X24-009PKT-RA
X24-009PKT-RA
    DIGIINTERNATIONAL
    MOD RF 24XSTREAM 50MW IND
X24-009PKT-RA 数据手册
XStream-PKG-R™ RS-232/485 RF Modem Product Manual v5.x00 For XStream RF Modem Part Numbers: X09-001PK…-R… X09-009PK…-R… X09-019PK…-R… X24-009PK…-R... X24-019PK…-R… 900 MHz and 2.4 GHz Stand-alone RF Modems by Digi International Inc. XH9-001PK…-R... XH9-009PK…-R… XH9-019PK…-R… XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 XStream-PKG-R RS-232/485 RF Modem – Product Manual v5.x00 (Part number 90002211 B) Revision B Date Description 10/15//14 Minor changes and new part number © 2014 Digi International Inc. All rights reserved. Digi, Digi International Inc., the Digi logo, and XStream® are trademarks or registered trademarks in the United States and other countries worldwide. All other trademarks mentioned in this document are the property of their respective owners. Information in this document is subject to change without notice and does not represent a commitment on the part of Digi International Inc. Digi provides this document “as is,” without warranty of any kind, expressed or implied, including, but not limited to, the implied warranties of fitness or merchantability for a particular purpose. Digi may make improvements and/or changes in this manual or in the product(s) and/or the program(s) described in this manual at any time. © 2014 Digi International Inc. ii XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Contents 1. XStream RS-232/485 RF Modem 1.1. Features 1.1.1. Worldwide Acceptance 4 4 4 Antenna Usage 53 FCC-Approved Antennas 54 IC (Industry Canada) Certification 55 1.2. Specifications 5 Appendix B: Development Guide 56 1.3. External Interface 6 RS-232 Accessories Kit Contents 56 2. Interfacing Protocol 7 2.1. RS-232 Operation 2.1.1. DIP Switch Settings and Pin Signals 2.2. RS-485 (2-wire) Operation 2.2.1. DIP Switch Settings and Pin Signals 7 7 3. RF Modem Operation 3.1. Serial Communications 3.1.1. RS-232 and RS-485/422 Data Flow 9 59 Contact Digi 60 10 12 12 12 12 14 3.2.1. Idle Mode 14 3.2.2. Transmit Mode 14 3.2.3. Receive Mode 16 3.2.4. Sleep Modes 16 3.2.5. Command Mode 19 4. RF Modem Configuration 21 21 22 4.2.1. AT Commands 22 4.2.2. Binary Commands 23 4.3. Command Reference Table 24 4.4. Command Descriptions 25 5. RF Communication Modes 40 5.1. Addressing 41 5.1.1. Address Recognition 41 5.2. Basic Communications 42 5.2.1. Streaming Mode (Default) 42 5.2.2. Repeater Mode 43 5.3. Acknowledged Communications 46 5.3.1. Acknowledged Mode 46 5.3.2. Multi-Streaming Mode 48 Appendix A: Agency Certifications FCC Certification OEM Labeling Requirements © 2014 Digi International Inc. 59 59 13 4.2. Programming Examples Appendix C: Additional Information Ordering Information 3.1.3. Flow Control 4.1. Automatic DIP Switch Configurations 58 1-Year Warranty 3.1.2. Host and RF Modem I/O Settings 3.2. Modes of Operation 57 Antennas 9 2.3. RS-485 (4-wire) and RS-422 Operation 10 2.3.1. DIP Switch Settings and Pin Signals Adapters 52 52 53 iii XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 1. XStream RS-232/485 RF Modem The XStream-PKG-R RF Modem provides long range data communications and advanced networking for OEMs and system integrators. Out-of-box, the modem is equipped to sustain long range wireless links between devices. Simply enter serial data into one modem and the data surfaces on the other end of the wireless link. The modem transfers a standard asynchronous serial data stream between two or more modems. Its built-in RS-232/485/422 interfacing facilitates rapid integration into existing data systems. 1.1. Features Long Range Easy-to-Use 9XStream-PKG-R (900 MHz) Range: Out-of-Box RF Communications - • Indoor/Urban: up to 1500’ (450 m) no configuration required • Outdoor line-of-sight: up to 7 miles (11 km) w/ 2.1 dBm dipole antenna External DIP Switch for configuring: • Outdoor line-of-sight: up to 20 miles (32 km) w/ high gain antenna 24XStream-PKG-R (2.4 GHz) Range: • Indoor/Urban: up to 600’ (180 m) • Outdoor line-of-sight: up to 3 miles (5 km) w/ 2.1 dBm dipole antenna • Outdoor line-of-sight: up to 10 miles (16 km) w/ high gain antenna Receiver Sensitivity: -110 dBm (900 MHz), -105 dBm (2.4 GHz) Advanced Networking and Security True peer-to-peer (no “master” required), point-to-point, point-to-multipoint, multidrop Retries and Acknowledgements 7 hopping channels, each with over 65,000 available network addresses • RS-232/485/422 support (multidrop included) • 2-wire (half-duplex) or 4-wire RS-485/422 operation • Parity options 7-18 VDC power supply Simple AT and Binary commands for programming the modem Software-selectable serial interfacing rates MODBUS, CTS, RTS, DTR, DCD (and more) I/O Support XII™ Interference Blocking Power-saving Sleep Modes (as low as 6 mA) FHSS (Frequency Hopping Spread Spectrum) 1.1.1. Worldwide Acceptance FCC Certified (USA) - Refer to Appendix A for FCC Requirements. Systems that contain XStream RF Modems automatically inherit Digi Certifications. ISM (Industrial, Scientific and Medical) frequency band Manufactured under ISO 9001:2000 registered standards 9XStream (900 MHz) RF Modems are approved for use in US, Canada, Australia and Israel (and more). © 2014 Digi International Inc. 4 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 1.2. Specifications Table 1.1. XStream-PKG-R RS-232/485 RF Modem Specifications Specification 9XStream-PKG-R (900 MHz) 24XStream-PKG-R (2.4 GHz) Indoor/Urban Range Up to 1500’ (450 m) Up to 600’ (180 m) Outdoor LOS Range Up to 7 miles (11 km) w/ dipole antenna Up to 20 miles (32 km) w/ high-gain antenna Up to 3 miles (5 km) w/ dipole antenna Up to 10 miles (16 km) w/ high-gain antenna Transmit Power Output 100 mW (20 dBm) 50 mW (17 dBm) Interface Data Rate 125 – 65,000 bps (software selectable) 125 – 65,000 bps (software selectable) Throughput Data Rate 9,600 bps 19,200 bps 9,600 bps 19,200 bps RF Data Rate 10,000 bps 20,000 bps 10,000 bps 20,000 bps Receiver Sensitivity -110 dBm -107 dBm -105 dBm -102 dBm Performance Power Requirements Supply Voltage 7-18 VDC 7-18 VDC Receive Current 70 mA 90 mA Transmit Current 170 mA 180 mA Pin Sleep Power-Down 6 mA 6 mA Frequency 902-928 MHz 2.4000-2.4835 GHz Spread Spectrum Frequency Hopping, Wide band FM modulator Frequency Hopping, Wide band FM modulator Network Topology Peer-to-Peer, Point-to-Multipoint, Point-to-Point, Multidrop Peer-to-Peer, Point-to-multipoint, Point-to-Point, Multidrop Channel Capacity 7 hop sequences share 25 frequencies 7 hop sequences share 25 frequencies Data Connection DB-9 DB-9 Enclosure 7.1 oz. (200g), Extruded aluminum, black anodized 7.1 oz. (200g), Extruded aluminum, black anodized Enclosure Size 2.750” x 5.500” x 1.125” (6.99cm x 13.97” x 2.86cm) 2.750” x 5.500” x 1.125” (6.99cm x 13.97” x 2.86cm) Operating Temperature 0 to 70º C (commercial), -40 to 85º C (industrial) 0 to 70º C (commercial), -40 to 85º C (industrial) Type ½ wave dipole whip, 6.75” (17.1 cm), 2.1 dBi Gain ½ wave dipole whip, 5.25” (13.3 cm), 2.1 dBi Gain Connector Reverse-polarity SMA Reverse-polarity SMA Impedance 50 ohms unbalanced 50 ohms unbalanced General Physical Properties Antenna Certifications (Refer to www.digi.com for additional certifications) FCC Part 15.247 OUR9XSTREAM OUR-24XSTREAM Industry Canada (IC) 4214A-9XSTREAM 4214A 12008 © 2014 Digi International Inc. 5 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 1.3. External Interface 1.1a. Power Switch Figure 1.1. Front View Move the Power Switch to the on (up) position to power the Interface Board. DIP Switch (1.2a] settings are only read during a power-up sequence. 1.1b. I/O and Power LEDs The LED indicators visualize diagnostic status information. The modem’s status is represented as follows: Yellow (top LED) = Serial Data Out (to host) 1.1a. Power Switch Green (middle) = Serial Data In (from host) 1.1c. DB-9 Serial Port 1.1b. I/O and Power LEDs 1.1d. Power Connector Red (bottom) = Power/TX Indicator (Red light is on when powered, off briefly during RF transmission) 1.1c. Serial Port (DB-9 Connector) Standard female DB-9 (RS-232) DCE connector – This connector can be also used for RS-485 and RS-422 connections. 1.1d. Power Connector 7-18 VDC Power Connector (Center positive, 5.5/2.1mm) – Power can also be supplied through Pin 9 of the DB-9 Serial Port. 1.2a. DIP Switch Figure 1.2. Back View The DIP Switch automatically configures the XStream RF Modem to operate in different modes. Each time the modem is poweredon, intelligence inside the XIB-R interface board (inside the modem) programs the modem according to the positions of the DIP Switch. (See figure below for DIP Switch settings] NOTE: In cases where AT Commands should not be sent each time the RF Modem is powered-on, the processor must be disabled by populating J7 on the interface board inside the modem (p21). 1.2b. Config Switch 1.2a. 1.2c. DIP Switch Antenna Port 1.2b. Config (Configuration) Switch The Configuration Switch provides an alternate way to enter “AT Command Mode”. To enter “AT Command Mode” at the RF modem’s default baud rate, hold the Configuration Switch down while powering on the modem using the Power Switch (1.1a). 1.2c. Antenna Port Figure 1.3. DIP Switch Settings Port is a 50Ω RF signal connector for connecting to an external antenna. The connector type is RPSMA (Reverse Polarity SMA) female. The connector has threads on the outside of a barrel and a male center conductor. Refer to table in the “Automatic DIP Switch Configurations” (p19] section for more information about configurations triggered by the DIP Switch. © 2014 Digi International Inc. 6 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 2. Interfacing Protocol The XStream-PKG-R RF Modem supports the following interfacing protocols: • RS-232 • RS-485 (2-wire) Half-Duplex • RS-485 (4-wire) and RS-422 2.1. RS-232 Operation 2.1.1. DIP Switch Settings and Pin Signals Figure 2.1. RS-232 DIP Switch Settings Figure 2.2. Pins used on the female RS-232 (DB-9) Serial Connector DIP Switch settings are read and applied only while powering-on. Table 2.1. RS-232 Signals and their implementations on the XStream RF Modem (Low-asserted signals are distinguished by horizontal line over pin name.) DB-9 Pin RS-232 Name AT Command Reference* Description Implementation 1 DCD DO3 Data-Carrier-Detect Connected to DSR (pin6) 2 RXD DO Received Data Serial data exiting the RF Modem (to host) 3 TXD DI Transmitted Data Serial data entering into the RF modem (from host) 4 DTR DI3 Data-Terminal-Ready Can enable POWER-DOWN on the RF Modem 5 GND - Ground Signal Ground 6 DSR DO3 Data-Set-Ready Connected to DCD (pin1) 7 / CMD DI2 Request-to-Send Provides flow control or enables “Command Mode” on the RF Modem DO2 Clear-to-Send - Ring Indicator 8 9 RI Provides flow control Optional power input that is connected internally to the positive lead of the front power connector * Inside the XStream RF Modem is an XStream OEM RF Module. The names in this column refer to the pin signals of the embedded RF module. XStream Commands (p24) used to configure pin behaviors are named according to the pins of the module, not the RS-232 connection pins. © 2014 Digi International Inc. 7 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Wiring Diagram: RS-232 DTE Device to a DCE RF Modem Figure 2.3. RS-232 DTE (male connector) device wired to an XStream RF Modem (female connector) Wiring Diagram: DCE RF Modem to an RS-232 DCE Device Figure 2.4. XStream RF Modem (female connector) wired to an RS-232 DTE (male connector) device Sample Wireless Connection: DTE  DCE DCE  DCE Figure 2.5. Typical wireless link between DTE and DCE devices © 2014 Digi International Inc. 8 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 2.2. RS-485 (2-wire) Operation 2.2.1. DIP Switch Settings and Pin Signals Figure 2.6. RS-485 (2-wire) Half-Duplex DIP Switch Settings Figure 2.7. Pins used on the female RS-232 (DB-9) Serial Connector Figure 2.8. RS-485 (2-wire) with Termination (optional) Termination is the 120 Ω resistor between T+ and T-. DIP Switch settings are read and applied only while powering-on. Note: Refer to Figures 2.15 and 2.16 for RJ-45 connector pin designations used in RS-485/422 environments. Table 2.2. RS-485 (2-wire half-duplex) Signals and their implementations on the XStream RF Modem DB-9 Pin RS-485 Name Description Implementation 2 T/R- (TRA) Negative Data Line Transmit serial data to and from the XStream RF Modem 5 GND Ground Signal Ground 8 T/R+ (TRB) Positive Data Line Transmit serial data to and from the XStream RF Modem 9 PWR Power Optional power input that is connected internally to the front power connector 1, 3, 4, 6, 7 not used Wiring Diagram: RS-485 (2-wire) Half-Duplex Figure 2.9. XStream RF Modem in an RS-485 (2-wire) half-duplex environment © 2014 Digi International Inc. 9 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 2.3. RS-485 (4-wire) and RS-422 Operation 2.3.1. DIP Switch Settings and Pin Signals Figure 2.10. RS-485 (4-wire) and RS-422 DIP Switch Settings Figure 2.11. Pins used on the female RS-232 (DB-9) Serial Connector Figure 2.12. RS-485 (4-wire) and RS-422 with Termination (optional) Termination is the 120 Ω resistor between T+ and T-. DIP Switch settings are read and applied only while powering-on. Table 2.3. RS-485/422 (4-wire) Signals and their implementations with the XStream-PKG-R RF Modem DB-9 Pin RS-485/422 Name Description Implementation 2 T- (TA) Transmit Negative Data Line Serial data sent from the XStream RF Modem 3 R- (RA) Receive Negative Data Line Serial data received by the XStream RF Modem 5 GND Signal Ground Ground 7 R+ (RB) Receive Positive Data Line Serial data received by the XStream RF Modem 8 T+ (TB) Transmit Positive Data Line Serial data sent from the XStream RF Modem 9 PWR Power Optional power input that is connected internally to the front power connector 1, 4, 6 not used Wiring Diagram: RS-485 (4-wire) Half-Duplex Figure 2.13. © 2014 Digi International Inc. XStream RF Modem in an RS-485 (4-wire) environment 10 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Wiring Diagram: RS-422 Figure 2.14. XStream RF Modem in an RS-485 (4-wire) environment RS-485/422 Connection Guidelines The RS-485/422 protocol provides a solution for wired communications that can tolerate high noise and push signals over long cable lengths. RS-485/422 signals can communicate as far as 4000 feet (1200 m). RS-232 signals are suitable for cable distances up to 100 feet (30.5 m). RS-485 offers multi-drop capability in which up to 32 nodes can be connected. The RS-422 protocol is used for point-to-point communications. Suggestions for integrating the XStream Modem with the RS-485/422 protocol: 1. When using Ethernet twisted pair cabling: Select wires so that T+ and T- are connected to each wire in a twisted pair. Likewise, select wires so that R+ and R- are connected to a twisted pair. (For example, tie the green and white/green wires to T+ and T-.) 2. For straight-through Ethernet cable (not cross-over cable) – The following wiring pattern works well: Pin3 to T+, Pin4 to R+, Pin5 to R-, Pin6 to T- 3. Note that the connecting cable only requires 4 wires (even though there are 8 wires). 