IX10-00G4
IX10-00G4
    DIGIINTERNATIONAL
    4G/3G/2G EDGE,GPRS,LTE 路由器 以太网,RJ-45,RS-232/485
IX10-00G4 数据手册
RUGGED, SECURE LTE INDUSTRIAL ROUTER Manage this device with Digi Remote Manager DIGI IX10 Rugged, reliable, cost-effective connectivity for critical industrial applications Digi IX10 is a full-featured cellular router built for troublefree reliability over a long service life. Its flexible power and connectivity options make it a versatile and costeffective choice for industrial, digital signage, ATMs, lottery terminals, kiosks and other unattended retail applications that need to provide secure transactions. Digi IX10 features an RJ-45 serial port supporting both RS-232 and RS-485, as well as dual SIMs for redundant connection. It can operate independently on LTE networks, with features to assist in network control and management, such as VLAN support, load balancing between cellular and Ethernet WANs, dual APNs and configurable APN search. Digi IX10 also offers low-touch and no-touch provisioning. FEATURES AND BENEFITS Gain critical insights into your deployed devices and manage your network with Digi Remote Manager® (Digi RM) — the command center for your deployment. Digi RM is a cloudbased solution that facilitates easy setup, mass configuration, maintenance and support, even for thousands of devices. Digi RM empowers you to evaluate, update and configure your Digi enterprise products, while providing easy visibility into the health of your network. In the event of an interruption to your primary network connection, Digi RM also provides secure terminal access for out-of-band management access to edge devices via Digi IX10 via serial port and command-line interface. In addition, Digi IX10 offers the convenience of a global SKU which simplifies inventory control for global distribution and deployment. APPLICATION EXAMPLE – Compact and economical cellular routing platform with industrial feature set Secure Connection – Redundant connectivity with dual SIMs and Digi SureLink® – Global bands and single part number to simplify global distribution, deployment and management – Built-in Digi TrustFence® for device security, device identity and data privacy – Digi Remote Manager platform for easy setup, mass configuration and out-of-band management HEADQUARTERS DIGI REMOTE MANAGER® VPN REMOTE SITE CELLULAR DIGI IX10 – Ethernet port and single RJ-45 serial port (RS-232/485) Ethernet RELATED PRODUCTS Digital Signage Digi IX14 Digi IX20 Digi WR31 Digi TX54 Digi Remote Manager Serial Industrial Controller SPECIFICATIONS DIGI® IX10 CELLULAR CERTIFICATIONS Visit www.digi.com/resources/certifications for latest certifications LTE (G4) LTE Cat 4: B1, B2, B3, B4, B5, B7, B8, B12, B13, B18, B19, B20, B25, B26, B28, B38, B39, B40, B41 3G: B1, B2, B4, B5, B6, B8, B19 2G EDGE / GPRS: 850 / 900 / 1800 / 1900 MHz CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF) SIM SECURITY Behind SIM cover, secured with screw (#1 Phillips) SOFTWARE AND MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager®; SNMP v2/v3 (user installed/managed) LOCAL MANAGEMENT WebUI (HTTP/HTTPS); CLI (Telnet, SSH) MANAGEMENT/ TROUBLESHOOTING TOOLS FTP client, SCP; protocol analyzer with PCAP for Wireshark; event logging with syslog and SMTP client; NTP/SNTP; Nagios, Intelliflow, iPerf, Dynamic DNS, ping, traceroute ETHERNET PORTS (1) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) RJ-45 10-pin (10P10C); RS-232/485; software selectable - RS-232 DTE (RXD, TXD, RTS, CTS, DTR, DCD, DSR, RI) - RS-485 (TX/RX+; RX/TX-); half-duplex PHYSICAL DIMENSIONS (L x W x H) 118 mm x 88 mm x 35 mm (4.65 in x 3.46 in x 1.38 in) WEIGHT 0.39 kg (0.86 lb) STATUS LEDs Power, Internet, SIM 1, SIM 2, SIM fail, LTE, signal strength (5) ENCLOSURE Glass-filled polyphenylene sulphide (PPS) / IP30 POWER REQUIREMENTS POWER INPUT 9 - 30 VDC, 1.0 A maximum POWER CONSUMPTION 2.5 W typical (idle); 6 W typical (peak Tx/Rx) ENVIRONMENTAL OPERATING TEMPERATURE -40° C to 70° C (-40° F to 158° F); device performance may be impacted above 50° C (122° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR Visit www.digi.com/resources/certifications for latest cellular certifications SAFETY IEC62368-1, CB, EN62311 ENVIRONMENTAL ROHS3 EMISSIONS / IMMUNITY CE; RED; FCC Part 15, Subpart B; ICES-003; AU/NZS CISPR32 WARRANTY PRODUCT WARRANTY 3-year* *Standard 3-year warranty upgradeable to 5 years with purchase of a Digi Remote Manager Premier 5-year subscription applicable to the product purchased only at the time of product purchase and with product registration at that time in Digi Remote Manager. DIGI.COM ENTERPRISE SOFTWARE DESCRIPTION CELLULAR CONNECTIVITY PROTOCOL SUPPORT HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH; remote management via Digi Remote Manager®; protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; dynamic DNS client compatible with BIND9/No-IP/DynDNS; captive portal, Intelliflow; Nagios, DNS server, NTP server, multicast, mDNS, IPerf SECURITY IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; TLS 1.2 and above, OpenVPN client and server; VPN tunnels; Authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support VPN IPSec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; Cryptology: SHA-1/256/384/512, MD5, RSA; Encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) ROUTING / FAILOVER IP pass-through; NAT, NAPT with IP port forwarding; GRE; multicast routing; Routing protocols: RIP (v1, v2) OSPF, BGP; IP failover: VRRP; automatic failover, Digi SureLink® OTHER PROTOCOLS DHCP; dynamic DNS client compatible with No-IP/DynDNS DIGI REMOTE MANAGER® CAPABILITIES – Activate, monitor and diagnose your mission-critical devices from a single point of command and control — on your desktop or mobile app – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access – Keep tabs on device health and connectvity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready DIGI.COM PRODUCT IMAGES FRONT BACK PART NUMBERS DIGI® IX10 IX10-00G4 Digi IX10 - LTE Cat 4 Global, (1) Ethernet, RS-232/485 PART NUMBERS ACCESSORIES 76002104 Power supply with plug tips for US, UK, EU, AU 76002103 (1) Cellular antenna (order quantity 2) 76002095 DIN rail clip kit 76000723 Connect EIA 422/485 devices to Digi products that have 10-pin RJ-45 connectors* *For RS-232 cabling pinouts and recommended cables, please refer to the Digi products cabling guide at: www.digi.com/resources/documentation/Digidocs/PDFs/90000253.pdf PART NUMBERS DIGI REMOTE MANAGER® DIGI-RM-STD-1YR Digi Remote Manager Standard - 1-year subscription DIGI-RM-PRM-1YR Digi Remote Manager Premier - 1-year subscription DIGI-RM-PRM-3YR Digi Remote Manager Premier - 3-year subscription DIGI-RM-PRM-5YR Digi Remote Manager Premier - 5-year subscription FOR MORE INFORMATION PLEASE VISIT DIGI.COM DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004436 A7/1120 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL GERMANY +49-89-540-428-0
IX10-00G4 价格&库存
很抱歉,暂时无法提供与“IX10-00G4”相匹配的价格&库存,您可以联系我们找货
IX10-00G4
库存:351
