WR31-L92A-DE1-TB
WR31-L92A-DE1-TB
    DIGIINTERNATIONAL
    3G HSPA+,LTE 路由器 以太网,RS-232/422/485,USB
WR31-L92A-DE1-TB 数据手册
4G LTE M2M ROUTER DIGI TRANSPORT WR31 Intelligent 4G LTE router designed for critical infrastructure and industrial applications Digi TransPort® WR31 is an intelligent 4G LTE router designed for performance and reliability across a range of critical infrastructure and industrial applications. It provides a secure, reliable connection to industrial controllers, process automation equipment and smart grid assets on third party sites or remote locations. Software-defined, multi-carrier networking and global LTE and HSPA+ options make it easy to get connected. This drop-in connectivity gives operators a way to reduce downtime and service calls, and also increase revenue by bringing distributed sites online faster. BENEFITS – Global HSPA+ and 4G LTE support and certification on major carrier networks around the world Ideal for connecting: - Building and process automation controllers - Smart grid assets (meters, switches, controllers) - IP cameras and access controllers - Remote data loggers, flow meters and sensing equipment - Telco infrastructure - Traffic and obstruction lighting APPLICATION EXAMPLE – Ethernet, serial I/O and Modbus bridging – Extremely resilient cellular connection through Digi’s patented SureLink™, VRRP+ protocol and dual SIM slots – Dedicated GNSS Receiver supporting GPS, GLONASS, BeiDou, Galileo MANAGED SERVICE PROVIDER – License-free enterprise software: VPN, firewall, logging and authentication DIGI REMOTE MANAGER® CENTRAL APPLICATION 3G/4G/LTE – Digi Remote Manager® device management tool DIGI TRANSPORT® WR31 – Rugged enclosure, optimized for DIN rail or shelf mounting – C1D2 and ATEX rated; NEMA TS2 temperature rated – Digi Foundations™ 1-, 3- or 5-year subscription available Traffic Controller Monitor Industrial Controller Meter Security Camera RELATED PRODUCTS Digi TransPort® WR21 Digi TransPort® WR44 R Digi Connect® Sensor+ Accessories Digi Remote Manager ® PLC SPECIFICATIONS Digi TransPort® WR31 WIRELESS INTERFACES CELLULAR LTE - ANZ/LATAM (L9) LTE-Advanced Cat 6: 700(B28)/850(B5,B18,B19)/900(B8)/1500(B21)/1800(B3)/1900(B39)/2100(B1)/ 2600(B7,B38)/2300(B40)/2500(B41) 3G HSPA+: 800/850/900/1700/2100 MHz Transfer rate (max): 300 Mbps down, 50 Mbps up GNSS: 30 channels (16 GPS, 14 GLONASS) simultaneous tracking LTE - NORTH AMERICA (M8) LTE-Advanced Cat 6: 700(B12,B13,B29)/800(B20,B26)/850(B5)/900(B8)/AWS(B4)/1800(B3)/1900(B2,B25)/ 2100(B1)/2300(B30)/2500(B41)/2600(B7) 3G HSPA+: 850/900/AWS/1800/1900/2100 MHz Transfer rate (max): 300 Mbps down, 50 Mbps up GNSS: 30 channels (16 GPS, 14 GLONASS) simultaneous tracking LTE - NORTH AMERICA (M5) LTE Cat 4: 700(B12,13)/850(B5)/AWS(B4)/1900(B2) 3G HSPA+: 850/1900 MHz Transfer rate (max): 150 Mbps down, 50 Mbps up LTE - EMEA/APAC (M7) LTE Cat 4: 800(B20)/900(B8)/1800(B3)/2100(B1)/2600(B7) HSPA: 900/2100 MHz EDGE: 900/1800 MHz Transfer rate (max): 150 Mbps down, 50 Mbps up LTE 450 - EMEA/APAC (M2) LTE Cat 3: 450(B31)/800(B20)/1800(B3)/2600 (B7) HSPA+: 900/2100 MHz EDGE: 900/1800 MHz Transfer rate (max): 100 Mbps down, 50 Mbps up GLOBAL HSPA+ (U9) 3G HSPA+: 850/900/1700AWS/1900/2100 MHz 2G EDGE/GPRS: 850/900/1800/1900 MHz Transfer rate (max): 21 Mbps down, 5.76 Mbps up CDMA EV-DO 450 MHZ - EMEA (D5) 3G EVDO Rev B: 450 MHz 2G 1XRTT: 450 MHz Transfer rate (max): 14.7 Mbps down, 5.4 Mbps up CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Screw-down SIM cover GNSS (SELECT MODELS) Protocol NMEA 0183 V3.0 Acquisition Time Hot Start 1 s; Warm Start 29 s; Cold Start 32 s Accuracy Horizontal: < 2 m (50%), < 5 m (90%); Altitude: < 4 m (50%), < 8 m (90%); Velocity: < 0.2 m/s SOFTWARE & MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager® (cloud based); SNMP v1/v2c/v3 (user installed/managed) LOCAL MANAGEMENT WebUI (HTTP/HTTPS); CLI (Telnet, SSH, SMS) MANAGEMENT/ TROUBLESHOOTING TOOLS FTP, SFTP, SCP; protocol analyzer with PCAP for Wireshark; event logging with Syslog and SMTP; NTP/SNTP WIRED INTERFACES ETHERNET PORTS (2) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) DB-9; DCE STANDARD RS-232/422/485 SIGNAL SUPPORT TXD, RXD, RTS, CTS, DTR, DCD, DSR, RI FLOW CONTROL Software (XON/XOFF), hardware supported I/O CONNECTOR 5-pin screw down terminal block DIGITAL 0-30 VDC, 200 mA max.; (2) I/O, software -selectable ANALOG (1) analog I/O; 4-20 mA or 0-10V, software selectable; 12 bit resolution USB PORTS (1) USB 2.0 Type A PHYSICAL DIMENSIONS (L X W X H) 12.7 cm x 8.9 cm x 5.1 cm (5 in x 3.5 in x 2 in) WEIGHT .5 kg (1.1 lb.) STATUS LEDS Power, service, WWAN, 3x signal strength, user programmable ENCLOSURE/RATING Aluminum / IP30 MOUNTING DIN rail mount included DIGI.COM SPECIFICATIONS Digi TransPort® WR31 POWER REQUIREMENTS POWER INPUT 9 – 30 VDC, 18 W min power source required POWER CONNECTOR Screw down removable terminal block POWER CONSUMPTION 4 W typical (Idle); 12 W typical (Peak Tx/Rx) ENVIRONMENTAL HAZARDOUS (CLASS 1 DIV 2) Yes OPERATING TEMPERATURE -34° C to 74° C (-29° F to 165° F); reduced cellular performance may occur above 60° C (140° F) STORAGE TEMPERATURE -40° C to 85° C (-40° F to 185° F) ETHERNET ISOLATION 1.5 kV RMS SERIAL PORT PROTECTION (ESD) 15 kV RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR PTCRB SAFETY Hazardous locations: ANSI/ISA-12.12.01-2015, CAN/CSA C22.2 NO.213-15 Ordinary locations: UL 60950-1, 2nd Edition, 2014-10-14; UL 62368:  2014, 2nd Edition ATEX standards: Protection method II 3 G Ex nA IIC T4 Gc EN 60079-0:2012+A11:2013, EN 60079-15:2010, DEMKO 15 ATEX 1574X Rev. 1 IECEX STANDARDS US/UL/ExTR17.0077/00 EMISSIONS/IMMUNITY CE, FCC Part 15 Class B, AS/NZS CISPR 22, EN55024, EN55022 Class B WARRANTY PRODUCT WARRANTY 3-year + Digi Foundations* *Digi Foundations can extend the standard three-year warranty to a Limited Lifetime Warranty that provides replacement with a new or similar Digi product for a period of five years from the date of purchase. After five years from the purchase date, the warranty value will revert to a 40 percent credit towards the MSRP of an equivalent product from Digi. ENTERPRISE SOFTWARE DESCRIPTION PROTOCOL SUPPORT HTTP, HTTPS, FTP, SFTP, SSL, SNMP, SNMP (v1/v2c/v3), SSH, Telnet and CLI for web management; remote management via Digi Remote Manager; SMS management, protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS, Dynamic DNS client compatible with BIND9/No-IP/DynDNS SECURITY/VPN IP filtering, stateful inspection firewall with scripting, address and port translation; VPN: IPSec with IKEv1, IKEv2, NAT Traversal; SSL, SSLv2, SSLv3, FIPS 197, Open VPN client and server; PPTP, L2TP; (5) VPN tunnels (not upgradable); cryptology: SHA-1, MD5, RSA; encryption: DES, 3DES and AES up to 256-bit (CBC mode for IPsec); authentication: RADIUS, TACACS+, SCEP for X.509; certificates; content filtering (via 3rd party); MAC address filtering; VLAN support ROUTING/FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; multicast routing; routing protocols: PPP, PPPoE, RIP (v1, v2) OSPF, SRI, BGP, iGMP routing (multicast); IP failover: VRRP, VRRP+TM; automatic failover/failback to second GSM network/standby APN OTHER PROTOCOLS DDHCP; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; QoS via TOS/DSCP/WRED; Modbus UDP/TCP to serial; X.25 including XOT, SNA/IP, TPAD and PAD; protocol switch; Modbus bridging for connecting diverse field assets PRODUCT IMAGES 5 inches (12.7 cm) 3.5 inches (8.9 cm) 2 in (5.1 cm) DIGI.COM DIGI REMOTE MANAGER® CAPABILITIES – Centralized management of remote devices over 3G/4G/LTE – Define standard configurations and automatically