HDM500O-112CS
HDM500O-112CS
    DIGITALPOWER
    AC/DC CONVERTER 12V
HDM500O-112CS 数据手册
(877) 634-0982 www.digipwr.com H D M5 0 0 S E R I E S AC-DC ITE AND MEDICAL SWITCHING PSU 500 WATT KEY FEATURES Digital Power’s HDM500 Series are switching power supplies that produce superior output wattages with natural convection. The series include enclosed, open fame and U bracket format with output voltage options of 12V, 15V, 24V and 48V. Featured with compact, low profile footprint, and best-in-class performance, HDM500 Series are optimal for ITE and Medical Applications. Designed with energy saving in mind, Digital Power’s HDM500 Series boasts not only high operating efficiency up to 93%, but also high-power density with full input range of 90-264Vac. HDM500 operates over wide temperature range from -30°C to +70°C with complete protections and certified to UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 Safety Approvals. 1 (877) 634-0982 www.digipwr.com PRODUCT SPECIFICATION Enclosed, U Bracket Switching Power Supply • Remote ON/OFF Function • 240 Watt with Free Air Convection • 500 Watt with 30CFM FAN • 4000VAC Input to Output 2MOPP Insulation • Built-in 12V/0.3A Auxiliary Output • Standby 5V@1A with Fan, @0.4A without Fan • High Efficiency up to 93% • With P.F.C. Function >0.94 • Current Share Function for Option (except for 115) • Ultra Compact Size: HDM500O: 5.03 x 3.0 x 1.38 Inches HDM500U: 5.5 x 3.25 x 1.6 Inches HDM500E: 5.5 x 3.25 x 2.42 Inches HDM500 Series 2 (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500O SERIES Model No. Max Output Wattage (W) HDM500O-112 Max Output Wattage (W) Voltage (Note 3) Input Output Protection Isolation Physical Safety EMC HDM500O-124 HDM500O-148 Frequency (Hz) Current (Full load) Inrush Current (160,000 h @ 25°C (MIL-HDBK-217F) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 5.03 x 3.0 x 1.38 Inches ( 127.8 x 76.2 x 35.0 mm ) Tolerance 0.5 mm 480 g Free convection / 30 CFM FAN Others: UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 115: UL / IEC / EN 60601 3.1rd Edition EN55011 / conducted class B, Radiated Class A EN60601-1-2 4th edition All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 3 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500O SERIES NOTE 1. Ripple & Noise are measured at 20MHz of bandwidth with ceramic 0.1uF & chemi-con KY 47uF parallel capacitor. A 30cm twisted pair of no.18 AWG copper wire is connected to a 47uF and 0.1uF capacitor of proper polarity and voltage rating. The oscilloscope probe ground led should connect right to the ground ring of the probe and be as short as possible. The oscilloscope bandwidth should be at 20MHz and connected to AC ground. 2. Hold-up Time measured at 90% Vout. 3. Please check the derating curve for more details. 4. Main Vout >3% Load, 12V (Aux) / 0.3A., 12V (Aux) need 0.1A Minimum Load, Auxiliary voltage output ground 10.2~13.3V 5. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. 6. Current Share Board (Optional): (a.)The output voltage difference of each parallel single element should be less than 0.2V. (b.)Output power at parallel operation = rated power per unit x number of unit x 90% (c.)Connect in parallel no more than 2 units. Please contact Digital Power for advice if more than HDM500 HDM500 2 is needed. (d.)Minimum Load Should be 15%. 7. CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. 