HD240
HD240
    DIGITALPOWER
    AC/DC CONVERTER
HD240 数据手册
(877) 634-0982 www.digipwr.com HD240 SERIES AC-DC ITE SWITCHING PSU - 240 WATT KEY FEATURES Digital Power’s HD240 Series are switching power supplies that produce superior output wattages with natural convection. The series include enclosed, open fame and U bracket format with output voltage options of 12V, 24V and 48V. Featured with compact, low profile footprint, and best-in-class performance, HD240 Series are optimal for broad Industrial and Telecommunication Applications. Designed with energy saving in mind, Digital Power's HD240 Series boasts not only high operating efficiency up to 94%, but also high-power density with full input range of 90-264Vac and built-in active PFC. HD240 Series operates over wide temperature range from -30°C to +80°C with complete protections; EMI configured for both Class I and Class II and certified to UL / IEC / EN 62368-1. 1 (877) 634-0982 www.digipwr.com PRODUCT SPECIFICATION Enclosed, Open Frame, U Bracket Switching Power Supply • Universal Input Range 90-264VDC • High Efficiency up to 94% • O/P Voltage: 12,24,48V • No Load Power Consumption250,000 h @ 25°C (MIL-HDBK-217F, Notice 1) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 4.02 x 2.05 x 1.09 Inches ( 101.9 x 52.1 x 27.6 mm ) Tolerance 0.5 mm 220 g Natural Convection / Conduction Cooling / 8CFM FAN UL 60950 UL / IEC / EN 62368 EN55032 Class B EN55032 Class I Class B / Class II Class A EN55035 All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 3 HD240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HD240O SERIES NOTE 1. 2. 3. 4. 5. 6. 7. Ripple & Noise are measured at 20MHz of bandwidth with 0.1uF & 47uF parallel capacitor. Hold-up Time measured at 90% Vout. Fan Supply=12V/0.5A (max) for driving a fan.. Please check the derating curve for more details. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. Vin at 230 VAC & 48 Vout The FAN supply is designed to serve as the source of the additive external fan for the cooling of the power supply, enabling the full load delivery and assuring the best life span of the product. Please do not use this FAN supply to drive other devices. For 112, 124, 148 Main Output Power FAN Voltage FAN Voltage FAN Voltage (at 0.1A) (at 0.25A) (at 0.5A) 25% 12.1V 11.8V 11.5V 50% 12.2V 11.9V 11.7V 75% 12.3V 12.0V 11.8V 100% 12.5V 12.2V 11.9V 8. Please secure the power supply unit to your metal case by using the four screw holes in the corners for either Class I or Class II equipment. 9. The ambient temperature derating of 3.5 /1000m with fanless models and of 5 /1000m with fan models for operating altitude higher than 2000m(6500ft). 10. At least 15mm insulation distance on the bottom of the unit should be kept and a Mylar film should be added between the unit and the system. 11. CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. 4 HD240 Series (877) 634-0982 www.digipwr.com NOTE 12. 4. M3x6mm DERATING 5 HD240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HD240O SERIES Standard Standard Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Brands Alex PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT 5 -DC OUT 6 PE JST Mating Housing Terminal Mating Housing 9396-3 96T series VHR-3N Terminal : M3.5 Pan HD screw in 2 positions Torque to 8 Ibs-in(90 cNm) max. ─ ─ Terminal SVH-41T-P1.1 ─ ─ Connector Pin (FAN) Brands PIN# Single F1 +AUX OUT F2 -AUX OUT Cherng Weei JST Mating Housing Terminal Mating Housing Terminal CX-H20-02 CP-T20B PHR-2 SPH-002TP0.5L 6 HD240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HD240O SERIES A Type A Type Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Brands Alex PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4~6 +DC OUT 7~9 -DC OUT 10 PE JST Mating Housing Terminal Mating Housing 9396-3 96T series VHR-3N SVH-41T-P1.1 9396-6 96T series VHR-6N SVH-41T-P1.1 ─ ─ Terminal ─ ─ Connector Pin (FAN) Brands PIN# Single F1 +AUX OUT F2 -AUX OUT Cherng Weei JST Mating Housing Terminal Mating Housing Terminal CX-H20-02 CP-T20B PHR-2 SPH-002TP0.5L 