XU3-A11
XU3-A11
    DIGIINTERNATIONAL
    RF 收发器 2.4GHz 802.15.4,DigiMesh,Zigbee USB 250kbps
XU3-A11 数据手册
USB-TO-DIGI XBEE® WIRELESS ADAPTER FOR LAPTOPS AND PCS DIGI XBEE 3 USB ADAPTER The Digi XBee 3 USB Adapter provides local connectivity to wireless Digi XBee networks from a laptop or PC, enabling local commissioning of the network and its devices The Digi XBee® 3 USB Adapter is an easy-to-use USB-toDigi XBee Wireless Personal Area Network (WPAN) adapter, providing local connectivity to wireless networks. Simply plug the Digi XBee 3 USB Adapter into the USB port of a laptop or PC for instant access to a Digi XBee network and its devices. This compact, USB-powered wireless adapter enables local network configuration, diagnostics and device monitoring. The Digi XBee 3 USB Adapter is part of Digi’s XBee family of solutions, providing wireless communication between devices, including routers and gateways. The Digi XBee 3 USB Adapter uses Digi’s XBee 3 module which lets you program the desired protocol using the Digi XCTU software platform. The adapter connects with DigiMesh, 802.15.4 and Zigbee network protocols. BENEFITS Digi XBee 3 USB Adapter and Network Assistant Digi Network Assistant is a Windows-based free software download that works in tandem with the Digi XBee 3 USB Adapter. Used together, these tools enable network technicians to perform a range of tasks on a local network, out in the field, whether or not network connectivity is available. These tasks may include administering on-site surveys and troubleshooting through the network mapping feature, reviewing the status of all nodes, and performing over-the-air firmware updates. You can download and install the Digi XBee Network Assistant at www.digi.com/xbeenetworkassistant. APPLICATION EXAMPLE – Provides connectivity to local Digi XBee networks from a laptop/PC – Enables fast local commissioning of devices on the local network – Programmable module to communicate with any of Digi’s supported wireless protocols Digi XBee® Network Assistant – USB powered DIGI XBEE® WIRELESS NETWORK – LEDs for UART traffic and network association Laptop Level Sensor on a Liquid Storage Tank RELATED PRODUCTS DIGI XBEE® 3 USB ADAPTER Digi XBee 3 Zigbee 3 Digi XBee Zigbee Gateway DIGI XBEE® 3 ZIGBEE 3 Digi Network Assistant Digi XCTU SPECIFICATIONS DIGI XBEE® 3 USB ADAPTER PERFORMANCE OUTDOOR/RF LINE-OF-SIGHT RANGE* Up to 1968 ft (600 m) TRANSMIT POWER OUTPUT (NOMINAL 25º C) 6.3 mW (8 dBm) RF DATA RATE 250 Kbps SERIAL INTERFACE DATA RATE (SOFTWARE SELECTABLE) 1200 bps - 921.6 Kbps DIGI XBEE 3 RECEIVER SENSITIVITY -103 dBm POWER REQUIREMENTS SUPPLY VOLTAGE 5V from PC USB port TRANSMIT CURRENT 45 mA RECEIVE CURRENT 26 mA POWER-DOWN CURRENT The Digi XBee 3 USB Adapter should not be put into sleep mode GENERAL FREQUENCY BAND 2.4 GHz ISM DIMENSIONS (L X W X H) 2.29 in x 0.80 in x 0.44 in (5.83 cm x 2.03 cm x 1.12 cm) OPERATING TEMPERATURE -40º C to +85º C CONNECTOR USB Type A ANTENNA OPTIONS Internal only NETWORKING & SECURITY SUPPORTED NETWORK TOPOLOGIES Zigbee Mesh, Point-to-Point, Point-to-Multipoint, Peer-to-Peer NUMBER OF CHANNELS (SOFTWARE SELECTABLE) 16 ADDRESSING OPTIONS PAN, Channel, Address REGULATORY APPROVALS FCC PART 15.247 (USA) Approved, contains: MCQ-XBEE3 IC (CANADA) Approved, contains IC: 1846A-XBEE3 EUROPEAN COMPLIANCE CE Marked *Range figure estimates are based on free-air terrain with limited sources of interference. Actual range will vary based on transmitting power, orientation of transmitter and receiver, height of transmitting antenna, height of receiving antenna, weather conditions, interference sources in the area, and terrain between receiver and transmitter, including indoor and outdoor structures such as walls, trees, buildings, hills, and mountains. DIGI XBEE 3 USB ADAPTER TOP PART NUMBERS XU3-A11 DIGI XBEE 3 USB ADAPTER SIDE DIGI XBEE 3 USB ADAPTER CONNECTOR DESCRIPTION Digi XBee 3 USB Adapter 802.15.4, US, Canada and EMEA DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2019 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004405 A3/618 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
XU3-A11 价格&库存
很抱歉,暂时无法提供与“XU3-A11”相匹配的价格&库存,您可以联系我们找货
XU3-A11
  • 1+1037.105951+129.92716
库存:1008