4. When using phone cabling (RJ-11) – Pin2 in the cable maps to Pin3 on opposite end of cable and Pin1 maps to Pin4 respectively. Figure 2.15. Male (yellow) DB-9 to RJ-45 Adapters Figure 2.16. Female (green) DB-9 to RJ-45 Adapters An RS-232 Accessories Kit is available that includes connectors that facilitate RS-232/485/422 and other serial communications. Refer to the Development Guide in Appendix B for information concerning the connectors and tools included in the kit. © 2014 Digi International Inc. 11 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 3. RF Modem Operation 3.1. Serial Communications 3.1.1. RS-232 and RS-485/422 Data Flow Devices that have a UART interface can connect directly through the pins of the XStream Modem as is shown in the figure below. Figure 3.1. System Data Flow Diagram in a UART-interfaced environment (Low-asserted signals distinguished with horizontal line over signal name.) 3.1.2. Host and RF Modem I/O Settings Serial communications between a host and an XStream RF Modem are dependent upon having matching baud rate, parity, stop bit and number of data bits settings. Failure to enter the modem into AT Command Mode is most commonly due to baud rate mismatch. Refer to the table below to ensure host serial port settings match those of the modem. Table 3.1. Parameter values critical to serial communications between the RF Modem and host Parameter Setting XStream RF Modem Default Parameter Value Baud (Serial Data Rate) 9600 bps or 19200 baud (Factory-set RF data rates) Number of Data Bits 8 (NB parameter = 0) Parity None (NB parameter = 0) Number of Stop Bits 1 (NB parameter = 0) Both the XStream RF Modem and host (PC) settings can be viewed and adjusted using Digi’s proprietary XCTU Software. Use the “PC Settings” tab to configure host settings. Use the “Terminal” or “Modem Configuration” tabs to configure the RF Modem settings. Refer to the RF Modem Configuration sections for more information (p21). © 2014 Digi International Inc. 12 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 3.1.3. Flow Control Figure 3.2. Internal Data Flow Diagram (The five most commonly-used pin signals are shown.) DI (Data In) Buffer and Flow Control When serial data enters the XStream Modem through the DI Pin, then the data is stored in the DI Buffer until it can be transmitted. When the RO parameter threshold is satisfied (refer to Transmit Mode (p14) and Command Descriptions (p25) sections for more information), the modem attempts to initialize an RF connection. If the modem is already receiving RF data, the serial data is stored in the modem’s DI Buffer. If the DI buffer becomes full, hardware or software flow control must be implemented in order to prevent overflow (loss of data between the host and XStream RF Modem). How to eliminate the need for flow control: 1. Send messages that are smaller than the DI buffer size. The size of the DI buffer varies according to the packet size and parity setting used. 2. Interface at a lower baud rate (BD Command) than the fixed RF data rate. Two cases in which the DI Buffer may become full and possibly overflow: 1. If the serial interface data rate is set higher than the RF data rate of the modem, the modem will receive data from the host faster than it can transmit the data over-the-air. 2. If the modem is receiving a continuous stream of RF data or if the modem is monitoring data on a network, any serial data that arrives on the DI pin is placed in the DI Buffer. The data in the DI buffer will be transmitted over-the-air when the modem no longer detects RF data in the network. Hardware Flow Control ( ). When the DI buffer is 17 bytes away from being full; by default, the modem de-asserts (high) to signal to the host device to stop sending data (refer to the FT (Flow Control Threshold) and CS (DO2 Configuration) commands). is re-asserted after the DI Buffer has 34 bytes of memory available. Software Flow Control (XON). XON/XOFF software flow control can be enabled using the FL (Software Flow Control) Command. This option only works with ASCII data. DO (Data Out) Buffer and Flow Control When RF data is received, the data enters the DO buffer and is then sent out the serial port to a host device. Once the DO Buffer reaches capacity, any additional incoming RF data is lost. Two cases in which the DO Buffer may become full and possibly overflow: 1. If the RF data rate is set higher than the interface data rate of the modem, the modem will receive data from the transmitting modem faster than it can send the data to the host. 2. If the host does not allow the modem to transmit data out from the DO buffer because of being held off by hardware or software flow control. Hardware Flow Control ( ). If is enabled for flow control (RT Parameter = 2), data will not be sent out the DO Buffer as long as is de-asserted. Software Flow Control (XOFF). XON/XOFF software flow control can be enabled using the FL (Software Flow Control) Command. This option only works with ASCII data. © 2014 Digi International Inc. 13 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 3.2. Modes of Operation XStream RF Modems operate in five modes. Figure 3.3. XStream Modes of Operation Modem can only be in one mode at a time. 3.2.1. Idle Mode When not receiving or transmitting data, the modem is in Idle Mode. The modem uses the same amount of power in Idle Mode as it does in Receive Mode. The modem shifts into the other modes of operation under the following conditions: • Serial data is received in the DI Buffer (Transmit Mode) • Valid RF data is received through the antenna (Receive Mode) • Command Mode Sequence is issued (Command Mode) • Sleep Mode condition is met (Sleep Mode) After responding to any of the preceding conditions, the modem automatically transitions back into Idle Mode. 3.2.2. Transmit Mode Note: RF reception must complete before the modem is able to enter into Transmit Mode. When the first byte of serial data is received from the UART in the DI buffer, the modem attempts to shift to Transmit Mode and initiate an RF connection with other modems. After transmission is complete, the modem returns to Idle Mode. RF transmission begins after either of the following criteria is met: 1. RB bytes have been received in the DI buffer and are pending for RF transmission (refer to RB (Packetization Threshold) command, p34). The RB parameter may be set to any value between 1 and the RF packet size (PK), inclusive. When RB = 0, the packetization threshold is ignored. 2. At least one character has been received in the DI buffer (pending for RF transmission) and RO time has been observed on the UART (refer to RO (Packetization Timeout) command). The timeout can be disabled by setting RO to zero. In this case, transmission will begin after RB bytes have been received in the DI buffer. After either RB or RO conditions are met, the modem then initializes a communications channel. (Channel initialization is the process of sending an RF initializer that synchronizes receiving modems with the transmitting modem. During channel initialization, incoming serial data accumulates in the DI buffer.) Serial data in the DI buffer is grouped into RF packets (refer to PK (RF Packet Size)); converted to RF data; then transmitted over-the-air until the DI buffer is empty. RF data, which includes the payload data, follows the RF initializer. The payload includes up to the maximum packet size (PK Command) bytes. As the transmitting modem nears the end of the transmission, it inspects the DI buffer to see if more data exists to be transmitted. This could be the case if more than PK bytes were originally pending in the DI buffer or if more bytes arrived from the UART after the transmission began. If more data is pending, the transmitting modem assembles a subsequent packet for transmission. © 2014 Digi International Inc. 14 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Figure 3.4. Data Transmission Sequence  RF Data Packet The RF packet is the sequence of data used for communicating information between Digi Modems. An RF Packet consists of an RF Initializer and RF Data. Figure 3.5. RF Data Packet Components * When streaming multiple RF packets, the RF Initializer is only sent in front of the first packet. RF Initializer An RF initializer is sent each time a new connection sequence begins. The RF initializer contains channel information that notifies receiving modems of information such as the hopping pattern used by the transmitting modem. The first transmission always sends an RF initializer. An RF initializer can be of various lengths depending on the amount of time determined to be required to prepare a receiving modem. For example, a wake-up initializer is a type of RF initializer used to wake remote modems from Sleep Mode (Refer to the FH, LH, HT and SM Commands for more information). The length of the wake-up initializer should be longer than the length of time remote modems are in cyclic sleep. Header The header contains network addressing information that filters incoming RF data. The receiving modem checks for a matching Hopping Channel (HP parameter), Vendor Identification Number (ID parameter) and Destination Address (DT parameter). Data that does not pass through all three network filter layers is discarded. CRC (Cyclic Redundancy Check) To verify data integrity and provide built-in error checking, a 16-bit CRC (Cyclic Redundancy Check) is computed for the transmitted data and attached to the end of each RF packet. On the receiving end, the receiving modem computes the CRC on all incoming RF data. Received data that has an invalid CRC is discarded (Refer to the Receive Mode section, next page). © 2014 Digi International Inc. 15 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 3.2.3. Receive Mode If the modem detects RF data while in Idle Mode, the modem transitions into Receive Mode to receive RF packets. Once a packet is received, the modem checks the CRC to ensure that the data was transmitted without error. If the CRC data bits on the incoming packet are invalid, the packet is discarded. If the CRC is valid, the packet proceeds to the DO Buffer. The modem returns to Idle Mode when valid RF data is no longer detected or after an error is detected in the received RF data. Figure 3.6. Data Reception Sequence Refer to the Addressing section (p41) of the RF Communication Modes chapter for more information regarding address recognition. Note: If serial data exists in the DI buffer while the modem is in Receive Mode, the UART data will be transmitted after the modem is finished receiving the RF data and has returned to Idle Mode. 3.2.4. Sleep Modes Sleep Modes enable the XStream Modem to operate at minimal power consumption when not in use. Three Sleep Mode options are available: • Pin Sleep (Host Controlled) • Serial Port Sleep (Wake on Serial Port activity) • Cyclic Sleep (Wake on RF activity) For the modem to transition into Sleep Mode, the modem must have a non-zero SM (Sleep Mode) parameter and one of the following must occur: 1. The modem is idle (no data transmission or reception) for a user-defined period of time (Refer to the ST (Time before Sleep) command). 2. SLEEP pin is asserted (only for Pin Sleep option). In Sleep Mode, the modem will not transmit or receive data until the modem first transitions to Idle Mode. All Sleep Modes are enabled and disabled using SM Command. Transitions into and out of Sleep Modes are triggered by various mechanisms as shown in the table below. Table 3.2. Summary of Sleep Mode Configurations Sleep Mode Setting Pin Sleep (SM = 1) Serial Port Sleep (SM = 2) Cyclic Sleep (SM = 3-8) Transition into Sleep Mode A microcontroller can shut down and wake modems by asserting (high) SLEEP pin. Note: The modem will complete a transmission or reception before activating Pin Sleep. Automatic transition to Sleep Mode occurs after a user-defined period of inactivity (no transmitting or receiving of data). The period of activity is defined using the ST (Time before Sleep) Command. Automatic transition to Sleep Mode occurs in cycles as defined by the SM (Sleep Mode) Command. Transition out of Sleep Mode Related Commands Typical Power Consumption De-assert SLEEP pin. SM 6 mA When serial byte is SM, ST received on the DI pin. 25 mA After the cyclic sleep time interval elapses. Note: Modem can be Note: The cyclic sleep time interval must be forced into Idle Mode shorter than the “Wake-up Initializer Timer” if PW (Pin Wake-up) (set by LH Command). Command is issued. SM, ST, HT, LH, 6 mA PW when sleeping For more information about Sleep Modes, refer to the individual commands listed in “Related Commands” column of the table. The SM command is central to all Sleep Mode configurations. © 2014 Digi International Inc. 16 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Pin Sleep (SM = 1) Pin Sleep requires the least amount of power. In order to achieve this state, the DI3 (SLEEP) pin must be asserted (high). The modem remains in Pin Sleep until the DI3 pin is de-asserted. After enabling Pin Sleep, the SLEEP pin controls whether the XStream Modem is active or in Sleep Mode. When DI3 is de-asserted (low), the modem is fully operational. When DI3 is asserted (high), the modem transitions to Sleep Mode and remains in its lowest power-consuming state until the DI3 (SLEEP) pin is de-asserted. DI3 is only active if the modem is setup to operate in this mode; otherwise the pin is ignored. Once in Pin Sleep Mode, DO2 ( ) is de-asserted (high), indicating that data should not be sent to the modem. The PWR pin is also de-asserted (low) when the modem is in Pin Sleep Mode. Note: The modem will complete a transmission or reception before activating Pin Sleep. Serial Port Sleep (SM = 2) Serial Port Sleep is a Sleep Mode in which the XStream Modem runs in a low power state until serial data is detected on the DI pin. When Serial Port Sleep is enabled, the modem goes into Sleep Mode after a user-defined period of inactivity (no transmitting or receiving of data). This period of time is determined by ST (Time before Sleep) Command. Once a character is received through the DI pin, the modem returns to Idle Mode and is fully operational. Cyclic Sleep (SM = 3-8) Cyclic Sleep is the Sleep Mode in which the XStream Modem enters into a low-power state and awakens periodically to determine if any transmissions are being sent. When Cyclic Sleep settings are enabled, the XStream Modem goes into Sleep Mode after a userdefined period of inactivity (no transmission or reception on the RF channel). The user-defined period is determined by ST (Time before Sleep) Command. While the modem is in Cyclic Sleep Mode, DO2 ( ) is de-asserted (high) to indicate that data should not be sent to the modem during this time. When the modem awakens to listen for data, DO2 is asserted and any data received on the DI Pin is transmitted. The PWR pin is also deasserted (low) when the modem is in Cyclic Sleep Mode. The modem remains in Sleep Mode for a user-defined period of time ranging from 0.5 seconds to 16 seconds (SM Parameters 3 through 8). After this interval of time, the modem returns to Idle Mode and listens for a valid data packet for 100 ms. If the modem does not detect valid data (on any frequency), the modem returns to Sleep Mode. If valid data is detected, the modem transitions into Receive Mode and receives incoming RF packets. The modem then returns to Sleep Mode after a Period of inactivity that is determined by ST “Time before Sleep” Command. The modem can also be configured to wake from cyclic sleep when SLEEP/DI3 is de-asserted (low). To configure a modem to operate in this manner, PW (Pin Wake-up) Command must be issued. Once DI3 is de-asserted, the modem is forced into Idle Mode and can begin transmitting or receiving data. It remains active until no data is detected for the period of time specified by the ST Command, at which point it resumes its low-power cyclic state. Note: The cyclic interval time defined by SM (Sleep Mode) Command must be shorter than the