7 HD240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HD240U SERIES Model No. Max Output Wattage (with 8CFM FAN) (W) Max Output Wattage (Conduction Cooling) (W)(Note 6) Max Output Wattage (Natural Convection) (W) Input Output Protection Voltage(Note 3) Frequency (Hz) Current (Full load) Inrush Current (0.9 at Full Load < 0.5W (115 / 230 VAC) 12V 24V 48V ±5% Output Voltage ±2% 20 10 5 20 10 5 17.5 8.96 4.48 19.5 10 5 ±1% ±1% 0% 8000µF 3000µF 470µF 1% Vout 92.5% 93% 94% 10 ms min. Auto recovery, Hiccup mode Auto recovery Auto recovery Protection level 1 (nominal):Continuous, Auto recovery Protection level 2 (instantaneous high current):Latch 4000VAC or 5656VDC 2000VAC or 2828VDC 1500VAC or 2121VDC -30°C…+80°C (with derating) -30°C…+80°C ±0.05%/°C 5000m 20~90% RH >250,000 h @ 25°C (MIL-HDBK-217F, Notice 1) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 4.1 x 2.46 x 1.54 Inches ( 104.0 x 62.5 x 39.2 mm ) Tolerance ±0.5 mm 350 g Natural Convection / Conduction Cooling / 8CFM FAN UL 60950 | UL / IEC / EN 62368 EN55032 Class B EN55032 Class I Class B / Class II Class A EN55035 All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 8 HD240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HD240U SERIES NOTE 1. 2. 3. 4. Ripple & Noise are measured at 20MHz of bandwidth with 0.1uF & 47uF parallel capacitor. Hold-up Time measured at 90% Vout. Please check the derating curve for more details. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. 5. Vin at 230 VAC & 48 Vout HD240 Series 300 x 300 x 3.0 mm 6. 7. 8. 9. The size of the suggested aluminum plate is shown as below. And for optimizing thermal performance, the aluminum plate must have an even and smooth surface (or coated with thermal grease), and HD240 series must be firmly mounted at the center of the aluminum plate. Please secure the power supply unit to your metal case by using the four screw holes in the corners for either Class I or Class II equipment The ambient temperature derating of 3.5 /1000m with fanless models and of 5 /1000m with fan models for operating altitude higher than 2000m(6500ft). CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. DERATING If input voltage is lower than 100VAC, please refer to the output derating V.S. input voltage curve for details 9 HD240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HD240U SERIES Standard A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands PIN# Single 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT 5 -DC OUT 6 PE Alex JST Mating Housing Terminal Mating Housing 9396-3 96T series VHR-3N Terminal : M3.5 Pan HD screw in 2 positions Torque to 8 Ibs-in(90 cNm) max. ─ ─ ─ Terminal SVH-41T-P1.1 ─ ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Standard Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Chassis of HD240U Series T=1.5mm 10 HD240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HD240U SERIES A Type A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands PIN# Single 1 AC IN (N) 2 3 4~6 NO PIN AC IN (L) +DC OUT 7~9 -DC OUT 10 PE Alex JST Mating Housing Terminal 9396-3 96T series VHR-3N SVH-41T-P1.1 9396-6 96T series VHR-6N SVH-41T-P1.1 ─ ─ A Type Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Mating Housing ─ Terminal ─ ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Chassis of HD240U Series T=1.5mm 11 HD240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HD240E SERIES Model No. Max Output Wattage (with 8CFM FAN) (W) Max Output Wattage (Conduction Cooling) (W) (Note 6) HD240E-112 HD240E-124 HD240E-148 240 W 240 W 210 W (100 VAC) / 215 W (100 VAC) / 240 W (230 VAC) Max Output Wattage (Natural Convection) (W) 234 W (230 VAC) Voltage(Note 3) 90-264 VAC Frequency (Hz) 47-63 Hz Current (Full load) < 3.0 A max. (115 VAC) / < 1.5 A max. (230 VAC) Inrush Current (0.9 at Full Load No Load < 0.5W (115 / 230 VAC) Voltage (V.DC.) 12V 24V 48V Voltage Adj Range (V.DC.) ±5% Output Voltage Voltage Accuracy ±2% Current (with 8CFM FAN) (A) (max.) 20 10 5 Current (Conduction Cooling) (A) (max.) 20 10 5 Current