4 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500O SERIES DERATING BLOCK DIAGRAM 5 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500O SERIES Brands PIN# Single Alex JST Mating Mating Terminal Terminal Housing Housing ─ ─ ─ ─ 1 PE 2 3 4 AC IN (N) NO PIN AC IN (L) 5 6 +DC OUT Terminal : M5 Pan HD screw in 2 positions. -DC OUT Torque to 8 lbs-in(90cNm) max 9396-3 SVH-41T96T series VHR-3N P1.1 Connector Pin (FAN) Brands PIN# Single F1 +12V F2 GND Alex JST Mating Mating Terminal Terminal Housing Housing CXCX-T2501 XHP-2 H250-02 Connector Pin (CN1) Brands PIN# Single C1 -5V SB C2 +5V SB C3 GND C4 DC-OK C5 -RC C6 +RC C7 -S C8 +S Cherng Weei Mating Housing Terminal PHD-H20PHD-T20 2X4P JST Mating Housing Terminal PHDR08VS SPHD001T- P0.5 SXH002TP0.6 6 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500O SERIES HDM500O with Current Share Function Brands Alex JST Mating Mating Terminal Terminal Housing Housing ─ ─ ─ ─ Connector Pin (CN1) PIN# Single 1 PE 2 3 4 AC IN (N) NO PIN AC IN (L) 5 6 +DC OUT Terminal : M5 Pan HD screw in 2 positions. -DC OUT Torque to 8 lbs-in(90cNm) max 9396-3 96T series VHR-3N SVH-41TP1.1 Connector Pin (FAN) Brands PIN# Single F1 +12V F2 GND Alex JST Mating Mating Terminal Terminal Housing Housing CXCX-T2501 XHP-2 H250-02 Brands SXH002TP0.6 PIN# Single C1 -5V SB C2 +5V SB C3 GND C4 DC-OK C5 -RC C6 +RC C7 -S C8 +S Cherng Weei Mating Housing Terminal PHD-H20PHD-T20 2X4P JST Mating Housing Terminal PHDR08VS SPHD001T- P0.5 Connector Pin (CN2) Brands PIN# Single C1 -S C2 +S Cherng Weei Mating Housing CP- H20-02 JST Terminal CP- T20B Mating Housing PHR-2 Terminal SPH002T- P0.5L 7 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500O SERIES Mating Housing Pin (CN3) Brands PIN# Single C1 -5V SB C2 +5V SB C3 GND C4 DC-OK C5 -RC C6 +RC Cherng Weei JST Connector Connector CP-W20-06 B6B-PH-K-S Connector Pin (CN4) Brands Cherng Weei PIN# Single C1 LS C2 LS Mating Housing CP- H20-02 Terminal CP- T20B JST Mating Housing PHR-2 Terminal SPH002T- P0.5L FUNCTION DESCRIPITON of CN1 and CN3 (CN3 without C7 and C8 pin) Pin No. Function C1 -5VSB Description This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C2 +5VSB C3 GND Stand by voltage output ground 4.2~5.5V, referenced to pin C1(-5VSB). The maximum load current is 1A with Fan, 0.4A without Fan.. This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C4 DC OK DC-OK Signal is a DC output, referenced to pin C3(DC-OK GND). C5 -RC This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C6 +RC C7 -S C8 +S Turns the output on and off by electrical or dry contact between pin C5 (-RC), Short: Power OFF, Open: Power ON. The input voltage must be less than 1V in order to disable VOUT and greater than 3.3V (up to 5V) to enable it. Negative sensing. The -S signal should be connected to the negative terminal of the load. The -S and +S leads should be twisted in pair to minimize noise pick-up effect. Positive sensing. The +S signal should be connected to the positive terminal of the load. The +S and -S leads should be twisted in pair to minimize noise pick-up effect. 8 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500O SERIES FUNCTION MANUAL & APPLICATION NOTE 1. DC-OK Signal Between DC-OK and GND 3.7~6V 0~1V Output Status ON OFF 2. Remote Control It can be turned ON/OFF by using the "Remote Control" function. Between +RC and -RC SW ON (Short) SW OFF (Open) Output Status OFF ON 3. +S and -S Sense Shorter wiring to each unit is recommended, as well as twisting +S and -S in pairs, as shown below 9 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500U SERIES Model No. HDM500U-112 Max Output Wattage (W) 500 W (30CFM FAN) Others: 190 W (115 VAC) / 200 W (230 VAC) 115: 170 W (115 VAC) / 180 W (230 VAC) 90-264 VAC or 127-370 VDC 47-63 Hz < 6.3 A max. (115 VAC) / 0.94 at Full Load 12V 15V 24V ±2% ±4% Output Voltage 41.5 33.3 20.8 15.83 11.33 7.91 16.6 12 8.33 Max Output Wattage (W) Voltage (Note 3) Frequency (Hz) Current (Full load) Input Inrush Current (160,000 h @ 25°C (MIL-HDBK-217F) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 5.5 x 3.25 x 1.6 Inches ( 139.7 x 82.55 x 40.6 mm ) Tolerance 0.5 mm 580 g Free convection / 30 CFM FAN Others: UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 115: UL / IEC / EN 60601 3.1rd Edition EN55011 / conducted