410-388
410-388
    DIGILENT(迪芝伦)
    SCREW TERMINAL ADAPTER FOR OPENL
410-388 数据手册
  Screw Terminal Adapter for OpenLogger  SKU: 410‐388    Product Description  Screw terminals are a common and handy connection method for data logging. The Screw  Terminal Adapter provides screw terminal block access to the eight analog inputs, 8 digital  I/O, waveform generator, power supplies, and ground signals on the OpenLogger. The trigger  pins, prog, and reset signals are broken out into male pin headers. The Screw Terminal  Adapter is designed to attach on top of the OpenLogger so that the OpenLogger stays  compact, and can be used with the OpenLogger in it's acrylic case. What's  Included:    Screw Terminal Adapter for OpenLogger  Custom Digilent protective packaging  OpenLogger Screw Terminal Adapter The OpenLogger Screw Terminal Adapter is intended to be used with the Digilent OpenLogger to provide external connections to the OpenLogger via screw terminal adapters for more readily accessible inputs. The Screw Terminal Adapter connects directly on top of the OpenLogger to maintain a small form factor. Features   Standard Screw Terminal Adapters for easy connectivity Designed to fit directly on top of the OpenLogger  Physical Dimensions The long side of the Screw Terminal Adapter for the Openlogger is 2.838 inches (72.1 mm) and the short side of the PCB is 2.2835 inches (58 mm) in length. Functional Description The OpenLogger Screw Terminal Adapter provides screw terminals for each analog input and each digital pin, with an analog ground pin to pair with each analog input. A screw terminal pair for the 5V power supply from the OpenLogger is available in the center of the board as well as additional headers for access to a few of the OpenLogger specific pins. Pinout Diagram Primary connector West Screw Terminals  North Screw Terminals  1  GPIO3  2  GPIO7  DC2  DC Output 2  DIO0  GPIO 0  3  GPIO2  4  GPIO6  GND  Digital Ground  DIO1  GPIO 1  5  GPIO1  6  GPIO5  DC1  DC Output 1  DIO2  GPIO 2  7  GPIO0  8  GPIO4  WGEN  Waveform  Generator  DIO3  GPIO 3  Primary connector West Screw Terminals  North Screw Terminals  9  DC 2  10  GND  AI8+  Analog Input 8  DIO4  GPIO 4  11  DC 1  12  GND  AGND  Analog Ground  DIO5  GPIO 5  13  Wavegen  14  GND  AI7+  Analog Input 7  DIO6  GPIO 6  15  Reserved  16  Reserved  AI6+  Analog Input 6  DIO7  GPIO 7  17  Reset  18  PROG  19  +5V  20  GND  AGND  Analog Ground  5V  5V Output  21  AI8+  22  AGND8  AI5+  Analog Input 5  GND  Digital Ground  23  AI7+  24  AGND7  AI4+  Analog Input 4  25  AI6+  26  AGND6  AGND  Analog Ground  TRG  OUT  Trigger Output (unused)  27  AI5+  28  AGND5  AI3+  Analog Input 3  TRG  IN  Trigger Input (unused)  29*  AI4+  30  AGND4  AI2+  Analog Input 2  PROG  Program Button  BTN  31*  AI3+  32  AGND3  AGND  Analog Ground  RESET  Reset Button  BTN  South Screw Terminals  Center Screw Terminals  Center Pin Headers  Primary connector 33  AI2+  34  AGND2  35  AI1+  36  AGND1  West Screw Terminals  AI1+  Analog Input 1  North Screw Terminals  GND  Digital Ground    *Note – pin 29 is mislabeled as pin 31 on the silkscreen in Rev A of the Screw Terminal Adapter            https://store.digilentinc.com/screw‐terminal‐adapter‐for‐openlogger/7‐16‐19
410-388 价格&库存
很抱歉,暂时无法提供与“410-388”相匹配的价格&库存,您可以联系我们找货
  • 1+264.558371+34.24433
