DIGI XBEE TO IP
GATEWAY WITH CLOUD
MANAGEMENT SERVICES
DIGI XBEE®
INDUSTRIAL GATEWAY
Programmable gateway connects Digi XBee enabled devices
to remote applications over Cellular or Ethernet
The Digi XBee Industrial Gateway is a rugged Digi XBee to
IP solution. Ideal for any environment, the gateway has an
extended temperture range and rugged enclosure.
The Digi XBee Industrial Gateway, features scalable remote
configuration and management of Digi XBee networks. By
default, all Digi XBee data sent to the gateway is automatically
available to online applications via Digi Remote Manager®.
With a simple, open-source Python development environment,
this gateway also enables custom applications to run locally
while interfacing across existing Ethernet or Cellular networks
for WAN connectivity to cloud-based applications.
BENEFITS
Digi XBee Gateway products can be managed remotely
via Digi Remote Manager, supporting features like remote
firmware upgrades, configuration changes and event alarms.
With Digi Remote Manager, users can scale their network
from a single device to hundreds of thousands of remote
devices.
APPLICATION EXAMPLE
– Open-source Python environment for custom
application development on the gateway
– Out-of-box integration with Digi Remote Manager®
enables remote connectivity, configuration and
DIGI REMOTE MANAGER®
REMOTE MONITORING
OFFICE
– Zigbee enabled for connection to local wireless devices
– Cellular and Ethernet WAN options for flexible
broadband connectivity
ZIGBEE WIRELESS MESH NETWORK
– Can be deployed in any environment due to industrial
temp range and rugged enclosure
RELATED PRODUCTS
Modules
Adapters
DIGI XBEE® INDUSTRIAL
GATEWAY
Street Light
Development
Kits
Digi Remote
Manager®
Digi Design
Services
Cellular/Ethernet
Street Light
DIGI XBEE®
MODULE
SPECIFICATIONS
Digi XBee® Industrial Gateway
Digi XBee® Industrial Cellular Gateway
GENERAL
MANAGEMENT
Secure enterprise management via Digi Remote Manager®
PROTOCOLS
UDP/TCP, DHCP
LEDS
Cellular Signal Strength, Network (LAN/WAN), ZigBee (Wireless LAN), Power
SECURITY
TLS 1.2, Cellular network security
WWAN
3G HSPA+, BANDS
N/A
B5(850), B8(900), B2(1900), B1(2100), B4(AWS)
LTE CATEGORY 1
N/A
Verizon: Bands 2, 4, 13
AT&T, T-Mobile: B2(1900), B4(AWS1700), B5(850), B12/B12(700)
ANTENNA CONNECTORS
N/A
HSPA+ version: 1 x 50 Ω SMA (Center pin: female);
LTE version: 2 x 50 Ω SMA (Center pin: female)
SIM SLOTS
N/A
2 x 2FF SIM Sliots; second SIM slot reserved for future use
SIM SECURITY
N/A
Screw-down SIM cover
SOFTWARE & MANAGEMENT
PYTHON
2.7.1
MEMORY FREE SPACE
20MB RAM and 20MB Flash for Python applications
XBEE GATEWAY APPLICATION
Wireless LAN data sent to the gateway is automatically available to online applications via Digi Remote Manager
ZIGBEE
ZIGBEE STACK
ZigBee Standard and ZigBee PRO versions available
ZIGBEE MODULE
Standard: Digi XBee ZB SMT (S2C); PRO: Digi XBee Pro ZB SMT (S2C)
ZIGBEE
Standard: Transmit power 6.3 mW (+8 dBm); Receiver sensitivity: -102 dBm
PRO: Transmit Power 63mW (18dBm): Receiver sensitivity: -102dBm
ZIGBEE ANTENNA
ETHERNET
PORTS
1 RJ-45 port
PHYSICAL LAYER
10/100Base-T
DATA RATE
10/100 Mbps (auto-sensing)
MODE
Full or half duplex (auto-sensing)
INTERFACE
Auto MDI/MDIX
ROUTING
Ethernet port designed for configuration and WAN backhaul
PHYSICAL
DIMENSIONS (L X W X H)
7.62 cm x 10.16 cm x 2.54 cm (3 in x 4 in x 1 in)
WEIGHT
0.5 lb (.22 kg)
ENCLOSURE MATERIAL/RATING
Industrial (Metal)/IP30
POWER REQUIREMENTS
POWER INPUT
5VDC +/- 5%; Digi approved power supply must be used
POWER SUPPLY
See accessory options
POWER CONSUMPTION
Typical 1.2 W, Max 2.5 W
Typical 3.5 W; Max 11 W
OPERATING TEMPERATURE
-30° C to 70° C (-22° F to 158° F)
-30° C to +70° C (-22° F to +158° F)
Reduced performance above 60° C
RELATIVE HUMIDITY
5% to 95% (non-condensing)
ENVIRONMENTAL
APPROVALS
GSM/UMTS
PTCRB
CELLULAR CARRIERS
Verizon, AT&T, Certified by most major international carriers
SAFETY
IEC 60950-1:2005; EN 60950-1:2006; SCA C22.22 No. 60950-1
EMISSIONS/IMMUNITY
FCC Part 15b, Industry Canada (IC), CE Mark
WARRANTY
PRODUCT WARRANTY
5 years
WWW.DIGI.COM
PART NUMBERS
DIGI XBEE® INDUSTRIAL GATEWAY
XGI-20CZ7-E00-W0
Digi XBee Industrial Gateway - ZigBee to Ethernet, power supply and antenna not included
XGI-20CZ7-EU7-W0
Digi XBee Industrial Gateway - ZigBee to HSPA+, power supply and antenna not included
XGI-2PCZ7-E00-W0
Digi XBee Industrial Gateway - ZigBee Pro to Ethernet, power supply and antenna not included
XGI-2PCZ7-EL1-W0
Digi XBee Industrial Gateway - ZigBee Pro to CAT 1, power supply and antenna not included
PART NUMBERS
ACCESSORIES
76000976
Kit, Digi TransPort 9-30V DC/DC adapter
76002021
Power supply, 5V barrel plug, wall plug in, commercial range
76000965
Kit, Digi TransPort WR11 XT power supply Int, industrial temperature range
FOR MORE INFORMATION
PLEASE VISIT WWW.DIGI.COM
DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi
is always available to serve you with expert technical support and our industry
leading warranty. For detailed information visit www.digi.com/support.
© 1996-2018 Digi International Inc. All rights reserved.
All trademarks are the property of their respective owners.
91004218
A1/1217
DIGI INTERNATIONAL WORLDWIDE HQ
877-912-3444 / 952-912-3444 / www.digi.com
DIGI INTERNATIONAL SINGAPORE
+65-6213-5380
DIGI INTERNATIONAL GERMANY
+49-89-540-428-0
DIGI INTERNATIONAL CHINA
+86-21-50492199 / www.digi.com.cn
DIGI INTERNATIONAL JAPAN
+81-3-5428-0261 / www.digi-intl.co.jp
很抱歉,暂时无法提供与“XGI-20CZ7-EU7-W0”相匹配的价格&库存,您可以联系我们找货
