EX12-0004-OUS
EX12-0004-OUS
    DIGIINTERNATIONAL
    LTE 调制解调器 以太网,RJ-45,RS-232
EX12-0004-OUS 数据手册
LTE CELLULAR EXTENDER FOR BUSINESS CONTINUITY Manage this device with Digi Remote Manager DIGI EX12 Avoid network outages with primary or backup LTE connectivity; integrate seamlessly with existing infrastructure The Digi EX12 LTE cellular extender is an affordable, scalable failover solution that enables you to retrofit your infrastructure for cellular network access. With a carrier-certified, embedded LTE Cat 4 cellular modem, equipped with dual SIM slots, Digi EX12 provides uninterrupted primary or backup connectivity. It protects against downtime by automatically switching to a secondary cellular carrier should the primary SIM lose Internet access. This compact, high-performance device is also compatible with any dual-WAN networking appliance and helps you achieve reliable connectivity at any location using your existing equipment. Couple the Digi EX12 with a dedicated wireline ISP connection to maximize uptime and ensure reliable network availability FEATURES AND BENEFITS for POS systems, ATMs, mobile kiosks, digital signage and more. Deployments are streamlined with installation accessories including an optional Remote Mounting Kit with a disposable battery pack for site survey, mounting bracket and a passive Power-over-Ethernet (PoE) injector for optimizing placement for the best cellular reception. Digi EX12 can be securely monitored and managed with Digi Remote Manager®, a cloud-based solution that facilitates setup, mass configuration, maintenance and support for hundreds or even thousands of remote Digi® devices. Digi Remote Manager lets you evaluate, update and configure your Digi products — and the health of your network — at scale after deployment. APPLICATION EXAMPLE – Redundant cellular connectivity with dual SIMs and Digi SureLink® INTERNET – Digi TrustFence® for built-in device security, secure encrypted connections, ongoing monitoring and support – Optional Remote Mounting Kit with bracket, accessories, passive PoE injector and site survey battery pack to identify the best location for optimum cellular reception – Automatic cellular carrier detection and switching with Carrier Smart Select™ – Digi Remote Manager software for easy setup, mass configuration and management LTE BACK OFFICE OR IN STORE BROADBAND MODEM (Cable/DSL ISP) POS TERMINAL DUAL-WAN CONNECTIVITY + POWER OVER ETHERNET RELATED PRODUCTS Digi EX15 Digi 6330-MX SERIAL OOB Digi 6310-DX Accessories Digi Remote Manager DIGI EX12 PRIVATE LAN POOR CELLULAR RECEPTION GOOD CELLULAR RECEPTION SPECIFICATIONS DIGI® EX12 CELLULAR CONNECTIVITY CELLULAR LTE: B2, B4, B5, B12, B13, B14, B66, B71; 3G: B2, B4, B5; Transfer rate (max): 150 Mbps down, 50 Mbps up CONNECTORS (2) 50 Ω SMA (center pin: female) SIM SLOTS (2) Mini-SIM (2FF); software selectable and hardware switchable SOFTWARE AND MANAGEMENT REMOTE MANAGEMENT Digi Remote Manager®; SNMP v3 (user installed/managed), encrypted SMS LOCAL MANAGEMENT WebUI (HTTP/HTTS); CLI (SSH, serial port) PROTOCOLS RIP, RIPng, OSPFv2, OSPFv3, BGP, Babel, IS-IS MANAGEMENT/ TROUBLESHOOTING TOOLS FTP client, SCP; protocol analyzer with PCAP for Wireshark; event logging with syslog and SMTP client; NTP/SNTP MEMORY 256 MB RAM, 512 MB flash ETHERNET PORTS (2) RJ-45; 10/100 Mbps (auto-sensing) SERIAL PORTS (1) RS-232 (RJ-45) PHYSICAL DIMENSIONS (L x W x H) 127 mm x 127 mm x 25 mm (5.0 in x 5.0 in x 1.0 in) WEIGHT 0.24 kg (8.25 oz) STATUS LEDs LAN (link = solid, flashing = act), WAN (link = solid, flashing = act), LTE, 5 signal ENCLOSURE Plastic POWER REQUIREMENTS POWER INPUT 18 VDC 1 A OTHER Includes power supply, cables, antennas and optional Remote Mounting Kit: temporary battery, passive PoE injector, mounting bracket and accessories (see part numbers for details); Note: only the Digi-supplied power supply and passive PoE injector are recommended for use with Digi