interval time defined by LH (Wake-up Initializer Timer). For example: If SM=4 (Cyclic 1.0 second sleep), the LH Parameter should equal 0x0B (“1.1” seconds). With these parameters set, there is no risk of the receiving modem being asleep for the duration of wake-up initializer transmission. “Cyclic Scanning” explains in further detail the relationship between “Cyclic Sleep” and “Wake-up Initializer Timer” © 2014 Digi International Inc. 17 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Cyclic Scanning. Each RF transmission consists of an RF Initializer and payload. The wake-up initializer contains initialization information and all receiving modems must wake during the wake-up initializer portion of data transmission in order to be synchronized with the transmitting modem and receive the data. Figure 3.7. Correct Configuration (LH > SM) Length of the wake-up initializer exceeds the time interval of Cyclic Sleep. The receiver is guaranteed to detect the wake-up initializer and receive the accompanying payload data. Figure 3.8. Incorrect Configuration (LH < SM) Length of wake-up initializer is shorter than the time interval of Cyclic Sleep. This configuration is vulnerable to the receiver waking and missing the wake-up initializer (and therefore also the accompanying payload data). © 2014 Digi International Inc. 18 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 3.2.5. Command Mode To modify or read modem parameters, the modem must first enter into Command Mode, the state in which incoming characters are interpreted as commands. Two command types are available for programming the modem: • AT Commands • Binary Commands For modified parameter values to persist in the modem registry, changes must be saved to nonvolatile memory using WR (Write) Command. Otherwise, parameters are restored to previously saved values when the modem is powered off and then on again. AT Commands To Enter AT Command Mode: 1. Send the 3-character command sequence “+++” and observe guard times before and after the command characters. (Refer to the “Default AT Command Mode Sequence” below.) The “Terminal” tab (or other serial communications software) of the XCTU Software can be used to enter the sequence. (OR) 2. Assert (low) the pin and turn the power going to the modem off and back on. This result can be achieved by keeping the configuration switch pressed while turning off, then on again the power supplying the RF Modem) Default AT Command Mode Sequence (for transition to Command Mode): • No characters sent for one second (refer to the BT (Guard Time Before) Command) • Input three plus characters (“+++”) within one second (refer to the CC (Command Sequence Character) Command.) • No characters sent for one second (refer to the AT (Guard Time After) Command.) To Send AT Commands: Send AT commands and parameters using the syntax shown below: Figure 3.9. Syntax for sending AT Commands NOTE: To read a parameter value stored in a register, leave the parameter field blank. The preceding example would change the modem Destination Address to “1F”. To store the new value to non-volatile (long term) memory, the Write (ATWR) Command must follow. System Response. When a command is sent to the modem, the modem will parse and execute the command. Upon successful execution of a command, the modem returns an “OK” message. If execution of a command results in an error, the modem returns an “ERROR” message. To Exit AT Command Mode: 1. Send ATCN (Exit Command Mode) Command. (OR) 2. If no valid AT Commands are received within the time specified by CT (Command Mode Timeout) Command, the Modem automatically returns to Idle Mode. For examples that illustrate the steps of programming the modem using AT Commands, refer to the RF Modem Configuration (p21) chapter. © 2014 Digi International Inc. 19 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Binary Commands Sending and receiving parameter values using binary commands is the fastest way to change operating parameters of the XStream RF Modem. Binary commands are used most often to sample signal strength (RS parameter) and/or error counts; or change modem addresses and channels for polling data systems. Since the sending and receiving of register values takes place through the same serial data path as “live” data (received RF payload), interference between the two types of data can be a concern. Common questions about using binary commands: • What are the implications of asserting CMD while live data is being sent or received? • After sending serial data, is there a minimum time delay before CMD can be asserted? • Is a delay required after CMD is de-asserted before payload data can be sent? • How does one discern between live data and data received in response to a command? The CMD pin must be asserted in order to send binary commands to the RF modem. The CMD pin can be asserted to recognize binary commands anytime during the transmission or reception of data. The status of the CMD signal is only checked at the end of the stop bit as the byte is shifted into the serial port. The application does not allow control over when data is received, except by waiting for dead time between bursts of communication. If the command is sent in the middle of a stream of payload data to be transmitted, the command will essentially be executed in the order it is received. If the radio is continuously receiving data, the radio will wait for a break in the received data before executing the command. The signal will frame the response coming from the binary command request (Figure 3.10). A minimum time delay of 100 µs (after the stop bit of the command byte has been sent) must be observed before the CMD pin can be de-asserted. The command executes after all parameters associated with the command have been sent. If all parameters are not received within 0.5 seconds, the modem returns to Idle Mode. Note: When parameters are sent, they are two bytes long with the least significant byte sent first. Binary commands that return one parameter byte must be written with two parameter bytes. Refer to p23 for a binary programming example. Commands can be queried for their current value by sending the command logically ORed (bitwise) with the value 0x80 (hexadecimal) with CMD asserted. When the binary value is sent (with no parameters), the current value of the command parameter is sent back through the DO pin. Figure 3.10. Binary Command Write then Read Signal #4 is CMD Signal #1 is the DIN signal to the radio Signal #2 is the DOUT signal from the radio Signal #3 is In this graph, a value was written to a register and then read out to verify it. While not in the middle of other received data, note that the (DO2 pin) signal outlines the data response out of the modem. IMPORTANT: For the XStream Modem to recognize a binary command, the RT (DI2 Configuration) parameter must be set to one. If binary programming is not enabled (RT ≠ 1), the modem will not recognize that the CMD pin is asserted and therefore will not recognize the data as binary commands. © 2014 Digi International Inc. 20 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 4. RF Modem Configuration 4.1. Automatic DIP Switch Configurations Each time the RF Modem is powered-on, intelligence on the XIB-R Interface Board (RS-232/485 interfacing board located inside the RF Modem) sends AT Commands that program the RF Modem based on positions of the DIP Switch. Automatic configurations that take place during the poweron sequence affect stored RF Modem parameter values as shown in the tables below. Figure 4.1. RF Modem DIP Switch Table 4.1. RF Modem Power-up Options (J7 jumper and Config Switch) Condition Behavior If J7 is populated Processor is disabled and AT Commands are not sent to the RF Modem If Config Switch is pressed Processor is disabled and RF Modem enters into AT Command Mode If J7 is NOT populated and Config Switch is NOT pressed Execute logic as shown in table below. Table 4.2. AT Commands Sent as result of DIP Switch Settings (SW = DIP Switch) Condition Behavior Restore Default Parameter Values of the RF Modem If SW1 and SW2 are ON (up) AT Commands sent: ATRE (Restore Defaults) Command ATWR (Write) Command AT Commands sent: ATCS 0 (RS-232 Operation: CTS function for CTS line, DB-9 pin 8) ATCD 2 (DO3 - RX LED = low) ATCS 3 (RS-485 or RS-422 Operation) ATCD 2 (DO3 - RX LED = low) Serial Interfacing Options If SW1 is ON (up) If SW1 is OFF (down) AT Commands sent: Parity Options If SW5 and SW6 are OFF (down) If SW5 is OFF (down) and SW6 is ON (up) If SW5 is ON (up) and SW6 is OFF (down) If SW5 is ON (up) and SW6 is ON (up) AT Commands sent: ATNB 0 (parity = none) AT Commands sent: ATNB 1 (parity = even) AT Commands sent: ATNB 2 (parity = odd) AT Commands sent: ATNB 5 (parity = 9th bit data over-the-air, v4.30 only) AT Commands sent: ATCN (Exit AT Command Mode) Exit AT Command Mode Always IMPORTANT: To avoid overwriting previously stored custom configurations (due to the automatic configurations that take place each time the RF Modem is powered-on), it is necessary to disable a processor located on the XIB-R interface board. To disable the processor, populate the J7 jumper of the XIB-R Interface Board. By default, J7 is not populated. © 2014 Digi International Inc. 21 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 4.2. Programming Examples For information about entering and exiting AT and Binary Command Modes, refer to the Command Mode section (p19). 4.2.1. AT Commands Digi has provided XCTU software for programming the modem using an extensive list of AT Commands. The XCTU software provides an interface that is divided into four tabs that facilitate the following functions: • PC Settings tab - Setup PC serial port to interface with an XStream RF Modem • Range Test tab – Test XStream RF Modem's range in varying environments • Terminal tab – Configure and read XStream RF Modem parameters using AT Commands • Modem Configuration tab – Configure and read RF Modem parameters To install the XCTU Software: Navigate to: www.digi.com/support/ . Then select “XCTU” under the product list. Select the appropriate driver to install the XCTU software. PC Settings Tab As stated in the Serial Communications section; in order to communicate data to the RF modem through the PC, baud (serial data rate), data bit, parity and stop bit settings on the PC serial port must match those of the RF modem. The PC Settings tab provides a software user interface that facilitates the modification of PC serial port settings. PC Setup 1. Set the DIP Switch to RS-232 mode. Switch 1 is ON (up) and the remaining 5 switches are OFF (down). 2. Connect the male DB-9 connector of the PC with the female DB-9 connector of the RF modem using an RS-232 cable. 3. Power the RF modem through the power connector. 4. Launch XCTU Software and select the PC Settings tab; then select parameter values from the dropdown lists that match the current parameter values of the RF modem. (Refer to Table 3.1 on for more information.) Figure 4.2. RF Modem Configurations through a Serial Cable Terminal Tab A terminal program has been built into the XCTU software and is located under the Terminal tab. The Terminal tab provides an easy-to-use interface for programming the modem. Multiple AT Commands. Multiple AT commands can be entered on one line with one carriage return at the end of the line. Each command must be delimited by a comma (spaces in between are optional). The “AT” prefix is only sent before the first command and should not be included with subsequent commands in a line. System Response. When a command is sent to the modem, the modem will parse and execute the command. Upon successful execution of a command, the modem returns an “OK” message. If execution of a command results in an error, the modem returns an “ERROR” message. © 2014 Digi International Inc. 22 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 EXAMPLE: Restore RF Modem Defaults using the Terminal tab The following steps show how to read currently stored modem parameter values; then restore the modem parameters to their factory-default states. Method 1 (One line per command) Issue AT Command +++ ATHP ATRE ATWR ATCN System Response OK (Enter into AT Command Mode) (system shows current channel number) OK (Restore modem default parameter values) OK (Write new values to non-volatile memory) OK (Exit AT Command Mode) Method 2 (Multiple commands on one line) Issue AT Command System Response +++ OK ATRE, WR, CN OK NOTE: Default parameter values of the RF modem can also be restored by selecting the “Restore Defaults” button located on the Modem Configuration tab (refer to the instructions below). Modem Configuration tab The “Modem Configuration” tab of the XCTU software provides an easy-to-use interface for reading and setting RF modem parameters. EXAMPLE: Read Parameters and Restore Defaults using the Modem Configuration tab The following steps show how to read currently stored modem parameter values; then restore the modem parameters to their factory-default states. 1. Open the XCTU program (Start --> Programs --> Digi --> XCTU): 2. Under the “PC Settings” tab, select the PC Serial Com Port from the dropdown list that will be used to connect to the RF Modem. 3. Select a "Baud rate" to match the default RF data rate of the RF Modem. Use default values for all other fields. 4. Select the “Modem Configuration” tab. 5. Select the “Read” button to read currently stored parameter values of the modem. 6. Select the “Restore” button to restore factory-default parameter values. 7. Select the “Write” button to save default values to non-volatile (long-term) memory. 4.2.2. Binary Commands Example: Send Binary Commands Example: Use binary commands to change the XStream Modem’s destination address to 0x1A0D and save the new address to non-volatile memory. 1. RT Command must be set to “1” in AT Command Mode to enable binary programming. 