Arty Z7: APSoC Zynq-7000 Development Board for
Makers and Hobbyists
Arty Z7: APSoC Zynq‐7000 Development Board for Makers and HobbyistsProduct Description
Digilent recommends the Arty Z7-20 with SDSoC voucher for those interested in video processing applications.
Vivado Design Suite voucher not included - Vivado Design Suite Edition is available for free download
(Vivado WebPACK).
The Arty Z7 is a ready-to-use development platform designed around the Zynq-7000™ All
Programmable System-on-Chip (AP SoC) from Xilinx. The Zynq-7000 architecture tightly integrates a
dual-core, 650 MHz ARM Cortex-A9 processor with Xilinx 7-series Field Programmable Gate Array
(FPGA) logic. This pairing grants the ability to surround a powerful processor with a unique set of
software defined peripherals and controllers, tailored by you for whatever application is being
conquered. The design process is very straightforward and provides a systematic path between
defining your custom peripheral set and bringing it's functionality up to a Linux OS running on the
processor. Digilent provides a number of materials and resources for the Arty Z7 that will get you up
and running with this process quickly.
Features:
Arty Z7 comes in two FPGA variants: Arty Z7-10 features Xilinx XC7Z010-1CLG400C. Arty Z7-20
features the larger Xilinx XC7Z020-1CLG400C. Arty Z7 has the features listed below:
Arty Z7-10
Arty Z7-20
FPGA part
XC7Z010‐1CLG400C
XC7Z020‐1CLG400C
1 MSPS On‐chip ADC
Yes
Yes
Processor
Dual ARM Cortex A9
Dual ARM Cortex A9
Look‐up Tables (LUTs)
17,600
53,200
Flip‐flops
35,200
106,400
Block RAM
270 KB
630 KB
Clock Management Tiles
2
4
Available Shield I/O
26
49
1 MSPS On‐chip ADC
Yes
Yes
Processor
Dual ARM Cortex A9
Dual ARM Cortex A9
17,600
53,200
Flip‐flops
35,200
106,400
Block RAM
270 KB
630 KB
2
4
26
49
ZYNQ Processor
650MHz dual-core Cortex-A9 processor
DDR3 memory controller with 8 DMA channels and 4 High Performance AXI3 Slave ports
High-bandwidth peripheral controllers: 1G Ethernet, USB 2.0, SDIO
Low-bandwidth peripheral controller: SPI, UART, CAN, I2C
Programmable from JTAG, Quad-SPI flash, and microSD card (Micro USB cable not included).
Programmable logic equivalent to Artix-7 FPGA
Memory
512MB DDR3 with 16-bit bus @ 1050Mbps
16MB Quad-SPI Flash with factory programmed 48-bit globally unique EUI-48/64™ compatible identifier
microSD slot
Power
Powered from USB or any 7V-15V external power source
USB and Ethernet
Gigabit Ethernet PHY
USB-JTAG Programming circuitry
USB-UART bridge
USB OTG PHY (supports host only)
Audio and Video
HDMI sink port (input)
HDMI source port (output)
PWM driven mono audio output with 3.5mm jack
Switches, Push-buttons, and LEDs
4 push-buttons
2 slide switches
4 LEDs
2 RGB LEDs
Expansion Connectors
Two standard Pmod ports
16 Total FPGA I/O
Arduino/chipKIT Shield connector
Up to 49 Total FPGA I/O (see table above)
6 Single-ended 0-3.3V Analog inputs to XADC
4 Differential 0-1.0V Analog inputs to XADC
What’s Included
Arty Board Zynq 7000 APSoC: choose between the Arty Z7‐10 and Arty Z7‐20 (Micro USB cable not included).
Digilent cardboard packaging with protective foam
很抱歉,暂时无法提供与“471-006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1947.440551+252.07589
