US100-301
US100-301
    DIGITALPOWER
    AC/DC CONVERTER 5V +/-12V 146W
US100-301 数据手册
(877) 634-0982 www.digipwr.com US100 Series 100 Watt Product Specification Universal Input Switchers Description Key Product Features • • • • • • • The US100 series are economical, open frame switchers that deliver up to 100W of continuous or 120W peak power from one to four outputs. The 90-264VAC universal input allows them to be used worldwide. 75% efficiency FCC class B EMI filter Up to 4 outputs 5" x 3.3" x 1.5" size CSA and CE approved Optional Cover Optional power good signal The US100 is one of the flexibility series. In addition to the popular models listed on this sheet, thousands of potential other modified standard models are available that include full safety agency approval and do not require any non-recurring engineering (NRE) charge. Prototype delivery is typically just a few weeks. Flexibility options include cover, adjustable post regulators on V3 and/or V4 outputs. Output voltage options are given in the table below. Fully custom models are also available. Please contact the factory for information on EN55022-B filtering, and power fail/power good detect. 0RGHO2SWLRQV 0RGHO1XPEHU 2XWSXW 2XWSXW9ROWDJH 0LQ1 2XWSXW&XUUHQW5DWLQJV 0D[3 0D[2 3HDN4 US100-105 V1 +5V 0A 10.0A 14.0A 20.0A US100-112 V1 +12V 0A 6.5A 8.0A 10.0A US100-124 V1 +24V 0A 3.0A 4.0A 4.5A US100-201 V1 +5V 0.5A 8.0A 14.0A 16.0A V2 +12V 0A 4.0A 6.0A 7.0A V1 +5V 0.5A 8.0A 10.0A 12.0A US100-301 US100-303 US100-401 Modified standard V2 +12V 0A 4.0A 6.0A 7.0A V3 -12V 0A 1.0A 2.0A 2.5A V1 +5V 0.5A 8.0A 10.0A 12.0A V2 +15V 0A 4.0A 6.0A 7.0A V3 -15V 0A 1.0A 2.0A 2.5A V1 +5V 0.5A 8.0A 10.0A 12.0A V2 +12V 0A 4.0A 6.0A 7.0A V3 -12V 0A 1.0A 2.0A 2.5A V45 -5V 0A 1.0A 2.0A 2.5A V1 ±3.3V to ±48V7 0.5A 15.0A flexibility output options6 V2 ±2.0V to ±48V8 0A 6.0A V3 ±2.0V to ±48V8 0A 2.0A V45 ±2.0V to ±48V8 0A 1- At least 20% of max output current is required to maintain stated regulation 2- Convection cooling 3- Forced air cooling 4- Peak output, 30 sec max, 50% load required on V1 5-Isolated output 2.0A 6- The US100 series allows very fast flexible modified standard designs within these paramaters without nonrecurring engineering charge and while retaining safety agency approval. Please contact the factory for details. 7- Can be specified in 0.1V increments 8- Can be specified in 0.75V increments US100 Series Note: Specifications are typical at 25°C unless otherwise stated Specifications Input Input Voltage Range 90-250VAC Input Frequency 47 to 63Hz Input Surge Current 25A max, cold start Efficiency 75% typ at nominal line, full power Output Output Power 80W natural convection cooling ; 100W 28CFM forced air ; 120W peak Line Regulation ±0.2%, Vin (min) to Vin (max) Load Regulation ±3% (V1, 20% to 100% I0) ; ±5% (V2-V4, 20% to 100% I0) Cross Regulation ±0.5% (V1, 20% to 100% I0 on V2-V4) ; ±5% (V2-V4, 50% to 100% I0 on V1) Noise and Ripple 25mV max RMS, 100mV max P-P on V1 with full load. 95-264VAC ; 0.5% max RMS, 1% max P-P, on V2-V4 with full load. 95-264VAC Overshoot 5% max, all outputs Transient Response for 25% to 75% I0 change, 5% max deviation, with recovery to 1% within 500µS Hold-Up Time 6mS, 115VAC input, full output power Overvoltage Protection Threshold 30% V0, all outputs Power Foldback Point 120% of max rated power Environment Operating Temperature Range (full power) 0ºC to 50ºC Operating Temperature Range (extended range) 0ºC to 70ºC Derate linearly from full power at 50ºC to half power at 70ºC Storage Temperature Range -25ºC to +85ºC Relative Humidity 5% to 95%, non-condensing Vibration 0.75G peak, 5Hz to 500 Hz. Test three orthogonal axes at 1 octave/min, 5 min dwell at four major resonances US100 Series Mechanical Drawing Digital Power Corporation 48430 Lakeview Blvd., Fremont, CA 94538, USA www.digipwr.com | (877) 634-0982 T: (877) 634-0982 | F: (510) 657-6634 sales@digipwr.com A Coolisys Technologies Company Digital Power Corporation designs and manufactures full custom, value added and standard comprehansive power solutions for the most demanding applications in the defense, healthcare, telecom, and industrial markets. US100_190924
US100-301
1. 物料型号:文档中列出了US100系列的不同型号,例如US100-105、US100-112、US100-124等,每个型号具有不同的输出电流配置。
2. 器件简介:US100系列是经济型开放式开关电源,可提供高达100W的连续功率或120W的峰值功率,具有1至4个输出。90-264VAC的通用输入使其可以在全球范围内使用。
3. 引脚分配:文档中没有提供具体的引脚分配图或详细说明,通常这需要查看具体的技术手册或数据手册。
4. 参数特性:文档提供了详细的参数特性,包括输入电压范围90-250VAC,效率75%,以及多种输出电压和电流选项。还提到了工作温度范围、存储温度范围、相对湿度和振动测试条件。
5. 功能详解:US100系列提供多种灵活性选项,包括外壳、V3和/或V4输出的可调节后置调节器。还提供了定制型号的选项,并可提供EN55022-B过滤和电源故障/正常检测等功能。
6. 应用信息:虽然文档中没有直接提到具体的应用案例,但根据其特性和参数,US100系列适用于需要高效率和灵活输出配置的多种应用场景。
7. 封装信息:文档中提到了产品的尺寸为5" x 3.3" x 1.5",并有可选的外壳,但没有提供详细的封装图纸或封装类型。
US100-301 价格&库存
很抱歉,暂时无法提供与“US100-301”相匹配的价格&库存,您可以联系我们找货