2. Assert CMD (Pin is driven high). (Enter Binary Command Mode) 3. Send Bytes (Parameter bytes must be 2 bytes long): 00 (Send DT (Destination Address) Command) 0D (Least significant byte of parameter bytes) 1A (Most significant byte of parameter bytes) 08 (Send WR (Write) Command) 4. De-assert CMD (Pin is driven low). Note: (Exit Binary Command Mode) is high when command is being executed. Hardware flow control must be disabled as will hold off parameter bytes. © 2014 Digi International Inc. 23 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 4.3. Command Reference Table Table 4.1. XStream Commands (The RF Modem expects numerical values in hexadecimal. “d” denotes decimal equivalent.) AT Command AM v4.30* AT Binary Command 0x3A (58d) 0x05 (5d) BD v4.2B* 0x15 (21d) Baud Rate BK v4.30* BO v4.30* BT CB v4.30* CC CD v4.2B* CE v4.30* CF v4.30* CL v4.30* CM v4.30* CN CO v4.30* CS v4.27D* CT DC v4.30* DR v4.30* DT E0 E1 ER FH FL FT v4.27B* GD HP HT 0x2E (46d) 0x30 (48d) 0x04 (4d) 0x33 (51d) 0x13 (19d) 0x28 (40d) 0x34 (52d) 0x35 (53d) 0x39 (57d) 0x38 (56d) 0x09 (9d) 0x2F (47d) 0x1F (31d) 0x06 (6d) 0x37 (55d) 0x2D (45d) 0x00 (0d) 0x0A (10d) 0x0B (11d) 0x0F (15d) 0x0D (13d) 0x07 (7d) 0x24 (36d) 0x10 (16d) 0x11 (17d) 0x03 (3d) Serial Break Passing Serial Break Timeout Guard Time Before Connection Duration Timeout Command Sequence Character DO3 Configuration Connection Inactivity Timeout Connection Failure Count Last Connection Address Connection Message Exit AT Command Mode DO3 Timeout DO2 Configuration Command Mode Timeout Disconnect DI3 Configuration Destination Address Echo Off Echo On Receive Error Count Force Wake-up Initializer Software Flow Control Flow Control Threshold Receive Good Count Hopping Channel Time before Wake-up Initializer ID v4.2B* 0x27 (39d) Modem VID IU v4.30* LH MD v4.30* MK MY v4.30* NB v4.30* PC v4.22* PK v4.30* PW v4.22* RB v4.30* RE RN v4.22* RO v4.2A* RP v4.2A* RR v4.22* RS v4.22* RT RZ v4.30* SB v4.2B* SH v4.27C* SL v4.27C* SM ST SY TO v4.30* TR v4.22* TT v4.22* VR WR 0x3B (59d) 0x0C (12d) 0x32 (50d) 0x12 (18d) 0x2A (42d) 0x23 (35d) 0x1E (30d) 0x29 (41d) 0x1D (29d) 0x20 (32d) 0x0E (14d) 0x19 (25d) 0x21 (33d) 0x22 (34d) 0x18 (24d) 0x1C (28d) 0x16 (22d) 0x2C (44d) 0x36 (54d) 0x25 (37d) 0x26 (38d) 0x01 (1d) 0x02 (2d) 0x17 (23d) 0x31 (49d) 0x1B (27d) 0x1A (26d) 0x14 (20d) 0x08 (8d) DI2, DI3 Update Timer Wake-up Initializer Timer RF Mode Address Mask Source Address Parity Power-up Mode RF Packet Size Pin Wake-up Packetization Threshold Restore Defaults Delay Slots Packetization Timeout RSSI PWM Timer Retries RSSI DI2 Configuration DI Buffer Size Stop Bits Serial Number High Serial Number Low Sleep Mode Time before Sleep Time before Initialization DO2 Timeout Transmit Error Count Streaming Limit Firmware Version Write AT Command Name Range Command Category Auto-set MY Guard Time After 0x02 – 0xFFFF (x 100 msec) Standard baud rates: 0 – 6 (custom rates also supported) 0–1 0 - 0xFFFF (x 1 second) 0 – 0xFFFF (x 100 msec) 0x01 – 0xFFFF (x 100 msec) 0x20 – 0x7F 0–4 0 – 0xFFFF (x 10 msec) 0 – 0xFFFF (read-only) 0–1 0 - 0xFFFF (x 1 second) 0–4 0x02 – 0xFFFF (x 100 msec) 0–4 0 – 0xFFFF 0 – 0xFFFF 0–1 0 – 0xFF (bytes) 0 – 0xFFFF 0–6 0 – 0xFFFF (x 100 msec) User-settable: 0x10 - 0x7FFF Read-only: 0x8000 – 0xFFFF 0 - 0xFFFF (x 100 msec) 0 – 0xFF (x 100 msec) 0–4 0 – 0xFFFF 0 – 0xFFFF 0–5 0–1 0 - 0x100 (bytes) 0–1 0 - 0x100 (bytes) 0 – 0xFF (slots) 0 – 0xFFFF (x 200 µsec) 0 - 0x7F (x 100 msec) 0 – 0xFF 0x06 – 0x36 (read-only) 0-2 (read-only) 0-1 0 – 0xFFFF (read-only) 0 – 0xFFFF (read-only) 0–8 0x10 – 0xFFFF (x 100 msec) 0 – 0xFF (x 100 msec) 0 - 0xFFFF (x 1 sec) 0 – 0xFFFF 0 – 0xFFFF (0 = disabled) 0 x 0xFFFF (read-only) - Networking and Security Command Mode Options # Bytes Returned 2 Serial Interfacing 2 Serial Interfacing Serial Interfacing Command Mode Options Networking and Security Command Mode Options Serial Interfacing Networking and Security Networking and Security Diagnostics Networking and Security Command Mode Options Serial Interfacing Serial Interfacing Command Mode Options Networking and Security Serial Interfacing Networking and Security Command Mode Options Command Mode Options Diagnostics Sleep (Low Power) Serial Interfacing Serial Interfacing Diagnostics Networking and Security Sleep (Low Power) 1 2 2 2 1 1 2 2 2 1 2 1 2 1 2 2 1 2 2 1 2 Factory Default 0x0A (10d) factory-set RF data rate 0 0 0x0A (10d) 0x28 (4d sec) 0x2B (“+”) 0 0x64 (1d sec) 0 0 0x03 0 0xC8 (200d) 0 0 0 0 varies 0 0 0xFFFF Networking and Security 2 - Serial Interfacing Sleep (Low Power) Networking and Security Networking and Security Networking and Security Serial Interfacing Command Mode Options Serial Interfacing Sleep (Low Power) Serial Interfacing (Special) Networking and Security Serial Interfacing Diagnostics Networking and Security Diagnostics Serial Interfacing Diagnostics Serial Interfacing Diagnostics Diagnostics Sleep (Low Power) Sleep (Low Power) Networking and Security Serial Interfacing Diagnostics Networking and Security Diagnostics (Special) 2 1 1 2 2 1 1 2 1 2 1 2 1 1 1 1 1 2 2 1 2 1 2 2 2 2 - 0x0A (10d) 0x01 0 0xFFFF 0xFFFF 0 0 0x40 (64d) 0 0x01 0 0 0 0 0 0 0 0x64 (100d) 0 (disabled) 0x03 0 0xFFFF - * Firmware version in which command and parameter options were first supported. NOTE: AT Commands issued without a parameter value will return the currently stored parameter. © 2014 Digi International Inc. 24 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 4.4. Command Descriptions Commands in this section are listed alphabetically. Command categories are designated between the “< >” symbols that follow each command title. XStream Modems expect numerical values in hexadecimal and those values are designated by a “0x” prefix. AM (Auto-set MY) Command AT Command: ATAM AM Command is Binary Command: 0x3A (58 decimal) used to automatically set the MY (Source Minimum firmware version required: 4.30 Address) parameter from the factory-set modem serial number. The address is formed with bits 29, 28 and 13-0 of the serial number (in that order). AT (Guard Time After) Command AT Command is used to set the time-of-silence that follows the command sequence character (CC Command). By default, AT Command Mode will activate after one second of silence. Refer to the AT Commands section (p19) to view the default AT Command Mode sequence. AT Command: ATAT Binary Command: 0x05 (5 decimal) Parameter Range: 0x02 – 0xFFFF (x 100 milliseconds) Number of bytes returned: 2 Default Parameter Value: 0x0A (10 decimal) Related Commands: BT (Guard Time Before), CC (Command Sequence Character) BD (Interface Data Rate) Command BD Command allows the user to adjust the UART interface data rate and thus modify the rate at which serial data is sent to the RF modem. The new baud rate does not take effect until the CN command is issued. The RF data rate is unaffected by the BD parameter. Most applications will require one of the seven standard baud rates; however, non-standard baud rates are also supported. Note: If the serial data rate is set to exceed the fixed RF data rate of the modem, flow control may need to be implemented in the Flow Control section (p13) of this manual. AT Command: ATBD Binary Command: 0x15 (21 decimal) Parameter Range (Standard baud rates): 0 – 6 (Non-standard baud rates): 0x7D – 0xFFFF BAUD (bps) Parameter Configuration 0 1200 1 2400 2 4800 3 9600 4 19200 5 38400 6 57600 Number of bytes returned: 2 Default Parameter Value: Set to equal to modem’s factory-set RF data rate. Minimum firmware version required: 4.2B (Custom baud rates not previously supported) Non-standard Interface Data Rates: When parameter values outside the range of standard baud rates are sent, the closest interface data rate represented by the number is stored in the BD register. For example, a rate of 19200 bps can be set by sending the following command line "ATBD4B00". NOTE: When using Digi’s XCTU Software, non-standard interface data rates can only be set and read using the XCTU “Terminal” tab. Non-standard rates are not accessible through the “Modem Configuration” tab. When the BD command is sent with a non-standard interface data rate, the UART will adjust to accommodate the requested interface rate. In most cases, the clock resolution will cause the stored BD parameter to vary from the parameter that was sent (refer to the table below). Reading the BD command (send "ATBD" command without an associated parameter value) will return the value that was actually stored to the BD register. Table 4.2. Parameter Sent vs. Parameter Stored BD Parameter Sent (HEX) 0 4 7 12C 1C200 © 2014 Digi International Inc. Interface Data Rate (bps) 1200 19,200 115,200 300 115,200 BD Parameter Stored (HEX) 0 4 7 12B 1B207 25 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 BK (Serial Break Passing) Command Pass a serial break condition on the DI pin to the DO pin of another modem. AT Command: ATBK Binary Command: 0x2E (46 decimal) Parameter Range: 0 – 1 Parameter Configuration 0 disable 1 enable Default Parameter Value: 0 Number of bytes returned: 1 Related Commands: BO (Serial Break Timeout) Minimum Firmware Version Required: 4.30 BO (Serial Break Timeout) Command DO pin will return to default after no serial break status information is received during the timeout period. AT Command: ATBO Use with BK parameter = 1. Default Parameter Value: 0 Binary Command: 0x30 (48 decimal) Parameter Range: 0 – 0xFFFF (x 1 second) Number of bytes returned: 2 Related Commands: BK (Serial Break Passing) Minimum Firmware Version Required: 4.30 BT (Guard Time Before) Command BT Command is used to set the DI pin silence time that must precede the command sequence character (CC Command) of the AT Command Mode Sequence. Refer to the AT Commands section (p19) to view the default AT Command Mode sequence. AT Command: ATBT Binary Command: 0x04 (4 decimal) Parameter Range: 2 – 0xFFFF (x 100 milliseconds) Default Parameter Value: 0x0A (10 decimal) Number of bytes returned: 2 Related Commands: AT (Guard Time After), CC (Command Sequence Character) CB (Connection Duration Timeout) Command Set/Read the maximum amount of time an exclusive connection between a base and remote modem in a point-to-multipoint network is sustained. The remote modem will disconnect when this timeout expires. AT Command: ATCB Binary Command: 0x33 (51 decimal) Parameter Range: 0x01 – 0xFFFF (x 100 milliseconds) Default Parameter Value: 0x28 (4d seconds) Number of bytes returned: 2 Related Commands: CE (Connection Inactivity Timeout), DC (Disconnect), MD (RF Mode) Minimum Firmware Version Required: 4.30 CC (Command Sequence Character) Command CC Command is used to set the ASCII character to be used between Guard Times of the AT Command Mode Sequence (BT+ CC + AT). The AT Command Mode Sequence activates AT Command Mode (from Idle Mode). Refer to the AT Commands section (p19) to view the default AT Command Mode sequence. © 2014 Digi International Inc. AT Command: ATCC Binary Command: 0x13 (19 decimal) Parameter Range: 0x20 – 0x7F Default Parameter Value: 0x2B (ASCII “+” sign) Number of bytes returned: 1 Related Commands: AT (Guard Time After), BT (Guard Time Before) 26 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 CD (DO3 Configuration) Command CD Command is used to redefine the behavior of the DO3 (Data Output 3)/RX LED line. AT Command: ATCD Binary Command: 0x28 (40 decimal) Parameter Range: 0 – 2 Parameter Configuration 0 RX LED 1 Default high 2 Default low 3 (reserved) Assert only when packet addressed to modem sent 4 Default Parameter Value: 0 Number of bytes returned: 1 Minimum Firmware Version Required: 4.2B CE (Connection Inactivity Timeout) Command Set/Read the duration of inactivity that will cause a break in a connection between modems. The base modem will disconnect when no payload has been transferred for the time specified by the CE parameter. AT Command: ATCE Binary Command: 0x34 (52 decimal) Parameter Range: 0 – 0xFFFF (x 10 milliseconds) Default Parameter Value: 0x64 (1d second) Number of bytes returned: 2 Related Commands: CB ( Connection Duration Timeout), DC (Disconnect), MD (RF Mode) Minimum Firmware Version Required: 4.30 CF (Connection Failure Count) Command Set/Read the number of times the base modem expired retries attempting to send a Connection Grant Packet. AT Command: ATCF Set the parameter value to zero to clear the register. Default Parameter Value: 0 Binary Command: 0x35 (53 decimal) Parameter Range: 0 – 0xFFFF Number of bytes returned: 2 Minimum Firmware Version Required: 4.30 CL (Last Connection Address) Command Read the address of the remote modem that last connected to the base modem. A remote modem will return its DT (Destination Address) parameter. AT Command: ATCL Binary Command: 0x39 (57 decimal) Parameter Range: 0 – 0xFFFF (read-only) Number of bytes returned: 2 Minimum Firmware Version Required: 4.30 CM (Connection Message) Command Select whether base sends connect messages to the host when a connection is established. When enabled, a “CONNECTXXXX” string is sent to the host of the base modem. “XXXX” is the MY (Source Address) of the connected remote modem. AT Command: ATCM Binary Command: 0x38 (56 decimal) Parameter Range: 0 – 1 Parameter Configuration 0 enable 1 disable Default Parameter Value: 0 Number of bytes returned: 1 Minimum Firmware Version Required: 4.30 © 2014 Digi International Inc. 27 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 CN (Exit AT Command Mode) Command CN Command is used to explicitly exit AT Command Mode. AT Command: ATCN Binary Command: 0x09 (9 decimal) CO (DO3 Timeout) Command DO3 (Data Output 3) output will return to default after no DI3 (Data Input 3) status information is received during the timeout period. AT Command: ATCO Use with CD = 1 or 2, DR = 1. Number of bytes returned: 2 Binary Command: 0x2F (47 decimal) Parameter Range: 0 – 0xFFFF (x 1 second) Default Parameter Value: 3 Related Commands: CD (DO3 Configuration), DR (DI3 Configuration) Minimum Firmware Version Required: 4.30 CS (DO2 Configuration) Command CS Command is used to select the behavior of the DO2 (Data Output 2) pin signal. This output can provide RS-232 flow control, control the TX enable signal (for RS-485 or RS-422 operations), or set the default level for the I/O line passing function. By default, DO2 provides RS-232 Send) flow control. (Clear-to- AT Command: ATCS Binary Command: 0x1F (31 decimal) Parameter Range: 0 – 4 Parameter Configuration 0 RS-232 flow control 1 RS-485 TX enable low 2 high 3 RS-485 TX enable high 4 low Default Parameter Value: 0 Number of bytes returned: 1 Related Commands: RT (DI2 Configuration), TO (DO2 Timeout) Minimum Firmware Version Required: 4.27D CT (Command Mode Timeout) Command CT Command sets the amount of time before AT Command Mode terminates automatically. After a CT time of inactivity, the modem exits AT Command Mode and returns to Idle Mode. AT Command Mode can also be exited manually using CN (Exit AT Command Mode) Command. AT Command: ATCT Binary Command: 0x06 (6 decimal) Parameter Range: 0x02 – 0xFFFF (x 100 milliseconds) Default Parameter Value: 0xC8 (200 decimal, 20 seconds) Number of bytes returned: 2 DC (Disconnect) Command DC Command is used (when in Multi-Streaming Mode (MD = 1 or 2)) to explicitly force the disconnection of an active exclusive connection. If MD = 1, the base modem will force the disconnection of an exclusive connection. If MD = 2, the remote modem will send a “Disconnect Request Packet” to the base modem. © 2014 Digi International Inc. AT Command: ATDC Binary Command: 0x37 (55 decimal) Related Commands: CB (Connection Duration Timeout), CE (Connection Inactivity Timeout), MD (RF Mode) Minimum Firmware Version Required: 4.30 28 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 DR (DI3 Configuration) Command The DR Command is used to configure the DI3 (Data Input 3 / SLEEP) line for I/O line passing (use with CD = 1 or 2 and CO) or controlling connection status (use with MD = 1 or 2). AT Command: ATDR Binary Command: 0x2D (45 decimal) Parameter Range: 0 – 4 Parameter Configuration 0 Disabled 1 DI3 I/O passing enabled 2 Connect on low 3 Disconnect on high 4 Connect and Disconnect Default Parameter Value: 0 Number of bytes returned: 1 Related Commands: CD (DO3 Configuration), CO (DO3 Timeout), MD (RF Mode) Minimum Firmware Version Required: 4.30 DT (Destination Address) Command DT Command is used to set the AT Command: ATDT networking address of an XStream Modem. Binary Command: 0x00 XStream Modems use three filtration layers – Parameter Range: 0 – 0xFFFF Vendor Identification Number (ATID), Channels (ATHP) and Destination Addresses (ATDT). DT Default Parameter Value: 0 Command assigns an address to a modem that Number of bytes returned: 2 enables it to communicate only with other Related Commands: HP (Hopping Channel), ID modems having the same addresses. All modems (Modem VID), MK (Address Mask) that share the same Destination Address can communicate freely with each other. Modems in the same network with a different Destination Address (than that of the transmitter) will listen to all transmissions to stay synchronized, but will not send any of the data out their serial ports. E0 (Echo Off) Command E0 Command turns off character echo in AT Command Mode. By default, echo