6002-410-021
6002-410-021
    DIGILENT(迪芝伦)
    USRP B205MINI-I: 1X1 USB SOFTWAR
6002-410-021 数据手册
    Ettus Research USRP B205mini-i: 1x1 USB Software-Defined Radio Platform SKU: 6002-410-021 Product Description   The USRP B205mini-i is a flexible and compact platform that is ideal for both hobbyist and OEM applications. It is designed by Ettus Research™ and provides a wide frequency range (70 MHz to 6 GHz) and a user-programmable, industrial-grade Xilinx Spartan-6 XC6SLX150 FPGA. The RF front end uses the Analog Devices AD9364 RFIC transceiver with 56 MHz of instantaneous bandwidth. The board is bus-powered by a high-speed USB 3.0 connection for streaming data to the host computer. The USRP B205mini-i also includes connectors for GPIO, JTAG, and synchronization with a 10 MHz clock reference or PPS time reference input signal. The hardware is conveniently accessible through the USRP Hardware Driver (UHD). UHD provides both a C/C++ and Python API that supports all USRP products and enables users to efficiently develop applications then seamlessly transition designs between platforms as requirements expand. UHD also offers cross-platform support for multiple industry standard development environments and frameworks, including RFNoC, LabVIEW, and Matlab/Simulink. To ensure you have no restrictions on how you use UHD, it is available on Linux, Windows, and Mac OS. Do you prefer graphical programming? Try out GNU Radio, a free and open-source software development framework offering a graphical design approach. Features RF Specifications Conversion Performance and Clocks Power Physical Environment Synchronization       Channels: 1 TX, 1 RX Frequency range: 70 MHz to 6 GHz Instantaneous Bandwidth: Up to 56 MHz IIP3 (at typical NF): -20 dBm Power Output: >10 dBm Receive Noise Figure:
6002-410-021 价格&库存
很抱歉,暂时无法提供与“6002-410-021”相匹配的价格&库存,您可以联系我们找货
  • 1+17077.300821+2219.23880
