CPCI-AC-6U-500
CPCI-AC-6U-500
    DIGITALPOWER
    AC/DC CNVRTR 5V 3.3V +/-12V 751W
CPCI-AC-6U-500 数据手册
(877) 634-0982 www.digipwr.com CPCI-6U Series 350–650 Watt Compact PCI Power Supply Product Specification Universal AC Input with PFC, 48VDC or 24/28VDC Input Key Product Features • Up to 650W • 6U Cabinet • Environmentally Rugged • High Current 3.3V and 5V Outputs • Up to 80A • Accurate Current Sharing • Internal Oring FETs for redundant applications • PICMG 2.11 Compliant Description The CPCI 6U Series of power supplies offer industry leading performance with up to 650 Watts in a 6U package. A full range of AC Input, 24/28VDC Input and 48VDC Input products is available and all products are compliant to the PICMG 2.11 power interface specification. These CPCI products are ruggedized and excel in defense and harsh industrial applications. Ratings Safety and EMC Input Voltage Range—AC Input 90-264 VAC, 47-63Hz • UL/cUL 60950-1, IEC/EN60950-1 Approved (AC Input and 48 VDC Input) Input Voltage Range—48VDC Input 36-72 VDC Input Voltage Range—24/28VDC Input 18-36 VDC EN55022 Level B Emissions Operating Temperature Range -5°C to +55°C Full Power with 400 LFM Current Sharing Accuracy (V1 and V2) 10% Sharing – up to 6 units • Model Selection Model Input Output Power V1 Output V2 Output V3 Output V4 Output CPCI-AC-6U-400 90-264VAC 400W +5V/50A +3.3V/80A +12V/7.5A -12V/1.5A CPCI-AC-6U-500 90-264VAC 500W +5V/65A +3.3V/80A +12V/12A -12V/1.5A CPCI-AC-6U-600 90-264VAC 600W +5V/70A +3.3V/70A +12V/7A -12V/1.5A CPCI-AC-6U-650 90-264VAC 650W +5V/80A +3.3V/70A +12V/7A -12V/1.5A CPCI-DC-6U-350/24 18–36VDC 350W +5V/50A +3.3V/60A +12V/7A -12V/1.5A CPCI-DC-6U-400/24 20–36VDC 400W +5V/50A +3.3V/60A +12V/7A -12V/1.5A CPCI-DC-6U-400/48 36–72VDC 400W +5V/50A +3.3V/80A +12V/7.5A -12V/1.5A CPCI-DC-6U-500/48 36–72VDC 500W +5V/65A +3.3V/80A +12V/12A -12V/1.5A CPCI-DC-6U-600/48 36–72VDC 600W +5V/70A +3.3V/70A +12V/7A -12V/1.5A CPCI-DC-6U-650/48 36–72VDC 650W +5V/80A +3.3V/70A +12V/7A -12V/1.5A CPCI-6U Series Electrical Specifications Input AC Models 90–264 VAC, 47–63 Hz Power Factor >0.90/0.95 typical @ 110/220 VAC (full load) Hold-up Time 16 ms minimum (full load) Inrush Current 0.90/0.95 typical @ 110/220 VAC (full load) Over-Voltage Protection 110–125% of V1/V2/V3 (latched shutdown) Overload Protection V1 and V2: 125% / V3 and V4: 200% (400W & 500W auto recovery)(600W & 650W recycle AC input power to reset.) Load Regulation V1 and V2: ±1% maximum, V3 and V4: ±5% maximum Min Load Requirement None Turn-On Delay 2 seconds maximum Initial Setting Accuracy V1 and V2 ±1% @ 50% load, V3 and V4 ±2% @ 50% load Ripple/Noise (20MHz BW) V1 and V2: 60 mV, V3 and V4: 120mV (20M Hz bandwidth) EMC and Safety Certifications Electromagnetic Compatibility Electrostatic Discharge EN61000-4-2, ±KV Contact / ±8KV Air Discharge Radiated Susceptibility EN61000-4-3, 26-1000MHz, 10V/M, 80% AM EFT / Bursts EN61000-4-4, ±2KV Surges EN61000-4-5, ±2KV Line-Earth, ±1KV Line-Line Conducted Immunity EN61000-4-6, 0.15-800MHz, 10V, 80% AM Voltage Dips EN61000-4-11, 30% Dip for 10ms, 60% Dip