Zmod ADC 1410: SYZYGY-compatible Dualchannel 14-bit Analog-to-Digital Converter Module
SKU: 410-396
The Zmod ADC is one of Digilent's first SYZYGY-compliant expansion modules. The
SYZYGY standard offers a much higher speed/bandwidth digital interface than Pmods,
but at a much smaller and lower-cost form-factor than FMC, enabling the user to
configure an FPGA development board with the right I/O for their application.
Driven by the SYZYGY carrier, the Zmod ADC can simultaneously acquire two ±25V
signals with 14 bits of resolution at a sample rate up to 100MS/s. Analog inputs can be
connected to a circuit using SMA cables.
When coupled to a base board using SYZYGY expansion, like the Eclypse
Z7 or Genesys ZU, the combination will serve as a powerful prototyping platform for
instrumentation, high-speed control, and SDR products. By utilizing these expansion
capabilities, users can spend more time on the analytical and system-level aspects of
the solution rather than having to focus on the component-level interactions of the
devices.
Features:
Channels: 2
Channel type: single-ended
Resolution: 14-bit
Input range: ±1V (High Gain) or ±25V (Low Gain)
Absolute Resolution 0.13mV (High Gain) or 3.21mV (Low Gain)
Sample rate (real time): 100MS/s
Input impedance: 1MΩ||18pF
Analog bandwidth: 70 MHz+ @ 3dB, 30 MHz @ 0.5dB, 20 MHZ @ 0.1dB
Input protected to: ±50V
https://store.digilentinc.com/zmod‐adc‐1410‐syzygy‐compatible‐dual‐channel‐14‐bit‐analog‐to‐digital‐converter‐module//11‐29‐19
很抱歉,暂时无法提供与“410-396”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2233.87219
- 5+2189.18641