is off. AT Command: ATE0 Binary Command: 0x0A (10 decimal) E1 (Echo On) Command E1 Command turns on the echo in AT Command Mode. Each typed character will be echoed back to the terminal when ATE1 is active. E0 is the default. AT Command: ATE1 Binary Command: 0x0B (11 decimal) ER (Receive Error Count) Command Set/Read the receive-error. The error-count records the number of packets partially received then aborted on a reception error. This value returns to 0 after a reset and is not non-volatile (Value does not persist in the modem’s memory after a power-up sequence). Once the “Receive Error Count” reaches its maximum value (up to 0xFFFF), it remains at its maximum count value until the maximum count value is explicitly changed or the modem is reset. © 2014 Digi International Inc. AT Command: ATER Binary Command: 0x0F (15 decimal) Parameter Range: 0 – 0xFFFF Default Parameter Value: 0 Number of bytes returned: 2 Related Commands: GD (Receive Good Count) 29 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 FH (Force Wake-up Initializer) Command FH Command is used to force a Wake-up Initializer to be sent on the next transmit. WR (Write) Command does not need to be issued with FH Command. AT Command: ATFH Binary Command: 0x0D (13 decimal) Use only with cyclic sleep modes active on remote modems. FL (Software Flow Control) Command FL Command is used to configure software flow control. Hardware flow control is implemented with the XStream Modem as the DO2 pin ( ), which regulates when serial data can be transferred to the modem. FL Command can be used to allow software flow control to also be enabled. XON character used is 0x11 (17 decimal). XOFF character used is 0x13 (19 decimal). AT Command: ATFL Binary Command: 0x07 (7 decimal) Parameter Range: 0 – 1 Parameter 0 1 Configuration Disable software flow control Enable software flow control Default Parameter Value: 0 Number of bytes returned: 1 FT (Flow Control Threshold) Command Set/Read the flow control threshold. When FT bytes have accumulated in the DI buffer, is de-asserted or the XOFF software flow control character is transmitted. AT Command: ATFT Binary Command: 0x24 (36 decimal) Parameter Range: 0 – (Receiving modem DO buffer size minus 0x11 bytes) Default Parameter Value: Receiving modem DO Buffer size minus 0x11 Number of bytes returned: 2 Minimum Firmware Version Required: 4.27B GD (Receive Good Count) Command Set/Read the count of good received RF packets. Parameter value is reset to 0 after every reset and is not non-volatile (Value does not persist in the modem’s memory after a power-up sequence). Once the “Receive Good Count” reaches its maximum value (up to 0xFFFF), it remains at its maximum count value until the maximum count value is manually changed or the modem is reset. AT Command: ATGD Binary Command: 0x10 (16 decimal) Parameter Range: 0 – 0xFFFF Default Parameter Value: 0 Number of bytes returned: 2 Related Commands: ER (Receive Error Count) HP (Hopping Channel) Command HP Command is used to set the modem’s hopping channel number. A channel is one of three layers of addressing available to the XStream modem. In order for modems to communicate with each other, the modems must have the same channel number since each network uses a different hopping sequence. Different channels can be used to prevent modems in one network from listening to transmissions of another. © 2014 Digi International Inc. AT Command: ATHP Binary Command: 0x11 (17 decimal) Parameter Range: 0 – 6 Default Parameter Value: 0 Number of bytes returned: 1 Related Commands: DT (Destination Address), ID (Modem VID), MK (Address Mask) 30 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 HT (Time before Wake-up Initializer) Command RR Command specifies the number AT Command: ATRR of retries that can be sent for a given RF packet. Binary Command: 0x18 (24 decimal) Once RR Command is enabled (set to a non-zero Parameter Range: 0 – 0xFF value), RF packet acknowledgements and retries are enabled. After transmitting a packet, the Default Parameter Value: 0 (disabled) transmitter will wait to receive an Number of bytes returned: 1 acknowledgement from a receiver. If the Minimum Firmware Version Required: 4.22 acknowledgement is not received in the period of time specified by the RN (Delay Slots) Command, the transmitter will transmit the original packet again. The packet will be transmitted repeatedly until an acknowledgement is received or until the packet has been sent RR times. Note: For retries to work correctly, all modems in the system must have retries enabled. © 2014 Digi International Inc. 35 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 RS (RSSI) Command RS Command returns the signal level of the last packet received. This reading is useful for determining range characteristics of the XStream Modems under various conditions of noise and distance. AT Command: ATRS Binary Command: 0x1C (28 decimal) Parameter Range: 0x06 – 0x36 (Read-only) Number of bytes returned: 1 Once the command is issued, the modem will Minimum Firmware Version Required: 4.22 return a value between 0x6 and 0x36 where 0x36 represents a very strong signal level and 0x4 indicates a low signal level. RT (DI2 Configuration) Command RT command is used to dictate the behavior of the DI2/ /CMD line. RT Command must be issued to enable flow control or binary programming. AT Command: ATRT Binary Command: 0x16 (22 decimal) Parameter Range: 0 – 2 Parameter Configuration 0 disabled 1 Enable Binary Programming 2 Enable Flow Control Default Parameter Value: 0 Number of bytes returned: 1 RZ (DI Buffer Size) Command The RZ command is used to read the size of the DI buffer (UART RX (Receive)). AT Command: ATRZ Note: The DO buffer size can be determined by multiplying the DI buffer size by 1.5. Parameter Range: Read-only Binary Command: 0x2C (44 decimal) Number of bytes returned: 2 Minimum Firmware Version Required: 4.30 SB (Stop Bits) Command SB Command is used to set/read the number of stop bits in the data packets. AT Command: ATSB Binary Command: 0x36 (54 decimal) Parameter Range: 0 – 1 Parameter Configuration 0 1 stop bits 1 2 stop bits Default Parameter Value: 0 Number of bytes returned: 1 Minimum Firmware Version Required: 4.2B SH (Serial Number High) Command Set/Read the serial number high word of the modem. AT Command: ATSH Binary Command: 0x25 (37 decimal) Parameter Range: 0 – 0xFFFF (Read-only) Number of bytes returned: 2 Related Commands: SL (Serial Number Low) Minimum Firmware Version Required: 4.27C © 2014 Digi International Inc. 36 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 SL (Serial Number Low) Command Set/Read the serial number low word of the modem. AT Command: ATSH Binary Command: 0x26 (38 decimal) Parameter Range: 0 – 0xFFFF (Read-only) Number of bytes returned: 2 Related Commands: SH (Serial Number High) Minimum Firmware Version Required: 4.27C SM (Sleep Mode) Command SM Command is used to adjust Sleep Mode settings. By default, Sleep Mode is disabled and the modem remains continually active. SM Command allows the modem to run in a lower-power state and be configured in one of eight settings. Cyclic Sleep settings wake the modem after the amount of time designated by SM Command. If the modem detects a wake-up initializer during the time it is awake, it will synchronize with the transmitter and start receiving data after the wake-up initializer runs its duration. Otherwise, it returns to Sleep Mode and continue to cycle in and out of inactivity until the Wake-up Initializer is detected. If a Cyclic Sleep setting is chosen, the ST, LH and HT parameters must also be set as described in the “Sleep Modes” section of this manual. Refer to the Sleep Mode sections (p16) for more information. AT Command: ATSM Binary Command: 0x01 Parameter Range: 0 – 8 Parameter Configuration 0 Disabled 1 Pin Sleep 2 4 Serial Port Sleep Cyclic 0.5 second sleep (Modem wakes every 0.5 seconds) Cyclic 1.0 second sleep 5 Cyclic 2.0 second sleep 6 Cyclic 4.0 second sleep 3 7 Cyclic 8.0 second sleep 8 Cyclic 16.0 second sleep Default Parameter Value: 0 Number of bytes returned: 1 Related Commands: For Pin Sleep – PC (Power-up Mode), PW (Pin Wake-up) For Serial Port Sleep – ST (Time before Sleep) For Cyclic Sleep – ST (Time before Sleep), LH (Wake-up Initializer Timer), HT (Time Before Wake-up Initializer), PW (Pin Wake-up) ST (Time before Sleep) Command ST Command sets the period of time (in tenths of seconds) in which the modem remains inactive before entering into Sleep Mode. For example, if the ST Parameter is set to 0x64 (100 decimal), the modem will enter into Sleep mode after 10 seconds of inactivity (no transmitting or receiving). This command can only be used if Cyclic Sleep or Serial Port Sleep Mode settings have been selected using SM (Sleep Mode) Command. © 2014 Digi International Inc. AT Command: ATST Binary Command: 0x02 Parameter Range: 0x10 – 0xFFFF (x 100 milliseconds) Default Parameter Value: 0x64 (100 decimal) Number of bytes returned: 2 Related Commands: SM (Sleep Mode), LH (Wake-up Initializer Timer), HT (Time before Wake-up Initializer) 37 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 SY (Time before Initialization) Command SY Command keeps a communication channel open as long as modem transmits or receives before the active connection expires. It can be used to reduce latency in a query/response sequence and should be set 100 ms longer than the delay between transmissions. AT Command: ATSY Binary Command: 0x17 (23 decimal) Parameter Range: 0 – 0xFF (x 100 milliseconds) Default Parameter Value: 0 (Disabled - channel initialization information is sent with each RF packet.) This command allows multiple XStream Modems to share a hopping channel for a given amount of Number of bytes returned: 1 time after receiving data. By default, all packets include an RF initializer that contains channel information used to synchronize any listening receivers to the transmitter’s hopping pattern. Once a new modem comes within range or is powered on within range, it is able to instantly synchronize to the transmitter and start receiving data. If no new modems are introduced into the system, the synchronization information becomes redundant once modems have become synchronized. SY Command allows the modems to remove this information from the RF Initializer after the initial synchronization. For example, changing the SY Parameter to 0x14 (20 decimal) allows all modems to remain in sync for 2 seconds after the last data packet was received. Synchronization information is not re-sent unless transmission stops for more than 2 seconds. This command allows significant savings in packet transmission time. Warning: Not recommended for use in an interference-prone environment. Interference can break up the session and the communications channel will not be available again until SY time expires. With SY set to zero, the channel session is opened and closed with each transmission - resulting in a more robust link with more latency. TO (DO2 Timeout) Command DO2 output will return to default after no DI2 status information is received during the timeout period. AT Command: ATTO Use with CS = 2 or 4. Default Parameter Value: 3 Binary Command: 0x31 (49 decimal) Parameter Range: 0 – 0xFFFF (x 1 second) Number of bytes returned: 2 Minimum Firmware Version Required: 4.30 TR (Transmit Error Count) Command TR Command records the number of retransmit failures. This number is incremented each time a packet is not acknowledged within the number of retransmits specified by the RR (Retries) Command. It therefore counts the number of packets that were not successfully received and have been dropped. The TR Parameter is not non-volatile and will therefore be reset to zero each time the modem is reset. © 2014 Digi International Inc. AT Command: ATTR Binary Command: 0x1B (27 decimal) Parameter Range: 0 – 0xFFFF Default Parameter Value: 0 Number of bytes returned: 2 Related Commands: RR (Retries) Minimum Firmware Version Required: 4.22 38 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 TT (Streaming Limit) Command TT Command defines a limit on the number of bytes that can be sent out before a random delay is issued. TT Command is used to simulate full-duplex behavior. AT Command: ATTT If a modem is sending a continuous stream of RF data, a delay is inserted which stops its transmission and allows other modems time to transmit (once it sends number of bytes specified by TT Command). Inserted random delay lasts between 1 and “RN + 1” delay slots, where each delay slot lasts 38ms. Default Parameter Value: 0xFFFF (65535 decimal) Binary Command: 0x1A (26 decimal) Parameter Range: 0 – 0xFFFF (0 = disabled) Number of bytes returned: 2 Related Commands: RN (Delay Slots) Minimum Firmware Version Required: 4.22 VR (Firmware Version) Command Read the Firmware Version of the XStream Modem. AT Command: ATVR Binary Command: 0x14 (20 decimal) Parameter Range: 0 – 0xFFFF (Read-only) Number of bytes returned: 2 WR (Write) Command WR Command writes configurable AT Command: ATWR parameters to the modem’s non-volatile memory Binary Command: 0x08 (Parameter values remain in the modem’s memory until overwritten by future use of WR Command). If changes are made without writing them to non-volatile memory, the modem reverts back to previously saved parameters the next time the modem is powered-on. © 2014 Digi International Inc. 39 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 5. RF Communication Modes Network configurations covered in this chapter are described in terms of the following: • Network Topology (Point-to-Point, Point-to-Multipoint or Peer-to-Peer) • RF Communication Type (Basic or Acknowledged) • RF Mode (Streaming, Repeater, Acknowledged or Multi-Streaming) The following table provides a summary of the network configurations supported. Table 5.1. Summary of network configurations supported by the XStream RF Modem Point-to-Point Definition An RF data link between two modems. Sample Network Profile * (Broadcast Communications) Use default values for all modems. Sample Network Profile * (Acknowledged Communications) All Modems: ATAM (auto-set MY (Source Address) parameter) ** ATDT FFFF (set Destination Address to 0xFFFF) Basic Communication RF Modes Streaming Mode (p42), Repeater Mode (p43) Acknowledged Communication RF Mode Acknowledged Mode (p46) Definition RF data links between one base and multiple remotes. Point-to-Multipoint Base: ATMY 0 (set Source Address to 0x00) ATDT FFFF (set Destination Address to 0xFFFF) Remotes: ATAM (auto-set MY (Source Address) parameter) ** ATDT 0 (set Destination Address to 0x00) Base: Sample Network Profile * (Acknowledged Communications) ATMY 0 (set Source Address to 0x00) ATDT FFFF (set Destination Address to 0xFFFF) ATRR 3 (set number of Retries to 3) Remotes: ATAM (auto-set MY (Source Address) parameter) ** ATDT 0 (set Destination Address to 0x00) ATRR 3 (set number of Retries to 3) Basic Communication RF Modes Streaming Mode (p42), Repeater Mode (p43) Acknowledged Communication RF Modes Acknowledged Mode (p46), Multi-Streaming Mode (p48) Definition Modems remain synchronized without use of a master/server. Each modem shares the roles of master and slave. Digi’s peer-to-peer architecture features fast synch times (35ms to synchronize modems) and fast cold start times (50ms before transmission). Sample Network Profile * (Basic Communications) Use default values for all modems. Sample Network Profile * (Acknowledged Communications) All Modems: ATAM (auto-set MY (Source Address) parameter) ** ATDT FFFF (set Destination Address