TX64-R210
TX64-R210
    DIGIINTERNATIONAL
    5G/4G/3G 802.11ac,HSPA+,LTE,WCDMA 路由器 AT&T,Verizon 以太网,RS-232,USB
TX64-R210 数据手册
CELLULAR CAT 20/ DUAL WI-FI MOBILE ACCESS RAIL ROUTER TX64 Rail Router PR High performance mobile access rail router with gigabit cellular communications for transit and transportation systems The TX64 rail router is an enterprise-class router designed to provide secure routing and gateway functions across traditional and wireless communications networks, protocols and interfaces. It bridges local private wired or wireless subnets across a public or untrusted network, ensuring message privacy and integrity, using trusted channels with authenticated systems. System operation is assured through design and verification to relevant industry standards. And an embedded python environment enables quick adaptation to future evolving system requirements. IM EL Ideal for challenging rail transportation environments, the TX64 rail router is a gigabit-class LTE-Advanced Pro router with true enterprise class routing, security, firewall and integrated VPN. It offers a flexible interface design with an integrated Wi-Fi access point/client, USB, serial, inertialguided GNSS and 4-port Ethernet switch. IN Internet access for riders, if enabled, is managed securely and segmented from onboard bus systems. Onboard systems retain priority and any remaining bandwidth is made available to Internet traffic. AR FEATURES AND BENEFITS APPLICATION EXAMPLE Y – 5G-ready platform: future-built with powerful quadcore processor and PCIe 2.0 internal data buses VPN Tunnel – LTE Advance Pro 2.0 Gbps CAT 20 cellular interface – Wired Gigabit Ethernet (4-port) for onboard systems CUSTOMER DATA CENTER DIGI REMOTE MANAGER® – Dual concurrent 867 Mbps 802.11ac Wi-Fi interfaces – Untethered dead reckoning combines GNSS with inertial sensors – Securely deploy, monitor and control devices with Digi Remote Manager® Wired Ethernet Cellular Link PUBLIC NETWORK Wi-Fi Link PRIVATE NETWORK – Cryptographic co-processor with secure key generation and storage Vehicle Network/GPS Passenger Internet RELATED PRODUCTS TX64 Rail Router Digi TX54 Digi TX64 Digi WR44 RR Accessories Digi Remote Manager ® Payment Kiosk Telematics PRELIMINARY SPECIFICATIONS TX64 Rail Router WIRELESS INTERFACES WWAN* Digi Ordering SKU TX64-R210, TX64-R210-PR CELLULAR MODULE LTE-ADVANCED PRO CAT 20 WORLDWIDE LTE FDD: B1 (2100), B3 (1800), B7 (2600), B8 (900), B12 (700ac), B13 (700c), B14 (700PS), B20 (800DD), B25 (1900); B26 (US 850 Ext), B28 (700 APAC), B29 (US 700de Lower); B30 (2300 WCS), B32 (1500), B48 (3600), B66 (AWS-3), B71 (600); LTE TDD: B38 (2600), B39 (1900), B40 (2300), B41 (2500), B42 (3500), B43 (3600), B46 (5200); Transfer rate (max): 2.0 Gbps down, 320 Mbps up per module (Cat 20) CONNECTOR 4 x 50 Ω TNC per module (center pin: female) SIM SLOTS 2 mini-SIM (2FF) SIM SECURITY SIM slot cover plate included WI-FI Private backhaul: 2 x 2 MU-MIMO 5 GHz 802.11 a/n/ac Wave 2, 867 Mbps (max) Public Wi-Fi: 2 x 2 MIMO 2.4/5 GHz 802.11 a/b/g/n/ac, 867 Mbps (max) HOTSPOT Captive portal, customizable splash page AUTHENTICATION Basic ToS acceptance, Enterprise RADIUS 3RD PARTY SERVICES Content filtering, embedded advertising MODES SECURITY CONNECTORS Up to 4 access points and 1 client per Wi-Fi module (8+2 total) WPA/WPA2-Personal, WPA/WPA2-Enterprise Private backhaul: 2 x 50 Ω RP-TNC (center pin: male) Public Wi-Fi: 2 x 50 Ω RP-TNC (center pin: male) EL GPS PR DUAL MODULES Untethered dead reckoning using inertial sensors (accelerometer, gyroscope); multi-constellation (GPS, Galileo, GLONASS, BeiDou) SENSITIVITY -163 dB PROTOCOL NMEA 0183 V2.3 sentence output CONNECTOR 1 x 50 Ω SMA (center pin: female); +3.3 VDC active antenna drive HARDWARE SERIAL PORTS / CONNECTOR 1 RS-232; DB-9 male PORTS / CONNECTOR 4; M12 X-CODE STANDARD IEEE 802.3; 10/100/1000 Base-T PORTS 2 STANDARD USB 3.0, Type A MEMORY 2 GB FLASH 8 GB (CFAST card) PHYSICAL Y RAM AR USB IN ETHERNET IM TECHNOLOGY DIMENSIONS 7.8 in x 10.2 in x 2.0 in WEIGHT 3.9 kg (8.6 lbs) STATUS LEDS Power, WWAN (signal, service) per module, Wi-Fi service (per module), GNSS service, LAN (link, activty) ENCLOSURE IP65 aluminum alloy POWER POWER INPUT 9 - 36 VDC, 60 W minimum power source required POWER CONSUMPTION 28 W typical (idle); 41 W (peak RF Tx/Rx) ENVIRONMENTAL MOUNTING Slotted mounting flanges, grounding stud OPERATING TEMPERATURE -34° C to 74° C (-29.2° F to 165.2° F) STORAGE TEMPERATURE -40° C to 85° C (-40° F to 185° F) RELATIVE HUMIDITY 0% to 95% (non-condensing) @ 25° C (77° F) *Transfer rates are network operator dependent PRELIMINARY SPECIFICATIONS TX64 Rail Router APPROVALS CELLULAR PTCRB, AT&T, Verizon, T-Mobile SHOCK/VIBE EN 61373 EMISSIONS/IMMUNITY FCC PART 15 Class B, EN 50121-3-2, IEC 61000-4-2/4-3, CISPR 16-2-3 ENVIRONMENTAL/INDUSTRY EN50155, IEC 60068-2-1/2-2/2-30, ISO 7637-2/3, ISO 16750-2 load dump WARRANTY PRODUCT WARRANTY 3-year ENTERPRISE SOFTWARE HTTP, HTTPS, FTP client, SSL, TLS v1.2, SCP (client and server), SFTP, SMTP client for use by scripts and the command line, SNMP (v2/v3), SSH; remote management via Digi Remote Manager; Protocol analyzer, ability to capture PCAP for use with Wireshark; DynDNS; Dynamic DNS client compatible with BIND9/No-IP/DynDNS; Captive portal, Intelliflow; X.509 certificate management; Dead Reckoning PROTOCOL SUPPORT VPN PR SECURITY DESCRIPTION IP filtering, stateful firewall, custom firewall rules (iptables), address and port translation; SSL, SSLv2, SSLv3; Authentication: RADIUS, TACACS+; certificates; MAC address filtering; VLAN support IPSec with IKEv1, IKEv2, NAT Traversal; OpenVPN client and server; GRE VPN tunnels; Cryptology: SHA-1/256/384/512, MD5, RSA; Encryption: 3DES and AES up to 256-bit (CBC mode for IPsec); Diffie Hellman: DH groups 1-32 (CURVE448) EL IP pass-through; NAT, NAPT with IP port forwarding; Ethernet bridging; GRE; Multicast routing; Routing protocols: RIP (v1, v2) OSPF, BGP; IP failover: VRRP; automatic failover, SureLink OTHER PROTOCOLS DHCP; Dynamic DNS client compatible with No-IP/DynDNS; Nagios, DNS server, NTP server, Multicast, mDNS, IPerf LOCAL MANAGEMENT Web interface (HTTP/HTTS); CLI (SSH, serial port) MANAGEMENT / TROUBLESHOOTING PROTOCOLS Protocol analyzer with PCAP for Wireshark, event and system logging (with Syslog), accessible from Digi Remote Manager, SFTP or SCP PROGRAMMING TOOLS / ENVIRONMENTS Python v3.6.10 AR BACK Y FRONT IN PRODUCT IMAGES IM ROUTING/FAILOVER DIGI REMOTE MANAGER® CAPABILITIES – Activate, monitor and diagnose your mission-critical devices from a single point of command and control — on your desktop or mobile app – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access – Keep tabs on device health and connectvity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready EL PR Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager IM DIGI REMOTE MANAGER® DIGI-RM-STD-1YR Digi Remote Manager Standard - 1-year subscription DIGI-RM-PRM-1YR Digi Remote Manager Premier - 1-year subscription DIGI-RM-PRM-3YR Digi Remote Manager Premier - 3-year subscription DIGI-RM-PRM-5YR Digi Remote Manager Premier - 5-year subscription IN PART NUMBERS AR Y DIGI.COM
TX64-R210 价格&库存
很抱歉,暂时无法提供与“TX64-R210”相匹配的价格&库存,您可以联系我们找货
