XEB09-CIPA-W
XEB09-CIPA-W
    DIGIINTERNATIONAL
    XPRESS ETH BRIDGE 900MHZ PAIR
XEB09-CIPA-W 数据手册
900 MHZ WIRELESS ETHERNET BRIDGE XPRESS™ ETHERNET BRIDGE The XPress Ethernet Bridge provides a secure point-to-point or point-to-multipoint IP connection without the expense and limitations of physical cabling The XPress Ethernet Bridge replaces costly wiring with a solution that can wirelessly connect industrial PLCs, digital signs, security cameras, access controllers and more. With a range of up to 15 miles, the ability to transmit through as many as 10 standard walls, a 1.5 Mbps data rate, and the added range and capabilities of the 900 MHz band, the easy-to-use, long-range XPress Ethernet Bridge communicates where Wi-Fi and other wireless data products fall short. available radio channel at start-up, monitor the signalto-noise ratio and move the network to a new channel if necessary. A web interface simplifies installation, allows users to monitor packet success and signal strength and facilitates remote troubleshooting. The XPress Ethernet Bridge is housed in a weatherproof enclosure. It is available in pre-paired units or single units for point-to-multipoint applications. The XPress Ethernet Bridge features a built-in spectrum analyzer, allowing users to monitor RF interference. Frequency agility enables the product to automatically select the best BENEFITS APPLICATION EXAMPLE – Easy-to-use web interface simplifies configuration and remote troubleshooting – Check packet success and signal strength with the web interface – Outdoor line-of-sight range of up to 15 miles (with high gain antenna) CENTRAL OFFICE XPRESS™ ETHERNET BRIDGE – AES encryption, FIPS 197 and optional FIPS 140-2 provide secure communication – Built-in NAT supports multiple IP client devices RF Signal – Frequency agility ensures reliable connection between radios – Monitor RF interference with built-in spectrum analyzer RELATED PRODUCTS Industrial PLC Network Camera OR OR Access Controller Network Printer OR XTend® RF Modem Digi XLR Pro™ ConnectPort® X2 XBee® ZigBee® Module XBee® ZigBee® Adapter VoIP Phone XPRESS™ ETHERNET BRIDGE OR Wi-Fi Access SPECIFICATIONS XPress™ Ethernet Bridge PERFORMANCE INDOOR/URBAN RANGE Up to 1000 ft (300 m) w/ 2.1 dB dipole antenna OUTDOOR/RF LINE-OF-SIGHT RANGE Up to 2 miles (3.2 km) w/ 2.5 dB dipole antenna, Up to 15 miles (24 km) w/ high-gain antenna TRANSMIT POWER OUTPUT 125 mW (+21 dBm), 4W EIRP w/ 15 dBi antenna THROUGHPUT DATA RATE 935 Kbps RF DATA RATE 1.536 Mbps RECEIVER SENSITIVITY -97 dBm (@10e-4 BER) FEATURES SUPPPORTED PROTOCOLS TCP/IP, Rockwell (RSLinx EtherNet/IP, CSP), Modbus/TCP BROWSER MANAGEMENT TOOLS QoS statistics, Network settings, Spectrum analyzer, Firmware upgrading DATA CONNECTION 10/100Base-T RJ-45, Auto MDI/MDIX INTERFERENCE IMMUNITY DSSS (Direct Sequence Spread Spectrum) ENCRYPTION 128-bit AES, FIPS 197/NIST certified (optional FIPS 140-2) RADIO CHANNELS/BANDWIDTH 12 channels (6 in international version) with 2.0833 MHz spacing and 1.75 MHz occupied bandwidth FREQUENCY BAND ISM 902-928 MHz (915-928 MHz international version) FREQUENCY AGILITY Radio channel automatically selected and adaptively optimized MANUAL FREQUENCY MODE Channel selected with DIP switch or web browser interface STATUS LEDS Power, RF TX/RX, Ethernet link, channel, link quality ERROR-CORRECTION TECHNIQUE Sub-block error detection and retransmission ADJACENT-BAND REJECTION >60 dB - SAW receiver filter attenuates cellular and pager interference REGULATOR TYPE Switching regulator ANTENNA CONNECTOR RF RPTNC female POE (POWER OVER ETHERNET) Proprietary system included SUBSCRIBER UNITS Up to 16 active (63 total) per access point SERIAL NUMBER BASED MATING PROTOCOL Yes DIMENSIONS (L X W X H) AND WEIGHT 7.9 in x 3.6 in x 2.4 in (20.0 cm x 9.1 cm x 6.1 cm); 415 grams POWER REQUIREMENTS POWER CONSUMPTION Transmit: 1.7W, Receive: 0.8W TRANSMIT CURRENT DRAW 9 - 48 VDC Power over Ethernet, 175 mA at 9 VDC, 140 mA at 12 VDC, 35 mA at 48 VDC POWER CONNECTOR Use PoE injector, power jack P5-2.1 mm center positive ENVIRONMENTAL OPERATING TEMPERATURE Radio/Enclosure: -40° C to +70° C; POE injector: -40° C to +85° C; Power supply: 0° C to +40° C WEATHERPROOFING The XPress Ethernet Bridge is IP65 rated. The PoE injector and power supply are not weatherproof and should be installed indoors. REGULATORY APPROVALS FCC (U.S.A) Yes IC (CANADA) Yes ETSI (EUROPE) N/A C-TICK (AUSTRALIA) Yes TELEC (JAPAN) N/A PART NUMBERS DESCRIPTION XEB09-CIPA XPress Ethernet Bridge, Pair XEB09-CIPAF XPress Ethernet Bridge, Pair - with FIPS 140-2 XEB09-CIPA-W XPress Ethernet Bridge, Pair (International) XEB09-CISA XPress Ethernet Bridge, Single XEB09-CISAF XPress Ethernet Bridge, Single - with FIPS 140-2 XEB09-CISAFB XPress Ethernet Bridge, Radio Board - with FIPS 140-2 XEB09-CISA-W XPress Ethernet Bridge, Single (International) DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2015 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91001402 D1/915 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL FRANCE +33-1-55-61-98-98 / www.digi.fr DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
XEB09-CIPA-W 价格&库存
很抱歉,暂时无法提供与“XEB09-CIPA-W”相匹配的价格&库存,您可以联系我们找货
