XBP24CZ7UIS-005
XBP24CZ7UIS-005
    DIGIINTERNATIONAL
    模块
    通用 ISM > 1GHz RF 收发器模块 2.4GHz 不含天线,U.FL 表面贴装型
XBP24CZ7UIS-005 数据手册
ZIGBEE RF MODULES FOR OEMS DIGI XBEE-PRO ZIGBEE Embedded Zigbee modules provide OEMs with a simple way to integrate mesh technology into their application Digi XBee-PRO® Zigbee RF modules provide cost-effective wireless connectivity to electronic devices. They are interoperable with other Zigbee Pro feature set devices, including devices from other vendors. The Serial Peripheral Interface (SPI) provides a highspeed interface and optimizes integration with embedded microcontrollers, lowering development costs and reducing time to market. Digi XBee-PRO Zigbee modules are ideal for applications in the energy and controls markets where manufacturing efficiencies are critical. Digi’s Zigbee compatible module is based on the Ember EM35x (EM357 and EM3587) system on chip (SoC) radio ICs from Silicon Labs, utilizing 32-bit ARM® Cortex® M3 processor. BENEFITS APPLICATION EXAMPLE – Surface mount form factors enable flexible design options – Link budgets of 110 dB for Digi XBee and 119 dB for Digi XBee-PRO – Industry-leading sleep current Ethernet DIGI REMOTE MANAGER® REMOTE MONITORING OFFICE – Firmware upgrades via UART, SPI or over the air (OTA) Cellular/Wi-Fi/Ethernet ZIGBEE WIRELESS MESH NETWORK – Turnkey development available from Digi WDS DIGI XBEE® ZIGBEE GATEWAY Solar panel RELATED PRODUCTS Solar Inverter Digi XBee® Gateways Modules Network Extenders Development Kits Digi Remote Manager® DIGI XBEE® MODULE SPECIFICATIONS SPECIFICATIONS Digi XBee-PRO Zigbee PERFORMANCE TRANSCEIVER CHIPSET Silicon Labs EM357 SoC DATA RATE RF 250 Kbps, serial up to 1 Mbps INDOOR/URBAN RANGE* Up to 90 m (300 ft) OUTDOOR/RF LINE-OF-SIGHT RANGE* Up to 3200 m (2 miles) TRANSMIT POWER 63 mW (+18 dBm) RECEIVER SENSITIVITY (1% PER) -101 dBm FEATURES SERIAL DATA INTERFACE UART, SPI CONFIGURATION METHOD API or AT commands, local or over-the-air (OTA) FREQUENCY BAND ISM 2.4 GHz FORM FACTOR Surface mount INTERFERENCE IMMUNITY DSSS (Direct Sequence Spread Spectrum) ADC INPUTS (4) 10-bit ADC inputs DIGITAL I/O 15 ANTENNA OPTIONS SMT: RF pad, PCB antenna, or U.FL connector OPERATING TEMPERATURE -40º C to 85º C (-40º F to 185º CF) DIMENSIONS (L X W X H) AND WEIGHT SMT: 2.199 x 3.4 x 0.305 cm (0.866 x 1.33 x 0.120 in) NETWORKING AND SECURITY PROTOCOL Zigbee PRO 2007, HA-Ready with support for binding/multicastingc ENCRYPTION 128-bit AES RELIABLE PACKET DELIVERY Retries/Acknowledgements IDS PAN ID and addresses, cluster IDs and endpoints (optional) CHANNELS 15 channels POWER REQUIREMENTS SUPPLY VOLTAGE 2.7 to 3.6 V TRANSMIT CURRENT 115 mA @ 3.3 VDC RECEIVE CURRENT 34 mA @ 3.3 VDC POWER-DOWN CURRENT
XBP24CZ7UIS-005 价格&库存
很抱歉,暂时无法提供与“XBP24CZ7UIS-005”相匹配的价格&库存,您可以联系我们找货
