471-036-2
471-036-2
    DIGILENT(迪芝伦)
    Eclypse Z7 Zynq-7000 AP SoC,具有 2 Zmod AWG 1411 AD9717,XC7Z020 Zynq®-7000 FPGA + MCU/MPU SoC 评估板
471-036-2 数据手册
Eclypse Z7: Zynq-7000 SoC Development Board with SYZYGYcompatible Expansion Eclypse Z7 Options: SKU: 410-393 Eclypse Z7: Just the board SKU: 471-036 Eclypse Z7 bundled with a Zmod DAC and Zmod ADC SKU: 471-036-2 Eclypse Z7 bundled with two Zmod DACs SKU: 471-036-1 Eclypse Z7 bundled with two Zmod ADCs The Eclypse Z7 product image, displayed at and angle. Top view product image of the Eclypse Z7. Bottom view product image of the Eclypse Z7. Product image of the Eclypse Z7, populated with the Zmod ADC and Zmod DAC. Please note: Zmods are only included in the bundle options. Top view product image of the Eclypse Z7, populated with the Zmod ADC and Zmod DAC. Please note: Zmods are only included in the bundle options. Overview The Eclypse Z7 is Digilent's newest FPGA/SoC development board, specifically designed to enable the rapid prototyping and development of embedded measurement systems. Featuring high-speed Zmod ports for modular expansion, a Xilinx Zynq®-7020 SoC plus software API from Digilent, the Eclypse Z7 is fast, flexible and shortens the time it takes for engineers and researchers to develop innovative and powerful new high-speed instrumentation, control, and measurement systems for edge-computing, medical, and communications applications. Eclypse Z7 is the first host board of the Eclypse Platform. Zmod Expansion Zmod is Digilent’s new expansion solution using the open-source SYZYGY standard from Opal Kelly. Faster than the Pmod Standard and more compact and costeffective than FMC, Zmods improve the customizability options for high-speed I/O. Plug in your application specific Zmods and get up and running in hours or days, instead of weeks or months. Two Zmods are being released alongside the Eclypse Z7, the Zmod ADC 1410 and Zmod DAC 1411, both with 100 MSPS, 14-bit converters, with more planned in the future. Eclypse Platform Software The Eclypse Z7 is a component of the Eclypse Platform, which pairs Digilent’s open software API with Digilent’s novel Eclypse hardware. Petalinux is supported out of the box, and pre-built Linux images are accompanied by the API for bulk data transfer. This system allows users to plug in their Zmods of choice and get started prototyping new high-speed measurement, instrumentation and control systems without directly interfacing with the FPGA until desired. With this system, embedded Linux developers can leverage the power of FPGA without possessing hardware expertise. Currently, C and C++ are supported, with plans to add support for other programming languages in the future. Features • • Zynq-7000 APSoC (XC7Z020-1CLG484C) • • • 667 MHz dual-core Cortex-A9 processor DDR3L memory controller with 8 DMA channels and 4 High Performance AXI3 Slave ports High-bandwidth peripheral controllers: 1G Ethernet, USB 2.0, SDIO Low-bandwidth peripheral controllers: SPI, UART, CAN, I2C Programmable from JTAG, Quad-SPI flash, and microSD • Memory • • • card Programmable logic equivalent to Artix-7 FPGA 1 GiB DDR3L with 32-bit bus @ 1066 MT/s 16 MB Quad-SPI Flash with factory programmed 128-bit random number and 48-bit globally unique EUI-48/64™ compatible identifier microSD card slot Power • • Powered from external 12V 5A supply Platform MCU for configuration of adjustable power supplies and temperature management USB and Ethernet • • • • Gigabit Ethernet PHY USB-JTAG programming circuitry USB-UART bridge USB micro AB port with USB 2.0 PHY with Host/Device/OTG capabilities • 2 ports following the SYZYGY Standard interface specification Compatible with a variety of SYZYGY pods, allowing for a wide variety of applications Dedicated differential clocks for input and output 8 differential I/Os per port 16 single-ended I/Os per port DNA interfaces connected to Platform MCU allowing for various auto-negotiated power supply configurations • Zmod Ports • • • • Pmod Ports • • 2 twelve-pin ports for a total of 16 FPGA-connected I/Os High speed voltage translation and protection circuitry User GPIO • • 2 push-buttons 2 RGB LEDs What's Included: • • • • • • • Eclypse Z7 Development Board FPGA fan USB A to Micro B programming cable USB A to Micro A cable 12V 5A power supply Digilent custom packaging Additional contents depend on the option choice: • Adding one Zmod ADC and one Zmod DAC • Adding two Zmod DACs • Adding two Zmod ADCs https://store.digilentinc.com/eclypse-z7-zynq-7000-soc-development-board-with-syzygy-compatible-expansion//4-22-20
471-036-2 价格&库存
很抱歉,暂时无法提供与“471-036-2”相匹配的价格&库存,您可以联系我们找货
  • 1+4880.85088
  • 5+4783.22115
库存:2
