HDM240
HDM240
    DIGITALPOWER
    AC/DC CONVERTER
HDM240 数据手册
(877) 634-0982 www.digipwr.com HDM240 SERIES AC-DC MEDICAL SWITCHING PSU - 240 WATT KEY FEATURES Digital Power’s HDM240 Series are switching power supplies that produce superior output wattages with natural convection. The series include enclosed, open fame and U bracket format with output voltage options of 12V, 15V, 24V and 48V. Featured with compact, low profile footprint, and best-in-class performance, HDM240 Series are optimal for Medical Applications. Designed with energy saving in mind, Digital Power’s HDM240 Series boasts not only high operating efficiency up to 94%, but also high-power density with full input range of 90-264Vac. HDM240 operates over wide temperature range from -30°C to +70°C with complete protections and certified to UL / IEC / EN 60601 3.1 Edition Safety Approvals. 1 (877) 634-0982 www.digipwr.com PRODUCT SPECIFICATION Enclosed, Open Frame, U Bracket Switching Power Supply • Cooling by Free Air Convection • 160 Watts and 240 Watt with 10CFM Forced Air • 4000VAC Input to Output 2MOPP Insulation • High Efficiency up to 94% • With P.F.C. Function >0.9 • 250,000 h @ 25°C (MIL-HDBK-217F, Notice 1) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 4.1 x 2.05 x 1.087 Inches ( 103.9 x 52.0 x 27.6 mm ) Tolerance 0.5 mm 234 g Free convection / 10 CFM FAN Others: UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 115: UL / IEC / EN 60601 3.1rd Edition / UL / IEC / EN 60950 AM2 (meet) EN55011 Conducted Class B EN55011 Class I class B / Class II class A EN60601-1-2 4th edition All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 3 HDM240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM240O SERIES NOTE 1. 2. 3. 4. 5. 6. Ripple & Noise are measured at 20MHz of bandwidth with 0.1uF & 47uF parallel capacitor. Hold-up Time measured at 90% Vout. Fan Supply=12V/0.5A (max) for driving a fan.. Please check the derating curve for more details. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. Vin at 230 VAC & 48 Vout (After 30 minutes of burn-in) 7. The FAN supply is designed to serve as the source of the additive external fan for the cooling of the power supply, enabling the full load delivery and assuring the best life span of the product. Please do not use this FAN supply to drive other devices. For 112, 124, 148 8. 9. For 115 Main FAN FAN FAN Main FAN FAN FAN Output Voltage Voltage Voltage Output Voltage Voltage Voltage Power (at 0.1A) (at 0.25A) (at 0.5A) Power (at 0.1A) (at 0.25A) (at 0.5A) 25% 12.1V 11.8V 11.5V 25% 10.8V 10.2V 9.3V 50% 12.2V 11.9V 11.7V 50% 10.9V 10.3V 9.4V 75% 12.3V 12.0V 11.8V 75% 10.9V 10.4V 9.5V 100% 12.5V 12.2V 11.9V 100% 11.0V 10.4V 9.5V Please secure the power supply unit to your metal case by using the four screw holes in the corners for either Class I or Class II equipment CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. 4 HDM240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM240O SERIES DERATING BLOCK DIAGRAM 5 HDM240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HDM240O SERIES Standard Standard Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Brands Alex PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT 5 -DC OUT 6 PE JST Mating Housing Terminal Mating Housing 9396-3 96T series VHR-3N Terminal : M5 Pan HD screw in 2 positions Torque to 8 Ibs-in(90 cNm) max. ─ ─ Terminal SVH-41T-P1.1 ─ ─ Connector Pin (FAN) Brands PIN# Single F1 +AUX OUT F2 -AUX OUT Cherng Weei Mating Housing CX-H250-02 JST Terminal Mating Housing Terminal CX-T2501 XHP-2 SXH-002TP0.6 6 HDM240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HDM240O SERIES A Type A Type Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Brands Alex PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4~6 +DC OUT 7~9 -DC OUT 10 PE JST Mating Housing