471-031
471-031
    DIGILENT(迪芝伦)
    ANALOG DISCOVERY STUDIO WITH BNC
471-031 数据手册
    Analog Discovery Studio: A portable circuits laboratory for  every student    What is the Analog Discovery Studio?  The Analog Discovery Studio is a fully functional, portable test and measurement device that can  turn any cross‐functional space into a pop‐up electronics laboratory. Equipped with 13 instruments,  including an Oscilloscope, Logic Analyzer, Spectrum Analyzer, Waveform Generator, and more; the  Analog Discovery Studio provides an entire stack of bench‐top instruments with a convenient,  replaceable, and breadboardable interface, perfect for enabling student learning anywhere!  With lab spaces decreasing and student enrollment increasing, many institutions are choosing studio  learning as a supplement to traditional laboratories, creating a need for a portable test and  measurement bench that can support all types of circuits projects. With an Analog Discovery Studio,  students can continue their hands‐on learning in the library, office hours, a tutoring center, a  classroom, or even in a coffee shop.  The Analog Discovery Studio supports hands‐on learning for any student, and is available with free  Mac, Linux, and Windows compatible software, WaveForms.     What is WaveForms?  WaveForms is the free software application for the Analog Discovery Studio and enables use of  the available analog and digital instruments. The software has been refined by customer  feedback for over 10 years and features a computer and laptop friendly user interface that has  the feel of traditional benchtop software. The Analog Discovery Studio communicates with  WaveForms via a USB connection to your computer, allowing users to capture, record, analyze,  and generate mixed signal and mixed domain waveforms. WaveForms can be downloaded and  installed in under 60 seconds and can be tested without hardware using its demo mode  feature. In addition to the use of instruments in the application, WaveForms has a script editor  tool, which allows custom scripting of the instrument in JavaScript.   Operating system compatibility  WaveForms is designed to be run on a laptop or desktop computer and is Mac, Windows, and  Linux compatible.      Features:   Analog Inputs:  Analog Outputs:    Used in the Oscilloscope, Network Analyzer,  Spectrum Analyzer, Voltmeter, Impedance  Analyzer, and Data Logger  Two analog input channels, accessible  through BNC or MTE connectors  Channel type: differential (with MTE) or  single‐ended (with BNC)  Analog bandwidth with BNC cables: 30+  MHz @ 3dB  Analog bandwidth with MTE flywires: 9 MHz  @ 3dB  Input range ±25 V (±50 V diff)  Input protected to ±50 V  14‐bit resolution  Operate at 100 MS/s              Used in the Waveform Generator and  Network Analyzer  Two arbitrary waveform generator  channels, accessible through BNC or MTE  connectors  AC amplitude (max): ±5 V  Analog bandwidth (BNC or MTE connectors:  8 MHz @ 3dB)  Operate at 100 MS/s  Digital Inputs and Outputs:  Power Supplies:        Used in the Logic Analyzer, Pattern  Generator, Protocol Analyzer, and Digital  I/O  Channels: 16  Input logic standard: LVCMOS (1.8/3.3V, 5V  tolerant)  Output logic standard: LVCMOS (3.3V,  12mA)        12 volt supply: 12V ±5%; 0.2 Amps max  ‐12 volt supply: ‐12V ±5%, 0.2 Amps max  5 volt supply: 5.0V ±5%; 1.0 Amps max  3.3 volt supply: 3.3V ±5%; 1.0 Amps max    V+ and V‐ rails: 1V to 5V (V+), and ‐1V to ‐5V  (V‐)   Maximum power output: 2.1W for each  supply   Maximum current output: 700mA for  each supply.    Software Compatibility:     Along with the stable WaveForms application, the Analog Discovery Studio is also a programmable  USB oscilloscope and logic analyzer. For more advanced users who require building applications or  automated test, WaveForms Software Development Kit (SDK) is also provided. The WaveForms SDK  provides libraries and examples for creating custom application in Python, C++, C#, and Visual Basic.  Additional 3rd party toolbox support, examples, and documentation is available for MATLAB and  LabVIEW from MathWorks and National Instruments, respectively. Perfect for comparing simulation  and actual results.  More information on specific operating system and programming language details can be found on  the WaveForms resource center. Questions about compatibility and operating systems should be  directed to the Digilent Forum.           Physical Design:  The Analog Discovery Studio is designed to  be a compact alternative to a stack of  benchtop equipment. Its durable enclosure  measures 1.25 x 9.25 x 7.5 inches and fits  on a bench, desktop, or backpack.  Students can access the Oscilloscope and  Waveform Generators via breadboardable  MTE cables, or industry standard BNC  cables, and the Logic Analyzer, Pattern  Generator, and Triggers can be accessed  via MTE cables.   Circuits or designs can be built on the  included, magnetically connected  Breadboard Canvas and conveniently  swapped out or removed for transit,  making the transition from working in the  lab to working at home as seamless as  possible. The Breadboard Canvas also  includes power supply outputs controlled  by physical switches, common I/O built‐in,  and a large breadboardable surface. The  Breadboard Canvas and the cost‐optimized  Blank Canvas can be purchased separately  in the event that an extra is needed, or if  the breadboards wear out.   The Analog Discovery 2 is an alternative  option to the Analog Discovery Studio if a  pocket‐sized or USB‐powered device is  needed.         What's  Included:  Analog Discovery Studio (410-384): Analog Discovery Studio Bundle contents (471-031):           Analog Discovery Studio  Breadboard Canvas  15 V 2.4A power supply  USB A to B cable  A set of Analog Discovery  Studio MTE Cables    Analog Discovery Studio  Breadboard Canvas  15 V 2.4A power supply  USB A to B cable  A set of Analog Discovery  Studio MTE Cables  Two BNC to mini‐grabber  cables  A set of two BNC to  oscilloscope probes                                                       https://store.digilentinc.com/analog‐discovery‐studio‐a‐portable‐circuits‐laboratory‐for‐every‐student//7‐17‐1
471-031 价格&库存
很抱歉,暂时无法提供与“471-031”相匹配的价格&库存,您可以联系我们找货
