DKS-SOLDERBREADBOX1
DKS-SOLDERBREADBOX1
    DIGI-KEYELECTRONICS(得捷电子)
    模拟板,通用 带镀层通孔(PTH) 一孔一焊盘(圆形) 0.100"(2.54mm)
DKS-SOLDERBREADBOX1 数据手册
1 SOLDERBREADBOX1-ND A Variant of the Original SOLDERBREAD#02-ND Made Specifically for the Box 377-2068-ND from Bud Industries Back Side Shown (Numbers are Reversed to Match the Front) Plating Pitch ENIG (Nickel Plated Gold) Plated Through Hole (PTH) 0.1” (2.54mm) Solder Hole Diameter 0.04" (1.00mm) Mounting Hole Diameter 0.12” (3.00mm) Size / Dimension Board Thickness Material Page Page Page Page Rev. OCT 2022 2 3 4 5 3.13"L x 1.97"W (79.6mm x 49.9mm) 0.063" (1.60mm) FR4 Epoxy Glass Board and Mounting Hole Dimensions Dimensions of SMT & Regular Pad Gaps and LED Example The Cast of Parts Used How to Solder Two Terminal SMT Parts 2 Center Mounting Holes are 3mm Diameter Overall Dimensions Rev. OCT 2022 3 Surface Mount (SMT) size 0201 and larger. Bridge neighboring nets using the special pads at each end of the numbered nets. These blocks are to scale for reference These LEDs were hand soldered as a test.  Hand Soldering 0201 parts should be avoided, but it can be done. The LEDs were powered in series at 10mA Rev. OCT 2022 4 Parts used: 0805 (2012 Metric) 732-4982-1-ND Blue – 3.2V (Typ) – 2.00mm x 1.25mm 0603 (1608 Metric) 3147-B1911USD-20D000114U1930CT-ND Red – 2V (Typ) – 1.60mm x 0.80mm 0402 (1005 Metric) 732-11990-1-ND Green – 3.2V (Typ) – 1.00mm x 0.50mm – Very bright, even at 1 mA 0201 (0603 Metric) 754-2027-1-ND Orange – 2V (Typ) – 10mA – 0.65mm x 0.35mm A Bonus LED - Lit in series at 5mA 1214-MP-1616-2103-PGCT-ND A 6V (Typ) ‘Green’ (Created by down-converting blue via phosphor like white LEDs are made) At 148lm/W, this little 1.60mm² package puts out a lot of green-white light, so even with a few milliamps; it can be a unique indicator. Be warned- their polarity markings are not obvious Rev. OCT 2022 5 How to Solder Two Terminal SMT Parts: 1. Place your part on pads (0603 used here) 2. Add flux to one side of part and pad 3. Add solder to your iron 4. Hold the part with tweezers 5. Touch iron to ‘fluxed’ pad 6. Turn board around and repeat. 7. Clean flux off 0201 shown for scale next to the Registered Trademark symbol on the board. Rev. OCT 2022
DKS-SOLDERBREADBOX1 价格&库存
很抱歉,暂时无法提供与“DKS-SOLDERBREADBOX1”相匹配的价格&库存,您可以联系我们找货