EX12 ENVIRONMENTAL OPERATING TEMPERATURE 0° C to 40° C (32° F to 104° F) RELATIVE HUMIDITY 5% to 95% (non-condensing) APPROVALS CELLULAR Visit www.digi.com/resources/certifications for latest certifications EMISSIONS / IMMUNITY FCC Part 15, Subpart B, Class A; CE, RCM; CAN ICES-3(B)/NMB-3(B) WARRANTY PRODUCT WARRANTY 3-year PRODUCT IMAGES 25 mm DIGI EX12 RIGHT SIDE DIGI EX12 LEFT SIDE DIGI EX12 TOP 127 mm Main AUX/SMA SIM Erase LAN WAN Serial Power /PoE input 18 V 127 mm DIGI.COM DIGI REMOTE MANAGER® CAPABILITIES – Activate, monitor and diagnose your mission-critical devices from a single point of command and control — on your desktop or mobile app – Schedule key operations — including firmware updates and file management — on a single device or on a group of devices, keeping your network functionality up-to-date and maintaining compliance standards – Manage edge devices out-of-band via console terminal access – Keep tabs on device health and connectvity across device deployments of any size – Create detailed reports and enable real-time alerts for specified conditions – Integrate device data through open APIs to gain deeper insights and control with third-party applications – Report and alert on performance statistics, including connection history, signal quality, latency, data usage and packet loss INFRASTRUCTURE Digi Remote Manager is the technology platform that brings networks to the next level, allowing networks — and the people who manage them — to work smarter. With Digi Remote Manager you can transform a multitude of dispersed IoT devices into a dynamic, intelligent network. Now you can easily deploy, monitor and diagnose thousands of mission-critical devices from a single point of command — on your desktop, tablet or phone. All the while, its software-defined security diligently safeguards your entire Digi ecosystem. Learn more at www.digi.com/digi-remote-manager – Hosted in a commercial-grade cloud server environment that meets SOC 1®, SOC 2® and SOC 3® standards – Superior availability, operating to 99.9% or greater – Open APIs available to support application development SECURITY – More than 175 security controls in place to protect your data – Member of the Center for Internet Security® (CIS®) – Enables compliance with security frameworks like ISO27002, HIPAA, NIST and more – Earned Skyhigh’s CloudTrust™ Program highest rating of Enterprise-Ready PART NUMBERS DIGI® EX12 EX12-R004-OUS Digi EX12 with Remote Mounting Kit - 2-port 10/100; RJ-45, RS-232; US and Canada, LTE / HSPA+ Cat 4; Includes antennas, power supply, site survey battery, PoE injector and mounting accessories EX12-0004-OUS Digi EX12 without Remote Mounting Kit - 2-port 10/100; RJ-45, RS-232; US and Canada, LTE / HSPA+ Cat 4; Includes antennas and power supply PART NUMBERS ACCESSORIES 450069 18 V PSU power supply with barrel jack connector (replacement) 500170 10/100 base-T passive PoE adapter, green (replacement) 440084 4 meter flat Cat 6 Ethernet cable, white (replacement) 440091 0.5 meter flat Cat 6 Ethernet cable, white (replacement) 560083 Temporary site survey battery pack, 9 V with 152.4 mm power lead, 2.1 mm barrel connector (replacement) DIGI SERVICE AND SUPPORT / You can purchase with confidence knowing that Digi is always available to serve you with expert technical support and our industry leading warranty. For detailed information visit www.digi.com/support. © 1996-2020 Digi International Inc. All rights reserved. All trademarks are the property of their respective owners. 91004418 B4/920 DIGI INTERNATIONAL WORLDWIDE HQ 877-912-3444 / 952-912-3444 / www.digi.com DIGI INTERNATIONAL SINGAPORE +65-6213-5380 DIGI INTERNATIONAL GERMANY +49-89-540-428-0 DIGI INTERNATIONAL CHINA +86-21-50492199 / www.digi.com.cn DIGI INTERNATIONAL JAPAN +81-3-5428-0261 / www.digi-intl.co.jp
EX12-0004-OUS 价格&库存
很抱歉,暂时无法提供与“EX12-0004-OUS”相匹配的价格&库存,您可以联系我们找货
EX12-0004-OUS
  • 1+3620.517731+467.05605