monitor individual devices for PCI security compliance – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss – No servers or applications to operate and maintain – Complete tasks for your entire device network in minutes – Edit configurations and update firmware for your individual devices or groups – Monitor the status and location of your remote device via a web browser – Active or deactivate cellular lines and monitor data to ensure you never incur overage charges INFRASTRUCTURE SECURITY – Hosted in a commercial-grade SAS 70-certified environment – Certified SSAE-16 facilities – Superior availability, operating to 99.9% or greater – Over 175 security controls in place to protect your data – Open APIs available to support application development – Enables compliance with security frameworks like PCI, HIPAA, NIST and more – Earned SkyHigh’s Cloud Trust Program highest ranking of Enterprise-ready – PCI certified; Attestation of Compliance DIGI FOUNDATIONS™ IT’S TIME TO CONNECT WITH CONFIDENCE The convenient, comprehensive and secure way to integrate IoT communications hardware, device management software, global support and lifetime warranty protection into a connectivity solution to simplify your IoT network growth. – Digi Remote Manager® (DRM) gives you a single point of contact, command and control with sophisticated remote device monitoring and management tools. – Digi Expert Support is available around the clock, seven days a week, around the world with experts ready to provide technical support by phone, email or online. – Digi Limited Lifetime Warranty lowers the total cost of ownership with hardware protection and equipment upgrades to expand your network as needs evolve. Digi Foundations, with DRM, simplifies network and device management – for hundreds or hundreds-of-thousands of Digi or third-party devices – with options to upgrade as technology evolves. Isn’t it time you got better connected? For more information visit: digi.com/foundations DIGI.COM PART NUMBERS WR31-M82A-DE1-TB DIGI TRANSPORT WR31 DESCRIPTION Digi TransPort WR31 - 4G LTE North America/EMEA, dual Ethernet, RS-232/422/485, Class 1 Div 2 (C1D2) WR31-L92A-DE1-TB Digi TransPort WR31 - 4G LTE LATAM/ANZ, dual Ethernet, RS-232/422/485, ATEX WR31-M52A-DE1-TB Digi TransPort WR31 - 4G LTE North America, dual Ethernet, RS-232/422/485, Class 1 Div 2 (C1D2) WR31-M72A-DE1-TB Digi TransPort WR31 - 4G LTE EMEA/APAC, dual Ethernet, RS-232/422/485, ATEX WR31-M22A-DE1-TB Digi TransPort WR31 - 4G LTE EMEA/APAC (450MHz), dual Ethernet, RS-232/422/485, ATEX WR31-U92A-DE1-TB Digi TransPort WR31 - HSPA+ Global, dual Ethernet, RS-232/422/485, Class 1 Div 2 (C1D2) WR31-D52A-DE1-TB Digi TransPort WR31 - CDMA 450MHz, dual Ethernet, RS-232/422/485, ATEX DIGI FOUNDATIONS™ AVAILABLE FOR DIGI TRANSPORT WR31 DGF-BDL-STAN-1YR Digi Foundations add-on, 1 year, includes Expert Support, Digi Remote Manager, and Limited Lifetime Warranty DGF-BDL-STAN-3YR Digi Foundations add-on, 3 years, includes Expert Support, Digi Remote Manager, and Limited Lifetime Warranty DGF-BDL-STAN-5YR Digi Foundations add-on, 5 years, includes Expert Support, Digi Remote Manager, and Limited Lifetime Warranty PART NUMBERS ACCESSORIES* 76000926 Antenna - cellular, 3G/4G/LTE 76000954 Antenna base – SMA, 1 m, RG174 76000736 AC power supply - extd temperature, US and EU power cords to 12 VDC - 2.1 mm locking barrel plug 76000966 Mounting bracket – wall mount 76000977 Mounting bracket – DIN rail 76000826 Cable - Ethernet, RJ-45 to RJ-45, 2 m *Sold separately, unless otherwise noted. FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2019 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91003183 C1/1019 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
WR31-L92A-DE1-TB 价格&库存
很抱歉,暂时无法提供与“WR31-L92A-DE1-TB”相匹配的价格&库存,您可以联系我们找货
