DKS-CRIMP-T1
Professional All-Purpose Crimping
Hand Tool with Dies
Product Highlights
Easy Handling
Ratchet Release
Ergonomic design
Specifications:
Length:
Width:
Depth:
Weight:
Packaging:
Approx. 220mm
Approx. 80mm
Approx. 24mm
Approx. 510 grams
Box
Conforms to the following Industry Standards:
ROHS Compliant
Yes
Die Compatibility
Die Part Number
DKS-DIE-1
DKS-DIE-2
DKS-DIE-3
DKS-CRIMP-T1
Application Range
Wire end ferrules with or without plastic
shroud acc. to DIN 46228
Red/blue/yellow DIN cable lugs, pin cable
lugs, tabs and receptacles, circular
connectors and receptacles, and butt and
parallel connectors.
Non-insulated cable lugs, closed barrel
Crimp tool with DKS-DIE-1, DKS-DIE-2, and
DKS-DIE-3
Page 1 of 1
www.digikey.com
Cross Section
0.14-10mm²
Red: 0.5-1.5mm² / AWG 20 – 16
Blue: 1.5-2.5mm² / AWG 16 – 14
Yellow: 4.0-6.0mm² / AWG 12 – 10
0.1-10mm² / AWG 26 – 8
很抱歉,暂时无法提供与“DKS-DIE-2”相匹配的价格&库存,您可以联系我们找货