for 100ms Voltage Interruptions EN61000-4-11, 95% Reduction, 5s Fluctuations & Flicker EN61000-3-3 Safety & Emissions Safety Approvals UL/cUL 60950-1, IEC/EN 60950-1 Emissions EN 55022 Level-B CPCI-6U Series Environmental Specifications Operating Temperature Range -5°C to 55°C (23°F to 131°F); De-rate of 2.5% per 1°C to 70°C (34°F to 158°F) Storage Temperature Range -40°C to 85°C (-40°F to 185°F) Cooling 400W and 500W models: 250LFM airflow required for full power at 55°C 600W and 650W models: 400LFM airflow required for full power at 55°C Humidity Up to 95% RH non-condensing Shock & Vibration Storage: EN 300 019-2-1 class 1.2. Transportation: EN 300 019-2-2 class 2.3. Use: EN 300 019-2-3 class 3.3. MTBF >400,000 hours per Belcore 332 issue 6 Status/Control Remote Inhibit Inhibited with GND or TTL“0” = Off DC Fail Open collector—Active Low signal. Indicates one or more outputs below 90% of specified rating Over Temperature Warning Open collector Active Low nominally 10 deg C before shut down. Remote Sense Available V1 and V2. Total voltage compensation up to 300 mV drop. Current Share Single wire (V1 and V2) ±10% up to 6 parallel units. Front Panel Green LED Outputs OK Front Panel Red LED Fault condition Output Power Derating CPCI-6U Series CPCI-6U Series Mechanical Outline 6.43 1.60 2.50 169.60 40.34 FORCED COOLING AIR POWER 233.35 255.85 183.35 10.00 FAULT 261.90 CPCI-6U Series OUTPUT CONNECTOR - Positronic-PCIH47M400A1/AA PIN ASSIGNMENT Pin Pin Type Signal Name. Description 1-4 5-12 13-18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 Normal Normal Normal Normal Normal Normal Normal Normal Normal Normal Normal Short Normal Normal Normal Normal Normal Normal Normal Normal Normal Normal Normal Normal Normal V1 RTN V2 RTN V3 V4 RTN RTN RTN GA-0 Reverse EN# GA-1 NC V1 Sense GA-2 NC V2 Sense S RTN V1 Share NC IPMB_SCL DEG# INH# IPMB_SDA V1 Output V1 and V2 Return V2 Output V3 Return V3 Output V4 Output Signal Return Signal Return V4 Return Geographic ADD-0 (option) Reverse Enable Geographic ADD-1 (option) Not Connected V1 Remote Sense Geographic ADD-2 (option) Not Connected V2 Remote Sense Sense Return V1 Current Share Not Connected System Manager Bus (option) Degrade Signal Open – ON Low - OFF System Manager Bus (option) 41 42 43 44 45 46 47 Normal V2 Share Normal FAL# Normal IPMB_PWR Normal NC Long Chassis GND Long Neutral Line Long V2 Current Share Fail Signal Power–System Manager (option) Not Connected Chassis GND DC input Neutral DC Input Line Digital Power Corporation CUSTOMER: T: (877) 634-0982 | F: (510) 657-6634 sales@digipwr.com Blvd., Fremont, CA 94538, USA SIZE 48430 Lakeview CAGE CODE DWG. NO. 59947 www.digipwr.com | (877) 634-0982 RELEASE DATE 11/7/11 SCALE 1650DC10 SHEET 6 REV 1 OF 9 A Coolisys Technologies Company Digital Power Corporation designs and manufactures full custom, value added and standard comprehansive power solutions for the most demanding applications in the defense, healthcare, telecom, and industrial markets. CPCI 6U V6_05-08-17
CPCI-AC-6U-500 价格&库存
很抱歉,暂时无法提供与“CPCI-AC-6U-500”相匹配的价格&库存,您可以联系我们找货