class B, Radiated Class A EN60601-1-2 4th edition All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 10 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500U SERIES NOTE 1. Ripple & Noise are measured at 20MHz of bandwidth with ceramic 0.1uF & chemi-con KY 47uF parallel capacitor. A 30cm twisted pair of no.18 AWG copper wire is connected to a 47uF and 0.1uF capacitor of proper polarity and voltage rating. The oscilloscope probe ground led should connect right to the ground ring of the probe and be as short as possible. The oscilloscope bandwidth should be at 20MHz and connected to AC ground. 2. Hold-up Time measured at 90% Vout. 3. Please check the derating curve for more details. 4. Main Vout >3% Load, 12V (Aux) / 0.3A., 12V (Aux) need 0.1A Minimum Load, Auxiliary voltage output ground 10.2~13.3V 5. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. 6. Current Share Board (Optional): (a.)The output voltage difference of each parallel single element should be less than 0.2V. (b.)Output power at parallel operation = rated power per unit x number of unit x 90% (c.)Connect in parallel no more than 2 units. Please contact Digital Power for advice if more than 2 is needed. HDM500 HDM500 (d.)Minimum Load Should be 15%. 7. CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. 11 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500U SERIES DERATING BLOCK DIAGRAM 12 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS – HDM500U SERIES A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands Alex JST Single Mating Housing A.B PE ─ 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT Terminal : M5 Pan HD screw in 2 positions. -DC OUT Torque to 8 lbs-in(90cNm) max PIN# 5 9396-3 Mating Terminal Housing ─ ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Terminal ─ ─ 96T series VHR-3N SVH-41T-P1.1 Chassis of HDM500U Series Connector Pin (CN1) Brands PIN# Single C1 -5V SB C2 +5V SB C3 GND C4 DC-OK C5 -RC C6 +RC C7 C8 Cherng Weei Mating Housing Terminal JST Mating Housing T=1.5mm Terminal Connector Pin (FAN) PHD-H20PHD-T20 2X4P PHDR08VS SPHD001T- P0.5 Brands PIN# Single -S F1 +12V +S F2 GND Alex Mating Housing JST Terminal CXCX-T2501 H250-02 Mating Housing Terminal XHP-2 SXH002TP0.6 13 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500U SERIES HDM500U with Current Share Function A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Alex JST PIN# Single Mating Housing Terminal Mating Housing Terminal A.B PE ─ ─ ─ ─ 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT Terminal : M5 Pan HD screw in 2 positions. -DC OUT Torque to 8 lbs-in(90cNm) max 5 9396-3 96T series VHR-3N SVH-41T-P1.1 Connector Pin (FAN) Chassis of HDM500U Series Brands T=1.5mm Alex PIN# Single F1 +12V F2 GND Mating Housing JST Terminal CX- H250- CX- T2501 02 Mating Housing Terminal XHP-2 SXH-002TP0.6 14 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500U SERIES Mating Housing Pin (CN3) Connector Pin (CN1) Cherng Weei Brands Mating Housing PIN# Single C1 -5V SB C2 +5V SB C3 GND C4 DC-OK C5 -RC C6 +RC C7 -S C8 +S Terminal PHD-H20PHD-T20 2X4P Connector Pin (CN2) Brands PIN# Single C1 C2 -S +S Brands JST Mating Housing PHDR08VS Terminal PIN# Single C1 -5V SB C2 +5V SB C3 GND C4 DC-OK C5 -RC C6 +RC SPHD001T- P0.5 Cherng Weei Mating Housing CPH20-02 Cherng Weei JST Connector Connector CP-W20-06 B6B-PH-K-S JST Terminal CP- T20B Mating Housing PHR-2 Terminal SPH002T- P0.5L Connector Pin (CN4) Brands Cherng Weei PIN# Single C1 LS C2 LS Mating Housing CP- H20-02 JST Terminal Mating Housing Terminal CP- T20B PHR-2 SPH002TP0.5L FUNCTION DESCRIPITON of CN1 and CN3 (CN3 without C7 and C8 pin) Pin No. Function Description C1 -5VSB This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C2 +5VSB Stand by voltage output ground 4.2~5.5V, referenced to pin C1(5VSB). The maximum load current is 1A