6026-410-002
6026-410-002
    DIGILENT(迪芝伦)
    FMC-SDP INTERPOSER
6026-410-002 数据手册
    FMC-SDP Interposer (RETIRED) SKU: 6026-410-002-RET Product Description The FMC-SDP interposer allows any Analog Devices SDP Evaluation Board to be used on a Xilinx® evaluation board with a FMC connector. The interposer uses the Low Pin Count (LPC) version of the FMC connector, so it can be used on either LPC or HPC hosts. The interposer can only be used with FPGA boards that support 3.3VIO for the FMC connection. Note: For more information and a list of existing projects which can be used with the FMC-SDP Interposer, please visit: http://wiki.analog.com/sdp-i-fmc. Features:    Allows any Analog Devices SDP Evaluation Board to be used on a Xilinx evaluation board with a FMC connector Uses Low Pin Count (LPC) FMC connector Can be used on either LPC or HPC hosts        http://store.digilentinc.com/fmc‐sdp‐interposer‐retired/ 6‐22‐17
6026-410-002
PDF文档解析结果如下:
物料型号:STC15F2K60S2 器件简介:这是宏晶科技生产的单片机,具有2K字节的Flash存储空间,适用于多种嵌入式控制应用。
引脚分配:该单片机共有40个引脚,包括电源引脚、地引脚、I/O引脚等。
参数特性:工作电压范围为2.3V-5.5V,工作频率最高可达24MHz,具备看门狗定时器、外部中断等功能。
功能详解:该单片机支持ISP编程和在线仿真,内置ADC模块,支持PWM输出等。
应用信息:适用于工业控制、家用电器、消费电子等领域。
封装信息:采用PDIP封装,共有40个引脚。
6026-410-002 价格&库存
很抱歉,暂时无法提供与“6026-410-002”相匹配的价格&库存,您可以联系我们找货