at 100 VAC 17.5 8.96 4.48 at 230 VAC 19.5 10 5 (Natural Convection) (A) (max.) Output Protection Line Regulation Load Regulation (0-100%) Minimum Load Maximum Capacitive Load Ripple & Noise (max.) (Note 1) Efficiency (at 230VAC) (Note 5) Hold-up Time (at 115 VAC) (Note 2) Over Power Protection Over Voltage Protection Overt Temperature Protection Weight Cooling Method Approval ±1% ±1% 0% 8000µF 3000µF 470µF 1% Vout 92.5% 93% 94% 10 ms min. Auto recovery, Hiccup mode Auto recovery Auto recovery Protection level 1 (nominal):Continuous, Auto recovery Protection level 2 (instantaneous high current):Latch 4000VAC or 5656VDC 2000VAC or 2828VDC 1500VAC or 2121VDC -30°C…+80°C (with derating) -30°C…+80°C ±0.05%/°C 5000m 20~90% RH >250,000 h @ 25°C (MIL-HDBK-217F, Notice 1) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 4.1 x 2.46 x 1.54 Inches ( 104.0 x 62.5 x 39.2 mm ) Tolerance 0.5 mm 365 g Natural Convection / Conduction Cooling / 8CFM FAN UL 60950 | UL / IEC / EN 62368 Conducted EMI (Note 7) Radiated EMI (Note 7) EMS EN55032 Class B EN55032 Class I Class B / Class II Class A EN55035 Short Circuit Protection Isolation Environment Input-Output (Note 4) Input-PE (Note 4) Output-PE (Note 4) Operating Temperature Storage Temperature Temperature Coefficient Altitude During Operation Humidity MTBF Vibration Shock Dimensions (L x W x H) Physical Safety EMC All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 12 HD240 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HD240E SERIES NOTE 1. 2. 3. 4. Ripple & Noise are measured at 20MHz of bandwidth with 0.1uF & 47uF parallel capacitor. Hold-up Time measured at 90% Vout. Please check the derating curve for more details. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. 5. Vin at 230 VAC & 48 Vout HD240 Series 300 x 300 x 3.0 mm 6. 7. 8. 9. The size of the suggested aluminum plate is shown as below. And for optimizing thermal performance, the aluminum plate must have an even and smooth surface (or coated with thermal grease), and HD240 series must be firmly mounted at the center of the aluminum plate. Please secure the power supply unit to your metal case by using the four screw holes in the corners for either Class I or Class II equipment The ambient temperature derating of 3.5 /1000m with fanless models and of 5 /1000m with fan models for operating altitude higher than 2000m(6500ft). CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. DERATING If input voltage is lower than 100VAC, please refer to the output derating V.S. input voltage curve for details 13 HD240 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS - HD240E SERIES Standard A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands Alex PIN# Single 1 AC IN (N) 2 NO PIN Mating Housing 9396-3 JST Terminal Mating Housing Terminal 96T series VHR-3N SVH-41T-P1.1 3 AC IN (L) 4 +DC OUT Terminal : M3.5 Pan HD screw in 2 positions Torque to -DC OUT 8 Ibs-in(90 cNm) max. 5 6 PE ─ ─ ─ ─ ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Chassis of HD240E Series T=1.5mm Standard Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. 14 HD240 Series MECHANICAL DIMENSIONS - HD240E SERIES A Type A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Chassis of HD240E Series T=1.5mm Brands Alex PIN# Single 1 AC IN (N) JST Mating Housing Terminal Mating Housing Terminal 9396-3 96T series VHR-3N SVH-41T-P1.1 2 NO PIN 3 AC IN (L) 4~6 7~9 +DC OUT -DC OUT 9396-6 96T series VHR-6N SVH-41T-P1.1 10 PE ─ ─ ─ ─ A Type Chassis of Digital Power Corporation HD240U 1635 S Main Street. Series Milpitas, CA 95035 USA T: (877) 634-0982 sales@digipwr.com F: (510) 657-6634 www.digipwr.com Please refer to the types of terminal block; the pictures shown are for illustration purpose only, actual product may vary. Digital Power Corporation designs and manufactures full custom, value added and standard comprehensive power solutions for the most demanding applications in the defense, healthcare, telecom, and industrial markets. 15 HD240 Series
HD240 价格&库存
很抱歉,暂时无法提供与“HD240”相匹配的价格&库存,您可以联系我们找货