with Fan, 0.4A without Fan.. C3 GND This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C4 DC OK DC-OK Signal is a DC output, referenced to pin C3(DC-OK GND). C5 -RC This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C6 +RC Turns the output on and off by electrical or dry contact between pin C5 (-RC), Short: Power OFF, Open: Power ON. The input voltage must be less than 1V in order to disable VOUT and greater than 3.3V (up to 5V) to enable it. C7 -S Negative sensing. The -S signal should be connected to the negative terminal of the load. The -S and +S leads should be twisted in pair to minimize noise pick-up effect. C8 +S Positive sensing. The +S signal should be connected to the positive terminal of the load. The +S and -S leads should be twisted in pair to minimize noise pick-up effect. 15 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500U SERIES FUNCTION MANUAL & APPLICATION NOTE 1. DC-OK Signal Between DC-OK and GND 3.7~6V 0~1V Output Status ON OFF 2. Remote Control It can be turned ON/OFF by using the "Remote Control" function. Between +RC and -RC SW ON (Short) SW OFF (Open) Output Status OFF ON 3. +S and -S Sense Shorter wiring to each unit is recommended, as well as twisting +S and -S in pairs, as shown below 16 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500E SERIES Model No. Max Output Wattage (W) Voltage (Note 3) Frequency (Hz) Current (Full load) Inrush Current (160,000 h @ 25°C (MIL-HDBK-217F) IEC60068-2-6 (10~500Hz, 2G 10min./1cycle, 60min. each along X, Y, Z axes) IEC60068-2-27 5.5 x 3.25 x 2.42 Inches ( 139.7 x 82.55 x 61.4 mm ) Tolerance 0.5 mm 690 g Approval Conducted and Radiated EMI EMS Others: UL / IEC / EN 60601 3.1rd Edition & UL / IEC / EN 60950 AM2 115: UL / IEC / EN 60601 3.1rd Edition EN55011 / conducted class B, Radiated Class A EN60601-1-2 4th edition All specifications valid at normal input voltage, full load and +25°C after warm-up time unless otherwise stated. 17 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500E SERIES NOTE 1. Ripple & Noise are measured at 20MHz of bandwidth with ceramic 0.1uF & chemi-con KY 47uF parallel capacitor. A 30cm twisted pair of no.18 AWG copper wire is connected to a 47uF and 0.1uF capacitor of proper polarity and voltage rating. The oscilloscope probe ground led should connect right to the ground ring of the probe and be as short as possible. The oscilloscope bandwidth should be at 20MHz and connected to AC ground. 2. Hold-up Time measured at 90% Vout. 3. Please check the derating curve for more details. 4. Main Vout >3% Load, 12V (Aux) / 0.3A., 12V (Aux) need 0.1A Minimum Load, Auxiliary voltage output ground 10.2~13.3V 5. Strongly recommend to conduct this test with DC Voltage. If customer wishes to test with AC Voltage, please disconnect all Y-Capacitors from Digital Power power supply. 6. Current Share Board (Optional): (a.)The output voltage difference of each parallel single element should be less than 0.2V. (b.)Output power at parallel operation = rated power per unit x number of unit x 90% (c.)Connect in parallel no more than 2 units. Please contact Digital Power for advice if more than 2 is needed. HDM500 HDM500 (d.)Minimum Load Should be 15%. 7. CAUTION: Double pole, neutral fusing. Disconnect mains before servicing. 