410-357-B
410-357-B
    DIGILENT(迪芝伦)
    FPGA - 编程器(在线/在系统)
410-357-B 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.store. digilent.com JTAG-SMT3-NC Reference Manual Revised September 6, 2018 This manual applies to the JTAG-SMT3-NC rev. A Overview The Joint Test Action Group (JTAG)-SMT3-NC is a compact, complete, and fully self-contained surface-mount programming module for Xilinx field-programmable gate arrays (FPGAs). The module can be accessed directly from all Xilinx Tools, including iMPACT, ChipScope™, Vivado, and EDK. Users can load the module directly onto a target board and reflow it like any other component. The JTAG-SMT3-NC uses a 3.3V main power supply and independent Vref supplies to drive the JTAG and UART signals. All JTAG signals use high speed 24mA three-state buffers that allow signal voltages from 1.8V to 5.5V, and bus speeds up to 30MBit/sec. All UART signals use high speed 24mA buffers that allow signal voltages from 1.8V to 5.5V and bus speeds up to 12Mbaud. The JTAG bus can be shared with other devices as the SMT3-NC signals are held at high impedance, except when actively driven during programming. The SMT3-NC module is CE certified and fully compliant with EU RoHS and REACH directives. The module routes the USB D+ (DP) and D- (DM) signals out to pads, providing the system designer with the ability to choose the type of USB connector and its location on the system board. • • • • • • • • The JTAG-SMT3-NC. DOC#: 410-357 • Small, complete, all-in-one JTAG programming/debugging solution for Xilinx FPGAs with UART side channel Compatible with Xilinx Tools High-Speed USB 2.0 port that can drive JTAG bus up to 30Mbit/sec (frequency settable by user) Open drain buffer on PS_SRST_B pin allows debugging software to reset the processor core of Xilinx’s Zynq® platform Dual channel USB controller provides simultaneous access to both JTAG and UART interfaces Separate Vref for JTAG and UART signals allows each interface to operate at difference voltages (1.8V to 5.5V) Small form-factor surface-mount module can be directly loaded on target boards USB D+ and D- signals routed to pads, allowing USB connector to be placed anywhere on the host PCB VBUS_DETECT pin allows for reduced current consumption when the module isn’t connected to a PC Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 10 JTAG-SMT3-NC Reference Manual Users can connect JTAG signals directly to the corresponding FPGA signals, as shown in Fig. 1. For best results, mount the module over a ground plane on the host PCB. Although users may run signal traces on top of the host PCB beneath the SMT3-NC, Digilent recommends keeping the area immediately beneath the SMT3-NC clear. Note: Keep the impedance between the SMT3-NC and FPGA below 100 Ohms to operate the JTAG at maximum speed. Note: If series resistors are used, they should be placed near the transmitting end in order to minimize reflections. In addition to supporting JTAG, the JTAG-SMT3-NC also features a UART Interface that allows communication with UART peripherals (see Fig. 2). The UART interface is presented as a virtual com port on the host PC, supports baud rates up to 12Mbaud, and has an independent voltage reference which allows it to interface with devices operating at voltages between 1.8V and 5.5V. 1 Software Support The JTAG-SMT3-NC has been designed to work seamlessly with Xilinx’s ISE® (iMPACT, ChipScope, EDK, and eFuse) and Vivado tool suites. The most recent versions of ISE and Vivado include all of the drivers, libraries, and plugins necessary to communicate with the JTAG-SMT3-NC. At the time of writing, the following Xilinx software included support for the SMT3: Vivado 2017.1+, Vivado 2016.1+, Vivado 2015.1+, Vivado 2014.1+, and ISE 14.1+. The SMT3NC is also compatible with ISE 13.1 - 13.4; however, these versions of ISE do not include all of the libraries, drivers, and plugins necessary to communicate with the SMT3-NC. In order to use the JTAG-SMT3-NC with these versions of ISE, version 2.5.2 or higher of the Digilent Plugin for Xilinx Tools package must be downloaded from the Digilent website and the ISE13 plugin must be manually installed as described in the included documentation. In addition to working seamlessly with all Xilinx tools, Digilent’s Adept software and the Adept software development kit (SDK) support the SMT3-NC module. For added convenience, customers may freely download the SDK from Digilent’s website. This Adept software includes a full-featured programming environment and a set of public application programming interfaces (API) that allow user applications to directly drive the JTAG chain. With the Adept SDK, users can create custom applications that will drive JTAG ports on virtually any device. Please see the Adept SDK reference manual for more information. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 10 JTAG-SMT3-NC Reference Manual 2 PS_SRST_B Pin When customers use the JTAG-SMT3-NC to interface the scan chain of Xilinx’s Zynq platform, they should connect the PS_SRST_B pin of the SMT3-NC to the Zynq’s PS_SRST_B pin. This connection allows the Xilinx Tools to reset the Zynq’s processor core at various times during debugging operations. The PS_SRST_B pin on the SMT3-NC is driven by an open drain buffer that is capable of sinking up to 32mA of current. Customers who connect this pin must provide an external pull-up to the appropriate supply rail. A pull-up resistor between 1K - 100K Ohms is recommended. Please see the following “Application Examples” section for more information. 3 VBUS_DETECT Pin The VBUS_DETECT pin is used by the USB controller to determine when VBUS is present. When a logic ‘0’ is detected on this pin, the USB controller is forced into suspend mode. This prevents the SMT3-MC from forcing current down the USB lines when the host or the hub is powered off. Additionally, it results in reduced current consumption from the module. Connect VBUS to the VBUS_DETECT pin using a resistor divider, similar to the one in Fig. 3 shown below. 4 Application Examples 4.1 Example 1: Interfacing a Zynq-7000 Figure 4 demonstrates how to connect the JTAG-SMT3-NC to Xilinx’s Zynq-7000 silicon. Please note that VCCO_0 and VCCO_MIO1 may be powered by the same supply or by different supplies. The PS_SRST_B pin of the SMT3NC is driven by an open drain buffer and therefore an external open drain buffer is not required to add an optional reset button. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 10 JTAG-SMT3-NC Reference Manual 4.2 Example 2: Interfacing a Zynq-7000 while retaining the Xilinx JTAG Header Figure 5 below demonstrates how to connect the JTAG-SMT3-NC to Xilinx’s Zynq-7000 silicon alongside Xilinx’s 14pin JTAG header. In this example, an open drain buffer allows both the SMT3-NC and Xilinx JTAG Header to drive the PS_SRST_B pin, which may operate a different voltage than the Zynq’s JTAG pins. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 10 JTAG-SMT3-NC Reference Manual 5 Supported Target Devices The JTAG-SMT3-NC is capable of targeting the following Xilinx devices: • • • • • • Xilinx FPGAs Xilinx Zynq-7000 Xilinx CoolRunner™/CoolRunner-II CPLDs Xilinx Platform Flash ISP configuration PROMs¹, ² Select third-party SPI PROMs¹, ² Select third-party BPI PROMs¹, ² The following devices cannot be targeted by the JTAG-SMT3-NC: • • • Xilinx 9500/9500XL CPLDs Xilinx 1700 and 18V00 ISP configuration PROMs Xilinx FPGA eFUSE programming Remote device configuration is not supported for the JTAG-SMT3-NC when used with Xilinx’s iMPACT software. ¹ — Note: Please see the “Introduction to Indirect Programming – SPI or BPI Flash Memory” help topic in iMPACT for a list of supported FPGA/PROM combinations. ² — Note: Please see the “Configuration Memory Support” section of Xilinx UG908 for a list of the FPGA/PROM combinations that Vivado supports. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 5 of 10 JTAG-SMT3-NC Reference Manual 5.1 Programming Solutions Comparison Chart Max Speed Voltage Range Xilinx Native Support Xilinx Plug-in Support Digilent Adept Support PC Interface Onboard USB Connector Host Board Connector Interface 4-Wire JTAG 2-Wire JTAG Zynq-7000 PS_SRST Support SPI Support Independent UART Channel 6 JTAG-SMT3-NC 30 MHz 1.8V – 5V ISE 14.1+ Vivado 2014.1 ISE 13.1+ YES USB YES 18-pad SMT JTAG-SMT2 30 MHz 1.8V – 5V ISE 14.1+ Vivado 2013.1+ ISE 13.1+ YES USB YES 11-pad SMT JTAG-SMT2-NC 30 MHz 1.8V – 5V ISE 14.1+ Vivado 2013.1+ ISE 13.1+ YES USB NO 13-pad SMT YES NO YES NO YES YES YES YES YES NO YES YES YES YES NO Pinout Table Pin Number 1 2 3 4 5 6 7 8 9 Pin Name GND VREF_UART CTS RTS RXD TXD GND VREF_JTAG PS_SRST_B Pin Number 10 11 12 13 14 15 16 17 18 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Pin Name TCK TDO TDI TMS GND VDD USB_DM USB_DP VBUS_DETECT Page 6 of 10 JTAG-SMT3-NC Reference Manual 7 Mechanical Information 8 General USB Signal Routing Guidelines • • Maintain a differential impedance of 90 Ohms between the DP and DM signals. Keep DP and DM trace lengths within 50 mils of each other. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 7 of 10 JTAG-SMT3-NC Reference Manual • • • • • • 8.1 Minimize DP and DM signal trace length. Keeping the trace length below 3 inches is recommended. When possible, route DP and DM on the plane closest to the ground plane. When possible, avoid routing the DP and DM signals through vias. If vias cannot be avoided, then keep them small and place the DP and DM traces on the same layer. When possible, avoid routing other traces near DP and DM. When possible, minimize or avoid the use of bends in the DP and DM traces. If 90 degree bends are necessary, then use two 45 degree turns or an arc instead of a single 90 degree turn. Do NOT route DP or DM near oscillators, crystals, switching regulators, clock generators, or inductors. Absolute Maximum Ratings Symbol Vdd Vref VIO IIK,IOK IOUT TSTG ESD 8.2 Parameter Operating supply voltage I/O reference/supply voltage Signal Voltage TMS, TCK, TDI, TDO, TXD, RXD, RTS, CTS, PS_SRST_B DC Input/Output Diode Current DC Output Current Storage Temperature Human Body Model JESD22-A114 Charge Device Model JESD22-C101 Condition Min -0.3 -0.3 -0.3 VIO < -0.3V Max 4.0 6 6 -50 VIO > 6V +20 -10 ±50 +60 4000 2000 Unit V V V mA mA ºC V V DC Operating Characteristics Symbol Vdd VREF_JTAG VREF_UART TDO, RXD, CTS VBUS_DETECT TMS, TCK, TDI TXD, RTS PS_SRST_B TA Symbol Parameter Operating supply voltage JTAG I/O reference/supply voltage UART I/O reference/supply voltage Input High Voltage (VIH) Input Low Voltage (VIL) Input High Voltage (VIH) Input Low Voltage (VIL) Output High (VOH) Output Low (VOL) Output High (VOH) Output Low (VOL) Output Low (VOL) Operating Temperature Parameter Min 2.97 1.65 Typ 3.3 3.3 Max 3.63 5.5 1.65 3.3 5.5 0.75 x Vref 0 2.0 0 0.78 x Vref 0 0.75 x Vref 0 0 -40 Min Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. 0.95 x Vref 0.05 x Vref Typ 5.5 0.55 Vdd 0.8 Vref 0.55 Vref 0.55 0.55 85 Max Page 8 of 10 JTAG-SMT3-NC Reference Manual 9 AC Operating Characteristics The JTAG-SMT3-NC’s JTAG signals operate according to the timing diagram in Fig. 7. The SMT3-NC supports JTAG/TCK frequencies from 30 MHz to 8 KHz at integer divisions of 30 MHz from 1 to 3750. Common frequencies include 30 MHz, 15 MHz, 10 Mhz, 7.5 MHz, and 6 MHz (see Table 2). The JTAG/TCK operating frequency can be set within the Xilinx tools. Note: Please refer to Xilinx’s iMPACT documentation for more information. 10 Mounting to Host PCBs The JTAG-SMT3-NC module has a moisture sensitivity level (MSL) of 3. It is suitable for reflow for up to 168 hours without additional drying. The factory finishes the JTAG-SMT3-NC signal pads with the ENIG process using 2u” gold over 150u” electroless nickel. This makes the SMT3-NC compatible with most mounting and reflow processes (see Fig. 8). The binding force of the solder is sufficient to hold the SMT3-NC firmly in place, so mounting should require no additional adhesives. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 9 of 10 JTAG-SMT3-NC Reference Manual 11 Packaging Digilent ships quantities under 40pcs individually packaged in antistatic bags. Digilent will pack and ship larger quantities in groups of 40 positioned in an antistatic bake tray (see Fig. 10). Trays will be packaged in an anti-static vacuum sealed bag. We also offer to bake them before shipping for an additional cost per 40pc lot. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 10 of 10
410-357-B 价格&库存
很抱歉,暂时无法提供与“410-357-B”相匹配的价格&库存,您可以联系我们找货
410-357-B
  • 1+531.740911+68.59594
410-357-B
    • 1+789.898141+101.89888
    • 10+658.2513710+84.91611
    • 50+552.9269550+71.32899
    • 100+547.66248100+70.64986
    • 500+542.39801500+69.97073
    • 1000+537.133541000+69.29160
    • 2000+534.496932000+68.95147
    库存:7
