410-397
410-397
    DIGILENT(迪芝伦)
    数模转换器(DAC) 数据采集 SYZYGY,Zmod 平台评估扩展板
410-397 数据手册
      Zmod DAC 1411: SYZYGY-compatible Dualchannel 14-bit Digital-to-Analog Converter Module SKU: 410-397   The Zmod DAC is one of Digilent's first SYZYGY-compliant expansion modules. The SYZYGY standard offers a much higher speed/bandwidth digital interface than Pmods, but at a much smaller and lower-cost form-factor than FMC, enabling the user to configure an FPGA development board with the right I/O for their application. Driven by the SYZYGY carrier, the Zmod DAC can simultaneously generate two ±5V signals with 14 bits of resolution at a sample rate up to 100MS/s. The analog outputs can be connected to a circuit using SMA cables. When coupled to a base board using SYZYGY expansion, like the Eclypse Z7 or Genesys ZU, the combination will serve as a powerful prototyping platform for instrumentation, high-speed control, and SDR products. By utilizing these expansion capabilities, users can spend more time on the analytical and system-level aspects of the solution rather than having to focus on the component-level interactions of the devices. Features:           Channels: 2 Channel type: single-ended Resolution: 14-bit Absolute Resolution (amplitude ≤1.25V): 167μV Absolute Resolution (amplitude >1.25V): 665μV Output impedance: 50Ω Sample rate (real time): 100MS/s. AC amplitude (max): ±5 V. Analog bandwidth: 40 MHz @ 3dB, 20 MHz @ 0.5dB, 14 MHz @ 0.1dB Slew rate (2V step): 180V/μs                                     https://store.digilentinc.com/zmod‐dac‐1411‐syzygy‐compatible‐dual‐channel‐14‐bit‐digital‐to‐analog‐converter‐module//11‐29‐19
410-397 价格&库存
很抱歉,暂时无法提供与“410-397”相匹配的价格&库存,您可以联系我们找货
    • 1+833.15904
    • 5+816.49690
    库存:2