18 HDM500 Series (877) 634-0982 www.digipwr.com ELECTRICAL SPECIFICATION - HDM500E SERIES DERATING BLOCK DIAGRAM 19 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS – HDM500E SERIES A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P Brands Alex Single Mating Housing A.B PE ─ 1 AC IN (N) 2 NO PIN PIN# 9396-3 JST Terminal Mating Housing Terminal ─ ─ ─ 96T series VHR-3N SVH-41T-P1.1 3 AC IN (L) 4 +DC OUT Terminal : M5 Pan HD screw in 2 positions. -DC OUT Torque to 8 lbs-in(90cNm) max 5 Chassis of HDM50E Series Connector Pin (CN1) Cherng Weei Brands PIN# Single C1 -5V SB C2 +5V SB Mating Housing Terminal ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm JST Mating Housing Terminal PHDR08VS SPHD-001TP0.5 T=1.5mm C3 GND C4 DC-OK C5 -RC C6 +RC PIN# Single C7 -S F1 +12V F2 GND C8 +S Connector Pin (FAN) PHXD-H20PHD-T20 2X4P Brands Alex JST Mating Mating Terminal Terminal Housing Housing CXCXH250-02 T2501 XHP-2 SXH002TP0.6 20 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500E SERIES HDM500E with Current Share Function A= For fixture to chassis only A=M3x0.5P B=For fixture to pcb/chassis only B=M3x0.5P ASSEMBLY INSTRUCTIONS U Case T=1.5mm Customer is advised to screw into the threads no more than 1.5mm Chassis of HDM500E Series Brands JST PIN# Single Mating Housing Terminal Mating Housing Terminal A.B PE ─ ─ ─ ─ 1 AC IN (N) 2 NO PIN 3 AC IN (L) 4 +DC OUT Terminal : M5 Pan HD screw in 2 positions. -DC OUT Torque to 8 lbs-in(90cNm) max 5 T=1.5mm Alex 9396-3 96T series VHR-3N SVH-41T-P1.1 Connector Pin (FAN) Brands PIN# Single F1 +12V F2 GND Cherng Weei Mating Housing CXH250-02 JST Terminal Mating Housing Terminal CXT2501 XHP-2 SXH002TP0.6 21 HDM500 Series (877) 634-0982 www.digipwr.com MECHANICAL DIMENSIONS– HDM500E SERIES Connector Pin (CN1) Mating Housing Pin (CN3) Cherng Weei Brands PIN# Single C1 Mating Housing JST Mating Housing Terminal Terminal Brands PIN# Single -5V SB C1 -5V SB C2 +5V SB C2 +5V SB C3 GND C4 DC-OK C3 GND C5 -RC C4 DC-OK C6 +RC C7 -S C5 -RC C8 +S C6 +RC PHD-H20PHD-T20 2X4P PHDR08VS SPHD001T- P0.5 Cherng Weei JST Connector Connector CP-W20-06 B6B-PH-K-S Connector Pin (CN2) Brands Cherng Weei PIN# Single C1 -S C2 +S Mating Housing Terminal CP- H20-02 CP- T20B JST Mating Housing Terminal SPH002T- P0.5L PHR-2 Connector Pin (CN4) Brands Cherng Weei PIN# Single C1 LS C2 LS Mating Housing CP- H20-02 JST Terminal Mating Housing Terminal CP- T20B PHR-2 SPH002TP0.5L FUNCTION DESCRIPITON of CN1 and CN3 (CN3 without C7 and C8 pin) Pin No. Function C1 -5VSB Description This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C2 +5VSB Stand by voltage output ground 4.2~5.5V, referenced to pin C1(5VSB). The maximum load current is 1A with Fan, 0.4A without Fan.. C3 GND This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C4 DC OK DC-OK Signal is a DC output, referenced to pin C3(DC-OK GND). C5 -RC This pin connects to the negative terminal(-V). Return for DC-OK and -RC signal output. C6 +RC Turns the output on and off by electrical or dry contact between pin C5 (-RC), Short: Power OFF, Open: Power ON. The input voltage must be less than 1V in order to disable VOUT and greater than 3.3V (up to 5V) to enable it. C7 -S Negative sensing. The -S signal should be connected to the negative terminal of the load. The -S and +S leads should be twisted in pair to minimize noise pick-up effect. C8 +S Positive sensing. The +S signal should be connected to the positive terminal of the load. The +S and -S leads should be twisted in pair to minimize noise pick-up effect. 22 HDM500 Series MECHANICAL DIMENSIONS – HDM500E SERIES FUNCTION MANUAL & APPLICATION NOTE 1. DC-OK Signal Between DC-OK and GND 3.7~6V 0~1V Output Status ON OFF 2. Remote Control It can be turned ON/OFF by using the "Remote Control" function. Between +RC and -RC SW ON (Short) SW OFF (Open) Output Status OFF ON 3. +S and -S Sense Shorter wiring to each unit is recommended, as well as twisting +S and -S in pairs, as shown below Digital Power Corporation 1635 S Main Street. Milpitas, CA 95035 USA T: (877) 634-0982 sales@digipwr.com F: (510) 657-6634 www.digipwr.com Digital Power Corporation designs and manufactures full custom, value added and standard comprehensive power solutions for the most demanding applications in the defense, healthcare, telecom, and industrial markets. 23 HDM500 Series
HDM500O-112CS 价格&库存
很抱歉,暂时无法提供与“HDM500O-112CS”相匹配的价格&库存,您可以联系我们找货
