471-032
471-032
    DIGILENT(迪芝伦)
    无焊剂试验电路板 端子条(无框架)
471-032 数据手册
    Blank Canvas  SKU:  410‐391 Blank Canvas    SKU:  471‐032 Add two solderless breadboards    The Blank Canvas provides a large prototyping surface for the Analog Discovery Studio and  connections to the six power supplies (3.3V, 5V, ±12V, ± variable). The large prototyping surface  has been wired in the configuration of two standard breadboards with 3 power rails for  convenience. The connections to the power supplies are available as copper pads that can be  soldered on directly, or the included power supply breadboard can be soldered on for a  solderless connection. Eleven breakouts are provided at the top of the board for common IC  package types. Two solderless breadboards can be optionally added to provide a solderless  breadboard surface.    Note: The two optional solderless breadboards come unattached and can be affixed via the  included sticky back. Once they are attached they cannot be removed. The power supply  breadboard is included (not attached) and can be soldered on.        Blank Canvas:   What's  Included:   Blank Canvas  2x12 power breadboard  (not attached)  Plastic Canvas Case  Blank Canvas with Breadboard:        Blank Canvas  2x12 power breadboard  (not attached)  Plastic Canvas Case  Regular‐sized breadboard  with two power rails  Regular‐sized breadboard  with one power rail  Blank Canvas Reference Manual  The Blank Canvas provides solderable breakouts for the power supplies on the Analog Discovery  Studio, and a large solderable prototyping surface. The prototyping surface is comprised of  copper through‐holes wired together in the same fashion as two regular sized breadboards, and  3 power rails. The power supply breakouts can be soldered on directly, or the included power  supply breadboard can be soldered on to provide a breadboardable surface. The top of the  board includes eleven IC breakouts for common package types. Solderless breadboards can be  affixed to the prototyping surface in the event that a breadboardable area is desired.  Mechanical Design  The Blank Canvas is designed to connect to the Analog Discovery Studio via standoffs. Magnets  are located within each of the holes that the standoffs slot into in order to hold the Canvas in  place. The Blank Canvas can be removed from the Analog Discovery Studio and swapped out  with other canvases.  Warning! Do not swap out Canvases while the Analog Discovery Studio is turned on.  Prototyping Surface  The prototyping surface of the Blank Canvas is wired like two regular‐sized breadboards with  three power rails. Breadboards can be attached to the surface if desired, but once attached,  they cannot be removed.  The power rail rows are each labeled + or ‐, and are electrically connected as in a breadboard  power rail. The breadboard columns are numbered, and the five or six pins making up column  are electrically connected. The breadboard rows are labeled A through L.    IC Breakouts  The Analog Discovery Studio Blank Canvas features through‐hole breakouts for a variety of  common surface mount component footprints.  One breakout of each footprint in the following list are included: SC89, SC70, SOT23, SOT89,  SOT23‐6, MSP8, DFN10, SOIC8 SO8, TSSOP16, SOIC16, QFN32 TQFP32.    Power Supplies  The Analog Discovery Studios fixed and variable power supply rails are exposed via through‐ holes.  The two variable power pins, labeled V+ and V‐, are connected to the Analog Discovery Studio's  programmable power supplies. They can be programmed to voltage levels from 1 to 5V (V+)  and ‐1 to ‐5V (V‐) through the use of WaveForms' Power Supplies instrument.  Four fixed supplies are available, +12V, ‐12V, 5.0V, and 3.3V.  A small labeled breadboard that can be soldered to the Blank Canvas's power supply pins, if  desired, comes in the box with the Blank Canvas.  Since each power supply is sourced directly from the Analog Discovery Studio, the minimum  and maximum current and power available for each supply depends on the Analog Discovery  Studio's specifications. See the Analog Discovery Studio Specifications for more information.           https://store.digilentinc.com/blank‐canvas//7‐17‐19
471-032 价格&库存
很抱歉,暂时无法提供与“471-032”相匹配的价格&库存,您可以联系我们找货
  • 1+674.852041+87.71431
    • 1+574.32312
    • 5+562.82624
    库存:7
    471-032
      库存:7
