Blank Canvas
SKU:
410‐391 Blank Canvas
SKU:
471‐032 Add two solderless breadboards
The Blank Canvas provides a large prototyping surface for the Analog Discovery Studio and
connections to the six power supplies (3.3V, 5V, ±12V, ± variable). The large prototyping surface
has been wired in the configuration of two standard breadboards with 3 power rails for
convenience. The connections to the power supplies are available as copper pads that can be
soldered on directly, or the included power supply breadboard can be soldered on for a
solderless connection. Eleven breakouts are provided at the top of the board for common IC
package types. Two solderless breadboards can be optionally added to provide a solderless
breadboard surface.
Note: The two optional solderless breadboards come unattached and can be affixed via the
included sticky back. Once they are attached they cannot be removed. The power supply
breadboard is included (not attached) and can be soldered on.
Blank Canvas:
What's
Included:
Blank Canvas
2x12 power breadboard
(not attached)
Plastic Canvas Case
Blank Canvas with
Breadboard:
Blank Canvas
(not attached)
Plastic Canvas Case
Regular‐sized breadboard
with two power rails
with one power rail
Blank Canvas Reference Manual
The Blank Canvas provides solderable breakouts for the power supplies on the Analog Discovery
Studio, and a large solderable prototyping surface. The prototyping surface is comprised of
copper through‐holes wired together in the same fashion as two regular sized breadboards, and
3 power rails. The power supply breakouts can be soldered on directly, or the included power
supply breadboard can be soldered on to provide a breadboardable surface. The top of the
board includes eleven IC breakouts for common package types. Solderless breadboards can be
affixed to the prototyping surface in the event that a breadboardable area is desired.
Mechanical Design
The Blank Canvas is designed to connect to the Analog Discovery Studio via standoffs. Magnets
are located within each of the holes that the standoffs slot into in order to hold the Canvas in
place. The Blank Canvas can be removed from the Analog Discovery Studio and swapped out
with other canvases.
Warning! Do not swap out Canvases while the Analog Discovery Studio is turned on.
Prototyping Surface
The prototyping surface of the Blank Canvas is wired like two regular‐sized breadboards with
three power rails. Breadboards can be attached to the surface if desired, but once attached,
The power rail rows are each labeled + or ‐, and are electrically connected as in a breadboard
power rail. The breadboard columns are numbered, and the five or six pins making up column
are electrically connected. The breadboard rows are labeled A through L.
IC Breakouts
The Analog Discovery Studio Blank Canvas features through‐hole breakouts for a variety of
common surface mount component footprints.
One breakout of each footprint in the following list are included: SC89, SC70, SOT23, SOT89,
SOT23‐6, MSP8, DFN10, SOIC8 SO8, TSSOP16, SOIC16, QFN32 TQFP32.
Power Supplies
The Analog Discovery Studios fixed and variable power supply rails are exposed via through‐
holes.
The two variable power pins, labeled V+ and V‐, are connected to the Analog Discovery Studio's
programmable power supplies. They can be programmed to voltage levels from 1 to 5V (V+)
and ‐1 to ‐5V (V‐) through the use of WaveForms' Power Supplies instrument.
Four fixed supplies are available, +12V, ‐12V, 5.0V, and 3.3V.
A small labeled breadboard that can be soldered to the Blank Canvas's power supply pins, if
desired, comes in the box with the Blank Canvas.
Since each power supply is sourced directly from the Analog Discovery Studio, the minimum
and maximum current and power available for each supply depends on the Analog Discovery
Studio's specifications. See the Analog Discovery Studio Specifications for more information.
https://store.digilentinc.com/blank‐canvas//7‐17‐19
很抱歉,暂时无法提供与“410-391”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+478.29713
- 5+468.73722
- 国内价格 香港价格
- 1+547.611201+70.89150
- 5+536.665905+69.47450
