Secondary Cellular Link Wired Ethernet Wi-Fi Links – Cryptographic co-processor with secure key generation – Securely deploy, monitor and control devices with Digi Remote Manager® DIGI® TX54 Smartphone Network Device Laptop/Tablet Legacy Equipment RELATED PRODUCTS Digi TX64 Digi WR44 RR Digi WR31 Accessories Digi Remote Manager ® Security Camera Ethernet Switch Fare Collection SPECIFICATIONS DIGI TX54 CELLULAR LTE-ADVANCED WORLDWIDE LTE FDD: B1 (2100), B2 (1900), B3 (1800), B4 (1700AWS), B5 (850), B7 2600), B8 (900), B12 (700ac), B13 (700c), B17 (700), B20 (800DD), B25 (1900), B26 (850), B28 (700 APAC), B29 (700), B30 (2300 Rx only), B66 (1700AWS); LTE TDD: B38 (2600), B40 (2300), B41 (2500); 3G HSPA+: B1 (2100), B2 (1900), B4 (1700AWS), B5 (850), B8 (900); Transfer rate (max): 600 Mbps down, 75 Mbps up (Cat 11) LTE-ADVANCED PRO UNITED STATES / CANADA LTE FDD: B1 (2100), B2 (1900), B3 (1800), B4 (1700AWS), B5 (850), B7 (2600), B8 (900), B9 (1800), B12 (700ac), B13 (700c), B14 (700PS), B18 (850), B19 (800), B20 (800DD), B26 (US 850 Ext), B29 (US 700de Lower), B30 (2300), B32 (1500), B48 (3600), B66 (AWS-3); LTE TDD: B41 (2500), B42 (3500), B43 (3600), B46 (5200); 3G HSPA: B1 (2100), B2 (1900), B4 (1700AWS), B5 (850), B6 (800), B8 (900), B9 (1700), B19 (800); Transfer rate (max): 600 Mbps down, 150 Mbps up (Cat 12) CONNECTOR Single cellular models: (2) 50 Ω SMA (center pin: female) Dual cellular models: (4) 50 Ω SMA (center pin: female) SIM SLOTS Single cellular models: (2) Mini-SIM (2FF) Dual cellular models: (4) Mini-SIM (2FF) SIM SECURITY Screw-down SIM cover WI-FI MODULE 2 x 2 MIMO 2.4/5 GHz 802.11 a/b/g/n/ac, 867 Mbps (max); dual Wi-Fi modules in TX54-A112 HOTSPOT Captive portal, customizable splash page AUTHENTICATION Basic ToS acceptance, enterprise RADIUS THIRD-PARTY SERVICES Content filtering, embedded advertising MODES Up to 4 access points and 1 client per Wi-Fi module (8+2 total) SECURITY WPA/WPA2-personal, WPA/WPA2-enterprise CONNECTORS 2 x 50 Ω RP-SMA (center pin: male) GPS TECHNOLOGY Multi-constellation: concurrent reception of up to 3 GNSS (GPS, Galileo, GLONASS, BeiDou) SENSITIVITY -163 dB PROTOCOL Protocol NMEA 0183 V2.3 sentence output CONNECTOR 1 x 50 Ω SMA (center pin: female); +3.3 VDC active antenna drive ETHERNET PORTS (4) RJ-45; 10/100/1000 Mbps (auto-sensing) SERIAL PORTS (1) DB9-M; RS-232 DTE ; Signal support TXD, RXD, RTS, CTS, DTR, DCD, DSR, RI software (XON/XOFF), hardware supported USB PORTS (1) USB 3.0 Type A connector PHYSICAL DIMENSIONS (L X W X H) 14.61 cm x 20.95 cm x 6.35 cm (5.75 in x 8.25 in x 2.5 in) WEIGHT 1.5 kg (3.3 lbs) STATUS LEDS Power on, WWAN signal strength, WWAN service ENCLOSURE Die-cast aluminium / IP54 POWER REQUIREMENTS POWER INPUT 9 - 36 VDC, 30 W minimum power source required POWER CONSUMPTION 13 W typical (idle); 20 W typical (peak Tx/Rx) ENVIRONMENTAL MOUNTING OPTIONS Flexible mounting options OPERATING TEMPERATURE -34° C to 74° C (-29° F to 165° F) STORAGE TEMPERATURE -40° C to 85° C (-40° F to 185° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR PTCRB, AT&T, OnGo, Sprint, Verizon, Anatel; see part numbers for more details on certifications on each SKU SAFETY EN60950, EN62368 VEHICLE ISO 7637-2/3, ISO 10605, ISO 16750-2 Pulses 4/5a/5b, SAE J1113, E-Mark RAIL EN50155, EN45545-2, EN50121-3-2 ENVIRONMENTAL MIL-STD-810G (temperature, humidity, vibration, shock, dust) EMISSIONS/IMMUNITY CE, FCC Part 15 Class B, AS/NZS CISPR 22, EN55024, EN55032 WARRANTY PRODUCT WARRANTY 3-year *Transfer rates are network operator dependent DIGI.COM ENTERPRISE SOFTWARE DESCRIPTION PROTOCOL SUPPORT HTTP, HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH; remote management via Digi Remote Manager®; Protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; Captive portal, Intelliflow; X.509 certificate management; Dead Reckoning SECURITY IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; SSL, SSLv2, SSLv3; Authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support VPN IPSec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; Cryptology: SHA-1/256/384/512, MD5, RSA; Encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: RIP (v1, v2) OSPF, BGP; IP failover: VRRP; automatic failover, Digi SureLink® OTHER PROTOCOLS DHCP; Dynamic DNS client compatible with No-IP/DynDNS; Nagios, DNS server, NTP server, Multicast, mDNS, IPerf LOCAL MANAGEMENT Web interface (HTTP/HTTS); CLI (SSH, serial port) MANAGEMENT / TROUBLESHOOTING PROTOCOLS Protocol analyzer with PCAP for Wireshark, event and system logging (with Syslog), accessible from Digi Remote Manager, SFTP or SCP PROGRAMMING TOOLS / ENVIRONMENTS Python v3.6.4 PRODUCT IMAGES FRONT POWER SUPPLY* BACK ACCESSORY KIT* DIGI.COM DIGI REMOTE MANAGER® CAPABILITIES – Centralized management of remote devices over 3G/4G/LTE – Define standard configurations and automatically monitor individual devices for PCI security compliance – Get alerts and create reports on performance statistics, including connection history, signal quality, latency, data usage and packet loss – No servers or applications to operate and maintain – Complete tasks for your entire device network in minutes – Edit configurations and update firmware for individual devices or groups – Monitor the status and location of remote devices via a web browser – Activate or deactivate cellular lines and monitor data to ensure you never incur overage charges INFRASTRUCTURE SECURITY – Hosted in a commercial-grade SAS 70-certified environment – Certified SSAE-16 facilities – Superior availability, operating to 99.9% or greater – Over 175 security controls in place to protect your data – Open APIs available to support application development – Enables compliance with security frameworks like PCI, HIPAA, NIST – Earned SkyHigh’s Cloud Trust Program highest rating of Enterprise-Ready PART NUMBERS DIGI TX54 TX54-A106 Digi TX54 single LTE-Advanced Cat 11, Wi-Fi, worldwide, Anatel TX54-A112 Digi TX54 single LTE-Advanced Cat 11, dual Wi-Fi, worldwide TX54-A206 Digi TX54 dual LTE-Advanced Cat 11, Wi-Fi, worldwide, Anatel TX54-A146 Digi TX54 single LTE-Advanced Pro Cat 12, Wi-Fi, North America, CBRS, Sprint TX54-A246 Digi TX54 dual LTE-Advanced Pro Cat 12, Wi-Fi, North America, CBRS, Sprint PART NUMBERS ACCESSORIES* 76002084 Digi TX54 accessory kit - single cellular 76002085 Digi TX54 accessory kit - dual cellular 76002086 Digi TX54 accessory kit - dual Wi-Fi 76002076 Digi TX54 power supply *Sold seperately, unless otherwise noted. FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004362 B1/420 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
TX54-A206 价格&库存
很抱歉,暂时无法提供与“TX54-A206”相匹配的价格&库存,您可以联系我们找货