to 0xFFFF) ATRR 3 (set number of Retries to 3) Basic Communication RF Mode Streaming Mode (p42) Acknowledged Communication RF Mode Acknowledged Mode (p46) Sample Network Profile * (Basic Communications) Peer-to-Peer * Assume default values for parameters not listed. Profiles do not reflect addressing implementations. ** AM (Auto-set MY) Command must be issued through a terminal program such as the one incorporated in the XCTU “Terminal” tab. © 2014 Digi International Inc. 40 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 5.1. Addressing Each RF packet contains addressing information that is used to filter incoming RF data. Receiving modems inspect the Hopping Channel (HP parameter), Vendor Identification Number (ID parameter) and Destination Address (DT parameter) contained in each RF packet. Data that does not pass through all three network security layers is discarded (Figure 5.1). Figure 5.1. Filtration layers contained in the RF packet header 5.1.1. Address Recognition Transmissions can be addressed to a specific modem or group of modems using the DT (Destination Address) and MK (Address Mask) parameters. The transmitting modem dictates whether the packet is intended for a specific modem (local address) or multiple modems (global address) by comparing the packet’s DT parameter to its own MK parameter (Figure 5.2). Figure 5.2. Local Packets vs. Global Packets (Transmitting Modem) TX_DT = Transmitter Destination Address TX_MK = Transmitter Address Mask Note: When TX_DT = 0xFFFF (default), RF packets are global and are received by all modems within range. (Receivers do not send ACKs.) A receiving modem will only accept a packet if a packet is addressed to it (either as a global or local packet). The RX modem makes this determination by inspecting the destination address of the RF packet and comparing it to its own address and mask (Figure 5.3). The Destination Address of the TX modem is logically “ANDed” with the Address Mask of the RX modem. Figure 5.3. Address Recognition (Receiving Modem) TX_DT = Transmitter Destination Address RX_DT = Receiver Destination Address RX_MY = Receiver Source Address NOTE: For more information regarding addressing and masks, refer to Application Note “XSTAN004b”. (Located on the Digi Support site at www.digi.com/support). © 2014 Digi International Inc. 41 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 5.2. Basic Communications Basic Communications are accomplished through two sub-types: • Broadcast - By default, XStream Modems communicate through Broadcast communications and within a peer-to-peer network topology. When any modem transmits, all other modems within range will receive the data and pass it directly to their host device. • Addressed - If addressing parameters match, received RF data is forwarded to the DO (Data Out) buffer; otherwise, the RF data is discarded. When using Basic Communications, any functions such as acknowledgements are handled at the application layer by the OEM/integrator. The Broadcast Modes provide transparent communications, meaning that the RF link simply replaces a wired link. 5.2.1. Streaming Mode (Default) Characteristics: Highest data throughput Lowest latency and jitter Reduced immunity to interference Transmissions never acknowledged (ACK) by receiving modem(s) Required Parameter Values (TX Modem): RR (Retries) = 0 Related Commands: Networking (DT, MK, MY), Serial Interfacing (PK, RB, RO, TT) Recommended Use: Mode is most appropriate for data systems more sensitive to latency and/or jitter than to occasional packet loss. For example: streaming audio or video. Streaming Mode Data Flow Figure 5.4. Streaming Mode State Diagram (TX Modem) Events and processes in this mode are common to all of the other RF Communication Modes. NOTE: When streaming data, RB and RO parameters are only observed on the first packet. After transmission begins, the TX event will continue uninterrupted until the DI buffer is empty or the streaming limit (TT Command) is reached. As with the first packet, the payload of each subsequent packet includes up to the maximum packet size (PK Command). The streaming limit (TT Command) is specified by the transmitting modem as the maximum number of bytes the transmitting modem can send in one transmission event. After the TT parameter threshold is reached, the transmitting modem will force a random delay of 1 to RN delay slots (exactly 1 delay slot if RN = 0). Subsequent packets are sent without an RF initializer since receiving modems stay synchronized with the transmitting modem for the duration of the transmission event (from preceding packet information). However, due to interference, some receiving modems may lose data (and synchronization to the transmitting modem), particularly during long transmission events. Once the transmitting modem has sent all pending data or has reached the TT limit, the transmission event ends. The transmitting modem will not transmit again for exactly RN delay slots if the local (i.e. transmitting modem’s) RN parameter is set to a non-zero value. The receiving modem(s) will not transmit for a random number of delay slots between 0 and (RN-1) if the local (i.e. receiving modem’s) RN parameter is set to a non-zero value. These delays are intended to lessen congestion following long bursts of packets from a single transmitting modem, during which several receiving modems may have become ready to transmit. © 2014 Digi International Inc. 42 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 5.2.2. Repeater Mode Characteristics: Self-organizing - No route configuration is necessary Self-healing / Fault-tolerant Low power consumption and Minimized interference Network throughput is determined by number of hops, not by number of repeaters. Multiple repeaters within range of source node count as one hop. Supports “transparent” multi-drop mode or addressed data filtering mode. Duplicate RF packets are automatically filtered out. All packets propagate to every node in the network (filtering rules apply). Broadcast communications - each packet comes out every node exactly once. Addressed communications - all radios see every packet. Only the modem with a matching address will forward it to the DO buffer (UART IN). Data entering the network on any modem is transmitted and forwarded through every repeater modem until it reaches the ends of the network. Each repeater will repeat a packet only once. Constraints: Requires that each modem have a unique MY (Source Address) parameter. System must introduce just one packet at a time to the network for transmission (256 bytes max). Each hop (H) decreases network throughput by a factor of 1/(H+1). Additional repeaters add network redundancy without decreasing throughput. Required Parameter Values (TX Modem): MD = 3 or 4, MY = unique value (can be accomplished by issuing the AM (Auto-set MY) and WR (Write) commands to all modems in the network) Related Commands: Networking (MD, DT, MY, AM), Serial Interfacing (RN, PK, RO, RB) Recommended Use: Use in networks where intermediary nodes are needed to relay data to modems that are beyond the transmission range of the base modem. Theory of Operation OEMs and integrators can extend the effective range and reliability of a data radio system by forwarding traffic through one or more repeaters. Instead of using routing tables and path discovery to establish dynamic paths through a network, the repeater system uses a sophisticated algorithm to propagate each RF packet through the entire network. The network supports RF packets up to 256 bytes. The repeater network can operate using broadcast or addressed communications for multi-drop networks and works well in many systems with no special configuration. When in Repeater Mode, the network repeats each message among all available nodes exactly one time. This mechanism eliminates the need for configuring specific routes. The network is selforganizing and self-healing so that the system is able to receive transmissions in the event of a modem going down. Figure 5.5. © 2014 Digi International Inc. Sample Repeater Network Topology 43 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Repeater Network Configuration A network may consist of End Nodes (EN), End/Repeater Nodes (ERN) and a Base Node (BN). The base node initiates all communications. The repeater network can be configured to operate using Basic Broadcast or Basic Addressed communications. The addressing capabilities of the modems allow integrators to send a packet as a global packet (DT = 0xFFFF) and shift out of every radio in the network (Basic Broadcast). Alternatively, the packet can be sent with a specific DT (Destination Address) parameter so that it is only accepted by a specific remote node (Basic Addressed). Configuration Instruction (Basic Broadcast Communications) Assign each radio modem a unique MY (source) address. (The AM (Auto-set MY) command will configure a unique source address that is based on modem serial number.) Enable Basic Broadcast Communications (DT = 0xFFFF) or Addressed Broadcast Communications (ATDT specifies a specific destination) Configure PK, RO and RB to ensure that RF packet aligns with protocol packet. (ex. PK=0x100, RB=0x100, RO depends on baud rate). Configure one or more repeaters in the system (ATMD = 3). Configure remote nodes as destinations (MD = 4). This will ensure that the remote node waits for the repeater traffic to subside before it transmits a response. The configuration instructions above reflect configuration for a Basic Broadcast Repeater system. To configure a Basic Addressed Repeater system, use the DT (Destination Address) parameter to assign unique addresses to each modem in the network. Algorithm details • Packet ID (PID) is composed of transmitting modem MY address and packet serial number. • Incoming packets with a PID already found in the PID buffer will be ignored. • Each modem maintains a PID buffer 8 deep of previously received packets (managed as FIFO). Packets may be shifted out the serial port and/or repeated depending on the DT parameter contained in the RF packet. Table 5.2. DT (Destination Address) parameter truth table Address Match Send out serial port? Repeat? Global Yes Yes Local Yes No None No Yes Repeat delay based on RSSI A transmitted packet may be received by more that one repeater at the same time. In order to reduce the probability that the repeaters will transmit at the same instant, resulting in a collision and possible data loss; an algorithm has been developed that will allow a variable back-off prior to retransmission of the packet by a repeater. The algorithm allows radios that receive the packet with a stronger RF signal (RSSI) to have the first opportunity to retransmit the packet. The RN (Delay Slots) parameter is used to configure this delay. Set RN=0 (no delays) for small networks with few repeaters or repeaters that are not within range of each other. Set RN=1 for systems with 2 to 5 repeaters that may be within range of each other. The actual length of the delay is computed by the formula: Delay (ms) = L * DS DS = (-41-RSSI)/10*RN)+RandomInt(0,RN) Where L is the length of the transmitted packet in milliseconds, DS is the number of delay slots to wait, RSSI is the received signal strength in dBm, RN is the value of the RN register and RandomInt(A,B) is a function that returns a random integer from A to B-0 © 2014 Digi International Inc. 44 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Response packet delay As a packet propagates through the repeater network, if any node receives the data and generates a quick response, the response needs to be delayed so as not to collide with subsequent retransmissions of the original packet. To reduce collisions, both repeater and end node radios in a repeater network will delay transmission of data shifted in the serial port to allow any repeaters within range to complete their retransmissions. The time for this delay is computed by the formula: Maximum Delay (ms) = L * DS DS = ((-41-(-100))/10)*RN)+RN+1 Where L is the length of the transmitted packet in milliseconds, DS is the number of delay slots to wait, RSSI is the received signal strength in dBm, and RN is the value of the RN register. Use Case - Broadcast Repeater Network Consider modems R1 through R10 each communicating to a PLC using the ModBus protocol and spaced evenly in a line. All ten nodes are configured as “destinations and repeaters” within the scope of Basic Broadcast Communications (MD=3, AM, DT=0xFFFF, PK=0x100, RO=0x03, RB=0x100, RN=1). The Base Host (BH) shifts payload that is destined for R10 to R1. R1 initializes RF communication and transmits payload to nodes R2 through R5 which are all within range of R1. Modems R2 through R5 receive the RF packet and retransmit the packet simultaneously. They also send the data out the serial ports, to the PLC's. Table 5.3. Commands used to configure repeater functions AT Binary AT Command Name Command Command AM 0x3A (58d) Auto-set MY DT 0x00 (0d) Destination Address MD 0x3C (60d) RF Mode MY 0x2A (42d) Source Address RN 0x19 (25d) Delay Slots WR 0x08 (8d) Write Range 0 – 0xFFFF 3-4 0 – 0xFFFF 0 – 0xFF (slots) - # Bytes Returned 2 1 2 1 - Factory Default 0 0 0xFFFF 0 - Bandwidth Considerations Using broadcast repeaters in a network reduces the overall network data throughput as each repeater must buffer an entire packet before retransmitting it. For example: if the destination is within range of the transmitter and the packet is 32 bytes long, the transmission will take 72ms on a 9600 baud XStream modem (much faster modems are available). If that same packet has to propagate through two repeaters, it will take 72ms to arrive at the first repeater, another 72 ms to get to the second and a final 72ms to get to the destination for a total of 216ms. Taking into account UART transfer times (~1ms/byte at 9600 baud), a server to send a 32 byte query and receive a 32 byte response is ~200ms, allowing for 5 polls per second. With the two repeaters in the path, the same query/response sequence would take about 500ms for 2 polls per second. To summarize, this system is sending and receiving 64 bytes 5 times per second for a throughput of 320 bytes per second with no repeaters and 128 bytes per second with 2 repeaters. Generally, the network throughput will decrease by a factor of 1/(R+1), with R representing the number of repeaters between the source and destination. Note that these numbers are absolutely worst case to illustrate how the system would perform in a typical, low bandwidth system. As a counter example the 115kbps 9XTend radio can transfer the same 32 byte packet in 12 ms for a round trip with UART transfer times of ~30ms or 33 polls per second (1066 bytes per second) with no repeaters. With two repeaters the time would be ~100ms round trip time for 10 polls per second or 320 bytes per second network throughput with two repeaters. © 2014 Digi International Inc. 45 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 5.3. Acknowledged Communications 5.3.1. Acknowledged Mode Characteristics: Reliable delivery through positive acknowledgements for each packet Throughput, latency and jitter vary depending on the quality of the channel and the strength of the signal. Recommended Use: Acknowledge Mode configuration is appropriate when reliable delivery is required between modems. If messages are smaller than 256 bytes, use RB and RO commands to align RF packets with application packets. Required Parameter Values (TX Modem): RR (Retries) >= 1 Related Commands: Networking (DT, MK, RR), Serial