CPCI-AC-3U-300
CPCI-AC-3U-300
    DIGITALPOWER
    AC/DC CNVRTR 5V 3.3V +/-12V 354W
CPCI-AC-3U-300 数据手册
(877) 634-0982 www.digipwr.com CPCI-3U Series 200–300 Watt Compact PCI Power Supply Product Specification Universal AC Input with PFC, 48VDC or 24/28VDC Input Key Product Features • Up to 300W • 3U Cabinet • Environmentally Rugged • High Current 3.3V and 5V Outputs • Up to 40A • Accurate Current Sharing • Internal Oring FETs for redundant applications • PICMG 2.11 Compliant Description The CPCI 3U Series of power supplies offer industry leading performance with up to 300 Watts in a 3U package. A full range of AC Input, 24/28VDC Input and 48VDC Input products is available and all products are compliant to the PICMG 2.11 power interface specification. These CPCI products are ruggedized and excel in defense and harsh industrial applications. Ratings Safety and EMC • UL/cUL 60950-1, IEC/EN60950-1 Approved (AC Input and 48 VDC Input) • EN55022 Level B Emissions (with external filter) Input Voltage Range—AC Input 85-264 VAC, 47-63Hz Input Voltage Range—48VDC Input 36-72 VDC Input Voltage Range—24/28VDC Input 18-36 VDC Operating Temperature Range -5°C to +55°C Full Power with 250 LFM Current Sharing Accuracy (V1 and V2) 10% Sharing – up to 6 units Model Selection Model Input Output Power V1 Output V2 Output V3 Output V4 Output Efficiency (Typical) CPCI-AC-3U-200 85-264VAC 200W +5V/20A +3.3V/30A +12V/3A -12V/0.5A 79-81% CPCI-AC-3U-300 85-264VAC 300W +5V/30A +3.3V/40A +12V/5A -12V/1.0A 79-81% CPCI-DC-3U-200/24 24/28VDC (18–36) 200W +5V/25A +3.3V/36A +12V/3A -12V/0.5A 82% CPCI-DC-3U-300/24 24/28VDC (20–36) 300W +5V/30A +3.3V/40A +12V/5A -12V/0.5A 82% CPCI-DC-3U-200/48 48VDC (36–72) 200W +5V/20A +3.3V/30A +12V/3A -12V/0.5A 83% CPCI-DC-3U-300/48 48VDC (36–72) 300W +5V/30A +3.3V/40A +12V/5A -12V/1.0A 83% VDC-Out Adjustment Range: V1= 4.8V-5.4V; V2=3.1V-3.5V; V3=0V; V4=0V CPCI-3U-200 Watt: Note: Maximum output power at any combination within this table is 200W CPCI-3U-300 Watt: Notes: 1) Maximum output power at any combination within this table is 300W 2) Maximum output power on V1+V3 not exceed 185W 3) Maximum output power on V2+V4 not exceed 138W CPCI-3U Series Electrical Specifications Input AC Models 85–264 VAC, 47–63 Hz Power Factor >0.90/0.95 typical @ 110/220 VAC (full load) Hold-up Time 20 ms minimum (full load) Inrush Current
CPCI-AC-3U-300 价格&库存
很抱歉,暂时无法提供与“CPCI-AC-3U-300”相匹配的价格&库存,您可以联系我们找货