Terminal Mating Housing 9396-3 96T series VHR-3N SVH-41T-P1.1 9396-6 96T series VHR-6N SVH-41T-P1.1 ─ ─ Terminal ─ ─ Connector Pin (FAN) Brands PIN# Single F1 +AUX OUT F2 -AUX OUT Cherng Weei Mating Housing CX-H250-02 JST Terminal Mating Housing Terminal CX-T2501 XHP-2 SXH-002TP0.6 7 HDM240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM240U SERIES Model No. Max Output Wattage (with 10CFM FAN) (W) Max Output Wattage (Free air Convection) (W) Voltage (Note 4) Frequency (Hz) Current (Full load) Inrush Current (0.9 at Full Load < 0.5W (115 / 230 VAC) 12V 15V 24V 48V ±4% Output Voltage ±2% 20 16 10 5 13.3 10.667 6.66 3.33 ±1% ±1% 0% 8000µF 2000µF 3000µF 470µF 1% Vout 92.5% 92.5% 93% 94% 10 ms min. Auto recovery, Hiccup mode Auto recovery Auto recovery Protection level 1 (nominal):Continuous, Auto recovery Protection level 2 (instantaneous high current):Latch 4000VAC or 5656VDC 2000VAC or 2828VDC 1500VAC or 2121VDC -30°C…+70°C (with derating) -30°C…+85°C ±0.05%/°C 5000m 20~90% RH 56 kPa to 106 kPa >250,000 h @ 25°C (MIL-HDBK-217F, Notice 1) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 4.1 x 2.44 x 1.544 Inches ( 104.0 x 62.0 x 39.2 mm ) Tolerance 0.5 mm 297 g Free convection / 10 CFM FAN Others: UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 115: UL / IEC / EN 60601 3.1rd Edition / UL / IEC / EN 60950 AM2 (meet) EN55011 Conducted Class B EN55011 Class I class B / Class II class A EN60601-1-2 4th edition All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 8 HDM240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM240U SERIES NOTE 1. 2. 3. 4. 5. 6. 7. Ripple & Noise are measured at 20MHz of bandwidth with 0.1uF & 47uF parallel capacitor. Hold-up Time measured at 90% Vout. Fan Supply=12V/0.5A (max) for driving a fan.. Please check the derating curve for more details. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. Vin at 230 VAC & 48 Vout The FAN supply is designed to serve as the source of the additive external fan for the cooling of the power supply, enabling the full load delivery and assuring the best life span of the product. Please do not use this FAN supply to drive other devices. For 112, 124, 148 8. 9. For 115 Main FAN FAN FAN Main FAN FAN FAN Output Voltage Voltage Voltage Output Voltage Voltage Voltage Power (at 0.1A) (at 0.25A) (at 0.5A) Power (at 0.1A) (at 0.25A) (at 0.5A) 25% 12.1V 11.8V 11.5V 25% 10.8V 10.2V 9.3V 50% 12.2V 11.9V 11.7V 50% 10.9V 10.3V 9.4V 75% 12.3V 12.0V 11.8V 75% 10.9V 10.4V 9.5V 100% 12.5V 12.2V 11.9V 100% 11.0V 10.4V 9.5V Please secure the power supply unit to your metal case by using the four screw holes in the corners for either Class I or Class II equipment CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. 9 HDM240 Series (877) 634-0982 www.digipwr.com DERATING BLOCK DIAGRAM 10 HDM240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HDM240U SERIES Standard A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands Alex Mating Terminal Housing JST Mating Housing Terminal 9396-3 VHR-3N SVH-41TP1.1 PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT Terminal : M5 Pan HD screw in 2 positions -DC OUT Torque to 8 Ibs-in(90 cNm) max. 5 6 PE ─ 96T series ─ ─ ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Chassis of HDM240U Series ─ T=1.5mm Standard Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. 11 HDM240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HDM240U SERIES A Type A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Brands PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4~6 +DC OUT 7~9 -DC OUT 10 PE Alex Mating Terminal Housing Mating Housing Terminal 9396-3 VHR-3N SVH-41T-P1.1 96T series JST Chassis of HDM240U Series T=1.5mm 9396-6 96T series VHR-6N SVH-41T-P1.1 ─ ─ ─ ─ A Type Connector Pin (FAN) Brands Cherng Weei PIN# Single F1 +AUX OUT F2 -AUX OUT JST Mating Housing Terminal Mating Housing Terminal CXH250-02 CXT2501 XHP-2 SXH002TP0.6 Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. 