Interfacing (PK, RN, TT, RO, RB) Table 5.4. Sample Network Profile Modem Parameter Settings (assume default values for parameters not listed) All ATRR A ATRN 5 (set number of Retries to 0x0A) (set number of Delay Slots to 5) Connection Sequence Figure 5.6. Acknowledged Mode State Diagram  After sending a packet while in Acknowledged Mode, the transmitting modem listens for an ACK (acknowledgement). If it receives the ACK, it will either send a subsequent packet (if more transmit data is pending), or will wait for exactly RN random delay slots before allowing another transmission (if no more data is pending for transmission). If the transmitting modem does not receive the ACK within the allotted time, it will retransmit the packet with a new RF initializer following the ACK slot. There is no delay between the first ACK slot and the first retransmission. Subsequent retransmissions incur a delay of a random number of delay slots, between 0 and RN. If RN is set to 0 on the transmitting modem, there are never any back-off delays between retransmissions. Note that during back-off delays, the transmitting modem will go into Idle Mode and may receive RF data. This can have the effect of increasing the back-off delay, as the radio cannot return to RF transmit (or retransmit) mode as long as it is receiving RF data. © 2014 Digi International Inc. 46 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 After receiving and acknowledging a packet, the receiving modem will move to the next frequency and listen for either a retransmission or new data for a specific period of time. Even if the transmitting modem has indicated that it has no more pending transmit data, it may have not received the previous ACK, and so it may retransmit the packet (potentially with no delay after the ACK slot). In this case, the receiving modem will always detect the immediate retransmission, which will hold off the communications channel and thereby reduce collisions. Receiving modems acknowledge each retransmission they receive, but they only pass the first copy of a packet they receive out the UART. RB and RO parameters are not applied to subsequent packets. This means that once transmission has begun, it will continue uninterrupted until the DI buffer is empty or the streaming limit (TT) has been reached. As with the first packet, the payload of each subsequent packet includes up to the maximum packet size (PK parameter). The transmitting modem checks for more pending data near the end of each packet. The streaming limit (TT parameter) specifies the maximum number of bytes that the transmitting modem will send in one transmission event, which may consist of many packets and retries. If the TT parameter is reached, the transmitting modem will force a random delay of 1 to RN delay slots (exactly 1 delay slot if RN is zero). Each packet is counted only once toward TT, no matter how many times the packet is retransmitted. Subsequent packets in acknowledged mode are similar to those in streaming mode, with the addition of an acknowledgement between each packet, and the possibility of retransmissions. Subsequent packets are sent without an RF initializer, as the receiving modems are already synchronized to the transmitting modem from the preceding packet(s) and they remain synchronized for the duration of the transmission event. Each retransmission of a packet includes an RF initializer. Once the transmitting modem has sent all pending data or has reached the TT limit, the acknowledged transmission event is completed. The transmitting modem will not transmit again for exactly RN delay slots, if the local RN parameter is set to a nonzero value. The receiving modem will not transmit for a random number of delay slots between 0 and (RN-1), if the local RN parameter is set to a nonzero value. These delays are intended to lessen congestion following long bursts of packets from a single transmitting modem, during which several receiving modems may have themselves become ready to transmit. © 2014 Digi International Inc. 47 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 5.3.2. Multi-Streaming Mode Characteristics: definition) Enables exclusive connections (refer to Theory of Operation section for Supports the passing of large data streams (> 256 bytes) from multiple remote modems to a base modem (If a complete data stream from a remote modem is less than 256 bytes, data can be sent from several remotes to a base location without enabling this mode and latencies will be much less.) Transmissions never acknowledged (ACK) by receiving modem(s) Required Parameter Values (TX Modem): MD = 1 (Base), MD = 2 (Remote), RN > 0, RR > 0, MY ≠ 0xFFFF Recommended Use: Use this mode in point-to-multipoint networks where remote modems initiate communications and require exclusive (uninterrupted) connections to the base modem. Table 5.5. Sample Network Profile Modem Parameter Settings (assume default values for parameters not listed) Base ATMD 1 (configure modem as Multi-Stream Base) * Remotes ATMD 2 (configure modem as Multi-Stream Remote) * * When Multi-Streaming is enabled, the following parameters are consequently modified (if they have not already been modified from their default states): RR, RN, MY, CD, AT and BT. (refer to Table 5.6) Theory of Operation When in Multi-Streaming Mode, all remote modems can initiate communications with the base modem at the same time, but only one remote is granted an exclusive connection. After an exclusive connection begins, data is transferred exclusively between two modems without interruption from any other modems in the network. An exclusive connection is a bi-directional connection that can only be established when in MultiStreaming Mode. An exclusive connection is immune to other remote modems interrupting the connection and interleaving data (The interleaved data potentially renders the base modem unable to discern from which remote modem the data was transmitted). When an exclusive connection is granted to a single remote, the other remotes are notified that the connection exists. The notification causes the remote modems to postpone transmissions until the base modem sends notification that the exclusive connection has ended. Figure 5.7. Sample Connection Sequence Diagram CRP = Connection Request Packet CGP = Connection Grant Packet DRP = Disconnect Request Packet (not shown in diagram – applicable when remote connection is disconnected using the pin sleep I/O line. DGP = Disconnect Grant Packet ACK = Acknowledgement of reception. Base modem = The central transmitting/receiving modem in a network of modems that maintains communications with remote modems. Remote modem = A modem in a network that sends data to and receives data from a base modem. Payload = Data contained inside the RF Data of the RF Packet that originates from a host to be transmitted over-the-air. In the connection sequence above, an exclusive connection is first granted to “Remote m”. The CGP (Connection Grant Packet) is broadcast to all remote modems in the network to communicate the base in engaged in an exclusive connection. Upon receipt of the CGP notification, remote modems will wait for a DGP (Disconnect Grant Packet) before attempting again to send data to the base modem. © 2014 Digi International Inc. 48 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Initiating a Connection Connection Guidelines: • A remote modem can only request a connection with the base modem. • The base modem may hold off or grant a connection request to another modem. • A remote modem will not try to establish a connection if one already exists. • A connection fails if no response is received after RR (Retries) CRP packets. After a failure, whatever condition was causing a connection to be established is cleared. If the condition was data to be sent, all data in the DI buffer will be flushed. If the condition was DI3 transition, then no connection will be attempted until another correct DI3 transition. • A global connection cannot fail. (Definition is on next page.) Once in Multi-Streaming Mode (MD > 0), several events can initiate an exclusive connection: 1. Remote modem has payload to transmit. After a remote modem receives data from its host, the modem will attempt to establish a connection with the base modem. The connection is defined by the remote’s DT (Destination Address) parameter. If another remote has a connection with the base, no connection will be established until the connection runs its course. Any remotes requesting a connection will then arbitrate for the next connection. RR (Retries) and RN (Random back-off) parameters control this arbitration. 2. Base sets the DT (Destination Address) parameter. When the base modem sets the DT (Destination Address) parameter, an exclusive connection is immediately initiated with the remote modem that has a matching DT parameter. After the DT command is sent (If ATCM=1), the base modem indicates a successful connection with a “CONNECT XXXX” string where "XXXX" is the remote's address. An unsuccessful connection is indicated with an “ERROR” string. If the connection is successful, the modem immediately exits AT Command Mode and data can be sent to and received from the connected remote modem. If an error is returned, the modem stays in AT Command Mode. If a base is connected to a remote when the DT command is executed, the current connection is disconnected before a new connection is created. 3. DI3 pin (pin 2, SLEEP) is asserted (set low). Both base and remote modems can create a connection (defined by the current DT (Destination Address) parameter) when the DI3 pin is asserted (driven high). DR (DI3 Configuration) Command is used to establish this mode. If a remote asserts DI3, a connection request will be sent when no connection is active. If the base asserts DI3, a connection will immediately be established with the remote after any connection. Initiating a Disconnection To disconnect, the base modem sends a DGP (disconnect grant packet). A remote modem can only request a disconnect. The following conditions cause a disconnect: 1. No over-the-air data sent or received for CE (Connection Inactivity Timeout) time. If no overthe-air data is successfully sent (no acknowledgement received) or received (any good packet) for CE time, the connection will be dropped. Only a base modem can detect this condition. Refer to CE Command. 2. Absolute CB (Connection Duration Timeout). The CB parameter defines an absolute timeout. A timer is started on the remote units when a connection is established. When the connection has been active for CB time, the base will close the connection. A remote that detects this condition will automatically disconnect (it will not send a DRP (disconnect request packet)). Remotes that monitor a connection between the base and another remote will disregard any connection after the CB time. Refer to CB Command. 3. DI3 pin (pin 2, SLEEP) is de-asserted (set high). A base or remote modem can cause a disconnect by setting the DI3 line high. If no connection is active, the de-assertion is ignored. A remote will request a disconnect if DI3 is de-asserted and the remote is currently connected the base. Refer to DR (DI3 Configuration) Command. 4. A remote or a base modem receives the ATDC (Disconnect) Command. © 2014 Digi International Inc. 49 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Configuration AT Command Mode AT command mode is used for all commands on base and remote modems. Binary command mode is not available when MD = 1 or 2. The base is in AT command mode when not engaged in an exclusive connection with a remote. No AT Command Mode sequence is needed. When a base modem is connected to a remote modem, the AT Command Mode sequence is used to enter AT command mode. The connection with the remote is maintained. Care should be taken that the CE (Connection Inactivity) timeout does not occur while in AT Command Mode. The remote must use the AT command sequence to enter AT Command Mode. When a connection exists with a base modem, the connection is maintained. Care must be taken that the CB (Connection Duration) timeout does not occur while in AT Command Mode. As of firmware version, 4.30, a faster method is available for entering AT Command Mode. If the BT and AT parameters are set to 0, BT (Guard Time Before) and AT (Guard Time After) times are set to 6 milliseconds. Beware that this will also mean that AT Command Mode cannot be entered by manually typing the AT command sequence (usually “+++”), because the AT time will occur faster than the characters can be typed. Auto Configuration When enabling Multi-Streaming Modes (by setting the MD (RF Mode) parameter to 1 or 2), other parameter values are automatically modified to support the mode. For example, when the MD parameter is changed to 1 or 2, the RR parameter is changed to 0x0A (hex). The modification only occurs if the RR parameter is 0 (its default) before the MD command was executed. If any other value is found for the RR parameter, the RR parameter will not be changed. Auto configuration occurs every time the modem is powered-up. Table 5.6. Auto Configurations Parameter changed when MD = 1 or 2 Condition for modification to take place (default values) Resulting Parameter Value RR (Retries) If RR = 0 RR = 0x0A (10 decimal) RN (Delay Slots) If RN = 0 RN = 5 MY (Source Address) If MY = 0xFFFF (and MD = 2) Unique value based on serial number * CD (DO3 Configuration) If CD = 0 CD = 3 BT (Guard Time Before) If BT = 0x0A BT = 0 AT (Guard Time After) If AT = 0x0A AT = 0 * The system requires that each remote have a unique address. The automatic address is based on the serial number and is not guaranteed unique, although the chances for a duplicate address are 1 in 16,000. No method currently exists for detecting and reassigning duplicate remote addresses. Global Connection The base modem can connect to all remote modems (to send a broadcast message) by connecting with a DT address of 0xFFFF (hex). There will be no acknowledgements from the remote radios and each packet from the base will be sent RR times. A remote cannot send messages to a base during a global connect. The CGP and DGP packets will be sent RR times to begin and end the global connection respectively. The connection can be terminated by CE, CB timers, DI3 or ATDC Command as any other connections. © 2014 Digi International Inc. 50 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Sleep Modes and Connections Cyclic sleep can be used with the remote modems to conserve power. ST “Time before Sleep” Parameter defines how long after a disconnect a remote will stay awake. A modem is not allowed to enter sleep mode when it is engaged in a connection. A modem will wake as defined by SM parameter and check for an RF message. If a message is detected, the modem will stay awake only if the message is a connect message from the base for this modem. DI3 (pin 2) wake-up can be used to wake a remote modem. Usually the connection on DI3 should also be enabled so that a connection is established on wake-up. NOTE: The ST (Time Before Sleep) time must be set long enough to account for the time it could take to make a connection if several remote modems get a connection before a remote’s ST times out. Pin sleep can also be used with a remote modem. A modem will not be allowed into pin sleep while a connection is active. Usually the connection on DI3 (DR = 4) should also be enabled so that a connection is established on wakeup. Pin wake-up could also be used to scan for a connection at an interval not defined by the cyclic sleep modes. I/O Passing and Connections I/O lines can be passed between a remote and base modem by enabling I/O line passing (see the RT, DR, CD, CO, CS, BK, BO commands). When a connection is not active, the output lines on the base and remote modems will be in their default state. When a connection is established, the base and remote output line will be set to reflect the corresponding input lines. Monitoring Connections The DO3 pin (RX LED) can be used to show when a connection is active on both remote and base modems. This is the default condition. This line will be asserted (high) during a connection and de-asserted (low) when there is no connection. A base modem can also be set to send the “CONNECT XXXX” string (where “XXXX” is the connecting modem’s MY (Source Address) parameter) anytime a connection is established. Refer to CM (Connection Message) Command. © 2014 Digi International Inc. 51 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Appendix A: Agency Certifications FCC Certification The XStream RF Modem complies with Part 15 of the FCC rules and regulations. Compliance with the labeling requirements, FCC notices and antenna usage guidelines is required. To fulfill the FCC Certification requirements, the OEM must comply with the following FCC regulations: 1. The system integrator must ensure that the text on the external label provided with this device is placed on the outside of the final product (Refer to Figure A.1 for 900 MHz operations. Refer to Figure A.2 for 2.4 GHz operations). 