TX64-A141
TX64-A141
    DIGIINTERNATIONAL
    4G/3G/2G LTE 路由器 AT&T,Sprint,Telstra,Verizon 以太网,RS-232,USB
TX64-A141 数据手册
DUAL CELLULAR / DUAL WI-FI 5G-READY PLATFORM Manage this device with Digi Remote Manager DIGI TX64 High performance cellular router with dual redundant communications for complex transit and transportation systems Ideal for challenging transportation and mobile environments, Digi TX64 is a dual cellular LTE-Advanced and LTE-Advanced Pro router with true enterprise class routing, security, firewall and integrated VPN. It offers a flexible interface design with an integrated Wi-Fi access point, USB, serial and 4-port Ethernet switch, as well as a variety of configuration options including GNSS and Bluetooth®. Internet access for riders is managed securely and without impact to onboard bus systems. Triple carrier aggregation on each cellular interface can be combined to deliver up to 1.2 Gbps to passengers. Onboard systems retain priority and any remaining bandwidth is made available to Internet traffic. FEATURES AND BENEFITS A captive portal and splash page enable term acceptance, targeted messaging and agency branding. Standard HTTP/ DNS redirect can be used to block malware and unwanted content through popular third-party service providers or an agency server. Reliable power circuitry supports 9-36 VDC input with ignition sense for direct integration into the vehicle’s power source. Dual cellular and dual Wi-Fi modules provide true segmented traffic flow of private and public data for fare collection, CAD/AVL data, camera log backhaul and passenger Wi-Fi access. APPLICATION EXAMPLE – 5G-ready platform: future-built with powerful quad core processor – Segmented private and public data communication across dual 1.2 Gbps LTE-Advanced Pro Cat 18 or LTE- Advanced Cat 11 cellular modules – Wired Gigabit Ethernet (4-port) for onboard systems – Video and vehicle data offload over 1.7 Gbps 802.11ac Wi-Fi backhaul – Passenger Wi-Fi over 867 Mbps 802.11ac access point VPN Tunnel DIGI REMOTE MANAGER® CUSTOMER DATA CENTER Primary and Secondary Cellular Link Wired Ethernet PUBLIC NETWORK Wi-Fi Link PRIVATE NETWORK – Securely deploy, monitor and control devices with Digi Remote Manager® Vehicle Network/GPS Passenger Internet RELATED PRODUCTS DIGI TX64 Digi TX54 Digi WR31 Digi WR44 RR Accessories Digi Remote Manager ® Payment Kiosk Telematics SPECIFICATIONS DIGI TX64 WIRELESS INTERFACES WWAN* DUAL MODULES LTE-ADVANCED WORLDWIDE LTE FDD: B1 (2100), B2 (1900), B3 (1800), B4 (1700AWS), B5 (850), B7 (2600), B8 (900), B12 (700ac), B13 (700c), B17 (700), B20 (800DD), B25 (1900), B26 (850), B28 (700 APAC), B29 (700), B30 (2300), B66 (1700AWS); LTE TDD: B38 (2600), B40 (2300), B41 (2500); 3G (HSPA): B1 (2100), B2 (1900), B3 (1800), B4 (1700AWS), B5 (850), B8 (900); Transfer rate (max): 600 Mbps down, 75 Mbps up per module (Cat 11) DUAL MODULES LTE-ADVANCED PRO WORLDWIDE LTE FDD: B1 (2100), B3 (1800), B7 (2600), B8 (900), B12 (700ac), B13 (700c), B14 (700PS), B20 (800DD), B25 (1900); B26 (US 850 Ext), B28 (700 APAC), B29 (US 700de Lower); B30 (2300 WCS), B32 (1500), B48 (3600), B66 (AWS-3), B71 (600); LTE TDD: B38 (2600), B39 (1900), B40 (2300), B41 (2500), B42 (3500), B43 (3600), B46 (5200); Transfer rate (max): 1.2 Gbps down, 150 Mbps up per module (Cat 18) CONNECTOR 2 or 4 x 50 Ω SMA per module (center pin: female) SIM SLOTS 2 mini-SIM (2FF) per module (4 total) SIM SECURITY SIM slot cover plate included WI-FI DUAL MODULES Private backhaul: 4 x 4 MU-MIMO 5 GHz 802.11 a/n/ac Wave 2, 1.733 Gbps (max) Public Wi-Fi: 2 x 2 MIMO 2.4/5 GHz 802.11 a/b/g/n/ac, 867 Mbps (max) HOTSPOT Captive portal, customizable splash page AUTHENTICATION Basic ToS acceptance, Enterprise RADIUS 3RD PARTY SERVICES Content filtering, embedded advertising MODES Up to 4 access points and 1 client per Wi-Fi module (8+2 total) SECURITY WPA/WPA2-Personal, WPA/WPA2-Enterprise CONNECTORS Private backhaul: 4 x 50 Ω RP-SMA (center pin: male) Public Wi-Fi: 2 x 50 Ω RP-SMA (center pin: male) GPS TECHNOLOGY Multi-constellation: concurrent reception of up to 2 GNSS (GPS, Galileo, GLONASS, BeiDou) SENSITIVITY -163 dB PROTOCOL NMEA 0183 V2.3 sentence output