电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
DKS-SOLDERBREAD-02
DKS-SOLDERBREAD-02
    DIGI-KEYELECTRONICS(得捷电子)
    模拟板,通用 带镀层通孔(PTH) 5孔焊盘(双面) 0.100"(2.54mm)
DKS-SOLDERBREAD-02 数据手册
1 SOLDERBREAD#02-ND A Perfboard with a solderless breadboard format. Back Side: Numbers are Reversed to Match the Rows Plating Pitch ENIG (Nickel Plated Gold) Plated Through Hole (PTH) 0.1” (2.54mm) Solder Hole Diameter 0.04" (1.00mm) Mounting Hole Diameter 0.12” (3.00mm) Size / Dimension Board Thickness Material Page Page Page Page 2 3 4 5 3.20"L x 2.00"W (81.3mm x 50.8mm) 0.063" (1.60mm) FR4 Epoxy Glass Board and Mounting Hole Dimensions Dimensions of SMT & Regular Pad Gaps and LED Example The Cast of Parts Used How to Solder Two Terminal SMT Parts Rev. November 2022 2 Mounting holes are 3mm Overall Dimensions Rev. November 2022 Special Pads for Surface Mount (SMT) 0201 and Up 3 And for Bridge Neighboring Nets at Each End (scraping the mask away first will help). These blocks for reference These LEDs were hand soldered as a test. • Hand Soldering 0201 parts should be avoided, but it can be done. • Rev. November 2022 The LEDs were powered in series at 10mA 4 Parts used: 0805 (2012 Metric) 732-4982-1-ND Blue – 3.2V (Typ) – 2.00mm x 1.25mm 0603 (1608 Metric) 3147-B1911USD-20D000114U1930CT-ND Red – 2V (Typ) – 1.60mm x 0.80mm 0402 (1005 Metric) 732-11990-1-ND Green – 3.2V (Typ) – 1.00mm x 0.50mm – Very bright, even at 1 mA 0201 (0603 Metric) 754-2027-1-ND Orange – 2V (Typ) – 10mA – 0.65mm x 0.35mm A Bonus LED - Lit in series at 5mA 1214-MP-1616-2103-PGCT-ND A 6V (Typ) ‘Green’ (Created by down-converting blue via phosphor like white LEDs are made) At 148lm/W, this little 1.60mm² package puts out a lot of green-white light, so even with a few milliamps; it can be a unique indicator. Be warned- their polarity markings are not obvious Rev. November 2022 5 How to Solder Two Terminal SMT Parts: 1. Place your part on pads (0603 used here) 2. Add flux to one side of part and pad 3. Add solder to your iron 4. Hold the part with tweezers 5. Touch iron to ‘fluxed’ pad 6. Turn board around and repeat. 7. Clean flux off 0201 shown for scale next to the Registered Trademark symbol on the board. Rev. November 2022 6 Errata: The first revision had the + and – reversed at the top. Rev. November 2022
DKS-SOLDERBREAD-02 价格&库存
很抱歉,暂时无法提供与“DKS-SOLDERBREAD-02”相匹配的价格&库存,您可以联系我们找货