2. The XStream RF Modem may be used only with Approved Antennas that have been tested with this modem. (Table A.1 or Table A.2) FCC Notices: IMPORTANT: The 9XStream (900 MHz) and 24XStream (2.4 GHz) OEM Modems have been certified by the FCC for use with other products without any further certification (as per FCC section 2.1091). Changes or modifications not expressly approved by Digi could void the user’s authority to operate the equipment. IMPORTANT: OEMs must test their final product to comply with unintentional radiators (FCC section 15.107 and 15.109) before declaring compliance of their final product to Part 15 of the FCC Rules. IMPORTANT: The XStream RF Modems have been certified for remote and base radio applications. If the XStream will be used for portable applications, the device must undergo SAR testing. This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: • Re-orient or relocate the receiving antenna. • Increase the separation between the equipment and receiver. • Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. • Consult the dealer or an experienced radio/TV technician for help. © 2014 Digi International Inc. 52 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 OEM Labeling Requirements Label Warning WARNING The Original Equipment Manufacturer (OEM) must ensure that FCC labeling requirements are met. This includes a clearly visible label on the outside of the final product enclosure that displays the contents shown in the figure below. Figure A.1. Required FCC Label for OEM products containing 9XStream (900 MHz) RF Modem Contains FCC ID: OUR9XSTREAM The enclosed device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference and (2) this device must accept any interference received, including interference that may cause undesired operation. Figure A.2. Required FCC Label for OEM products containing 24XStream (2.4 GHz) RF Modem Contains FCC ID: OUR-24XSTREAM The enclosed device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference and (2) this device must accept any interference received, including interference that may cause undesired operation. Antenna Usage Antenna Warning WARNING: This device has been tested with Reverse Polarity SMA connectors with the antennas listed in Tables A.1 and A.2 of Appendix A. When integrated in OEM products, fixed antennas require installation preventing end-users from replacing them with non-approved antennas. Antennas not listed in the tables must be tested to comply with FCC Section 15.203 (unique antenna connectors) and Section 15.247 (emissions). RF Exposure WARNING: This equipment is approved only for mobile and base station transmitting devices, separation distances of (i) 20 centimeters or more for antennas with gains < 6 dBi or (ii) 2 meters or more for antennas with gains ≥ 6 dBi should be maintained between the antenna of this device and nearby persons during operation. To ensure compliance, operation at distances closer than this is not recommended. The preceding statement must be included as a CAUTION statement in manuals for OEM products to alert users on FCC RF Exposure compliance. Digi radio modems are pre-FCC approved for use in fixed base station and mobile applications. As long as the antenna is mounted at least 20 cm (8 in) from nearby persons, the application is considered a mobile application. If the antenna will be mounted closer than 20 cm to nearby persons, then the application is considered “portable” and requires an additional test performed on the final product. This test is called the Specific Absorption Rate (SAR) testing and measures the emissions from the radio modem and how they affect the person. Over 100 additional antennas have been tested and are approved for use with Digi 900 MHz Radio Modems (including “Mag Mount”, “Dome”, “Multi-path” and “Panel” antennas). Because of the large number of approved antennas, Digi requests that you send specific information about an antenna you would like to use with the modem and Digi will evaluate whether the antenna is covered under our FCC filing. © 2014 Digi International Inc. 53 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 FCC-Approved Antennas Table A.1. Antennas approved for use with 9XStream (900 MHz) RF Modems. Manufacturer Part Number Type Gain Application Min. Separation Distance * * Digi * * Digi Digi Digi Digi * * Digi Digi Digi Digi * * A09-Y8 * * A09-Y11 (FCC pending) A09-F2 A09-F5 A09-F8 * * A09-M7 A09-H A09-HBMM-P5I A09-QBMM-P5I 6.2 dBi 7.2 dBi 8.2 dBi 9.2 dBi 10.2 dBi 11.2 dBi 2.2 dBi 5.2 dBi 8.2 dBi 9.2 dBi 7.2 dBi 7.2 dBi 2.1 dBi 2.1 dBi 1.9 dBi Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 20 cm 1 cm 1 cm * * Yagi Yagi Yagi Yagi Yagi Yagi Omni Direct. Omni Direct. Omni Direct. Omni Direct. Omni Direct. Omni Direct. 1/2 wave antenna 1/2 wave antenna 1/4 wave antenna 1/4 wave integrated wire antenna 1.9 dBi Fixed/Mobile ** 1 cm Table A.2. Antennas approved for use with 24XStream (2.4 GHz) RF Modems. Manufacturer Part Number Type Gain Application Min. Separation Distance * * * * * * * * * * * * * * * * * * Digi Digi * * * Digi Digi Digi Digi Digi * * * * * * * * * * * * * * * * * * * * A24-P8 A24-P13 * * * A24-P19 A24-HABMM-P6I A24-HBMM-P6I A24-HABSM A24-QABMM-P6I A24-Q1 * Yagi Yagi Yagi Yagi Yagi Yagi Yagi Yagi Yagi Omni Direct Omni Direct Omni Direct Omni Direct Omni Direct Omni Direct Omni Direct Omni Direct Omni Direct Panel Panel Panel Panel Panel Panel Dipole Dipole Dipole Monopole Monopole Monopole 6 dBi 8.8 dBi 9 dBi 10 dBi 11 dBi 12 dBi 12.5 dBi 13.5 dBi 15 dBi 2.1 dBi 3 dBi 5 dBi 7.2 dBi 8 dBi 9.5 dBi 10 dBi 12 dBi 15 dBi 8.5 dBi 13 dBi 14 dBi 15 dBi 16 dBi 19 dBi 2.1 dBi 2.1 dBi 2.1 dBi 1.9 dBi 1.9 dBi 1.9 dBi Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** Fixed/Mobile ** 2m 2m 2m 2m 2m 2m 2m 2m 2m 20 cm 20 cm 20 cm 2m 2m 2m 2m 2m 2m 2m 2m 2m 2m 2m 2m 20 cm 20 cm 20 cm 20 cm 20 cm 20cm * FCC-approved antennas not inventoried by Digi – Contact Digi (866) 765-9885 for information. ** Can be approved for portable applications if integrator gains approval through SAR testing © 2014 Digi International Inc. 54 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 IC (Industry Canada) Certification Labeling requirements for Industry Canada are similar to those of the FCC. A clearly visible label on the outside of the final product enclosure must display the following text: Contains Model 9XStream Radio (900 MHz), IC: 4214A-9XSTREAM Contains Model 24XStream Radio (2.4 GHz), IC: 4214A 12008 Integrator is responsible for its product to comply with IC ICES-003 and FCC Part 15, Sub. B Unintentional Radiators. ICES-003 is the same as FCC Part 15 Sub. B and Industry Canada accepts FCC test report or CISPR 22 test report for compliance with ICES-003. © 2014 Digi International Inc. 55 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Appendix B: Development Guide RS-232 Accessories Kit Contents The accessories listed below are included with XStream RF Modems that carry the “-RA” suffix on the product number. For example: Part number “X09-019PKC-RA” includes the listed accessories and part number “X09-019PKC-R” does not. The accessories kit includes hardware and software needed for developing long range wireless links. For testing the modem’s range, Digi recommends the purchase of one RF Modem with the accessories and one without. Table B.1. Accessories Kit Contents Item Qty. Description Part Number Quick Start Guide 1 Familiarizes users with some of the modem’s most important functions. MD0019 CD 1 Contains documentation, software and tools needed for RF operation. MD0030 XStream-PKG-R™ RS-232/485 RF Modem 1 Long Range RF Modem with RPSMA Connector X09… or X19… Antenna 1 RPSMA, 6" Half-Wave, dipole, articulating A09-HASM-675 Serial Loopback Adapter 1 Connects to the female RS-232 (DB-9) serial connector of the Interface Board and can be used to configure the modem to function as a repeater (for range testing) JD2D3-CDL-A NULL Modem Adapter (male-to-male) 1 Connects to the female RS-232 (DB-9) serial connector of the Interface Board and can be used to connect the modem to another DCE (female DB9) device JD2D2-CDN-A NULL Modem Adapter (female-to-female) 1 Used to bypass radios to verify serial cabling is functioning properly JD3D3-CDN-A Male DB-9 to RJ-45 Adapter 1 Facilitates adapting the DB-9 Connector of the Interface Board to a CAT5 cable (male DB9 to female RJ45) JE1D2-CDA-A Female DB-9 to RJ-45 Adapter 1 Facilitates adapting the DB-9 Connector of the Interface Board to a CAT5 cable (female DB9 to female RJ45) JE1D3-CDA-A Power Adapter 1 Allows Interface Board to be powered by a 110 Volt AC power supply JP4P2-9V10-6F RS-232 Cable (6’) 1 Connects interface board to devices having an RS-232 serial port JD2D3-CDS-6F © 2014 Digi International Inc. 56 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Adapters The XStream Development Kit comes with several adapters that support the following functions: • Performing Range Tests (Serial Loopback) • Connecting to other RS-232 DCE and DTE devices (Male-to-Male NULL modem) • Testing Cables (Female-to-Female NULL modem) • Connecting to terminal blocks or RJ-45 (for RS-485/422 devices) Serial Loopback Adapter Part Number: JD2D3-CDL-A (Red, DB-9 M-F) The serial loopback adapter is used for range testing. During a range test, the serial loopback adapter configures the radio modem to function as a repeater by looping serial data back into the radio for retransmission. Figure B.1. Serial loopback adapter and pinouts NULL Modem Adapter (male-to-male) Part Number: JD2D2-CDN-A (Black, DB-9 M-M) The male-to-male NULL modem adapter is used to connect two DCE devices. A DCE device connects with a straight-through cable to the male serial port of a computer (DTE). Figure B.2. Male NULL modem adapter and pinouts Figure B.3. Example of a Digi Radio Modem (DCE Device) connecting to another DCE device) NULL Modem Adapter (female-to-female) Part Number: JD3D3-CDN-A (Gray, DB-9 F-F) The female-to-female NULL modem adapter is used to verify serial cabling is functioning properly. To test cables, insert the female-to-female NULL modem adapter in place of a pair of modem assemblies (XIB-R-R interface board + XStream Modem) and test the connection without radio modems in the connection. Figure B.4. Female NULL modem adapter and pinouts For use in RS-485/422 systems: DB-9 to RJ-45 adapters are illustrated in the RS-485/422 Connection Guidelines section. © 2014 Digi International Inc. 57 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Antennas (Refer to Appendix A for a list of FCC-Approved Antennas) Factors that determine wireless link range: • Ambient RF noise (interference) • Line-of-sight obstructions • Transmit power • Receive sensitivity • Antenna configuration • XStream Antenna Connector Options To comply with the FCC rules and obtain a “modular” certification, it is required that XStream Modems utilize a “non-standard” connector. This is to ensure the modems are used only with approved antennas. RPSMA The Reverse Polarity SMA (RPSMA) connector uses the same body as a regular SMA connector. In order to be a “non standard” connector, the gender of the center conductor is changed. The female RPSMA actually has a male center conductor. Antenna Cables RF cables are typically used to connect a radio installed in a cabinet to an antenna mounted externally. As a general rule, it is best to keep the RF cable as short as possible. All cables promote signal loss which is usually measured in dB loss per 100 ft. Digi provides LMR-195 rated cables. Common cables and dB losses are included in this table: Table B.2. Potential Signal Strength Loss due to Antenna Cable Length Cable Type Loss at 900 MHz per 100’ (loss per 100m) Loss at 2.4 GHz per 100’ (loss per 100m) Diameter RG-58 14.5 dB (47.4 dB) 25.3 dB (83.2 dB) 0.20” (4.95 mm) RG-174 25.9 dB (85.0 dB) 44.4 dB (145.8 dB) 0.10” (2.54 mm) RG-316 24.7 dB (81.0 dB) 42.4 dB (139.0 dB) 0.10” (2.59 mm) LMR-195 11.1 dB (36.5 dB) 19.0 dB (62.4 dB) 0.20” (4.95 mm) LMR-240 7.6 dB (24.8 dB) 12.9 dB (42.4 dB) 0.24“ (6.10 mm) LMR-600 2.5 dB (8.2 dB) 4.4 dB (14.5 dB) 0.59” (15.0 mm) © 2014 Digi International Inc. 58 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Appendix C: Additional Information 1-Year Warranty XStream RF Modems from Digi International Inc. (the "Product") are warranted against defects in materials and workmanship under normal use, for a period of 1-year from the date of purchase. In the event of a product failure due to materials or workmanship, Digi will repair or replace the defective product. For warranty service, return the defective product to Digi, shipping prepaid, for prompt repair or replacement. The foregoing sets forth the full extent of Digi's warranties regarding the Product. Repair or replacement at Digi's option is the exclusive remedy. THIS WARRANTY IS GIVEN IN LIEU OF ALL OTHER WARRANTIES, EXPRESS OR IMPLIED, AND DIGI SPECIFICALLY DISCLAIMS ALL WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL DIGI, ITS SUPPLIERS OR LICENSORS BE LIABLE FOR DAMAGES IN EXCESS OF THE PURCHASE PRICE OF THE PRODUCT, FOR ANY LOSS OF USE, LOSS OF TIME, INCONVENIENCE, COMMERCIAL LOSS, LOST PROFITS OR SAVINGS, OR OTHER INCIDENTAL, SPECIAL OR CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE PRODUCT, TO THE FULL EXTENT SUCH MAY BE DISCLAIMED BY LAW. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES. THEREFOR, THE FOREGOING EXCLUSIONS MAY NOT APPLY IN ALL CASES. This warranty provides specific legal rights. Other rights which vary from state to state may also apply. Ordering Information Figure C.1 Digi RF Modem Part Numbers Key © 2014 Digi International Inc. 59 XStream-PKG-R™ RS-232/485 RF Modem – Product Manual v5.x00 Contact Digi If you need assistance, contact technical support: Documentation: www.digi.com/support/ Technical Support: Phone Online © 2014 Digi International Inc. (866) 765-9885 toll-free U.S. and Canada (801) 765-9885 Worldwide 8:00 am – 5:00 pm (U.S. Central Time) www.digi.com/support/eservice 60
X24-009PKT-RA 价格&库存
很抱歉,暂时无法提供与“X24-009PKT-RA”相匹配的价格&库存,您可以联系我们找货