12 HDM240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM240E SERIES Model No. Max Output Wattage (with 10CFM FAN) (W) Voltage (Note 4) Frequency (Hz) Current (Full load) Input Inrush Current (0.9 at Full Load 12V 15 V 24V 48V ±4% Output Voltage ±2% 20 16 10 5 ±1% ±1% 0% 8000µF 2000µF 3000µF 470µF 1% Vout 92% 92% 92.5% 93% 10 ms min. Auto recovery, Hiccup mode Auto recovery Auto recovery Protection level 1 (nominal):Continuous, Auto recovery Protection level 2 (instantaneous high current):Latch 4000VAC or 5656VDC 2000VAC or 2828VDC 1500VAC or 2121VDC -30°C…+70°C (with derating) -30°C…+85°C ±0.05%/°C 5000m 20~90% RH 56 kPa to 106 kPa >250,000 h @ 25°C (MIL-HDBK-217F, Notice 1) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 4.1 x 2.44 x 1.99 Inches ( 104.0 x 62.0 x 50.5 mm ) Tolerance 0.5 mm 328 g Others: UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 115: UL / IEC / EN 60601 3.1rd Edition / UL / IEC / EN 60950 AM2 (meet) EN55011 Conducted Class B EN55011 Class I class B / Class II class A EN60601-1-2 4th edition All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 13 HDM240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM240E SERIES NOTE 1. 2. 3. 4. 5. 6. 7. 8. Ripple & Noise are measured at 20MHz of bandwidth with 0.1uF & 47uF parallel capacitor. Hold-up Time measured at 90% Vout. Main Vout must be >50% Load, 12V (Aux) / 0.5A. Please check the derating curve for more details. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. After 30 minutes of burn-in Please secure the power supply unit to your metal case by using the four screw holes in the corners for either Class I or Class II equipment CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. DERATING If the input voltage is below 99VAC, the product can be used only in an environment where temperature is higher than -10 degrees Celsius. BLOCK DIAGRAM 14 HDM240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HDM240E SERIES Standard A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands Alex JST Mating Housing Terminal Mating Housing Terminal 9396-3 96T series VHR-3N SVH-41T-P1.1 PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT Terminal : M5 Pan HD screw in 2 positions Torque to 8 -DC OUT Ibs-in(90 cNm) max. 5 6 PE Connector Pin (FAN) Brands PIN# Single F1 +AUX OUT F2 -AUX OUT ─ ─ ─ ─ ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Chassis of HDM240E Series T=1.5mm Standard Cherng Weei Mating Housing Terminal JST Mating Housing CX-H250-02 CX-T2501 XHP-2 Terminal SXH-002TP0.6 Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. 15 HDM240 Series MECHANICAL DIMENSIONS - HDM240E SERIES A Type A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands Alex PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4~6 +DC OUT 7~9 -DC OUT 10 PE ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm JST Mating Housing Terminal Mating Housing Terminal 9396-3 96T series VHR-3N SVH-41T-P1.1 9396-6 96T series VHR-6N SVH-41T-P1.1 ─ ─ ─ ─ Chassis of HDM240E Series T=1.5mm Connector Pin (FAN) Brands PIN# Single F1 +AUX OUT F2 -AUX OUT Cherng Weei JST Mating Housing Terminal Mating Housing CX-H250-02 CX-T2501 XHP-2 Terminal SXH-002TP0.6 A Type Digital Power Corporation 1635 S Main Street. Milpitas, CA 95035 USA T: (877) 634-0982 sales@digipwr.com F: (510) 657-6634 www.digipwr.com Digital Power Corporation designs and manufactures full custom, value added and standard comprehensive power solutions for the most demanding applications in the defense, healthcare, telecom, and industrial markets. Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. 16 HDM240 Series
HDM240 价格&库存
很抱歉,暂时无法提供与“HDM240”相匹配的价格&库存,您可以联系我们找货
