HD160-112
HD160-112
    DIGITALPOWER
    AC/DC CONVERTER 12V 160W
HD160-112 数据手册
(877) 634-0982 www.digipwr.com HD160 Series 160 Watt High-Density AC/DC Power Supply Product Specification Universal AC Input 90‐264VAC 2” x 4” Footprint Single Main Output plus Aux. 12V Key Product Features • Medical (2 MOPP) Safety Approved • ITE Safety Approved • High Density • Active PFC • Low Profile (1.06” height) • High Efficiency 90% typ. • Convection rated to 100W • 12V, 0.5A Aux (Fan) Output • RoHS Compliant Description The HD160 Series of open frame switching power supplies utilizes a highly advanced circuit topology to deliver 160 Watts in an industry standard package that has a 4.00 x 2.00 inch footprint and 1U height. The series has been designed meet the requirements of Medical, Telecom and Industrial applications and operates over the universal AC input range. These supplies have active power factor correction (PFC), flexible output configurations an auxiliary 12V output that can be used to drive a fan, and compliance to worldwide safety and EMC standards. Ratings Safety and EMC Input Voltage Range 90 to 264 VAC, 47 to 63 Hz or 170 to 370 VDC • CSA/UL 60601-1-1 3rd Ed. Safety Output Power—200 LFM Forced Air 160W (5V model is 100W) • CSA/UL 60950-1 ITE Safety Output Power—Free Air 100W Power Factor 0.98 at 230VAC Efficiency 90% Output Ripple 1% pk-pk, 0 to 20MHz Aux. Fan Output 12V, 0.5A Size Industry Standard 2 in. x 4 in. x 1.06 in. • NEMKO EN60601-1/EN60950-1 • CE Mark (LVD) • EN50022 (CISPR 22) Conducted Class A • EN61000-3-2 Class D Harmonics • EN61000-3-3 Voltage Fluctuations • EN61000-4-2, 3, 4, 5, 6, 11 Immunity Model Selection Model Output Power Standby Voltage HD 160-105 100 Watts +5V @ 20A HD 160-112 160 Watts 12V @ 13.3A HD 160-118 160 Watts 18V @ 8.88A HD 160-124 160 Watts 24V @ 6.66A HD 160-148 160 Watts 48V @ 3.33A Contact factory for other voltage configurations. HD160 Series Electrical Specifications Input AC Input Voltage 90-264VAC (47-63Hz) or 170-370 VDC Input Current 2A Max Continuous Input Reflected Ripple FCC 68 part 15 Class B Power Factor Correction 0.98 at 220VAC (typical) Input Line Protection 3A 250VAC IEC Type Hold-up Time >16msec @ Full Load Efficiency 90% Typical Leakage 100/200uA @ 115/230 VAC (max) Output Line Regulation ± 0.1% for Vin (min.) to Vin (max.) Load Regulation V1 = ±1% / V2 = ±5% Max Adjustment Range ±5% Minimum Min. Load Requirement None Ripple ± 1% (20MHz) Transient Response 5% Max Deviation For 50% Load Step Over-Voltage Protection 115-150% (Latched Shut-down) Turn-On Delay 1 Sec. Max. Initial Setting Accuracy ± 1% Over-Current 110-130% of I-Max (Auto-Recovery) Aux Fan Output 12 VDC @ 500m A EMC and Safety Certifications Electromagnetic Compatibility Electrostatic Discharge EN61000-4-2, ±4KV Contact / ±8KV Air Discharge Radiated Susceptibility EN61000-4-3, 26-1000MHz, 10V/M, 80% AM EFT / Bursts EN61000-4-4, ±2KV Surges EN61000-4-5, ±2KV Line-Earth, ±1KV Line-Line Conducted Immunity EN61000-4-6, 0.15-800MHz, 10V, 80% AM Voltage Dips EN61000-4-11, 95% Dip & 10ms, 30% Dip & 500ms Voltage Interruptions EN61000-4-11, 95% Reduction, 5s Fluctuations & Flicker EN61000-3-3 Safety & Emissions Safety Approvals CSA/UL 22.2 No. 60950-1-M90 & 60601-1-M90, NEMKO EN60950-1 / EN60601-1, CE Mark (LVD) Conducted Emissions EN S0022 (CISPR 22) Class A HD160 Series Environmental Specifications Operation Temperature -20 ~ +50C Derate Minus 2.5%/C from +50C to +70C Storage Temperature -20C ~ +85C Cooling Forced Air Cooling 200LFM, 100W Max Convection Humidity Up to 95% RH Non-condensing Shock & Vibration 0.75G Peak Half Sine, 6 Axes MTBF >300,000 Hours Mechanical Outline Digital Power Corporation 48430 Lakeview Blvd., Fremont, CA 94538, USA www.digipwr.com | (877) 634-0982 T: (877) 634-0982 | F: (510) 657-6634 sales@digipwr.com A Coolisys Technologies Company Digital Power Corporation designs and manufactures full custom, value added and standard comprehansive power solutions for the most demanding applications in the defense, healthcare, telecom, and industrial markets. HD160 V6_190924
HD160-112 价格&库存
很抱歉,暂时无法提供与“HD160-112”相匹配的价格&库存,您可以联系我们找货
