HD365-112
HD365-112
    DIGITALPOWER
    AC/DC CONVERTER 12V 199W
HD365-112 数据手册
(877) 634-0982 www.digipwr.com HD365 Series 365 Watt High Density AC/DC Power Supply Product Specification Universal AC Input with PFC, 3” x 5” Footprint Single Main Output plus 5V standby and Aux. 12V Key Product Features • Medical (2 MOPP) Safety Approved • ITE Safety Approved • High Density • Active PFC • Low Profile (1.30” height) • High Efficiency 90% typ. • 200W Convection rated • 5V, 2A Standby Output • 12V, 1A Aux (Fan) Output Safety and EMC Description The HD365 Series of open frame switching power supplies utilizes a highly advanced circuit technology to deliver 365 Watts in an industry standard package that has a 5.00 x 3.00 inch footprint and 1U (1.300 in.) height. The series has been designed meet the requirements of Medical,elecom T and Industrial applications and operates over the universal AC input range. These supplies have active power factor correction (PFC), flexible output configurations a 5V, 2A housekeeping (standby) supply and an auxiliary 12V output that can be used to drive a fan. They are fully and compliant with worldwide safety and EMC standards. Ratings Input Voltage Range 90 to 264 VAC, 47 to 63 Hz or 170 to 370 VDC Output Power—200 LFM Forced Air 365W Output Power—Free Air 200W Power Factor 0.98 at 230VAC Efficiency 90% Output Ripple 1% pk-pk, 0 to 20MHz • CSA/UL 60601-1-1 3rd Ed. Safety • CSA/UL 60950-1 ITE Safety Stand byOutput 5V, 2.0A (1.0A convection) • NEMKO EN60601-1/EN60950-1 Aux. Fan Output 12V, 1.0A (0.5A convection) • CE Mark (LVD) Size Industry Standard 3 in. x 5 in. x 1.3 in. • EN50022 (CISPR 22) Conducted Class A • EN61000-3-2 Class D Harmonics • EN61000-3-3 Voltage Fluctuations • EN61000-4-2, 3, 4, 5, 6, 11 Immunity Model Selection Model Main Output Ratings¹ Standby Output² Fan Output² HD365-112 12V, 30.4A (16.6A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-115 15V, 24.3A (13.3A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-119 19V, 19.2A (10.5A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-124 24V, 15.2A (8.3A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-129 29V, 12.5A (6.9A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-132 32V, 11.4A (6.2A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-136 36V, 10A (5.5A) 5V, 2A (1A) 12V, 1A (0.5A) HD365-148 48V, 7.6A (4.16A) 5V, 2A (1A) 12V, 1A (0.5A) Notes: 1. Output ratings given for 200LFM airflow and (no airflow). 2. Total continuous output power must not exceed 365W with 200LFM airflow (200W with no airflow). HD365 Series Electrical Specifications Input AC Input Voltage 90-264VAC (47-63Hz) or 170-370 VDC Input Current 4A Max Continuous Input Reflected Ripple FCC 68 part 15 Class B Power Factor Correction 0.98 at 220VAC (typical) Input Line Protection 6.3A 250VAC IEC Type Hold-up Time >16msec @ Full Load Efficiency 90% Typical Leakage 275uA @ 230 VAC (max) Output Line Regulation ± 0.1% for Vin (min.) to Vin (max.) Load Regulation V1 = ±1% / V2 = ±5% Max Adjustment Range ±5% Minimum Min. Load Requirement None Ripple ± 1% (20MHz) Transient Response Better than 5% For 50% Step Load Over-Voltage Protection 115-150% (Latched Shut-down) Turn-On Delay 1 Sec. Max. Initial Setting Accuracy ± 1% Over-Current 110-130% of I-Max (Auto-Recovery) EMC and Safety Certifications Electromagnetic Compatibility Electrostatic Discharge EN61000-4-2, ±4KV Contact / ±8KV Air Discharge Radiated Susceptibility EN61000-4-3, 26-1000MHz, 10V/M, 80% AM EFT / Bursts EN61000-4-4, ±2KV Surges EN61000-4-5, ±2KV Line-Earth, ±1KV Line-Line Conducted Immunity EN61000-4-6, 0.15-800MHz, 10V, 80% AM Voltage Dips EN61000-4-11, 95% Dip & 10ms, 30% Dip & 500ms Voltage Interruptions EN61000-4-11, 95% Reduction, 5s Fluctuations & Flicker EN61000-3-3 Safety & Emissions Safety Approvals (pending) CSA/UL 22.2 No. 60950-1-M90 & 60601-1-M90, VDE EN60950-1 / EN60601-1, CE Mark (LVD) HD365 Series Environmental Specifications Operation Temperature -20 ~ +50C Derate of 2.5%/C up to +70C Storage Temperature -20C ~ +85C Cooling Forced Air Cooling 200LFM, 220W Max Convection Humidity Up to 95% RH Non-condensing Shock & Vibration 0.75G Peak Half Sine, 6 Axes MTBF >300,000 Hours Status/Control Remote Sense Compensates for
HD365-112 价格&库存
很抱歉,暂时无法提供与“HD365-112”相匹配的价格&库存,您可以联系我们找货