CONNECTOR 1 x 50 Ω SMA (center pin: female); +3.3 VDC active antenna drive HARDWARE SERIAL PORTS / CONNECTOR 1 RS-232; DB-9 male ETHERNET PORTS / CONNECTOR 4; RJ-45 STANDARD IEEE 802.3; 10/100/1000 Base-T USB PORTS 3 STANDARD USB 3.0, Type A MEMORY RAM 2 GB FLASH 8 GB (CFAST card) PHYSICAL DIMENSIONS 260 mm x 196 mm x 67 mm (10.2 in x 7.8 in x 2.6 in) WEIGHT 3.3 kg (7.25 lbs) STATUS LEDS Power, WWAN (signal, service) per module, Wi-Fi service (per module), GNSS service, LAN (link, activty) ENCLOSURE IP40 aluminum alloy POWER POWER INPUT 9 - 36 VDC, 60 W minimum power source required POWER CONSUMPTION 28 W typical (idle); 41 W (peak RF Tx/Rx) ENVIRONMENTAL MOUNTING Flexible mounting options OPERATING TEMPERATURE -30° C to 70° C (-22° F to 158° F) STORAGE TEMPERATURE -40° C to 85° C (-40° F to 185° F) RELATIVE HUMIDITY 0% to 95% (non-condensing) @ 25° C (77° F) *Transfer rates are network operator dependent DIGI.COM SPECIFICATIONS DIGI TX64 APPROVALS CELLULAR PTCRB, AT&T, Verizon SAFETY UL 60950/EN62368, CSA 22.2 No. 60950 EMISSIONS/IMMUNITY CE, FCC Part 15 Class B, EN55024, EN55032 Class B, EN301489-1/-17 INDUSTRY MIL-STD 810G (temperature, humidity, vibration, shock, dust) Vehicle-grade certifications: E-Mark (E13), SAE J1113-2 / J1455, ISO 7637-2/3, ISO 10605, ISO 16750-2 load dump WARRANTY PRODUCT WARRANTY ENTERPRISE SOFTWARE 3-year DESCRIPTION PROTOCOL SUPPORT HTTP, HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH; remote management via Digi Remote Manager®; Protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; Captive portal, Intelliflow; X.509 certificate management; Dead Reckoning SECURITY IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; SSL, SSLv2, SSLv3; Authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support VPN IPSec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; Cryptology: SHA-1/256/384/512, MD5, RSA; Encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: RIP (v1, v2) OSPF, BGP; IP failover: VRRP; automatic failover, Digi SureLink® OTHER PROTOCOLS DHCP; Dynamic DNS client compatible with No-IP/DynDNS; Nagios, DNS server, NTP server, Multicast, mDNS, IPerf LOCAL MANAGEMENT Web interface (HTTP/HTTS); CLI (SSH, serial port) MANAGEMENT / TROUBLESHOOTING PROTOCOLS Protocol analyzer with PCAP for Wireshark, event and system logging (with Syslog), accessible from Digi Remote Manager, SFTP or SCP PROGRAMMING TOOLS / ENVIRONMENTS Python v3.6.4 PRODUCT IMAGES FRONT BACK DIGI.COM DIGI REMOTE MANAGER® CAPABILITIES – Centralized management of remote devices over 3G/4G/LTE – Define standard configurations and automatically monitor individual devices for PCI security compliance – Get alerts and create reports on performance statistics, including connection history, signal quality, latency, data usage and packet loss – No servers or applications to operate and maintain – Complete tasks for your entire device network in minutes – Edit configurations and update firmware for individual devices or groups – Monitor the status and location of remote devices via a web browser – Activate or deactivate cellular lines and monitor data to ensure you never incur overage charges INFRASTRUCTURE SECURITY – Hosted in a commercial-grade SAS 70-certified environment – Certified SSAE-16 facilities – Superior availability, operating to 99.9% or greater – Over 175 security controls in place to protect your data – Open APIs available to support application development – Enables compliance with security frameworks like PCI, HIPAA, NIST – Earned SkyHigh’s Cloud Trust Program highest rating of Enterprise-Ready PART NUMBERS DESCRIPTION TX64-A121 Digi TX64 - dual LTE-Advanced Cat 11, dual Wi-Fi, worldwide TX64-A141 Digi TX64 - dual LTE-Advanced Pro Cat 18, dual Wi-Fi, worldwide PART NUMBERS ACCESSORIES* 76002076 AC power supply - 12 VDC - 3-pin power connector 76002069 Digi TX64-A121 accessory kit 76002087 Digi TX64-A141 accessory kit 76000826 Cable - Ethernet, RJ-45 to RJ-45, 2 m *Sold separately, unless otherwise noted. FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004416 B1/420 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
TX64-A141 价格&库存
很抱歉,暂时无法提供与“TX64-A141”相匹配的价格&库存,您可以联系我们找货
